; NAME: OPTION.A
; DESC: Configuration options for .S files
; HISTORY:
; 02.28.2002: ver 0.0
; 03.11.2003: ver 0.0 attached for 2440.
; jan E, 2004: ver0.03 modified for 2440A01.
;这个Option.inc文件主要是为设置时钟服务的,选择好分频系数
;Start address of each stacks,
_STACK_BASEADDRESS EQU 0x33ff8000
_MMUTT_STARTADDRESS EQU 0x33ff8000
_ISR_STARTADDRESS EQU 0x33ffff00
;定义一个全局的逻辑变量,变初始化为TRUE
GBLL PLL_ON_START
PLL_ON_START SETL {TRUE}
;定义一个全局的逻辑变量,变初始化为FALSE
GBLL ENDIAN_CHANGE
ENDIAN_CHANGE SETL {FALSE}
;定义一个全局的数字变量,变初始化为16
GBLA ENTRY_BUS_WIDTH
ENTRY_BUS_WIDTH SETA 16
;BUSWIDTH = 16,32
GBLA BUSWIDTH ;max. bus width for the GPIO configuration
BUSWIDTH SETA 32
GBLA UCLK
UCLK SETA 96000000;48000000
GBLA XTAL_SEL
GBLA FCLK
GBLA CPU_SEL
;(1) Select CPU
;CPU_SEL SETA 32440000 ; 32440000:2440X.
CPU_SEL SETA 32440001 ; 32440001:2440A
;(2) Select XTaL
XTAL_SEL SETA 12000000
;XTAL_SEL SETA 16934400
;(3) Select FCLK
;FCLK SETA 296352000
;FCLK SETA 271500000
;FCLK SETA 100000000
FCLK SETA 240000000
FCLK SETA 280000000
FCLK SETA 320000000
FCLK SETA 360000000
FCLK SETA 400000000
;(4) Select Clock Division (Fclk:Hclk:Pclk)
;CLKDIV_VAL EQU 5 ; 0=1:1:1, 1=1:1:2, 2=1:2:2, 3=1:2:4, 4=1:4:4, 5=1:4:8, 6=1:3:3, 7=1:3:6.
;定义时钟比例
;下面根据外部晶振是12MMhz(else是16.9344Mhz),再根据我们的主时钟是(271.5MHz或304.8MHz),决定分频系数M_MDIV、M_PDIV、M_SDIV
;根据我们的USB时钟(48MHz或者96MHz),决定分频系数U_MDIV、U_PDIV、U_SDIV
;[是IF伪操作的同义词,|是ELSE伪操作的同义词,]是ENDIF伪操作的同义词
[ XTAL_SEL = 12000000
[ FCLK = 271500000
CLKDIV_VAL EQU 7 ;1:3:6
M_MDIV EQU 173 ;Fin=12.0MHz Fout=271.5MHz
M_PDIV EQU 2
[ CPU_SEL = 32440001
M_SDIV EQU 2 ; 2440A
M_SDIV EQU 1 ; 2440X
[ FCLK = 100000000
CLKDIV_VAL EQU 0 ;1:1:1
M_MDIV EQU 42 ;Fin=12.0MHz Fout=100MHz
M_PDIV EQU 4
M_SDIV EQU 1 ; 2440A
M_SDIV EQU 0 ; 2440X
[ FCLK = 240000000
CLKDIV_VAL EQU 4 ;1:4:4
M_MDIV EQU 112 ;Fin=12.0MHz Fout=240MHz
M_PDIV EQU 4
[ FCLK = 280000000
M_MDIV EQU 132 ;Fin=12.0MHz Fout=280MHz
M_PDIV EQU 4
[ FCLK = 320000000
CLKDIV_VAL EQU 5 ;1:4:8
M_MDIV EQU 72 ;Fin=12.0MHz Fout=320MHz
M_PDIV EQU 1
[ FCLK = 360000000
M_MDIV EQU 82 ;Fin=12.0MHz Fout=360MHz
M_PDIV EQU 1
[ FCLK = 400000000
M_MDIV EQU 127 ;127
M_PDIV EQU 2 ;2
[ UCLK = 48000000
U_MDIV EQU 56 ;Fin=12.0MHz Fout=48MHz
U_PDIV EQU 2
U_SDIV EQU 2 ; 2440A
U_SDIV EQU 1 ; 2440X
[ UCLK = 96000000
U_MDIV EQU 56 ;Fin=12.0MHz Fout=96MHz
U_PDIV EQU 2
U_SDIV EQU 1 ; 2440A
U_SDIV EQU 0 ; 2440X
| ; else if XTAL_SEL = 16.9344Mhz
[ FCLK = 266716800
M_MDIV EQU 118 ;Fin=16.9344MHz
M_PDIV EQU 2
[ FCLK = 296352000
M_MDIV EQU 97 ;Fin=16.9344MHz
M_PDIV EQU 1
[ FCLK = 541900800
M_MDIV EQU 120 ;Fin=16.9344MHz
M_PDIV EQU 2
[ UCLK = 48000000
U_MDIV EQU 60 ;Fin=16.9344MHz Fout=48MHz
U_PDIV EQU 4
[ UCLK = 96000000
U_MDIV EQU 60 ;Fin=16.9344MHz Fout=96MHz
U_PDIV EQU 4
上一篇:S3C2440串口的基本使用
下一篇:系统时钟和UART的设置
推荐阅读最新更新时间:2024-11-09 11:54
设计资源 培训 开发板 精华推荐
- LT1952MPGN 36V 至 72V 输入至 5V/20A 同步正向转换器的典型应用电路
- NCV33074ADTBR2G 有源高 Q 陷波滤波器运算放大器的典型应用
- EVAL-AD7863CB,AD7863 评估板,14 位,250KSPS,便携式 2 通道 ADC
- FRDM-STBC-AGM01,用于 FXAS21002C 陀螺仪和 FXOS8700CQ 6 轴传感器的 9 轴传感器工具箱开发板
- TAR5SB18 点稳压器(低压降稳压器)的典型应用
- Sg1525A稳压脉宽调制器典型应用电路
- MA730高速磁编码器
- EVAL-RS485HDEBZ,采用 8 引脚 SOIC 封装的 ADM4852 半双工 RS-485 收发器评估板
- (大赛作品)STM32F072RB NUCLEO智能家居控制
- 使用 NXP Semiconductors 的 TDA8559 的参考设计
