60W低音放大器 (60W Bass Amplifier)
最新更新时间:2013-11-13来源: 互联网关键字:60W  低音  放大器 手机看文章 扫描二维码
随时随地手机看文章
Amplifier parts:
R1__________________6K8    1W Resistor
R2,R4_____________470R   1/4W Resistors
R3__________________2K   1/2W Trimmer Cermet
R5,R6_______________4K7  1/2W Resistors
R7________________220R   1/2W Resistor
R8__________________2K2  1/2W Resistor
R9_________________50K   1/2W Trimmer Cermet
R10________________68K   1/4W Resistor
R11,R12______________R47   4W Wirewound Resistors
C1,C2,C4,C5________47΅F   63V Electrolytic Capacitors
C3________________100΅F   25V Electrolytic Capacitor
C6_________________33pF   63V Ceramic Capacitor
C7_______________1000΅F   50V Electrolytic Capacitor
C8_______________2200΅F   63V Electrolytic Capacitor (See Notes)
D1_________________LED    Any type and color
D2________Diode bridge   200V 6A
Q1,Q2____________BD139    80V 1.5A NPN Transistors
Q3_____________MJ11016   120V 30A NPN Darlington Transistor (See Notes)
Q4_____________MJ11015   120V 30A PNP Darlington Transistor (See Notes)
SW1_______________SPST Mains switch
F1__________________4A Fuse with socket
T1________________220V Primary, 48-50V Secondary 75 to 150VA Mains transformer
PL1_______________Male Mains plug
SPKR______________One or more speakers wired in series or in parallel
                  Total resulting impedance: 8 or 4 Ohm
                  Minimum power handling: 75W
Preamplifier circuit diagram:
Preamplifier parts:
P1_________________10K   Linear Potentiometer
P2_________________10K   Log. Potentiometer
R1,R2______________68K   1/4W Resistors
R3________________680K   1/4W Resistor
R4________________220K   1/4W Resistor
R5_________________33K   1/4W Resistor
R6__________________2K2  1/4W Resistor
R7__________________5K6  1/4W Resistor
R8,R18____________330R   1/4W Resistors
R9_________________47K   1/4W Resistor
R10________________18K   1/4W Resistor
R11_________________4K7  1/4W Resistor
R12_________________1K   1/4W Resistor
R13_________________1K5  1/4W Resistor
R14,R15,R16_______100K   1/4W Resistors
R17________________10K   1/4W Resistor
C1,C4,C8,C9,C10____10΅F   63V Electrolytic Capacitors
C2_________________47΅F   63V Electrolytic Capacitor
C3_________________47pF   63V Ceramic Capacitor
C5________________220nF   63V Polyester Capacitor
C6________________470nF   63V Polyester Capacitor
C7________________100nF   63V Polyester Capacitor
C11_______________220΅F   63V Electrolytic Capacitor
Q1,Q3____________BC546    65V 100mA NPN Transistors
Q2_______________BC556    65V 100mA PNP Transistor
J1,J2___________6.3mm. Mono Jack sockets
SW1_______________SPST Switch
Circuit description:
This design adopts a well established circuit topology for the power amplifier, using a single-rail supply of about 60V and capacitor-coupling for the speaker(s). The advantages for a guitar amplifier are the very simple circuitry, even for comparatively high power outputs, and a certain built-in degree of loudspeaker protection, due to capacitor C8, preventing the voltage supply to be conveyed into loudspeakers in case of output transistors' failure.
The preamp is powered by the same 60V rails as the power amplifier, allowing to implement a two-transistors gain-block capable of delivering about 20V RMS output. This provides a very high input overload capability.
Technical data:
Sensitivity:
70mV input for 40W 8 Ohm output
63mV input for 60W 4 Ohm output
Frequency response:
50Hz to 20KHz -0.5dB; -1.5dB @ 40Hz; -3.5dB @ 30Hz
Total harmonic distortion @ 1KHz and 8 Ohm load:
Below 0.1% up to 10W; 0.2% @ 30W
Total harmonic distortion @ 10KHz and 8 Ohm load:
Below 0.15% up to 10W; 0.3% @ 30W
Total harmonic distortion @ 1KHz and 4 Ohm load:
Below 0.18% up to 10W; 0.4% @ 60W
Total harmonic distortion @ 10KHz and 4 Ohm load:
Below 0.3% up to 10W; 0.6% @ 60W
Bass control:
Fully clockwise = +13.7dB @ 100Hz; -23dB @ 10KHz
Center position = -4.5dB @ 100Hz
Fully counterclockwise = -12.5dB @ 100Hz; +0.7dB @ 1KHz and 10KHz
Low-cut switch:
-1.5dB @ 300Hz; -2.5dB @ 200Hz; -4.4dB @ 100Hz; -10dB @ 50Hz
Notes:
The value listed for C8 is the minimum suggested value. A 3300΅F capacitor or two 2200΅F capacitors wired in parallel would be a better choice.
