使用RT-Thread Studio基于rt-thread4.0.2构建的工程:
这里记录一下最基本的收发代码。
* Copyright (c) 2006-2019, RT-Thread Development Team
* SPDX-License-Identifier: Apache-2.0
* Change Logs:
* Date Author Notes
* 2020-02-20 ShineRoyal the first version
#include #include #include #include static const char *send_data = "GET /download/rt-thread.txt HTTP/1.1rn" "Host: www.rt-thread.orgrn" "User-Agent: rtthread/4.0.1 rttrnrn"; void udpclient(int argc, char **argv) { int sock, port, count; struct hostent *host; struct sockaddr_in send_addr, recv_addr; const char *url; /* 接收到的参数小于 3 个 */ if (argc < 3) { rt_kprintf("Usage: udpclient URL PORT [COUNT = 10]n"); rt_kprintf("Like: tcpclient 192.168.12.44 5000n"); return; } url = argv[1]; port = strtoul(argv[2], 0, 10); if (argc > 3) count = strtoul(argv[3], 0, 10); else count = 10; /* 通过函数入口参数 url 获得 host 地址(如果是域名,会做域名解析) */ host = (struct hostent *) gethostbyname(url); /* 创建一个 socket,类型是 SOCK_DGRAM,UDP 类型 */ if ((sock = socket(AF_INET, SOCK_DGRAM, 0)) == -1) { rt_kprintf("Socket errorn"); return; } /* 初始化预连接的服务端地址 */ send_addr.sin_family = AF_INET; send_addr.sin_port = htons(port); send_addr.sin_addr = *((struct in_addr *) host->h_addr); rt_memset(&(send_addr.sin_zero), 0, sizeof(send_addr.sin_zero)); recv_addr.sin_family = AF_INET; recv_addr.sin_port = IPADDR_ANY; recv_addr.sin_addr = *((struct in_addr *) host->h_addr); rt_memset(&(recv_addr.sin_zero), 0, sizeof(recv_addr.sin_zero)); /* 总计发送 count 次数据 */ while (count) { /* 发送数据到服务远端 */ sendto(sock, send_data, strlen(send_data), 0, (struct sockaddr * )&send_addr, sizeof(struct sockaddr)); /* 线程休眠一段时间 */ rt_thread_delay(50); char str[100]; memset(str, 0, sizeof(str)); recvfrom(sock, str, sizeof(str), 0, &recv_addr, sizeof(recv_addr)); rt_kprintf("%s:%d=>%sn", inet_ntoa(recv_addr.sin_addr), ntohs(recv_addr.sin_port), str); /* 计数值减一 */ count--; } /* 关闭这个 socket */ closesocket(sock); } MSH_CMD_EXPORT(udpclient, udpclient); 收发情况如下:
上一篇:LwIP之TCP Client发送和接收Demo
下一篇:HAL库使用修改为外部25M晶振
推荐阅读最新更新时间:2024-11-11 11:13
设计资源 培训 开发板 精华推荐
- 单节18650充放电兼保护板
- EVAL-AD7612CB,用于 AD7612、16 位、750 Ksps PulSAR 模数转换器的评估板
- 【长安大学】滚筒测距装置+林泽淮
- LTC3621IDCB-3.3 1.2Vout、同步至 600kHz、强制连续模式同步降压型稳压器的典型应用
- LT8570IMS8E-1 1MHz 升压转换器从 5V-12V 输入产生 24V 的典型应用
- 使用 NXP Semiconductors 的 MC32PF3000A0EP 的参考设计
- 使用 TJA1042/3 高速 CAN 收发器和 3V MCU 的应用电路
- 用于汽车照明的 9-LED 通用 LED 驱动器
- 4063-915-PDK,用于 Si4063/Si4362 915-MHz 射频收发器的 EZRadio-PRO 无线开发套件
- ZET6
