LinkSwitch-PH dramatically simplifies implementation of LED drivers requiring Power Factors greater than 0.9, TRIAC dimming, and high efficiency. This highly integrated controller introduces a new control technique that provides very high power factor and accurate output current control, and eliminates passive circuitry required for power factor correction, optocoupler and secondary current control circuitry.
Each device incorporates a 725V power MOSFET, a continuous-mode PWM controller, a high voltage switched current source for self biasing, frequency jittering, cycle-by-cycle current limit and hysteretic thermal shutdown circuitry into a monolithic IC.
LinkSwitch-PH系列产品亮点:
Dramatically Simplifies Off-line LED Drivers
Single-stage power factor correction and accurate constant current (CC) output
Flicker-free, phase-controlled TRIAC dimming
Eliminates optocoupler and all secondary current control circuitry
Eliminates all control loop compensation circuitry
Simple primary-side PWM dimming interface
Universal input voltage range
Enables designs that are electrolytic-free
Accurate and Consistent Performance
Fast start-up time
Compensates for transformer inductance tolerances
Compensates for line input voltage variations
Frequency jittering greatly reduces EMI filter size and costs
Advanced Protection and Safety Features
Auto-restart for short circuit protection
Open circuit fault detection mode
Automatic thermal shutdown or restart with hysteresis
Meets high voltage creepage requirement between DRAIN and all other signal pins both on PCB and at package
EcoSmart - Energy-Efficiency Technology
Low standby power remote ON/OFF feature (< 50 mW at 230 VAC)
No current sense resistors - maximizes efficiency
High efficiency operation, >85% achievable
Green Package
Halogen free and RoHS compliant package
LinkSwitch-PH应用:
• Off-line LED driver
图1. LinkSwitch-PH系列功能方框图
图2. LinkSwitch-PH系列绝缘TRIAC调光高功率因素通用输入14W LED驱动器电路图
图3. LinkSwitch-PH系列绝缘无调光高功率因素通用输入7W LED驱动器电路图 采用LNK417EG无电解电容高效率(≥90%) PFC大于0.9的15W LED驱动器参考设计
This document describes an isolated, power factor corrected, very high efficiency LED driver designed to drive a 30 V LED string at a current of 500 mA (nominal). The input voltage range is 90 VAC to 265 VAC.
The LED driver uses a LNK417EG device from the LinkSwitch-PH family of ICs. This integrated controller and 725 V MOSFET dramatically reduces the complexity and component count of the solution.
The key design goals were to achieve the highest possible efficiency and eliminate electrolytic capacitors. Both are key factors for increasing the lifetime and reliability of LED drivers making this solution ideal for industrial and commercial applications.
15W LED驱动器参考设计主要特性:
No electrolytic capacitors
Clean monotonic start-up – no output blinking
Fast start-up (<100 ms) – no perceptible delay
Highly energy efficient
o ≥90% at 115 VAC and 230 VAC input Low cost, low component count and small printed circuit board footprint solution
o No current sensing required
o Frequency jitter for smaller, lower cost EMI filter components Integrated protection and reliability features
o Output open-circuit / output short-circuit protected with auto-recovery
o Line input overvoltage shutdown extends voltage withstand during line faults.
o Auto-recovering thermal shutdown with large hysteresis protects both components and printed circuit board
o No damage during brown-out or brown-in conditions
Meets IEC 61000-4-5 ring wave, IEC 61000-3-2 Class C harmonics and EN55015 B conducted EMI
图4.15W LED驱动器参考设计外形图: 3.115” L x 1.525” W.
电源指标:
图5.15W LED驱动器参考设计电路图
图6.变压器电路图
变压器主要指标:
图7. PCB布局图(顶层)
上一篇:基于TNY279的大功率LED光源驱动电路设计
下一篇:有源纹波补偿BUCK型LED驱动电路设计
推荐阅读最新更新时间:2023-10-18 15:35
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- 英飞凌推出符合ASIL-D标准的新型汽车制动系统和电动助力转向系统三相栅极驱动器 IC
- 南芯科技推出80V升降压转换器,持续深耕工业储能市场
- 法雷奥与罗姆联合开发新一代功率电子领域
- 贸泽电子开售能为电动汽车牵引逆变器提供可扩展性能的 英飞凌HybridPACK Drive G2模块
- Vishay推出采用eSMP®系列SMF(DO-219AB)封装的全新1 A和2 A Gen 7 1200 V FRED Pt®超快恢复整流器
- Littelfuse推出高性能超级结X4-Class 200V功率MOSFET
- 恩智浦发布首个超宽带无线电池管理系统解决方案
- 非常见问题解答第223期:如何在没有软启动方程的情况下测量和确定软启动时序?
- Vicor高性能电源模块助力低空航空电子设备和 EVTOL的发展
