MicrochipdsPIC33F离线1000WUPS电源参考设计
最新更新时间:2012-03-11来源: 21IC关键字:不间断电源  DSC  dsPIC 手机看文章 扫描二维码
随时随地手机看文章
    不间断电源( UPS)参考设计采用dsPIC33FJ16GS系16位数字信号控制器(DSC),输入交流电压210 – 242V, 50 Hz (+/- 3 Hz),输出交流电压220V @ 50 Hz (+/ - 1 Hz),额定功率1000VA,效率84%,纯正弦波输出THD小于3%,火线到电池转换时间小于10ms,可用作计算机和通信设备的保护电源.本文介绍了UPS参考设计主要指标,采用dsPIC33FJ16GS504的离线UPS方框图,电路图,材料清单和PCB元件布局图.
    Digital Pure Sine Wave Uninterruptible Power Supply (UPS) Reference Design dsPIC33FJ06GS101/X02 and dsPIC33FJ16GSX02/X04 Data Sheet High-Performance, 16-bit Digital Signal Controllers
图1.正弦波UPS参考设计外形图
    UPS参考设计输入/输出指标:
Input / Output Specifications:
Input Range AC:
95 – 135V, 60 Hz (+/ - 3 Hz) (110V version)
210 – 242V, 50 Hz (+/- 3 Hz) (220V version)
Output Voltage AC:
110V @ 60 Hz (+/ - 1 Hz) (110V version)
220V @ 50 Hz (+/ - 1 Hz) ( 220V version)
DC Input:
36V (12 VDC X 3)
Lead Acid Battery
Rating:
1000 VA Steady-State Output Power
1350 VA Peak Power (Surge)
Features:
High-frequency design
Adjustable Charging current
Efficiency of 84%
Pure sine wave output with THD <3%
Mains to Battery Transfer time < 10 ms
Supports Crest Factor of 3:1
Minimum Power Factor(Leading/Lagging) of 0.65
Fault indications
USB Communication with PC
LCD front panel
An Uninterruptible Power Supply, or UPS, is an electronic device that provides an alternative electric power supply to connected electronic equipment when the primary power source is not available.
Unlike auxiliary power, a UPS can provide instant power to connected equipment, which can protect sensitive electronic devices by allowing them to shut down properly and preventing extensive physical damage. However, a UPS can only supply energy for a limited amount of time, typically 15 to 20 minutes.
Although its use can extend to a virtually unlimited list of applications, in past years the UPS has become even more popular as a means of protecting computers and telecommunication equipment, thus preventing serious hardware damage and data loss.
Types of UPS Systems
A typical UPS for computers has four basic protection roles: being able to cope with power surges, voltage shortage, complete power failure and wide variations in the electric current frequency. There are three types of UPS systems, depending on how the electric power is being stored and relayed to the electronic device connected to them:
• Offline UPS (also known as Stand-by UPS)
• Line-Interactive (or Continuous UPS)
• Online UPS (often called double conversion supply)
图2.离线UPS方框图
图3.采用dsPIC33FJ16GS504的离线UPS方框图
The reference design in this application note describes the design of an Offline Uninterruptible Power Supply (UPS) using a Switch Mode Power Supply (SMPS) dsPIC® Digital Signal Controller (DSC).
