Powerint LNK454DG RDR268超小型LED驱动方案
最新更新时间:2011-03-12来源: 中电网关键字:LED  Powerint  RDR268 手机看文章 扫描二维码
随时随地手机看文章
   Powerint 公司的RD-268是采用LinkSwitchTM-PL系列LNK454DG的1.1W PFC LED驱动器(非绝缘)参考设计,单路恒流输出366mA,LED电压3.0V,通用85 VAC到265 VAC, 47 Hz 到63 Hz输入,功率系数大于0.85,THD小于25%,具有很小的尺寸,可以装入枝状大烛台的有限空间.本文介绍了LinkSwitch-PL系列产品的亮点, 功能方框图, 典型应用电路图, 替代A19白炽灯的5W 15V LED驱动电路以及采用LinkSwitchTM-PL系列 LNK454DG的1.1W PFC LED驱动器(非绝缘)参考设计RD-268电路图和材料清单(BOM).
The LinkSwitch-PL family enables a very small and low cost single-stage power factor corrected constant current driver for solid state lighting. Optimized for direct LED current sensing, the LinkSwitch-PL operates over a wide input voltage range delivering an output power of up to 16 W. The LinkSwitch-PL control algorithm provides flicker-free TRIAC dimming with minimal external components.
Each device incorporates a 725 V rated power MOSFET, a novel discontinuous mode variable frequency variable on-time controller, frequency jitter, cycle by cycle current limit and hysteretic thermal shutdown in a monolithic 4-pin IC, available in SO-8C, eSOP-12, and eDIP-12 packages.
LinkSwitch-PL系列产品亮点:
Dramatically Simplifies Off-line LED Drivers
Flicker-free phase-controlled TRIAC dimming
Single stage power factor correction and accurate constant current (CC) output
Very low component count with small non-electrolytic bulk capacitor for compact replacement lamp designs
Compact SO8, eSOP, and eDIP packages
Completely eliminates control loop compensation
Advanced Performance Features
Optimized for non-isolated flyback designs
Frequency jitter greatly reduces EMI filter size and costs
Low dissipation direct sensing of LED current
Advanced Protection and Safety Features
Cycle skipping regulation for abnormally low output power to clamp peak output current delivered
725 V integrated power MOSFET allows small bulk capacitance and maximizes power capability
Short-circuit, overload, open feedback and output overvoltage protection
Hysteretic thermal shutdown
Meets high-voltage creepage between DRAIN and all other pins both on PCB and at package
EcoSmart™ - Energy Efficient
High power factor optimizes system lumen per input VA
Control algorithm balances switching and conduction losses over line and load to maintain optimum efficiency
图1.LinkSwitch-PL系列功能方框图
图2.LinkSwitch-PL系列典型应用电路图
图3.替代A19白炽灯的5W 15V LED驱动电路
采用LinkSwitchTM-PL LNK454DG的1.1W PFC LED驱动器(非绝缘)参考设计
Reference Design Report for a 1.1 W Power Factor Corrected LED Driver (Non-Isolated) Using LinkSwitchTM-PL LNK454DG
This document is an engineering report describing a non-isolated LED driver (power supply) utilizing a LNK454DG from the LinkSwitchTM-PL family of devices. It contains the power supply specification, schematic, bill of materials, transformer documentation,printed circuit layout, and performance data.
The RD-268 provides a single constant current output of 366 mA with a nominal LED voltage of 3 V.
The board was optimized to operate over a universal AC input voltage range (85 VAC to 265 VAC, 47 Hz to 63 Hz) but suffers no damage over an input range of 0 VAC to 300 VAC. This increases field reliability and lifetime during line sags and swells.Key benefits of this design are the very high power factor (>0.85), low THD (<25%) and low harmonic content (a significant challenge due to the low output power) and the ability to fit inside the limited space of a candelabra size lamp base.
High PF is a requirement or desire in many commercial applications, for example large chandeliers in hotel foyers. Here a large number of lamps (25 to >200) are connected in parallel however by using individual lamps that have PFC allows the overall fixture to meet PFC and THD requirements with the large energy savings that come from using LEDs vs. incandescent lamps.
