平台:Code Composer Studio 10.4.0
MSP432P401R SimpleLink™ 微控制器 LaunchPad™ 开发套件
(MSP-EXP432P401R)
任务的简单创建
根据上篇机翻的函数作用,及观察本例程模板,可总结出使用默认参数初始化线程任务的函数:
三个参数分别是线程任务名,优先级和堆栈大小
void My_Task_Init(void (*TaskName)(void *arg), int priority, size_t stacksize)
pthread_t thread;
pthread_attr_t attrs;
struct sched_param priParam;
int retc;
/* Initialize the attributes structure with default values */
pthread_attr_init(&attrs);
/* Set priority, detach state, and stack size attributes */
priParam.sched_priority = priority;
retc = pthread_attr_setschedparam(&attrs, &priParam);
retc |= pthread_attr_setdetachstate(&attrs, PTHREAD_CREATE_DETACHED);
retc |= pthread_attr_setstacksize(&attrs, stacksize);
if (retc != 0)
/* failed to set attributes */
while (1)
retc = pthread_create(&thread, &attrs, TaskName, NULL);
if (retc != 0)
/* pthread_create() failed */
while (1)
为方便管理
我在工程目录下新建了src文件夹和inc文件夹
在其中建立了myTask.c 、myTask.h,同时还把工程的一些文件名改了,并删掉了例程模板中的empty.c
myTask.c
* myTask.c
* Created on: 2021年8月2日
* Author: Royic
#include /* POSIX Header files */ #include /* RTOS header files */ #include /* Driver configuration */ #include "ti_drivers_config.h" /* For usleep() */ #include #include #include #include "./inc/myTask.h" void My_Task_Init(void *(*startroutine)(void *), int priority, size_t stacksize) { pthread_t thread; pthread_attr_t attrs; struct sched_param priParam; int retc; /* Initialize the attributes structure with default values */ pthread_attr_init(&attrs); /* Set priority, detach state, and stack size attributes */ priParam.sched_priority = priority; retc = pthread_attr_setschedparam(&attrs, &priParam); retc |= pthread_attr_setdetachstate(&attrs, PTHREAD_CREATE_DETACHED); retc |= pthread_attr_setstacksize(&attrs, stacksize); if (retc != 0) { /* failed to set attributes */ while (1) { } } retc = pthread_create(&thread, &attrs, startroutine, NULL); if (retc != 0) { /* pthread_create() failed */ while (1) { } } } myTask.h /* * myTask.h * * Created on: 2021年8月2日 * Author: Royic */ #ifndef INC_MYTASK_H_ #define INC_MYTASK_H_ void My_Task_Init(void *(*startroutine)(void *), int priority, size_t stacksize); #endif /* INC_MYTASK_H_ */ 图形化配置上手 打开.syscfg格式的文件,此为CCS用于图形化配置的文件 应该是之前TI出的图形化配置工具TI PinMux的CCS内置版(下图为TI PinMux) 简简单单点个灯 配置引脚 由原理图可知,P1.0 控制LED1,LED2为RGB灯,其中P2.0控制其中的红灯 仿造原工程修改其中的GPIO模块,设LED1为输出模式,正常(非开漏)模式,驱动能力中等,初始电平为低电平,不上拉下拉 Use Hardware选项是可选板子预设好的GPIO种类,选为None后可在下面的GPIO Pin改为自定义引脚。 同理,设置LED2的红灯 建立任务 在myTask.c中建立两个任务 其中一个1s反转一次LED1,另一个2s反转一次LED2的红灯 sleep(n)用于秒级的挂起 usleep(n)用于微秒级的挂起 #include void *LED1_Task(void *arg0) { while (1) { sleep(1); GPIO_toggle(LED1); } } void *LED2_Task(void *arg0) { while (1) { sleep(2); GPIO_toggle(LED2); } } 在myTask.h中声明 extern void *LED1_Task(void *arg0); extern void *LED2_Task(void *arg0); 在main中初始化 int main(void) { /* Call driver init functions */ Board_init(); GPIO_init(); My_Task_Init(LED1_Task, 1, 1024); My_Task_Init(LED2_Task, 1, 1024); BIOS_start(); return (0); } 实验结果 可以观察到两个任务近似并行同时执行,LED1 约1s翻转一次,LED2 约2s翻转一次。 整体代码 main.c /* * ======== main_tirtos.c ======== */ #include /* POSIX Header files */ #include /* RTOS header files */ #include /* Driver configuration */ #include #include #include "./inc/myTask.h" /* * ======== main ======== */ int main(void) { /* Call driver init functions */ Board_init(); GPIO_init(); My_Task_Init(LED1_Task, 1, 1024); My_Task_Init(LED2_Task, 1, 1024); BIOS_start(); return (0); } myTask.c /* * myTask.c * * Created on: 2021年8月2日 * Author: Royic */ #include /* POSIX Header files */ #include /* RTOS header files */ #include /* Driver configuration */ #include "ti_drivers_config.h" /* For usleep() */ #include #include #include #include "./inc/myTask.h" #include void My_Task_Init(void *(*startroutine)(void *), int priority, size_t stacksize) { pthread_t thread; pthread_attr_t attrs; struct sched_param priParam; int retc; /* Initialize the attributes structure with default values */ pthread_attr_init(&attrs); /* Set priority, detach state, and stack size attributes */ priParam.sched_priority = priority; retc = pthread_attr_setschedparam(&attrs, &priParam); retc |= pthread_attr_setdetachstate(&attrs, PTHREAD_CREATE_DETACHED); retc |= pthread_attr_setstacksize(&attrs, stacksize); if (retc != 0) { /* failed to set attributes */ while (1) { } } retc = pthread_create(&thread, &attrs, startroutine, NULL); if (retc != 0) { /* pthread_create() failed */ while (1) { } } } void *LED1_Task(void *arg0) { while (1) { sleep(1); GPIO_toggle(LED1); } } void *LED2_Task(void *arg0) { while (1) { sleep(2); GPIO_toggle(LED2); } } myTask.h /* * myTask.h * * Created on: 2021年8月2日 * Author: Royic */ #ifndef INC_MYTASK_H_ #define INC_MYTASK_H_ void My_Task_Init(void *(*startroutine)(void *), int priority, size_t stacksize); extern void *LED1_Task(void *arg0); extern void *LED2_Task(void *arg0); #endif /* INC_MYTASK_H_ */
上一篇:MSP432P401R TI Drivers 库函数学习笔记(四)GPIO
下一篇:MSP432P401R TI Drivers 库函数学习笔记(二)认识TI-RTOS (TI-POSIX)
推荐阅读最新更新时间:2024-11-19 17:53
设计资源 培训 开发板 精华推荐
- 合见工软发布集成开放的一体化协同设计环境UniVista Integrator
- 芯原图像信号处理器IP获得汽车功能安全标准ISO 26262认证
- Microchip发布新款用于边缘嵌入式视觉设计的新一代开发工具
- Diodes Incorporated 推出符合汽车规格的 500mA LDO
- 亚信电子推出最新EtherCAT从站双核微控制器解决方案
- 诺基亚10 PureView有望采用骁龙875芯片与蓝宝石玻璃
- 三星Galaxy S21 Ultra开始部分生产工作,或明年1月发布
- 安卓11亲儿子谷歌Pixel 5电量显示错误:3个小时才“耗1%”
- DxO宣布周四推出全新测试标准解密
- 英特尔收购了AI软件优化平台SigOpt