The Offline UPS Reference Design consists of three major UPS topology blocks:
• Push-Pull Converter (steps up the DC battery voltage to a constant high-voltage DC)
• Full-Bridge Inverter (converts DC voltage to a sinusoidal AC output)
• Flyback Switch Mode Charger (current source and charges battery with constant current)
1kW离线UPS主要指标:
图4.离线UPS参考设计框图
图5.开关模式充电器框图
图6.离线UPS详细框图
图7.离线UPS参考设计电路图(1)
图8.离线UPS参考设计电路图(2)
图9.离线UPS参考设计电路图(2)
图10.离线UPS参考设计电路图(3)
图11.离线UPS参考设计电路图(4)
图12.离线UPS参考设计电路图(5)
图13.离线UPS参考设计电路图(6)
图14.离线UPS参考设计电路图(7)
图15.离线UPS参考设计PCB布局图(顶层)
详情请见:
http://ww1.microchip.com/downloads/en/DeviceDoc/70318D.pdf
http://ww1.microchip.com/downloads/en/AppNotes/01279B.pdf
关键字:不间断电源  DSC  dsPIC 编辑:探路者 引用地址:MicrochipdsPIC33F离线1000WUPS电源参考设计
上一篇:CypressCY8CPLC20动力线通信(PLC)解决方案
下一篇:设计面向高级数据系统的高效、高功率 DC/DC 电源架构
推荐阅读最新更新时间:2023-10-18 16:29
基于dsPIC33F和PIC24H设计的Microstick
本文 首先介绍了PIC24H系列16 位高性能单片机主要特性,方框图,接着介绍了Microstick 开发板主要特性及其电路图。 Microstick 开发板是Microchip 公司的用来开发16位数字信号控制器(DSC)dsPIC33F 和16位MCU PIC24H,主要用来开发智能传感器和其它嵌入式控制应用。Microstick 开发板的成本很低,它集成了编程器/调试器,可以单独使用,也可以插入原型板进行开发,成本很低。 PIC24H系列16 位高性能单片机主要特性: 通信模块: • 4 线SPI (最多2 个模块): - 帧支持与简单编解码器的I/O 接口 - 支持8 位和16 位数据 - 支持所有串行时钟格式
[电源管理]
基于<font color='red'>dsPIC</font>33F和PIC24H设计的Microstick
世平集团所代理产线ADI针对DSC提出一系列解决方
世平集团所代理产线ADI针对DSC提出一系列解决方案 针对DSC的应用,提供了以下产品来满足客户的设计需求: 一.用于CCD Sensor Analog Front―AD9920 AD9920 是ADI新一代的数码相机的前端产品,整合 Analog Front End, Timing Generator 和Vertical Driver为单一的芯片。18个频道的垂直信号,以及可编写的Timing Generator,可已满足目前市面上几乎所有的CCD传感器。1.8V的核心电压比其它同级产品更省电,并且提供简易操作的GPO用来控制相机的机械快门?闪光灯等元件,加上ADI领先业界的40MHZ 12bit ADC,
[模拟电子]
世平集团所代理产线ADI针对<font color='red'>DSC</font>提出一系列解决方
dsPIC及其在交流变频调速中的应用研究
在现代交流调速中,越来越多地采用交流变频调速。PWM变频器与鼠笼型电机的结合,就性价比而言是公认的优选方案。Microchip公司生产的16位微处理器dsPIC30F4012具有片内波形发生器,是专为电机高速控制而设计的。本文引入了dsPIC30F4012芯片,并介绍采用它与IPM模块结合实现的全数字化SPWM变频调速系统的构成及基本算法。系统主电路采用交直一交电压型变频方式,逆变电路采用三菱电机推出的第4代智能功率模块PM100CVA120,给出实验结果。实验结果表明,系统有较 好的控制效果,具有较高性价比,有广泛的应用前景。 1 控制芯片dsPIC30F4012介绍 dsPIC30F4012是Microchip公司专门为电
