The NCP1072/NCP1075 products integrate a fixed frequency current mode controller with a 700 V MOSFET. Available in a PDIP−7 or SOT−223 package, the NCP1072/5 offer a high level of integration, including soft−start, frequency−jittering, short−circuit protection, skip−cycle, a maximum peak current set point, ramp compensation, and a Dynamic Self−Supply (eliminating the need for an auxiliary winding).
Unlike other monolithic solutions, the NCP1072/5 is quiet by nature: during nominal load operation, the part switches at one of the available frequencies (65, 100 or 130 kHz). When the output power demand diminishes, the IC automatically enters frequency foldback mode and provides excellent efficiency at light loads. When the power demand reduces further, it enters into a skip mode to reduce the standby consumption down to a no load condition.
Protection features include: a timer to detect an overload or a short−circuit event, Overvoltage Protection with auto−recovery and AC input line voltage detection. For improved standby performance, the connection of an auxiliary winding stops the DSS operation and helps to reduce input power consumption below 50 mW at high line.
NCP1072/NCP1075主要特性:
• Built−in 700 V MOSFET with RDS(on) of 11
• Large Creepage Distance Between High−voltage Pins
• Current−Mode Fixed Frequency Operation – 65 / 100 /130 kHz (130 kHz on demand only)
• Peak Current: NCP1072 with 250 mA and NCP1075 with 450 mA
• Fixed Ramp Compensation
• Skip−Cycle Operation at Low Peak Currents Only: No Acoustic Noise!
• Dynamic Self−Supply: No Need for an Auxiliary Winding
• Internal 1 ms Soft−Start
• Auto−Recovery Output Short Circuit Protection with Timer−Based Detection
• Auto−Recovery Overvoltage Protection with Auxiliary Winding Operation
• Frequency Jittering for Better EMI Signature, Including Frequency Foldback Mode
• No Load Input Consumption < 50 mW
• Frequency Foldback to Improve Efficiency at Light Load
• Internal Temperature Shutdown
• These are Pb−Free Devices
NCP1072/NCP1075典型应用:
• Auxiliary / Standby Isolated Power Supplies White Goods / Smart Meter / E−Meter
图1.NCP1072/NCP1075方框图
图2.NCP1075 12V/0.85A通用输入电源电路图
15W开关电源评估板NCP1075SOTGEVB
图3.15W开关电源评估板NCP1075SOTGEVB外形图
图4.15W开关电源评估板NCP1075SOTGEVB电路图
15W开关电源评估板NCP1075SOTGEVB材料清单(BOM):
详情请见:
http://www.onsemi.cn/pub_link/Collateral/NCP1072-D.PDF
上一篇:STSTEVAL-ISV013V1250WDC-DC太阳能模块解决方案
下一篇:TOP204开关电源IC制成的开关电源
推荐阅读最新更新时间:2023-10-17 15:01
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- MathWorks 和 NXP 合作推出用于电池管理系统的 Model-Based Design Toolbox
- 意法半导体先进的电隔离栅极驱动器 STGAP3S为 IGBT 和 SiC MOSFET 提供灵活的保护功能
- 全新无隔膜固态锂电池技术问世:正负极距离小于0.000001米
- 东芝推出具有低导通电阻和高可靠性的适用于车载牵引逆变器的最新款1200 V SiC MOSFET
- 【“源”察秋毫系列】 下一代半导体氧化镓器件光电探测器应用与测试
- 采用自主设计封装,绝缘电阻显著提高!ROHM开发出更高电压xEV系统的SiC肖特基势垒二极管
- 艾迈斯欧司朗发布OSCONIQ® C 3030 LED:打造未来户外及体育场照明新标杆
- 氮化镓取代碳化硅?PI颠覆式1700V InnoMux2先来打个样
- 从隔离到三代半:一文看懂纳芯微的栅极驱动IC
