本文介绍了CS1500主要特性,方框图,基本应用电路和材料清单,以及90W高效PFC LLC谐振转换器参考设计电路图和材料清单(BOM).
CS1500是Cirrus 公司的适用于通用输入的高性能功率修正因素(PFC)控制器,采用有所有权的数字算法的不连续导通模式(DCM),具有可变的接通时间和可变频率控制,从而保证PFC为一. CS1500的保护特性包括过压,过流,超功率,开路和短路以及超温保护,主要用在电源和照明镇流器设计.
Digital Power Factor Correction IC
The CS1500 is a high-performance power factor correction (PFC) controller for universal AC input, which uses a proprietary digital algorithm for discontinuous conduction mode (DCM) with variable on-time and variable frequency control, ensuring unity power factor.
The CS1500 incorporates all the safety features necessary for robust and compact PFC stages. In addition, it has burst mode control to lower the light-load/standby losses to a minimum.
Protection features such as overvoltage, overcurrent, overpower, open- and short-circuit protection, overtemperature, and brownout help protect the device during abnormal transient conditions.
The digital controller optimizes the system stability and transient performance, simplifies the PFC design, reduces the external component count and BOM costs. The simple design and minimum cost makes CS1500 the ideal choice for PFC up to 300 watts.
CS1500主要特性:
Digital EMI Noise Shaping
Excellent Efficiency Under All Load Conditions
Minimal External Devices Required
Optimized Digital Loop Compensation
Comprehensive Safety Features
• Undervoltage Lockout (UVLO)
• Output Overvoltage Protection
• Input Current Limiting
• Output Overpower Protection
• Input Brownout Protection
• Open/short Loop Protection for IAC & FB Pins
• Thermal Shutdown
图1.CS1500方框图
图2.CS1500基本应用电路图
应用电路中元件数值表:
CS1500 90W, High-efficiency PFC w/ LLC Resonant Converter Reference Design
The CRD1500-90WLLC circuit has two stages: a digitally controlled front-end PFC and a resonant LLC converter. The CS1500 is a high-performance power factor correction (PFC) controller for universal AC input that uses a proprietary digital algorithm with variable ontime, variable frequency, & DCM, which ensures unity power factor.
The resonant LLC converter uses the L6599A controller in the second stage.
90W高效转换器参考设计主要特性:
Universal Input
– Mains Range: 90~265 VAC
– Line Frequency: 45~65 Hz
Rated Output Specification: 19 V, 90 W
EN6100-3-2 Class-D Compliance
Efficiency: 91% @ 90 W, 230 VAC
Low No-load Power Dissipation
Low PFC Component Count
Board Dimension: 61 mm x 135 mm
图3.90W高效PFC LLC谐振转换器参考设计外形图
图4.参考设计电路图(1)
图5.参考设计电路图(2)
参考设计材料清单(BOM):
关键字:CS1500 PFC 电源
编辑:神话 引用地址:基于CS1500设计的90W高效PFC电源技术
CS1500主要特性:
• Thermal Shutdown
图1.CS1500方框图
图2.CS1500基本应用电路图
应用电路中元件数值表:
90W高效转换器参考设计主要特性:
Universal Input
图4.参考设计电路图(1)
图5.参考设计电路图(2)
参考设计材料清单(BOM):
上一篇:集成RCC式开关电源器件设计及应用
下一篇:有源和无源滤波器混合并行方案在铁路牵引站谐
推荐阅读最新更新时间:2023-10-13 10:55
逐渐摆脱Dialog,果苹自主电源管理芯片最快明年问世
电子网综合报道,据Nikkei的消息,苹果自主设计的电源管理芯片最快将用于明年的iPhone机型,以降低对英国半导体公司Dialog的依赖。 过去几年,苹果越来越多地自主设计芯片,例如iPhone和iPad使用的A系列CPU、GPU等。苹果下一个自主设计芯片的领域似乎是电池和电源管理。Nikkei称,苹果的电源管理芯片“将是业内最先进的”。 按照苹果目前的计划,该公司打算从明年开始利用自主电源管理芯片取代部分或一半当前使用的iPhone电源管理芯片。另外一位知情人士称,苹果确实在为iPhone开发电源管理芯片,但是推出时间还不确定,可能会推迟到2019年。 Dialog目前为iPhone设计电源管理芯片。如果报道属实,
[半导体设计/制造]
示波器耦合方式对电源负载动态恢复特性测试结果的影响
一、问题的提出
开关电源测试中通常都要测量负载动态恢复特性,其目的是测试输出负载变化情况下,电源输出电压稳定在整定值的能力。最关注的测试指标是过冲幅度和恢复时间。图一所示为过冲幅度和恢复时间的定义及测试方法接线图。恢复时间是指直流输出电压随着负载的变化开始出现过冲开始,恢复至小于等于并不再超过负载调整率处止的这段时间。(没有输出负载调整率要求的以输出电压范围界定)
图一过冲幅度和恢复时间的定义及测量方法接线图
过冲幅度是指负载变化带来的过冲的最大值和电压稳态值的电压差。
[测试测量]
挑选优秀电源解决方案,仅仅单片集成怎么够?
