NXPSSL4101T四路145WLED驱动解决方案
最新更新时间:2012-07-23来源: NXP关键字:NXPSSL4101T  四路  145WLED 手机看文章 扫描二维码
随时随地手机看文章
NXP公司的SSL4101T是GreenChip III+第三代绿色开关电源控制器,集成了PFC和反激控制器,内置的绿色功能能使在所有的功率等级上具有高效率.SSL4101T是多芯片模块(MCM),包含两个芯片,适用于70 V (AC)到305 V (AC)电压,极少外接元件,并即有多种保护特性,适用于10W-300W间的所有的LED照明应用.本文介绍了SSL4101T主要特性和优势,方框图,典型配置图和应用电路图,SSL4101DB02四路LED驱动演示板主要特性和指标,电路图,材料清单.
The GreenChip III+ is the third generation of green Switched Mode Power Supply (SMPS)controller ICs. The SSL4101T combines a controller for Power Factor Correction (PFC) and a flyback controller. Its high level of integration allows the design of a cost-effective LED lighting application power supply with a very low number of external components.
The special built-in green functions provide high efficiency at all power levels. This applies to quasi-resonant operation at high power levels, quasi-resonant operation with valley skipping, as well as to reduced frequency operation at lower power levels. At low power levels, the PFC switches off to maintain high efficiency.
During low power conditions, the flyback controller switches to frequency reduction mode and limits the peak current to 25 % of its maximum value. This will ensure high efficiency at low power and good standby power performance while minimizing audible noise from the transformer.
The SSL4101T is a MultiChip Module, (MCM), containing two chips. The proprietary high voltage BCD800 process which makes direct start-up possible from the rectified universal mains voltage in an effective and green way. The second low voltage SiIlicon On Insulator(SIO) is used for accurate, high speed protection functions and control.
The SSL4101T enables extremely efficient and reliable LED lighting application power supplies with power requirements from 10 W to 300 W, to be designed easily and with a minimum number of external components.
The new SSL4101T allows a typical 150 W LED lighting application power supply(universal input, 48 V (DC) output, TEA1761T on the secondary side for Synchronous Rectification) to achieve the following performances at full load:
• 120 V (AC): 92 % efficiency, 0.998 PF, 5.8 % THD, < 190 mW standby power
• 277 V (AC): 94 % efficiency, 0.978 PF, 9 % THD, < 350 mW standby power
The SSL4101T enables LED lighting application power supplies to achieve the industry standard of < 20 % THD for the input current at full load and all nominal input voltages:100 V (AC), 120 V (AC), 230 V (AC), 240 V (AC) and 277 V (AC).
• Extremely low input power in Standby mode eliminates the need for an additional housekeeping power supply to power the lighting controllers/dimmers.
• Using SSL4101T, a low power controller (< 50 mW) can be driven directly by the LED lighting application power supply’s output while maintaining the input power in Standby mode below the maximum of 0.5 W.
• Extremely high-efficiency can be achieved in LED lighting application power supplies using the SSL4101T (between 92 % to 94 %). This enables the power supply to operate reliably in enclosed spaces with very little cooling (which is typical for SSL applications).
