Reference Design Report for a 150 W Power Factor Corrected LLC Power Supply for LED Street Lighting
LinkSwitch-TN is specifically designed to replace all linear and capacitor-fed (cap dropper) non-isolated power supplies in the under 360 mA output current range at equal system cost while offering much higher performance and energy efficiency.
LinkSwitch-TN devices integrate a 700 V power MOSFET, oscillator, simple On/Off control scheme, a high voltage switched current source, frequency jittering, cycle-by-cycle current limit and thermal shutdown circuitry onto a monolithic IC. The startup and operating power are derived directly from the voltage on the DRAIN pin, eliminating the need for a bias supply and associated circuitry in buck or fl yback converters. The fully integrated auto-restart circuit in the LNK304-306 safely limits output power during fault conditions such as short-circuit or open loop, reducing component count and system-level load protection cost. A local supply provided by the IC allows use of a non-safety graded optocoupler acting as a level shifter to further enhance line and load regulation performance in buck and buck-boost converters, if required.
LNK302产品亮点:
Cost Effective Linear/Cap Dropper Replacement
• Lowest cost and component count buck converter solution
• Fully integrated auto-restart for short-circuit and open loop fault protection – saves external component costs
• LNK302 uses a simplifi ed controller without auto-restart for very low system cost
• 66 kHz operation with accurate current limit – allows low cost off-the-shelf 1 mH inductor for up to 120 mA output current
• Tight tolerances and negligible temperature variation
• High breakdown voltage of 700 V provides excellent input surge withstand
• Frequency jittering dramatically reduces EMI (~10 dB) – minimizes EMI fi lter cost
• High thermal shutdown temperature (+135 °C minimum)
Much Higher Performance over Discrete Buck and Passive Solutions
• Supports buck, buck-boost and fl yback topologies
• System level thermal overload, output short-circuit and open control loop protection
• Excellent line and load regulation even with typical confi guration
• High bandwidth provides fast turn-on with no overshoot
• Current limit operation rejects line ripple
• Universal input voltage range (85 VAC to 265 VAC)
• Built-in current limit and hysteretic thermal protection
• Higher effi ciency than passive solutions
• Higher power factor than capacitor-fed solutions
• Entirely manufacturable in SMD
EcoSmart®– Extremely Energy Effi cient
• Consumes typically only 50/80 mW in self-powered buck topology at 115/230 VAC input with no load (opto feedback)
• Consumes typically only 7/12 mW in fl yback topology with external bias at 115/230 VAC input with no load
• Meets California Energy Commission (CEC), Energy Star, and EU requirements
LNK302应用:
• Appliances and timers
• LED drivers and industrial controls
图1.LNK302功能动框图
150W LED街灯照明参考设计
This engineering report describes a 48 V, 150 W reference design power supply for 90 VAC - 265 VAC LED street lights which can also serve as a general purpose evaluation board for the combination of a PFS power factor stage with an LCS output stage using devices from the Power Integration’s HiperPFS and HiperLCS device families.
The design is based on the PFS708EG IC and LQA05TC600 diode for the PFC front end, with a LNK302 utilized in a non-isolated flyback bias supply. An LCS702HG IC is used for the LLC output stage.
The circuit shown in this report is optimized for >0.9 power factor, over an input voltage range of 90 VAC - 230 VAC, at both 100% load and 50% load. If >0.9 power factor is not required at 50% load, the circuit can be cost reduced by downsizing common mode filter L1 and PFC input capacitor C6. Contact Power Integrations for more details.
This power supply is designed to be mounted inside a grounded enclosure for streetlight service, with the input AC safety ground connected to the chassis. EMI and line surge tests should be performed with the supply screwed down to a ground plane with the input AC safety ground connected to this plane.
150W LED街灯照明参考设计主要特性:
Integrated PFC stage using
o PFS708EG from HiperPFS family of ICs
o LQA05TC600 ultrafast soft recovery QSpeed diode
Integrated LLC stage using
o LCS702HG from HiperLCS family of ICs
Simple snubberless bias supply using
o LNK302DG from LinkSwitch-TN family of ICs
CAPZero (CAP002DG) IC used to discharge X capacitors for higher efficiency compared to resistive solution
High frequency (250 kHz) LLC for small transformer size
>95% full load PFC efficiency at 115 VAC
>95% full load LLC efficiency
System efficiency 91% / 93% at 115 VAC / 230 VAC
图2.150W LED街灯照明参考设计(RD-292)外形图
150W LED街灯照明参考设计主要指标:
图3.150W LED街灯照明参考设计(RDR-292)电路图:输入滤波器,PFC功率级和偏压电源
图4.150W LED街灯照明参考设计(RDR-292)电路图:LLC级
150W LED街灯照明参考设计(RDR-292)材料清单:
图5.150W LED街灯照明参考设计(RDR-292)PCB布局图:顶层
图6.150W LED街灯照明参考设计(RDR-292)PCB布局图:底层
详情请见:
http://www.powerint.com/sites/default/files/product-docs/lnk302_304-306.pdf
和
http://www.powerint.com/sites/default/files/PDFFiles/rdr292.pdf
上一篇:便携式设备背光源节能的新技术介绍
下一篇:显示器背光调节解析方案
推荐阅读最新更新时间:2023-10-18 16:43
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- 非常见问题解答第223期:如何在没有软启动方程的情况下测量和确定软启动时序?
- Vicor高性能电源模块助力低空航空电子设备和 EVTOL的发展
- Bourns 推出两款厚膜电阻系列,具备高功率耗散能力, 采用紧凑型 TO-220 和 DPAK 封装设计
- Bourns 全新高脉冲制动电阻系列问世,展现卓越能量消散能力
- Nexperia推出新款120 V/4 A半桥栅极驱动器,进一步提高工业和汽车应用的鲁棒性和效率
- 英飞凌推出高效率、高功率密度的新一代氮化镓功率分立器件
- Vishay 新款150 V MOSFET具备业界领先的功率损耗性能
- 强茂SGT MOSFET第一代系列:创新槽沟技术 车规级60 V N通道 突破车用电子的高效表现
- 面向车载应用的 DC/DC 电源
- 下载有礼|西北模电王《新概念模拟电路》全五册
- 下载送好礼|人工智能物联网时代即将来临,您准备好了吗?
- 有奖活动|NI 助您设计更靠谱的数据采集系统
- 意法半导体工业峰会2023 直播结束
- 【EEWORLD第二十六届】2011年05月社区明星人物揭晓!
- “玄铁杯”第三届RISC-V应用创新大赛—国产高性能RISC-V Linux开发板LicheePi 4A报名专场,万元奖金,邀您奔赴开源设计盛宴
- 看是德科技资料填调查问卷赢好礼
- 有奖直播:TI MSP430TM集成可配置信号链模块在传感测量领域的应用
- 25美分实现25种功能的TI MSP430铁电超值微控制器方案即将直播!快来报名围观!
- 美信基础模拟IC APP下载 助力您创新模拟设计!
