Si2155:新一代硅调谐器详细介绍
最新更新时间:2013-09-28来源: 互联网关键字:Si2155  硅调谐器 手机看文章 扫描二维码
随时随地手机看文章
Si2155 基于SiliconLabs公司专利技术的电视调谐器架构,提供超清晰模拟和数字广播电视接收。通过提供卓越的线性特性和完全集成的高品质跟踪滤波电感器,SiliconLabs公司新一代电视调谐器具有业界最高的抗干扰能力,可以在城区接收最多的模拟和数字电视频道。Si2155集成电路的RF前端也提供了无与伦比的灵敏度性能和一致的调谐特性,即使在远离发射台的乡村区域也能做到这一点。
  Si2155 电视调谐器具有紧凑的5mm×5mmQFN封装,通过最小化电路板尺寸和器件数量、支持低成本的外部器件,Si2155电视调谐器使电视制造商有效降低系统成本。Si2155IC集成了完整的从RF输入到IF输出的信号路径。与传统分立式基于MOPLL的调谐器方案相比,基于Si2155的设计减少了超过 100个的外围器件,包括低噪声放大器(LNA)、声表面波(SAW)滤波器,也不像其他硅调谐器需要使用跟踪滤波电感器,这使得混合调谐器的设计最简便、BOM成本最低。Si2155也支持采用低成本的外部器件来实现具有成本效益的板上调谐器设计方案。
  描述:
  The Si2155 integrates a complete hybrid TV tuner supporting all worldwide terrestrial and cable TV standards. Leveraging Silicon Labs’ field proven digital low-IF architecture, the Si2155 maintains the unmatched performance and design simplicity of the Si2153 while further reducing footprint size and bill of materials cost. No external LNAs, tracking filters, wirewound inductors, or SAW filters are used.
  Compared with competing silicon tuners and discrete MOPLL-based tuners, the Si2155 delivers superior picture quality and a higher number of received stations in crowded and near/far real-world reception conditions. The high linearity and low noise RF front-end delivers superior blocking performance and higher sensitivity in the presence of strong undesired channels and interference.
Si2155
  The Si2155 integrates the complete signal path from antenna input to IF outputs for both analog and digital transmission standards. Compared to traditional discrete MOPLL-based tuners, the Si2155 eliminates hundreds of external components including external LNAs, tracking filter varactors and inductors (unlike competing silicon tuners), and SAW filters, resulting in the simplest, lowest-cost BOM for a hybrid TV tuner.
  Interfacing the Si2155 seamlessly with the Si2165 DVB-T/C demodulator creates a complete terrestrial and cable DVB-T/C receiver plus PAL/SECAM tuner.
  特性:
  Worldwide hybrid TV tuner
  Analog TV: NTSC, PAL/SECAM
  Digital TV: ATSC/QAM, DVB-T/T2/C, ISDB-T/C, DTMB
  42-870 MHz frequency range
  Compliance to A/74, NorDig, D-Book, C-Book, ARIB, EN55020, OpenCable™ specifications
  Best-in-class real-world reception
  Exceeds discrete MOPLL-based tuners
  Highly integrated, lowest BOM
  No SAW filters or wirewound inductors required
  Integrated LNAs and complete tracking filters
  No alignment, tuning or calibration required
  Digital low-IF architecture
  Integrated channel select filters
  Flexible output interface
  ALIF to analog TV demodulator or SoC
  DLIF to digital TV demodulator or SoC
  3.3 and 1.8 V power supplies
  Standard CMOS process technology
  5 x 5 mm, 32-pin QFN package
  RoHS compliant
  应用:
  Hybrid ½-NIM
  iDTV (Integrated Digital TV)
  Digital terrestrial and cable STB
  Hybrid PVR and DVD recorder
