The CY8CLEDAC02 is a high performance offline LED driver, designed to interface directly with most conventional phase cut based wall dimmers. The device uses proprietary digital control technology to provide automatic detection of dimmer type (leading or trailing edge). It automatically generates dimming signals for LED loads and has the ability to dim down to 2 percent. It modulates LED brightness using a linear dimming scheme and switches to a pulse width modulation (PWM) based dimming scheme for output current levels lower than 20 percent of the full load current. In PWM mode optimized dimming frequencies in the range of 900 Hz result in zero visible flicker.At the heart of a CY8CLEDAC02 based system is the chopping circuit which provides the load necessary to enable correct wall dimmer operation. It also improves PF when there is no dimmer on the line.
The devices’ proprietary primary side sensing enables tight LED current regulation and eliminates the need for secondary feedback circuitry. No opto-couplers are necessary to meet UL isolation requirements; enabling flyback conversion with automatic isolation.
The CY8CLEDAC02 operates in quasi-resonant mode to achieve high efficiency. This mode of operation helps minimize external component count and simplifies EMI design, lowering the total bill of material cost.
The device’s cycle-by-cycle adaptive digital regulation uses critical discontinuous conduction mode (CDCM) when driving LED loads. The control algorithm for cycle-by-cycle regulation has internal compensation for guaranteed system phase and gain margins; requiring no external components for loop compensation.
The CY8CLEDAC02 has full featured circuit protection not normally available with other primary-side control solutions. The built-in protection includes output overvoltage protection, output short circuit protection, overtemperature protection, current-sense resistor short protection, and peak current limit protection. It also enables automatic LED brightness adjustment to compensate for temperature drift by simply connecting a NTC resistor to the VT pin.
CY8CLEDAC02主要特性:
■ AC offline input range from 80 to 277 VAC
■ Up to 25 W output power range
■ Intelligent wall dimmer detection:
❐ Leading edge (R, RL) dimmers
❐ Trailing edge (RC, RLC) dimmers
❐ No dimmer
■ Wide dimming range from 2 to 100 percent
■ Resonant control to achieve high efficiency (85 percent without dimmer)
■ Meets harmonic requirement with high power factor (0.7 without dimmer)
■ Primary-side sensing eliminates opto-isolators
■ Tight LED current regulation (typically < + 2.5 percent)
■ Low startup current (typically 10uA)
■ Low startup time (typically 0.5 s with active startup)
■ Multiple protection features:
❐ Output overvoltage protection (OOVP)
❐ Output short circuit protection (OSCP)
❐ Overtemperature protection (OTP)
❐ Current-sense resistor short protection (CSSP)
❐ Peak current limit protection (PCLP)
❐ Single-point fault protection
CY8CLEDAC02应用:
❐ Dimmable offline LED driver
❐ Dimmable LED replacement lamps
❐ Dimmable LED luminaires
图1.CY8CLEDAC02逻辑框图
图2.CY8CLEDAC02简化的应用框图
A55 220VAC 12W调光LED驱动器参考设计
This document describes a highline 12 W dimmable LED driver reference design using the CY8CLEDAC02 AC-DC power controller device. This design is capable of driving a string of LEDs with a typical forward voltage of 27 V at 350 mA. The CY8CLEDAC02 is a high-performance offline LED driver, designed to interface directly with most conventional phase-cut based wall dimmers. The device uses proprietary digital control technology to provide automatic detection of dimmer type (leading or trailing edge). It automatically generates dimming signals for LED loads and has the ability to dim down to 2 percent.
图3.12W LED驱动器参考设计外形图
LED驱动器参考设计指标:
图4. 12W LED驱动器参考设计电路图
LED驱动器参考设计材料清单:
变压器指标:
Electrical specifications
Primary inductance: 2360 μH at 10 kHz
Primary leakage inductance:
Renco Electronics ≤ 44 μH at 10 kHz
Würth Elektronik ≤ 25 μH at 10 kHz
Peak primary current: 380 mA
Peak secondary voltage: 29 V
Peak secondary current: 350 mA
Primary-to-secondary turns ratio: 5-to-1
Secondary-to-auxiliary turns ratio: 2-to-1
Flyback switching frequency: 120 kHz to 150 kHz
Materials
Core: EP13 (Ferrite material TDK PC40 or equivalent)
Bobbin: EP13
Magnet wire: Type 2UEW
Triple insulated wire: TEX-E or equivalent
Layer insulation tape: 3M1350f-1 or equivalent
Teflon sleeve
图5.变压器尺寸和电路图
图6.参考设计PCB元件布局图(顶层)
上一篇:利用反相升降压拓朴调节LED电流
下一篇:分析便携式投影仪6A RGB LED驱动器参考设计方案
推荐阅读最新更新时间:2023-10-18 15:37
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- MathWorks 和 NXP 合作推出用于电池管理系统的 Model-Based Design Toolbox
- 意法半导体先进的电隔离栅极驱动器 STGAP3S为 IGBT 和 SiC MOSFET 提供灵活的保护功能
- 全新无隔膜固态锂电池技术问世:正负极距离小于0.000001米
- 东芝推出具有低导通电阻和高可靠性的适用于车载牵引逆变器的最新款1200 V SiC MOSFET
- 【“源”察秋毫系列】 下一代半导体氧化镓器件光电探测器应用与测试
- 采用自主设计封装,绝缘电阻显著提高!ROHM开发出更高电压xEV系统的SiC肖特基势垒二极管
- 艾迈斯欧司朗发布OSCONIQ® C 3030 LED:打造未来户外及体育场照明新标杆
- 氮化镓取代碳化硅?PI颠覆式1700V InnoMux2先来打个样
- 从隔离到三代半:一文看懂纳芯微的栅极驱动IC
- CGD和Qorvo将共同革新电机控制解决方案
- 是德科技 FieldFox 手持式分析仪配合 VDI 扩频模块,实现毫米波分析功能
- 贸泽开售可精确测量CO2水平的 英飞凌PASCO2V15 XENSIV PAS CO2 5V传感器
- 玩法进阶,浩亭让您的PCB板端连接达到新高度!
- 长城汽车研发新篇章:固态电池技术引领未来
- 纳芯微提供全场景GaN驱动IC解决方案
- 解读华为固态电池新专利,2030 叫板宁德时代?
- 让纯电/插混车抓狂?中企推全球首款-40℃可放电增混电池,不怕冷
- 智驾域控知多少:中低端车型加速上车,行泊一体方案占主体
- Foresight推出六款先进立体传感器套件 彻底改变工业和汽车3D感知
- 安富利有奖调查问卷 150+份礼品等你拿
- 开工大吉,抢楼有礼!预测:2021年电子热门关键词
- 下载有好礼!超多精美礼品等您拿!
- 【已结束】力源直播【安森美 25KW 充电桩模块方案】(9:30入场)
- 有奖直播:ADI在中国能源互联网应用中的技术及产品 1月8日上午10:00-11:30 准时开启!
- 泰克70周年庆 了解新品 参与掀盖有礼活动 最多可获得6次抽奖机会
- Microchip直播:单片机编程不再难, 利用MPLAB®代码配置器(MCC)实现快速开发
- 技术直播:TI 60G毫米波传感器概述和应用介绍,种草封装了天线的智能传感器IWR6843
- Digi-key干货视频教程来袭,意见领袖讲解疑难设计问题,带你突破成长瓶颈~
