基于SiC414设计的6A降压电源稳压技术
SiC414是Vishay公司的集成了5V/200mA LDO的6A降压电源稳压器,开关频率高达1MHz,全部采用陶瓷电容.连续输出电流达6A,效率大于95%,内部软起动和软关断,主要用在笔记本电脑,台式电脑和服务器,数字HDTV和消费类电子,网络和通信设备,打印机,DSL和STB,嵌入式应用和点负载电源.本文介绍了SiC414主要特性, 功能方框图, 典型应用电路图和SiC414评估板电路图以及材料清单(BOM).
SiC414 pdf:http://www.elecfans.com/soft/39/2010/2010032371827.html
The Vishay Siliconix SiC414 is an advanced stand-alone synchronous buck regulator featuring integrated power MOSFETs, bootstrap diode, and an internal 5 V LDO in a space-saving MLPQ 4 x 4 - 28 pin package.
The SiC414 is capable of operating with all ceramic solutions and switching frequencies up to 1 MHz. The programmable frequency, synchronous operation and selectable power-save allow operation at high efficiency across the full range of load current. The internal LDO may be used to supply 5 V for the gate drive circuits or it may be bypassed with an external 5 V for optimum efficiency and used to drive external n-channel MOSFETs or other loads. Additional features include cycle-by-cycle current limit, voltage softstart, under-voltage protection, programmable over-current protection, soft shutdown and selectable power-save. The Vishay Siliconix SiC414 also provides an enable input and a power good output.
SiC414主要特性:
• High efficiency > 95 %
• 6 A continuous output current capability
• Integrated bootstrap switch
• Integrated 5 V/200 mA LDO with bypass logic
• Temperature compensated current limit
• Pseudo fixed-frequency adaptive on-time control
• All ceramic solution enabled
• Programmable input UVLO threshold
• Independent enable pin for switcher and LDO
• Selectable ultra-sonic power-save mode
• Internal soft-start and soft-shutdown
• 1 % internal reference voltage
• Power good output and over voltage protection
• Halogen-free according to IEC 61249-2-21 definition
• Compliant to RoHS directive 2002/95/EC
SiC414应用:
• Notebook, desktop and server computers
• Digital HDTV and digital consumer applications
• Networking and telecommunication equipment
• Printers, DSL and STB applications
• Embedded applications
• Point of load power supplies
图1.SiC414功能方框图
图2.SiC414典型应用电路图
图3.SiC414评估板电路图
SiC414评估板材料清单(BOM):
图4.SiC414评估板PCB布局图(顶层)
关键字:SiC414 电源稳压
编辑:神话 引用地址:基于SiC414设计的6A降压电源稳压技术
推荐阅读最新更新时间:2023-10-13 10:56
低压差线性稳压器(LDO)在开关电源中的应用
LDO简介
LDO 是一种微功耗的低压差 线性稳压器 ,它通常具有极低的自有噪声和较高的电源抑制比PSRR(PowerSupplyRejectionRatio)。