The form factor of the board was chosen to meet the requirements for standard candelabra shaped LED replacement lamps. The output is non-isolated and requires the mechanical design of the enclosure to isolate the output of the supply and the LED load from the user.
1.1W PFC LED驱动器(非绝缘)参考设计主要特性:
Low cost, low component count and small PCB footprint solution
Superior performance and end user experience
Clean monotonic start-up – no output blinking
Fast start-up (<300 ms) – no perceptible delay
Universal input
Integrated protection and reliability features
Output open-circuit protected /output short-circuit protected with auto-recovery
Auto-recovering thermal shutdown with large hysteresis protects both components and printed circuit board
No damage during brown out conditions
Extended pin creepage distance between device DRAIN pin and other pins for reliable operation in high pollution and humid environments
Surge protected for high reliability
Meets IEC ringwave and differential mode surge
Meets EN55015 conducted EMI
PF >0.9 at 115 VAC and PF>0.85 at 230 VAC
%ATHD <15% at 115 VAC and <25% at 230 VAC
Meets EN61000-3-2 harmonic current requirements
电源指标:
图4.参考设计RD-268外形图
图5.装在枝状大烛台基座的RD-268驱动器板外形图(金属部分是LED散热器)
图6.RD-268参考设计电路图
RD-268参考设计材料清单(BOM):
关键字:LED  Powerint  RDR268 编辑:探路者 引用地址:Powerint LNK454DG RDR268超小型LED驱动方案
上一篇:面向下一代3D LCD TV的局部调光LED背光解决方案
下一篇:汽车LED组合尾灯及其实际应用
推荐阅读最新更新时间:2023-10-18 15:11
立体旋转LED汇编程序设计
org 00h jmp cfg org 03h clr 00h reti cfg: ;setb ea ; setb ex0 ; setb it0 mov dptr,#tab MM00: CLR 00H mm: mov a,r2 movc a,@a+dptr cpl a call hbit mov r4,a deC r2 mov a,r2 movc a,@a+dptr dec r2 cpl a call hbit jb 01h,gr0 mov p1,a mov p3,r4 jmp gr00 gr0:mov p2,a mov p0,r4 gr00:
[单片机]
适合驱动 LED的38VIN、10A 升压型 µModule 稳压器
2018 年 7 月 3 日 – Analog Devices Inc. (ADI) 宣布推出 Power by Linear™ LTM8005 升压型 DC/DC µModule® (电源模块) 稳压器,这是专为驱动 LED 而设计。LTM8005 将一个 DC/DC 控制器、电源开关、肖特基二极管和电流检测电阻器置于一个 9mm x 11.25mm x 2.22mm BGA 封装中。LTM8005 可在 5V 至 38V 的输入电压范围内工作,并能在高达 38V 的输出电压下提供高至 1.6A 的稳定电流。采用了一个外部电感器,因而使得 LTM8005 能够利用一个耦合电感器容易地配置在不同的操作模式,包括升压、降压-升压、降
[电源管理]
LED照明优势无法体现 关键在于低压驱动芯片
LED光源 使用寿命长、节能省电、应用简单方便、使用成本低,因而在家庭照明都将得到海量的应用。LED光源的技术日趋成熟,每瓦发光 流明 迅速增长,促使其逐年递减降价。 LED灯具 的高节能、长寿命、利环保的优越性能获得普遍的公认。    LED 高节能:直流 驱动 ,超低功耗(单管0.03瓦-1 瓦)电 光功率 转换接近100%,相同照明效果比传统光源节能80%以上。 LED长寿命:LED光源被称为长寿灯。固体 冷光源 ,环氧树脂封装,灯体内也没有松动的部分,不存在灯丝发光易烧、热沉积、光衰快等缺点。   LED寿命:使用寿命可达5万到10万小时,比传统光源寿命长10倍以上。   LED利环保:led是
[电源管理]
LED驱动电源“三分天下” 多种方案如何抉择?