SSL4101T主要特性和优势:
Distinctive features
关键字:NXPSSL4101T  四路  145WLED 编辑:探路者 引用地址:NXPSSL4101T四路145WLED驱动解决方案
上一篇:艾睿推出业界首款基于云计算的中文照明设计平台
下一篇:解析LED灯具死灯原因
推荐阅读最新更新时间:2023-10-17 14:58
Maxim推出高效生成模拟输出的参考设计
Maxim Integrated的Alameda子系统提供灵活的4通道双极性模拟输出,是工业自动化应用的理想选择。 中国,北京,2014年5月13日。Maxim Integrated Products, Inc. (NASDAQ: MXIM)推出Alameda (MAXREFDES24#)子系统参考设计(现已开始销售),使设计人员可以方便地在其工业自动化设计中添加4路高精度模拟输出,所需元件与竞争方案相比减少33%。 工业可编程逻辑控制器(PLC)需要多路、可灵活配置的高精度模拟输出。Alameda子系统在单块电路板上包含了四路高精度( ±0.1%)输出以及一个高效、低噪声电源控制器。Alameda
[工业控制]
固德威隆重推出50kW~75kW三相组串式光伏逆变器
固德威隆重推出MT系列三相四路组串式光伏逆变器,功率包含50kW/60kW/65kW/75kW,非常适用于工商业屋顶,山地丘陵,农光渔光互补,光伏扶贫等分布式电站及地面电站。MT系列采用先进的拓扑结构及创新的控制技术,实现高达98.8%的转换效率,大大提高了用户的投资收益。 近两年分布式光伏发展良好,针对户用系统和小型工商业屋顶,固德威均提供了完美的解决方案。固德威单相系列(1-5kW)小巧精便,多达十项安全检测;三相系列(4-30kW)型号齐全,稳定高效,通讯及监控方式灵活。针对大中型分布式项目,更高功率的组串式逆变器可以减少系统的布线、安装、运维成本,而目前市场上功率在50kW以上的优质大功率组串式逆变器选择较少,所以固德威
[新能源]
NS LM3463高压LED驱动解决方案
NS 公司的LM3463是四路高压LED驱动器,LM3464输入电压为12V-80V,LM3464A输入电压为12V-95V,四路输出可单独电流稳压,通路间的精度高,数字PWM/模拟调光控制接口,动态静空控制最大化效率,主要用于街灯照明和固态照明解决方案。本文介绍了LM3464/64A 主要特性,方框图,典型应用电路图,LM3464 4路led驱动器评估板主要特性,电路图,材料清单和PCB元件布局图。 LED Driver with Dynamic Headroom Control and Thermal Control Interfaces The LM3464/64A is a 4-channEL high
[电源管理]
NS LM3463<font color='red'>四</font><font color='red'>路</font>高压LED驱动解决方案
MAX16008/MAX16009可调节窗口电压监视器
MAX16008/MAX16009是可调节的四路窗口电压监视器,采用薄型QFN封装。这些器件监视多路电源电压,提高了系统可靠性,当任何电压高于其过压门限或者低于其欠压门限时,都会产生故障信号。   这些器件提供用户可调门限,允许监视低至0.4V的电压。这些器件可以使用3个外部电阻设置每个窗口监视器的过压门限和欠压门限。   为指示故障情况,每一个监视门限都具有独立的开漏极输出。这些输出可以通过“线或”连接到一起,以指示单个故障输出。开漏极输出带有30µA内部上拉电流,但可被外部驱动至其他电平,以实现与其他逻辑电平接口。   两款器件都提供状态控制输入,可在状态测试过程中或者上电后的任何时候禁止输出。MAX16009提
[电源管理]
MAX16008/MAX16009可调节<font color='red'>四</font><font color='red'>路</font>窗口电压监视器
微软新CEO纳德拉突围…出击
    微软公司4日指派内部老将纳德拉(Satya Nadella)接任执行长,但真正的挑战才开始:因应个人计算机(PC)时代落幕,带领微软在行动与云端运算市场取得领先地位。金融时报专栏作家华特斯指出,纳德拉必须从四个方向着手。 ●平息内部动荡 前执行长鲍默尔去年中发动人事大改组,导致内部惶惶不安,一个月后他又投下退休震撼弹,使管理阶层在关键时刻面临真空。纳德拉上任后,首先必须向外界证明,微软拥有坚强的领导团队、运作顺畅的组织与全力支持的董事会。 在此之际,微软预定3月底前完成收购诺基亚手机部门,如何快速整合诺基亚与旗下业务、减少亏损与夺回智能手机市场市占,将是优先要务。专家建议可以Lumia品牌为基础,赢回消费者的心。 ●强化消费
[手机便携]
基于TMS320DM355的视频多媒体监控器
   1 引言   数字视频是利用诸如摄像机的视频捕捉设备采集外界影像信息并将影像信息数字化,然后将其记录到储存介质(如录像带、硬盘、光盘)或通过网络传输。而视频监控在安全防范系统中具有重要意义。这里提出基于TMS320DM355型达芬奇(DaVinci)数字媒体片上系统(DMSoC)的便携式多媒体视频监控器。    2 DaVinci技术简介   DaVinci技术是TI公司针对数字视频图像处理及应用而提供的一套完整的解决方案,包括处理器、开发工具、软件以及系统专业技术。DaVinci技术可利用数字信号处理与集成电路技术提供高度集成的片上系统(SoC),优化和处理数字视频。该片上系统具有高效的处理能力、存储器、
[嵌入式]
资本收购了日月光家大陆封测工厂
12月1日,全球最大的半导体封测集团日月光集团正式官宣,将其大陆四家工厂及业务出售给智路资本,智路资本在封测领域又一大手笔并购交易。 据报道,日月光投控1日召开董事会,决议处分部份大陆营运据点。日月光投控与北京智路资本签署股权买卖协议,约定日月光以14.6亿美元对价,并加计各标的公司帐上现金并扣除负债金额,出售GAPT Holding Limited股份及直接或间接持有Global Advanced Packaging Test(Hong Kong)、日月光威海、苏州日月新、上海日荣半导体、日月光半导体昆山等股权予智路资本或其指定之从属公司。 根据本交易股权买卖协议约定,智路资本或其指定之从属公司应于交割日支付交割款约10.8
[手机便携]
OPPO Enco Air 无线耳机预热:为款配色,双快充
OPPO 将于 5 月 6 日举行 K 系列发布会,将发布无线蓝牙耳机 OPPO Enco Air。   近日,OPPO 官方对 OPPO Enco Air 进行了预热,该耳机拥有蓝、黑、白、青四款配色,支持双路快充,充电 10 分钟,听歌 8 小时。同时,OPPO Enco Air 拥有德国莱茵 TÜV 认证,稳定不延迟。   IT之家了解到,根据商品详情页显示,OPPO Enco Air 支持蓝牙 5.2,采用入耳式设计。   此外,OPPO 将于 5 月 6 日发布 7 个产品、两个套装,确认有 K9 手机和 K9 电视,售价 2999 元起。
[手机便携]
小广播
最新电源管理文章