LDO低压差线性稳压器的结构如图(2)主要包括启动电路、恒流源偏置单元、使能电路、调整元件、基准源、误差放大器、反馈电阻网络和保护电路等。基本工作原理是这样的:系统加电,如果使能脚处于高电平时,电路开始启动,恒流源电路给整个电路提供偏置,基准源电压快速建立,输出随着输入不断上升,当输出即将达到规定值时,由反馈网络得到的输出反馈电压也接近于基准电压值,此时误差放大器将输出反馈电压和基准电压之间的误差小信号进行放大,再经调整管放大到输出
[电源管理]
具有高电源抑制比性能的线性稳压器
低压降稳压器(LDO)主要用于产生供音频和射频电路使用的低纹波、低噪声电源,也可以作为频率合成器和VCO的局部纯净电源。一般情况下,LDO的输入是在直流电压上叠加了宽带交流纹波的电源电压。流经电池和连接器阻抗的电流变化所引起的电气噪声就是其中一种宽带交流纹波。LDO可用来全面抑制这些寄生信号。LDO的输入端还可连接交换式稳压器的输出,以提供纯净、低噪声的输出电压,在这种应用中,LDO必须能够应付从100kHz到3MHz以上的开关频率。 首先,可将LDO稳压器视为一个具有开关功能的低损耗、紧凑型多节低通滤波器。然而,这种模型存在不少局限性,特别是抑制输入端宽带纹波的能力。假设工作电流小于250μA(对于合理的效率而言),IC设计师可
[电源管理]
TPS7350/tps6735设计的正负5V稳压电源电路
TPS7350设计的正负5V稳压电源电路:如图7所示,分别采用tps7350和tps6735作为+5v和-5v稳压电源。
[电源管理]
雷达发射机高压稳压电源
1 引言
现代雷达发射机已广泛采用栅控功率行波管,由于行波管相位灵敏度的提高,为了满足雷达系统对改善因子的指标要求,因而对其管体高压的稳定度和纹波均有很高的要求。又为了提高行波管的效率,普遍采用收集极降压方式,所以其高压电源由两组组成,一组是管体高压稳压电源,一组是收集极高压不稳压电源。现就某雷达发射机高压电源设计的思路和设计方法作一介绍。
2 主要技术要求
1)输入电压 ~220V/400Hz(±5%)。
2)输出管体高压
电压 UA=20~25kV,稳压,连续可调;
电流 Ia≥15mA,脉冲电流Iap≥1A;
电压稳定度Sv≤10-3(输入电压±5%变化);
[电源管理]
路灯照明系统中智能稳压电源设计应用
引言 现今工业厂区普遍有较大的工作区域,其间路灯众多,一般采用的是高压钠灯,而该灯功耗非常大,导致厂内供电电压不稳定,波动幅度大。尤其在下半夜,电压通常高达250V以上,致使灯泡损耗率极高(达60%以上)。为节省能耗,减少浪费,降低成本,有必要进行节能改造。 1 节能改造分析 1.1 供电状况 供电部门为了避免输电过程中的各种损耗以及用电高峰期造成线路末端电压过低对用电设备产生的不良影响,而以比标称电压高10%的电压向用户(以单相220V标称电压为例,实际供电电压为220 22010%=242V)供电,以确保供电线路远端的电压不会低于220-22010%=198V。因此供电线路上的绝大部分区域的电压都会等
[电源管理]
LM7805构成的5V稳压电源电路
LM7805构成的5V稳压电源电路
如图所示电路为输出电压+5V、输出电流1.5A的稳压电源。它由电源变压器B,桥式整流电路D1~D4,滤波电容C1、C3,防止自激电容C2、C3和一只固定式三端稳压器(7805)极为简捷方便地搭成的。
220V交流市电通过电源变压器变换成交流低压,再经过桥式整流电路D1~D4和滤波电容C1的整流和滤波,在固定式三端稳压器LM7805的Vin和GND两端形成一个并不十分稳定的直流电压(该电压常常会因为市电电压的波动或负载的变化等原因而发生变化)。此直流电压经过LM7805的稳压和C3的滤波便在稳压电源的输出端产生了精度高、稳定度好的直流输出电压。本稳压电源可作为TTL电路或
[电源管理]
基于UC3842的开关稳压电源系统设计
随着电力电子技术的发展,电源装置大量出现在生产生活的各个领域,其电压电流的稳定性、电压调整率、负荷调整率、变换器的效率等因素将直接影响到用电及通信设备的正常运行,严重时还将影响到设备的安全性。因此,如何改善上述各项指标,成为电源装置设计时需要考虑的重要因素。本文介绍一种行之有效的开关稳压电源的系统设计方案。
1 方案论证
1. 1 DC-DC 变换器方案选取
隔离变压器输出工频电压有效值为18 ± 3 V,经桥式整流滤波后输出直流电压约为18 ~ 26 V。要求开关电源的输出电压范围在30 ~ 36 V 之间稳定可调,单端反激式和Boost 直接变换式都可以满足要求。但是,考虑到单端反激式开关电源
[单片机]
工业自动化电源困境:同步稳压器改进电源系统
介绍 本应用笔记是工业自动化电源设计中高压同步稳压器系列文章的两部分的第2部分。第1部分讨论工业控制架构以及电源需求和困境。在本系列的第 2 部分中,我们将讨论新电源如何采用同步开关技术,同时能够承受高达 60V 的电压尖峰和高达 3.5A 的电源,这在以前是不切实际的。这些功能通过提高效率,从而降低发热和功耗,减少元件尺寸,并限制分立式外部元件的数量,从而简化工业自动化系统电源设计。 新型同步稳压器 同步稳压器似乎是应对工业自动化系统电源设计挑战的完美解决方案。这些器件效率高,功耗有限,系统温度更低。它们需要的空间很小,降低了 BOM 成本。 有许多同步稳压器的额定工作电压高达28V,少数额定工作电压高达40V。然而,这
[嵌入式]
