InfineonICE2QS03G36W(12V3A)电源解决方案
最新更新时间:2012-02-21来源: 21IC关键字:AC/DC  转换器  开关电源 手机看文章 扫描二维码
随时随地手机看文章
    Infineon公司的ICE2QS03G是准谐振PWM控制器,适用于离线开关电源如LCD TV,CRT TV和笔记本电脑适配器.采用突发模式操作,待机时具有超低功耗.器件采用BiCMOS技术,高达26V工作电压.本文介绍了ICE2QS03G亮点,主要特性,方框图和典型应用电路,以及36W评估板主要指标,电路图,材料清单和PCB布局图.
    ICE2QS03G is a quasi-resonant PWM controller optimized for off-line switch power supply applications such as LCD TV, CRT TV and notebook adapter. The digital frequency reduction with decreasing load enables a quasi-resonant operation till very low load. As a result, the overall system efficiency is significantly improved compared to other conventional solutions. The active burst mode operation enables an ultra-low power consumption at standby mode with small and controllable output voltage ripple. Based on the BiCMOS technology, the product has a wide operation range (up to 26V) of IC power supply and lower power consumption. The numerous protection functions give a full protection of the power supply system in failure situations. All of these make the ICE2QS03G an outstanding controller for quasi-resonant flyback converter in the market.
    ICE2QS03G亮点:
• Active burst mode for low standby power
• Digital frequency reduction for better overall system efficiency
• Integrated power cell for IC self-power supply
ICE2QS03G主要特性:
• Quasiresonant operation till very low load
• Active burst mode operation at light/no load for low standby input power (< 100mW)
• Digital frequency reduction with decreasing load
• Power cell for VCC pre-charging with constant current
• Built-in digital soft-start
• Foldback correction and cycle-by-cycle peak current limitation
• Auto restart mode for VCC Overvoltage protection
• Auto restart mode for VCC Undervoltage protection
• Auto restart mode for openloop/overload protection
• Latch-off mode for adjustable output overvoltage protection
• Latch-off mode for Short-winding protection
图1.ICE2QS03G方框图
图2.ICE2QS03G典型应用电路图
    采用准谐振PWM控制器ICE2QS03G的36W评估板
    The demo-board described here is a 36W power supply using quasi-resonant flyback converter topology. The PWM controller ICE2QS03G is a second generation quasi-resonant controller IC developed by Infineon Technologies. The typical applications are for TV-sets, DVD-players, Set-top boxes, netbook adapters, home audio and printer applications. In normal operation, the digital frequency reduction with decreasing load enables a quasi-resonant operation till very low load. As a result, the system efficiency over the entire load range is significantly improved compared to conventional free running quasi resonant converter implemented with only maximum switching frequency limitation. In addition, numerous protection functions have been implemented in ICE2QS03G to protect the system and customize the IC for the chosen application. In case of failure modes, like open control-loop/over load, output overvoltage, and transformer short winding, the device switches into Auto Restart Mode or Latch-off Mode. By means of the cycle-by-cycle peak current limitation plus foldback point correction, the dimension of the transformer and the secondary diode can be lower which leads to more cost effective design.
图3. 36W评估板EVALQRS-36W-ICE2QS03G外形图
36W评估板主要指标:
图4. 36W评估板电路图
36W评估板材料清单:
图5. 36W评估板变压器架构图
图6. 36W评估板PCB布局图(顶层)
图7. 36W评估板PCB布局图(底层)
详情请见:
http://www.infineon.com/dgdl/Datasheet_ICE2QS03G_V21_20100205.pdf?folderId=db3a304412b407950112b4182a3d24f8&fileId=db3a304324fc7f9a01250689233a7046
http://www.infineon.com/dgdl/EVALS-ICE2QS03G-36W-V12-20111112.pdf?folderId=db3a304412b407950112b4182a3d24f8&fileId=db3a304324fc7f9a0125068d0b17704b
关键字:AC/DC  转换器  开关电源 编辑:探路者 引用地址:InfineonICE2QS03G36W(12V3A)电源解决方案
上一篇:MaximMAX17595峰值电流模式反激和升压电源解决方案
下一篇:低电压/低功耗的可编程片上系统为嵌入式系统提供了灵活的电源管理
推荐阅读最新更新时间:2023-10-18 16:25
使用48V分布式电源架构是否可解决汽车电气化难题?