The Darlington transistor types listed could be too oversized for such a design. You can substitute them with MJ11014 (Q3) and MJ11013 (Q4) or TIP142 (Q3) and TIP147 (Q4).
T1 transformer can be also a 24 + 24V or 25 + 25V type (i.e. 48V or 50V center tapped). Obviously, the center-tap must be left unconnected.
SW1 switch inserts the Low-cut feature when open.
In all cases where Darlington transistors are used as the output devices it is essential that the sensing transistor (Q2) should be in as close thermal contact with the output transistors as possible. Therefore a TO126-case transistor type was chosen for easy bolting on the heatsink, very close to the output pair.
R9 must be trimmed in order to measure about half the voltage supply from the positive lead of C7 and ground. A better setting can be done using an oscilloscope, in order to obtain a symmetrical clipping of the output waveform at maximum output power.
To set quiescent current, remove temporarily the Fuse F1 and insert the probes of an Avo-meter in the two leads of the fuse holder.
Set the volume control to the minimum and Trimmer R3 to its minimum resistance.
Power-on the circuit and adjust R3 to read a current drawing of about 30 to 35mA.
Wait about 15 minutes, watch if the current is varying and readjust if necessary.
关键字:60W  低音  放大器 编辑:神话 引用地址:60W低音放大器 (60W Bass Amplifier)
上一篇:5000W超轻,高功率放大器电路,无开关电源
下一篇:高保真BTL放大器的原理及设计
推荐阅读最新更新时间:2023-10-12 20:52
ANADIGICS为多款中兴新型智能手机提供功率放大器
2012年5月22日,新泽西州沃伦讯 —— ANADIGICS, Inc. (纳斯达克股票代码:ANAD) 是全球首屈一指的射频 (RF) 解决方案供应商。该公司今日宣布开始为中兴的V889D、V788D、N788、N910和PF200五款智能手机批量供应AWT6621、AWT6624、AWT6625A和AWT6628A等第四代低功耗高效率 (HELP™4) 功率放大器 (PA)。V788D、N788、N910和PF200配备了一块3.5英寸的屏幕、500万像素摄像头和Android 2.3 Gingerbread操作系统。而格外引人注目的V889D则采用一块4英寸的屏幕和Android 4.0 Ice Cream Sandwic
[手机便携]
基于SG3525A的车载逆变器设计方案
随着经济水平的提高,汽车正逐渐成为人们的日常交通工具然而,人们随身携带的电子产品,例如手机,却不能使用汽车上的电源,因此开发一款经济实用的车载逆变器就成为一种需求。 我们采用集成脉宽调制芯片SG3525A为主控芯片,以CD4020B计数器及与非门电路构成分频分相电路并配以保护电路,实现了逆变器的脉宽调制其在逆变电源工作时的持续输出功率为100W,并具有输出过流保护及输入欠压保护等功能,可实现电源逆变、电压稳定、欠压保护及过流保护等功能。 1 系统基本原理 本逆变器输入端为汽车蓄电池(+12V,4.5Ah),输出端为工频方波电压(50Hz,220V)其系统主电路和控制电路框图如图1所示,采用了典型的二级变换,即DC/DC