[嵌入式]
Microchip PIC24F dsPIC33E flash 自擦写的尿性小结
最近摸了好久,发现这个东西真的难, MHCP 这套16bit 体系flash的擦写操作,分为ICSP和RTSP两种方式,前者就是常见的官方pickit/ICD编程烧写操作时序。而后者是为bootload或者数据保存自擦写准备的,运行过程中的擦写操作。 RTSP flash读很简单,速度也很快。 但是RTSP擦写就是各种坑了。看了编程手册和datasheet发现这货在写入之前必须进行擦除操作,而擦除的最小擦除单位是一个page,不是一个row。那么一个page是多大呢,大概一千多words吧。摔QQQQ!!!! 然后,擦完了一页,就可以写入了,每次可以按row写32/64个words;也可以按双字节写,每次写一个指令
[单片机]
安森美半导体的全系列IGBT满足汽车、太阳能逆变器、不间断电源、白家电等各类应用需求
安森美半导体是领先的功率器件半导体供应商,提供全面的功率器件,包括MOSFET、IGBT、二极管、宽带隙(WBG)等分立器件及智能功率模块(IPM)等功率模块,尤其在收购Fairchild半导体后,是全球第二大功率分立器件半导体供应商,在IGBT领域有着不可比拟的优势,提供同类最佳的IGBT技术和最宽广的IGBT产品阵容。下面就随电源管理小编一起来了解一下相关内容吧。 安森美半导体在IGBT领域的优势 安森美半导体在功率器件、IGBT、薄晶圆和封装技术方面有强大的知识产权阵容,在全球多地拥有IGBT制造设施,量产点火IGBT具有30年经验,600 V和1200 V沟槽场截止IGBT平台性能已通过分立产品和功率集成模块(PIM
[电源管理]
基于DSC的数字脉冲MIG弧焊逆变电源设计
    脉冲MIG(Metal Inert Gas)是一种熔化极惰性气体保护焊。数字脉冲MIG焊机具有诸多优点,在制造工业中占有重要地位。研制弧焊逆变电源具有重要意义。     弧焊逆变电源自上世纪80年代问世以来,经过不断的发展完善,已成为焊接电源的主流产品。弧焊逆变电源的逆变频率一般在20~100kHz,由于目前的逆变电源多采用模拟电路控制,限制了逆变电源性能的提高。焊机的数字化是当今焊接装备发展的潮流,它使得数字控制应用于弧焊逆变电源成为可能。在国内,数字化焊机的研究尚处于起步阶段,较之世界先进水平仍有很大的差距。这使我们研究弧焊逆变电源有了很大的必要。     1 电源主电路设计     1.1 系统概述
[电源管理]
基于<font color='red'>DSC</font>的数字脉冲MIG弧焊逆变电源设计
三相不间断电源的新进展
    引言     在今后相当长的一段时间内,我国市电电网供电不足,电压波动大,干扰严重的局面仍将存在。而各行业、各领域的快速发展对供电质量提出了越来越高的要求,尤其是实时性很强的重要系统、重要部门和重要的用电设备对供电质量的要求和我国的电网实际状况的矛盾日益尖锐。因此,不间断电源(UPS)作为一种稳压稳频纯净化的绿色电源越来越成为人们关注的焦点。为了不断提高UPS的性能,科研人员对UPS系统做了大量的研究,提出了很多的电路拓扑与控制策略。     1 UPS的电路拓扑     UPS的可靠运行离不开各模块的协调工作,下面就UPS主要功能模块电路拓扑进行简要分析。     1.1 整流和功率因数校正电路
[电源管理]
三相<font color='red'>不间断电源</font>的新进展
OMNIVISION推出DSC 等级的高质量成像产品
OmniVision Technologies, Inc.,于今日宣布推出针对手机、基于1.75µ OmniBSI™(背面照度)架构的最新成像解决方案。该方案特别为了满足消费者对手机上数字静态照相机 (DSC) 的成像质量的需求而设计。新的设备具备业界最佳的低光灵敏度 (大于 1400m V/lux-sec),并在信噪比方面达到 2 倍的改善 (小于 70 lux),同时堆叠高度也是世界最小*,非常适合用于时下流行的超薄手机。另外,此设备具备自动影像控制功能以及视频编码的高帧率,即使在最严苛的光线条件下,也能带来生动鲜活的静态和视频影像。 1.75µ OmniBSI 架构包括 500 万像素的 RAW 传感器(用
[手机便携]
小广播
最新电源管理文章
