战舰开发板的程序
main函数
int main(void)
delay_init(); //延时函数初始化
LED_Init(); //初始化与led连接的硬件配置
while(1)
LED0=1;
LED1=1;
delay_ms(300);
LED0=0;
LED1=0;
delay_ms(300);
delay_init();函数
void delay_init()
#ifdef OS_CRITICAL_METHOD //如果OS_CRITICAL_METHOD定义了,说明使用ucosII了.
u32 reload;
#endif
SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8); //选择外部时钟 HCLK/8
fac_us=SystemCoreClock/8000000; //为系统时钟的1/8
reload=SystemCoreClock/8000000; //每秒钟的计数次数 单位为K
reload*=1000000/OS_TICKS_PER_SEC;//根据OS_TICKS_PER_SEC设定溢出时间
//reload为24位寄存器,最大值:16777216,在72M下,约合1.86s左右
fac_ms=1000/OS_TICKS_PER_SEC;//代表ucos可以延时的最少单位
SysTick->CTRL|=SysTick_CTRL_TICKINT_Msk; //开启SYSTICK中断
SysTick->LOAD=reload; //每1/OS_TICKS_PER_SEC秒中断一次
SysTick->CTRL|=SysTick_CTRL_ENABLE_Msk; //开启SYSTICK
#else
fac_ms=(u16)fac_us*1000;//非ucos下,代表每个ms需要的systick时钟数
#endif
要修改io的步骤
#define LED0 PDout(4)// 改为相应的Px(x)
Px(x)的宏定义
#define PDout(n) BIT_ADDR(GPIOD_ODR_Addr,n) //输出
#define PDin(n) BIT_ADDR(GPIOD_IDR_Addr,n) //输入
GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIODE, ENABLE); //使能PB,PE端口时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //LED0-->PB.5 端口配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB.5 GPIO_SetBits(GPIOD,GPIO_Pin_5); //PB.5 输出高 GPIO_InitStructure.GPIO_Pin
= GPIO_Pin_5; //LED1-->PE.5 端口配置, 推挽输出 GPIO_Init(GPIOE, &GPIO_InitStructure); //推挽输出 ,IO口速度为50MHz
GPIO_SetBits(GPIOE,GPIO_Pin_5); //PE.5 输出高
如果要改成PD4和PD5 需要修改
1.#define LED0 PDout(4)// 改为相应的Px(x)
2.#define LED1 PDout(5)// 改为相应的Px(x)
3. GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); //使能PD端口时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; //LED0-->PB.5 端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_Init(GPIOD, &GPIO_InitStructure); //根据设定参数初始化GPIOB.5
GPIO_SetBits(GPIOD,GPIO_Pin_4); //PB.5 输出高
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //LED1-->PE.5 端口配置, 推挽输出
GPIO_Init(GPIOD, &GPIO_InitStructure); //推挽输出 ,IO口速度为50MHz
OK! 有arm一闪一闪亮晶晶去。。。。。
上一篇:keil_提示出错 cannot load flash programming algorithm !
下一篇:为什么STM32的Flash地址要设置到0x08000000