系统工程师常常为电源解决方案的选择而苦恼:要分立解决方案,还是集成解决方案?分立吧,占板面积太大,设计起来比较复杂;而集成的方案通常会因为工艺上的技术瓶颈而牺牲一些性能。有没有两全其美的方法呢?国际整流器(International Rectifier,IR)公司最新款稳压器产品SupIRBuck系列便为服务器设计工程师解决了这一难题。
从工艺上作文章,玩转集成“新花样”
包括IBM、HP在内,越来越多的服务器生产厂商愿意选择单片集成的电源解决方案,这种解决方案的高密度、设计简单等优势自然不用说,重要的是,单片集成方案由一家厂商提供, 比起分立方案来,供应渠道的稳定性要好很多,而且当电源系统出现故障时,单片集成的解决方
[焦点新闻]
Altera全球业务开发总监:数字电源跃居FPGA SoC设计新宠
20/14奈米现场可编程闸阵列(FPGA)将加速改搭数位电源。FPGA迈向20/14奈米先进制程,导致电路复杂度和电源供应需求激增,相关晶片商已开始导入高整合、可编程,且支援大电流的数位电源解决方案,从而提升FPGA核心电源轨的供电效能,同时改善系统整体功耗、占位空间和散热机制,以满足系统业者日益严格的节能设计要求。
Altera全球业务开发总监Patrick Wadden强调,资料中心业者将更加注重伺服器核心处理器功耗。
Altera全球业务开发总监Patrick Wadden表示,基地台、伺服器正扩大导入20奈米以下先进制程,并整合各种处理核心的FPGA系统单晶片(SoC),然而,随着FPGA SoC
[嵌入式]
ADIADP244136V1A效率94%降压DC电源稳压方案
ADI 公司的ADP2441是36V /1A同步降压DC/DC电源稳压器,负载电流高达1A,输入电压4.5V-36V,输出电压从0.6V到0.9VxVIN,精度±1%,开关频率从300 kHz到1 MHz,效率高达94%,关断电流小于15uA,主要用在POL,分布式电源系统,工业控制电源和DC转换器.本文介绍了ADP2441主要特性,方框图,多种典型应用电路以及ADP2441评估板主要特性,电路图,材料清单和PCB元件布局图. The ADP2441 is a constant frequency, current mode control, synchronous, step-down dc-to-dc regulator tha
[电源管理]
爆料称英伟达因电源跳闸和端子熔化等问题而搁置了RTX Titan新卡皇
尽管许多人期待着英伟达带来旗舰级 RTX 4090 Ti 或所谓的 Ada Lovelace Titan 新卡皇,但有传闻称其因触发断路保护、且偶尔情况下可能过热熔化电源连接器而被 NVIDIA 搁置。此前还有消息称,其原本有望成为首批采用 GDDR7 显存的显卡。 最新发布的 GeForce RTX 4090 显卡,已凭借 450W 热设计功耗(TDP)、1600 美元建议零售价(国行 12999 RMB)、以及 24GB @ 21Gbps 的 GDDR6X 显存而惊艳众人。 不过在 48GB @ 24Gbps 显存和 900W TGP 功耗的 Ada Lovelace 旗舰产品推出之前,我们又听到了更多传闻。 据 Mo
[家用电子]
开关电源原理与设计(连载26)双激式变压器开关电源(part1)
1-8.双激式变压器开关电源
所谓双激式变压器开关电源,就是指在一个工作周期之内,变压器的初级线圈分别被直流电压正、反激励两次。与单激式变压器开关电源不同,双激式变压器开关电源一般在整个工作周期之内,都向负载提供功率输出。双激式变压器开关电源输出功率一般都很大,因此,双激式变压器开关电源在一些中、大型电子设备中应用很广泛。这种大功率双激式变压器开关电源最大输出功率可以达300瓦以上,甚至可以超过1000瓦。
推挽式、半桥式、全桥式等变压器开关电源都属于双激式变压器开关电源。
1-8-1.推挽式变压器开关电源的工作原理
在双激式变压器开关电源中,推挽式变压器
[电源管理]
嵌入式便携设备中电源管理的分析与研究
引言
现今对电子系统设备性能的要求越来越高,在权衡电子系统的性能和功耗时,电子系统的性能往往得到更多的重视。容量有限的电池是便携设备的惟一能量来源,而电池容量的提高速度明显赶不上中央处理器性能的提高速度,因此,如何利用有限的电能为便携设备提供最高性能,是便携设备中电源管理的主要目标。除此之外,电源管理还要兼顾稳定性和散热性。电源管理模块是在可编程电源管理的设备上,为电源管理提供实现各种功耗模式的应用编程接口的软件模块。
功率消耗有两种方式: 静态功耗和动态功耗。静态功耗主要为晶体管泄漏(leakage)功率;动态功耗则来源于电路有效性激活,例如地址线或者数据线输入时引起的寄存器线路的有效性激活。开关电容所消耗的
[嵌入式]
