说明
P1.4引脚作为信号输入引脚
在变量窗口创建并查看fvpp的值即可
代码
该代码可以直接在CCS上编译运行
#include #include "stdint.h" uint16_t adcbuff[50] = {0}; uint16_t maxval[50] = {0}; uint16_t minval[50] = {0}; uint16_t max = 0; uint16_t min = 0; uint16_t vpp = 0; /* * @fn: void InitSystemClock(void) * @brief: 初始化系统时钟 * @para: none * @return: none * @comment:初始化系统时钟 */ void InitSystemClock(void) { /*配置DCO为1MHz*/ DCOCTL = CALDCO_1MHZ; BCSCTL1 = CALBC1_1MHZ; /*配置SMCLK的时钟源为DCO*/ BCSCTL2 &= ~SELS; /*SMCLK的分频系数置为1*/ BCSCTL2 &= ~(DIVS0 | DIVS1); } /* * @fn: void InitUART(void) * @brief: 初始化串口,包括设置波特率,数据位,校验位等 * @para: none * @return: none * @comment:初始化串口 */ void InitUART(void) { /*复位USCI_Ax*/ UCA0CTL1 |= UCSWRST; /*选择USCI_Ax为UART模式*/ UCA0CTL0 &= ~UCSYNC; /*配置UART时钟源为SMCLK*/ UCA0CTL1 |= UCSSEL1; /*配置波特率为9600@1MHz*/ UCA0BR0 = 0x68; UCA0BR1 = 0x00; UCA0MCTL = 1 << 1; /*使能端口复用*/ P1SEL |= BIT1 + BIT2; P1SEL2 |= BIT1 + BIT2; /*清除复位位,使能UART*/ UCA0CTL1 &= ~UCSWRST; } /* * @fn: void UARTSendString(uint8_t *pbuff,uint8_t num) * @brief: 通过串口发送字符串 * @para: pbuff:指向要发送字符串的指针 * num:要发送的字符个数 * @return: none * @comment:通过串口发送字符串 */ void UARTSendString(uint8_t *pbuff,uint8_t num) { uint8_t cnt = 0; for(cnt = 0;cnt < num;cnt ++) { while(UCA0STAT & UCBUSY); UCA0TXBUF = *(pbuff + cnt); } } /* * @fn: void PrintNumber(uint16_t num) * @brief: 通过串口发送数字 * @para: num:变量 * @return: none * @comment:通过串口发送数字 */ void PrintNumber(uint16_t num) { uint8_t buff[6] = {0,0,0,0,0,'n'}; uint8_t cnt = 0; for(cnt = 0;cnt < 5;cnt ++) { buff[4 - cnt] = (uint8_t)(num % 10 + '0'); num /= 10; } UARTSendString(buff,6); } /* * @fn: void PrintFloat(float num) * @brief: 通过串口发送浮点数 * @para: num:变量 * @return: none * @comment:通过串口发送浮点数,可发送1位整数位+3位小数位 */ void PrintFloat(float num) { uint8_t charbuff[] = {0,'.',0,0,0}; uint16_t temp = (uint16_t)(num * 1000); charbuff[0] = (uint8_t)(temp / 1000) + '0'; charbuff[2] = (uint8_t)((temp % 1000) / 100) + '0'; charbuff[3] = (uint8_t)((temp % 100) / 10) + '0'; charbuff[4] = (uint8_t)(temp % 10) + '0'; UARTSendString(charbuff,5); } /* * @fn: void InitADC(void) * @brief: 初始化ADC * @para: none * @return: none * @comment:初始化ADC */ void InitADC(void) { /*设置ADC时钟MCLK*/ ADC10CTL1 |= ADC10SSEL_2; /*ADC 2分频*/ //ADC10CTL1 |= ADC10DIV_0; /*设置ADC基准源*/ ADC10CTL0 |= SREF_1; /*设置ADC采样保持时间16CLK*/ ADC10CTL0 |= ADC10SHT_2; /*设置ADC采样率200k*/ ADC10CTL0 |= ADC10SR; /*ADC基准选择2.5V*/ ADC10CTL0 |= REF2_5V; /*开启基准*/ ADC10CTL0 |= REFON; /*选择ADC输入通道A4*/ ADC10CTL1 |= INCH_4; /*允许A4模拟输入*/ ADC10AE0 |= 1 << 