  电气规范:
  电气规范
  引脚图和封装:
Si2155引脚图
Si2155封装
关键字:Si2155  硅调谐器 编辑:神话 引用地址:Si2155:新一代硅调谐器详细介绍
上一篇:基于linux的全彩LED显示屏脱机控制系统设计
下一篇:基于FPGA的SPI Flash控制器的设计方案
推荐阅读最新更新时间:2023-10-12 20:49
恩智浦推出为板载设计全面优化的突破性电视调谐器
2011年12月12日—— 恩智浦半导体NXP Semiconductors N.V. (NASDAQ:NXPI) 近日宣布推出一款突破性的高性能硅调谐器TDA18274,可用于全球的地面和有线电视接收。TDA18274混合型硅调谐器支持所有模拟和数字电视标准,有两种版本可用:一种采用48引脚HLQFN封装,针对直接“板载”式设计而优化,完全集成射频滤波器;另一种采用40引脚HVQFN封装,搭载外置UHF和VHF滤波器。TDA18274同时针对多调谐器应用而优化,集成射频分频器功能,免除了对辅助芯片的需求,且可通过晶振输出缓冲器实现单个16-MHz晶体的共享,并提供一个控制接口,借助四个I2C地址可管理多达4个调谐器。 TDA1
[手机便携]
恩智浦推出为板载设计全面优化的突破性<font color='red'>硅</font>电视<font color='red'>调谐器</font>
多频带调谐器支持多标准
  恩智浦半导体发布了首款多频带硅调谐器TDA18292。TDA18292是第一个支持五个全球性移动设备电视标准(DVB-T、DVB-H、DVB-SH、T-DMB、ISDB-T)及五个重要频带(VHF、UHF、L1、L2、S-band)的产品。   TDA18292具有低功耗、低噪、小尺寸及对其它手机和连接标准的抵抗干扰能力,从而使它应用于笔记本电脑、USB棒、便携式多媒体播放器(PMP)、便携式DVD播放器、手机、便携式导航系统(GPS)和其它手持设备的电视解决方案。在大批量的情况下低于2美元。   “恩智浦全新的硅调谐器在推动随时、随地的电视观赏体验方面是一个非常重要的成就。”咏发科技执行副总裁Philip Sun
[新品]
恩智浦全新的TDA18272为调谐器订立了基准
随着电视工业开始全面采用硅调谐器,恩智浦半导体(NXP Semiconductors)近日宣布推出面向全球无线及有线电视接收的高性能硅调谐器——TDA18272。兼容DVB-T2标准的TDA18272支持全球所有模拟及数字电视标准,让电视制造商能为下一代电视做好准备。迄今为止,恩智浦已售出了4亿多只恩智浦硅调谐器,对普及系统优化的硅调谐器起到了推动作用。TDA18272也代表着恩智浦所设计的第四代硅调谐器。 由于硅调谐器即将取代各种基于MoPLL的传统CAN调谐器,TDA18272满足了全球对高度集成的低功耗超薄电视架构与日俱增的需求。TDA18272的尺寸小巧,采用了40引脚,6x6毫米封装
[家用电子]
恩智浦全新的TDA18272为<font color='red'>硅</font><font color='red'>调谐器</font>订立了基准
Silicon Labs公司推出业界领先的第六代电视调谐器
硅电视调谐器领导厂商Silicon Labs宣布推出高性能且经过现场验证的第六代电视调谐器IC。Silicon Labs最新的Si2151和Si2141电视调谐器满足全球数模混合电视和数字电视市场的需求,同时支持模拟和数字视频广播接收,并符合全球所有的地面/有线电视标准。凭借Silicon Labs历经五代持续进化的业界领先架构,Si2151/41电视调谐器使开发人员可以利用卓越的线性度和灵敏度、全球最小的封装、最低的物料(BOM)成本和超低功耗,进一步提升他们的电视和机顶盒(STB)设计。 Si2151/41系列产品为全球领先的电视机生产国——中国提供了一个理想的、极具成本效益的硅电视调谐器解决方案。DisplaySearch
[嵌入式]
世界最小尺寸的电视调谐器为中国电视和机顶盒厂商以及全球地面/有线电视市场带来最低BOM成本 。 中国,北京-2014年10月29日-硅电视调谐器领导厂商Silicon Labs(芯科实验室有限公司,NASDAQ:SLAB)今天宣布推出高性能且经过现场验证的第六代电视调谐器IC。Silicon Labs最新的Si2151和Si2141电视调谐器满足全球数模混合电视和数字电视市场的需求,同时支持模拟和数字视频广播接收,并符合全球所有的地面/有线电视标准。凭借Silicon Labs历经五代持续进化的业界领先架构,Si2151/41电视调谐器使开发人员可以利用卓越的线性度和灵敏度、全球最小的封装、最低的物料(BOM)成本和
[家用电子]
Silicon Labs公司推出业界领先的第六代<font color='red'>硅</font>电视<font color='red'>调谐器</font>
首款应用 RT810 调谐器的液晶电视系统方案
宏观微电子(股)公司选择龙源电子科技(有)公司为策略联盟伙伴,双方于今日共同宣布推出首款整合RT810硅晶调谐器之液晶电视系统方案,此方案的应用范围广泛,可接收全球模拟电视广播与模拟有线电视讯号 (PAL/ NTSC/ SECAM)。因为采用RT810硅晶调谐器,此方案大幅精简了电视硬件的外围组件,可有效地降低成本、体积与功耗,完全符合全球电视市场轻、薄、短、小、省之未来趋势,极适合于便携式与中尺寸液晶电视之消费市场,是一个具备前瞻性与高性价比的整体解决方案。此外,此方案已通过多项产品验证与实地测试,可大幅缩短系统客户产品开发与量产导入时间。 此套由宏观微电子与龙源电子科技所共同开发的液晶电视方案,同时采用宏观微
[家用电子]
恩智浦推出高性能有线机顶盒调谐器
中国上海, 2012 年 3 月 16 日讯 ―― 硅电视调谐器全球市场领导者恩智浦半导体公司(纳斯达克代码: NXPI )今日发布了 TDA18250A 和 TDA18260A―― 涵盖全球数字有线标准的最新高性能有线机顶盒( STB )单路和双路硅调谐器。 TDA18250A 和 TDA18260A 是业内首款提供零功率环路输出的硅调谐器,使机顶盒厂商得以遵循最新的欧盟生态设计指令规范;该规范于 2013 年起实施,限定了基本型机顶盒的待机功耗必须低于半瓦。恩智浦新一代的有线硅调谐器同样也是业内第一款片内完全集成 8 KV ESD 保护的产品,更加稳定可靠且进一步减少所需的外部元器件数目。集成的零功率环路输出加上 E
[家用电子]
小广播
最新模拟电子文章
换一换 更多 相关热搜器件