[嵌入式]
由OP放大器反馈环跑构成的恒定电压驱动的电桥传感器电路
电路的功能 这是一种适合电桥传感器使用的驱动、检测电路。采用恒定电压驱动、电压为正负2.5V,如必用产生基准电压的IC,也可以用正负5V或正负10V。 电路工作原理 OP放大器A1是+2.5V的基准电压生成电路,为了能输出十毫安电流,加了电流增强器TT1。如果电桥传感器的电阻相等,A2的反相输入端为假想地,所以TT2的射极电压应为-2.5V。
[工业控制]
由OP<font color='red'>放大器</font>反馈环跑构成的恒定电压驱动的电桥传感器电路
帕斯卡驱动小型重低音音箱电路原理图
当今的HI-FI发烧线圈内,“质”,“量”兼具的超重低音系统成为发烧友“苦心经营”的对像。所谓超重低音是指从40HZ以下一直延续到次声的范围,在欣赏音乐时,它几乎是由人类体表感受到的,给人一种震撼的快感。本文参考日本一家公司的利用帕斯卡定律开发的重低音重放模式,设计并实验了本文所示 音箱 系统好,频响30~20000HZ,灵敏度为85DB。 音箱结构如图9-48所示。采用密封箱体,高音单元制作与一般箱体相同,在低音单元的箱内斜置隔板,隔板上安装帕斯卡驱动器(扬声器),由独立的低频功率放大器驱动。 其工作原理如图9-49所示,信号IC1及外围电路
[模拟电子]
帕斯卡驱动小型重<font color='red'>低音</font>音箱电路原理图
德州仪器推出全面集成型单声道 D 类音频放大器
德州仪器 (TI) 宣布推出业界首款汽车 D 类音频放大器,可在单个器件上集成负载突降保护与诊断功能,适用于紧急呼叫 (eCall) 和仪表盘系统。设计人员使用该单声道模拟差动输入 TAS5421-Q1,不仅可取消多个分立式组件,简化汽车级诊断设计,而且还可延长电池备用电源的使用时间。   目前,用户对车载 eCall 系统的需求正在不断提升。在发生碰撞事故时,eCall 系统可自动与最近的急救中心通信,向其发送车辆位置信息,这可缩短应急响应时间,从而提升挽救生命的机会。eCall 系统在只使用备用电池电源的情况下,即可长时间保持稳定可靠的自动运行。系统设计人员可充分发挥 TAS5421-Q1 高达 90% 的效率以及低静态
[嵌入式]
ADC驱动器或差分放大器设计指南
作为应用工程师,我们经常遇到各种有关差分输入型高速模数转换器(ADC)的 驱动 问题。事实上,选择正确的ADC 驱动 器和配置极具挑战性。为了使鲁棒性ADC 电路 设计多少容易些,我们汇编了一套通用“路障”及解决方案。本文假设实际驱动ADC的 电路 ——也被称为ADC驱动器或差分放大器——能够处理高速信号。 引言 大多数现代高性能ADC使用差分输入抑制共模噪声和干扰。由于采用了平衡的信号处理方式,这种方法能将动态范围提高2倍,进而改善系统总体性能。虽然差分输入型ADC也能接受单端输入信号,但只有在输入差分信号时才能获得最佳ADC性能。ADC驱动器专门设计用于提供这种差分信号的电路——可以完成许多重要的功能,包括幅度调整
[模拟电子]
XMOS助力OPPO屡获殊荣的HA-2耳机放大器
OPPO蝉联EISA大奖 多核微控制器领域领导者XMOS有限公司日前宣布:XMOS的xCORE器件已被OPPO选中,用于助力其新推出的便携式Hi-Fi耳机放大器HA-2。HA-2最近荣获了2015-2016年度欧洲影音协会(EISA)Hi-Fi类大奖。这是继2013年的OPPO蓝光播放器BDP-103,2014年的OPPO平面振膜耳机PM-1之后,OPPO连续第三次获奖。为了在这些使用了xCORE-L和xCORE-U系列器件的产品中提供高解析度音频,XMOS和OPPO已经展开了密切的合作。 对高解析度音频内容的消费需求正在形成旺盛的势头。领先的智能手机制造商们纷纷在其高端机型中加入了播放高解析度
[手机便携]
如何正确地选择运算放大器
现代电子工业的趋势是集成更多的功能到尽可能小巧的外形中,这已经不是什么秘密。移动电话就是这样的实例。当今许多生产商将MP3播放器、数码相机甚至卫星电视功能集成在移动电话里。过去几年,该市场已经取得了巨大的发展,并且仍在快速扩展。 这些产品的设计周期通常较短,测试比实际设计耗费更长的时间(设计大约需要4个月,测试需要6个月)。为此,设计师必须谨慎选择器件,以避免对最终的产品进行反复修改和导致延误。 下文将重点说明一些有用的设计技术、简短的计算和通用的评估方法,以帮助设计师更好地进行评估。 在便携电子领域,设计师基于多种因素(尺寸、成本和性能),利用他们的专业知识和最佳判断来选择器件。但这些因素通常需要进行权衡,设计
[模拟电子]
小广播
最新模拟电子文章
换一换 更多 相关热搜器件
随便看看