4; /*DTC传输模式*/ ADC10DTC0 |= ADC10CT; /*传输次数*/ ADC10DTC1 = 50; /*起始地址*/ ADC10SA = (uint16_t)(adcbuff); /*开启ADC*/ ADC10CTL0 |= ADC10ON; /*允许转换*/ ADC10CTL0 |= ENC; } /* * @fn: uint16_t GetADCValue(void) * @brief: 进行一次ADC转换并返回ADC转换结果 * @para: none * @return: ADC转换结果 * @comment:ADC转换结果为10bit,以uint16_t类型返回,低10位为有效数据 */ uint16_t GetADCValue(void) { /*开始转换*/ ADC10CTL0 |= ADC10SC|ENC; /*等待转换完成*/ while(ADC10CTL1&ADC10BUSY); /*返回结果*/ return ADC10MEM; } /* * @fn: void StartADCConvert(void) * @brief: 进行一次ADC转换 * @para: none * @return: none * @comment:ADC转换结果为10bit */ void StartADCConvert(void) { /*开始转换*/ ADC10CTL0 |= ADC10SC|ENC; /*等待转换完成*/ while(ADC10CTL1&ADC10BUSY); } /* * @fn: uint16_t Max(uint16_t *numptr,uint16_t num) * @brief: 查找最大值 * @para: * @return: 最大值 * @comment: */ uint16_t Max(uint16_t *numptr,uint16_t num) { uint16_t cnt = 0; uint16_t max = 0; for(cnt = 0;cnt < num;cnt ++) { if(numptr[cnt] > max){ max = numptr[cnt]; } } return max; } /* * @fn: uint16_t Min(uint16_t *numptr,uint16_t num) * @brief: 查找最小值 * @para: * @return: 最小值 * @comment: */ uint16_t Min(uint16_t *numptr,uint16_t num) { uint16_t cnt = 0; uint16_t min = 0; min = numptr[0]; for(cnt = 0;cnt < num;cnt ++) { if(numptr[cnt] < min){ min = numptr[cnt]; } } return min; } /* * @fn: uint16_t Average(uint16_t *datptr) * @brief: 计算平均值 * @para: none * @return: none * @comment: */ uint16_t Average(uint16_t *datptr) { uint32_t sum = 0; uint8_t cnt = 0; for(cnt = 0;cnt < 50;cnt ++) { sum += *(datptr + cnt); } return (uint16_t)(sum / 50); } /* * main.c */ int main(void) { uint8_t cnt = 0,cnt1 = 0; volatile float fvpp = 0.0f; WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer InitSystemClock(); InitUART(); InitADC(); while(1) { for(cnt1 = 0;cnt1 < 50;cnt1 ++) { for(cnt = 0;cnt < 50;cnt ++) { StartADCConvert(); } maxval[cnt1] = Max(adcbuff,50); minval[cnt1] = Min(adcbuff,50); } max = Max(maxval,50); min = Min(minval,50); vpp = max - min; fvpp = (float)vpp * 2.5 / 1023; fvpp = fvpp; __delay_cycles(1000000); } return 0; }
上一篇:利用MSP430G2553测量信号频率(频率计)
下一篇:MSP430G2553 PWM控制速度,并自我检测和简单调节速度
推荐阅读最新更新时间:2024-11-12 16:24
设计资源 培训 开发板 精华推荐
- LTC1727IS8-5 单电源监视器的典型应用与其他禁用
- 测试夹_探针_开源
- LT1071 反激式转换器的典型应用
- Tda7385 4 X 30W 四桥车载收音机放大器的典型应用
- EVAL-RS485FD8EBZ,采用 8 引脚 SOIC 封装的 ADM4854 半双工 RS-485 收发器评估板
- 应用笔记 28 - 使用具有数据和中断输出的 MICRF002 接收器的数据静噪
- LTC3035,一种非常低压差的双碱性至 1.8V 应用
- TS79L 三端100mA负电压稳压器典型应用
- 基于 L6902D 的 STEVAL-ISA155V1、1A 恒流 DC/DC 转换器评估板
- AD8601ARTZ-REEL7 高端运算放大器电流监视器的典型应用