轿车、卡车、公交车及摩托车制造商都在快速为其车辆实现电气化,以提高内燃机的燃油效率,减少二氧化碳排放。电气化选择很多,但大多数制造商都没有选择完全混合动力总成,而是选择 48 伏轻度混合动力系统。轻度混合动力系统除了有传统 12V 电池之外,还新增了一款 48V 电池。 这可增加 4 倍的电量 (P = V • I),用于催化式排气净化器等重负荷。48V 系统可为混合动力发动机供电,在节省燃油的同时,更快、更平稳的加速,以提高车辆性能。额外的电源不仅可为转向、刹车以及悬架系统提供支持,而且还可增加新的安全、娱乐及舒适特性。 引入 48 伏轻度混合动力系统,一旦完成设计,会有很大的优势。克服对长期存在的 12 伏供电网络 (
[嵌入式]
爱立信开创性PKB4413DA高级总线转换器提供业界领先效率
新的PKB4413DA高级总线转换器为电源系统设计人员提供业界领先的408W和34A输出,输入从36-75V,这得益于爱立信先进的混合调节比(HRR)拓扑 是大功率、高性能应用的理想选择,该模块通过在12V输出时提供高达96%的业界领先效率,降低了冷却和能源成本 转换器出色的热降额使其非常适合于气流受限或环境温度较高的环境应用 高性能DC/DC转换器由于其严格的稳压供电,是网络和电信领域中间总线转换应用的理想选择 爱立信新推出的PKB4413DA是一款扁平的408W DC/DC转换器模块,设计用于在电流高达34A时仍能提供12V严格稳压输出的负载点(POL)DC/DC转换器。该模块的5引脚,1/8砖封装与分布式电源开
[电源管理]
英飞凌多模式反激控制器改善中高端LED照明性能并降低功耗
2016年3月7日,德国慕尼黑讯 英飞凌科技股份公司(FSE: IFX / OTCQX: IFNNY)近日推出一款面向LED应用的多模式反激控制器IC。它可缩短灯具 点亮时间 ,节省器件数量,降低运行和待机功耗。IRS2982S专为满足中高端LED设计的性能和效率要求而设计,是一款适合各种室内、室外、办公室和工厂照明方案需求的多功能控制器解决方案。 IRS2982S配备600 V高压启动单元,使得 点亮时间 小于0.5秒,而且节省了外部分压电阻。可配置的临界导通模式(CrCM)和断续导通模式(DCM)确保它满足各种各样的应用需求,适合全电流范围内的调光LED转换器设计。IRS2982S的主要应用是CV(
[电源管理]
工业标准封装母线转换器
产品特征: • 工业标准1/8砖开放式IBC模块; • 满载效率大于97%,98%的峰值效率; • 比竞争产品降低50%的功耗及发热; • 显著的功率密度提升:高达240W/in2; • 高于50%以上的功率密度; • 10倍开关频率及低噪声拓扑:降低了滤波要求。 Vicor公司(纳斯达克股票代码:VICR)发布了VI BRICK™中间母线转换器IBC048系列产品。与竞争产品相比,此产品具有两倍功率密度,且只有一半的转换损耗。IBC048系列可替代工业标准八分之一砖及四分之一砖 5:1 与 4:1中间母线转换器。目前开始提供300 W和500 W模块,其标称输入电压为48V,输入范围从38 V至55V,输出为9.
[电源管理]
基于开关电源的系统电磁兼容设计探讨
随着电子技术的飞速发展,电子设备同时也朝着功能集成化,体积小型化方向发展,这给我们带来诸多的便利,但是各种电子设备之间的电磁耦合也成了工程师们面对的主要问题。电子环境污染的危害性不亚于传统的环境污染。而电磁污染作为环境污染的一部分也被提上了议程。电子设备在正常工作时候,会承受各种 电磁干扰 ,包括自身内部器件的相互干扰,以及周围其他电子设备的干扰,同时会对周围其他的电子设备产生电磁干扰。电子设备在不同应用环境中(家用、工控、电力)要求差异性非常大,这方面可以参考通用标准IEC / EN61000-6系列或者对应产品的行业要求。 这种电磁干扰在传输途径方面主要是包括两个方面:一是沿着线束进行传输,这方面主要包括沿着电源端口进行传输以
[电源管理]
基于<font color='red'>开关电源</font>的系统电磁兼容设计探讨
利用计算机设计单片开关电源讲座
下面对35个设计步骤作详细的阐述。 确定开关电源的基本参数 (1)交流输入电压最小值:Umin,见表1。 (2)交流输入电压最大值:Umax,见表1。 表1根据交流输入电压范围确定Umin、Umax值 交流输入电压U(V) Umin(V) Umax(V) 固定输入:100/115 85 132 通用输入:85~265 85 265 固定输入:230±15% 195 265 (3)电网频率fL:50Hz或60Hz。 表2反馈电路的类型及UFB参数值 反馈电路类型 UFB(V) UO的准确度(%) SV(%)
[电源管理]
利用计算机设计单片<font color='red'>开关电源</font>讲座
主电源的降压DC/DC转换器提供额外的辅助电源
许多系统除了需要 电源 " 主 电源 外还需要 低功率 电源 。一个典型例子就是当模拟前端放大器需要±5V电源时,主数字电路只需要+5V电源。由于成本、库存管理、电磁兼容等原因,采用单独的-5V转换器设计这个 低功率 电源也许并不合适,所以必须利用某些方法从 主电源 获得额外的电源轨。 执行降压型转换器IC的开关操作可以提供一个或多个隔离或非隔离的、准稳压或非稳压的输出,这样就有可能得到大小等于 主电源 输出电流10%至30%的辅助电源输出电流。 首先回顾一下降压转换器的工作波形,以确定可用来产生额外输出的电压和电流(图1)。在LX引脚上,转换电压波形的幅值范围为: (V IN(MAX) -V DIODE )
[电源管理]
主电源的降压<font color='red'>DC</font>/<font color='red'>DC</font><font color='red'>转换器</font>提供额外的辅助电源
ADI最新推出集成式电源管理开关稳压器
    AnalogDevices,Inc.,全球领先的高性能信号处理解决方案供应商,最新推出集成式电源管理开关稳压器系列的最新成员ADP2118DC/DC开关稳压器。这款新型集成式3A、降压型DC/DC同步稳压器包含低导通电阻开关FET(场效应晶体管),可最大限度地提高效率,并集成了内部回路补偿、电源良好指示器、精密使能、跟踪和同步功能,以简化负载点电源系统的设计。ADP2118设计用于支持从医疗设备到通信基础设施设备等多种应用中的高性能信号链负载,这些应用信号链可能包括ADC(模数转换器)、DAC(数模转换器)、精密放大器以及诸如DSP(数字信号处理器)和FPGA(现场可编程门阵列)等其它高性能亚微米IC。     “对于
[电源管理]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