众所周知,决定 LED驱动 电源品质有两点最重要:   一:要认准电容的品牌;其中红宝石(Rubycom日本)特别知名,恒英(HY国产)万裕(SAMXON)比较常见,当然价格要比其他不是品牌电容要贵几毛钱;   二:IC控制芯片;因为IC控制芯片具有止短路,过压,过载,过温等保护功能。   市面上现在使用较多的有以下三种驱动方式,简单做个比方:    一、开关电源   成品的开关电源走高端有:明纬(台湾)、茂硕(深圳),低端杂牌的就太多了;但是总体来说开关电源价格比较贵。这部分的高端品牌定位是“茂业百货式”的消费。    二、线性电源   线性电源其实很多,也是未来市场的一个趋势,方案有线性ic驱动,包括分段式,恒流二极管等。
[电源管理]
LED优点及产业分类
led是通电时可发光的半导体材料制成的发光元件,材料使用III- V族化学元素(如:磷化鎵(GaP)、砷化鎵(GaAs)等),发光原理是将电能转换为光,也就是对化合物半导体施加电流,透过电子与电洞的结合,过剩的能量会以光的形式释出,达成发光的效果,属于冷性发光。 LED最大的特点在于:无须暖灯时间(idling time)、反应速度很快(约在10^-9秒)、体积小、用电省、污染低、适合量产,具高可靠度,容易配合应用上的需要制成极小或阵列式的元件,适用范围颇广,如汽车、通讯产业、电脑、交通号誌灯、液晶面板用背光源、LED屏幕等。 LED产业主要可以分成上、中、下游三类。上游为单芯片及其外延,中游为LED芯片加
[电源管理]
利亚德:Micro LED2022年产能将达到1600KK/月
1月4日,利亚德在投资者互动平台表示,Micro LED目前已达产的产能是800KK/月,2022年将达到1600KK/月。公司全资子公司美国NP及北京虚拟动点拥有的光学动作捕捉技术和产品可以用于虚拟现实、元宇宙等场景的制作。 在近日发布的投资者调研活动记录中,利亚德指出,德凭借多年以来行业龙头地位的优势,以及与上游供应商长期合作关系的积累,跟上游厂家签订了保量的供货协议,保证了公司的接单供货能力。面对涨价同行各家采取了不同的做法,从而也会带来后续不同的影响。 产能方面,今年利亚德对三个生产基地进行了扩产:一个是位于深圳的南方产业园,将之前包括深圳利亚德在内的几个生产基地整体搬迁到一个产业园进行集中的生产和管理,以提升效
[手机便携]
利亚德:Micro <font color='red'>LED</font>2022年产能将达到1600KK/月
基于射极输出器关断的声光控LED照明灯
在没有接入220 V 市电的简易建筑物内, 使用基于射极输出器关断的声光控开关, 控制led 照明灯工作,方法简便, 安装容易, 方便人们生活。   1 基于220 V 交流电源的声光控开关电路   图1 所示是一种基于220 V 交流电源的声光控开关电路原理图。在电路的最右部分,220 V 市电输出后(图中标记1、3)经过桥式整流,串接一只小于100 W 的白炽灯。整流后输出的有过零点的脉动电压(图中标记2、4)接可控硅的阳极,通过可控硅的通断来控制白炽灯的亮与暗。 图1 基于220 V 交流电源的声光控开关电路   一般声光控开关的主电流回路主要采用可控硅控制, 由于可控硅导通与否与施加电压
[电源管理]
基于射极输出器关断的声光控<font color='red'>LED</font>照明灯
采用FP7208升压LED驱动模块做的升压车灯方案
近年来随着汽车的不断普及,车灯方面也在不断发展,由最开始的卤素灯发展为氙气大灯,再到现在的LED大灯和矩阵式LED大灯。 车灯对于汽车不仅是外观件更是汽车主动安全的重要组成部分。灯光在保证照亮前部道路的同时,还要确保不对对面车辆产生眩目影响。同时需要针对不同路况和不同载荷引起的灯光偏离进行调整,这就需要有车灯调光系统来保持装车后车灯的照射光型。 下面将带着大家跟小戴一起拆解看看采用FP7208 升压LED驱动模块做的升压车灯方案。 01 LED车灯的内部组成结构 车灯内部组成:远近光灯,驱动板,散热器,远近光切换模块。 车灯内部组成图 02 驱动板详解 驱动板上由LED升压驱动模块,LED降压驱动模块,以及其它组件
[嵌入式]
采用FP7208升压<font color='red'>LED</font>驱动模块做的升压车灯方案
小广播
最新电源管理文章
