TIBQ25504超低功耗能量收集电池增压转换器设计方案
最新更新时间:2013-02-25来源: 微型机与应用关键字:TIBQ25504  功耗能量  电池增压 手机看文章 扫描二维码
随时随地手机看文章
TI公司的BQ25504是一款最新集成纳米智能能源收集电源管理解决方案,本方案非常适合有特殊需要的超低功耗的应用环境。该产品是专门设计来有效地获取和管理微瓦和毫瓦的电力,电力通常来自各种光伏太阳能直流源或热电动发电机。BQ25504是第一种面向产品和系统实现高效的执行转换器或充电器,例如应用在对操作功耗有严格的需求无线电传感器网络。采用BQ25504设计的DC-DC升压转换器/充电器,只需要毫瓦的电力就可以工作。本文通过总结BQ25504器件的特点,介绍器件、特性、应用方向及内部结构框图,并给参考设计实例原理图、制板图及元器件清单。
The bq25504 is the first of a new family of intelligent integrated energy harvesting Nano-Power management solutions that are well suited for meeting the special needs of ultra low power applications. The product is specifically designed to efficiently acquire and manage the microwatts (μW) to miliwatts (mW) of power generated from a variety of DC sources like photovoltaic (solar) or thermal electric generators. The bq25504 is the first device of its kind to implement a highly efficient boost converter/charger targeted toward products and systems, such as wireless sensor networks (WSN) which have stringent power and operational demands. The design of the bq25504 starts with a DCDC boost converter/charger that requires only microwatts of power to begin operating.
BQ25504主要特性:
Ultra Low Power With High Efficiency DC/DC Boost Converter/Charger
–  Continuous Energy Harvesting From Low Input Sources: VIN ≥ 80 mV(Typical)Ultra Low Quiescent Current: IQ < 330 nA (Typical)
–  Cold-Start Voltage: VIN ≥ 330 mV (Typical)Programmable Dynamic Maximum Power Point Tracking (MPPT)
–  Integrated Dynamic Maximum Power Point Tracking for Optimal Energy Extraction From a Variety of Energy Generation Sources Input Voltage Regulation Prevents Collapsing Input Source Energy Storage
–  Energy can be Stored to Re-Chargeable Li-ion Batteries, Thin-film Batteries, Super-Capacitors, or Conventional Capacitors Battery Charging and Protection
–  User Programmable Undervoltage and Overvoltage Levels
–  On-Chip Temperature Sensor with Programmable Overtemperature Shutoff Battery Status Output
–  Battery Good Output Pin
–  Programmable Threshold and Hysteresis
–  Warn Attached Microcontrollers of Pending Loss of Power
–  Can be Used to Enable/Disable System Loads
BQ25504应用:
• Energy Harvesting
• Solar Charger
• Thermal Electric Sources Generator (TEG) Harvesting
• Wireless Sensor Networks (WSN)
• Industrial Monitoring
• Environmental Monitoring
• Bridge and Structural Health Monitoring (SHM)
• Smart Building Controls
• Portable and Wearable Health Devices
• Entertainment System Remote Controls
图1. BQ25504方框图
BQ25504参考设计主要特性:
• Evaluation module for bq25504
• Ultra low power boost converter/charger with battery management for energy harvester applications
• Resistor-programmable settings for under voltage, over voltage providing flexible battery management;
POTs Included for fine tuning the settings (not populated)
• Programmable push-pull output Indicator for battery status (VBAT_OK)
• Test points for key signals available for testing purpose – easy probe hook-up.
• Jumpers available – easy to change settings
BQ25504设计原理图:
图2. BQ25504设计原理图
BQ25504设计方案材料清单:
PCB元件布局图:
关键字:TIBQ25504  功耗能量  电池增压 编辑:探路者 引用地址:TIBQ25504超低功耗能量收集电池增压转换器设计方案
上一篇:OnSemiLV5980MC低功率损耗、高效转换降压型稳压器设计方案
下一篇:美大学开发出无需外置降压电路的集成型DC-DC转换电路
推荐阅读最新更新时间:2023-10-17 15:14
创新的低功耗能量采集传感器方案
  智能环境代表了家庭自动化和楼宇自动化的未来。各种传感器、控制器和执行器分布在整个环境中,并发挥多种作用。这种分布也带来了一些技术挑战。例如,每个传感器都需要有自己的电源。监视电池的低电量状态是一项标准操作。但是,更换电池需要人工辅助。本文提出了一种低功耗能量采集传感器的实现方案。当传感器需要发送大量数据或执行连续测量时,能量采集供电的无线传感器更为适合。采用能量采集供电的传感器可在数年内完全免维护,而电池供电的传感器在几个月内就会耗尽电量。   如今的无线传感器实现方案五花八门。但是,此类系统的总成本不仅仅取决于硬件。实施不同行业标准的成本也会增加总成本。这不仅包括附加的软硬件要求,还包括不甚明显的项目,如认证(例如ZigBe
[电源管理]
能量收集、超低功耗、无线充电,可穿戴设备离不开我们仨
2014年,可穿戴设备成为消费者的新宠,预示着另一种先进的电子消费品正在普及中,或许从苹果发布的吸引眼球的Apple Watch可以说明一二。但是,我们明显看到,可穿戴设备的电池续航依旧显得差强人意,解决掉电池续航问题,或许才能够真正促进可穿戴设备大热。 我们知道,可穿戴设备的上下游产业技术涉及传感器、存储器、电池、触控模组、语音交互技术、体感相关产品等诸多环节,而其中,最影响使用体验的莫过于功耗问题,我想,谁也不愿意自己的智能手表要每天充电吧?故此,我们认为,超低功耗技术、能量采集技术、无线充电技术将是三大要素。 德州仪器高性能模拟半导体产品部电池管理产品市场及应用经理文司华博士亦认为:功耗、电池寿命都是阻碍可穿戴设备市
[嵌入式]
TI公司的BQ25504是一款最新集成纳米智能能源收集电源管理解决方案,本方案非常适合有特殊需要的超低功耗的应用环境。该产品是专门设计来有效地获取和管理微瓦和毫瓦的电力,电力通常来自各种光伏太阳能直流源或热电动发电机。BQ25504是第一种面向产品和系统实现高效的执行转换器或充电器,例如应用在对操作功耗有严格的需求无线电传感器网络。采用BQ25504设计的DC-DC升压转换器/充电器,只需要毫瓦的电力就可以工作。本文通过总结BQ25504器件的特点,介绍器件、特性、应用方向及内部结构框图,并给参考设计实例原理图、制板图及元器件清单。 The bq25504 is the first of a new family of intell
[电源管理]
<font color='red'>TIBQ25504</font>超低<font color='red'>功耗</font><font color='red'>能量</font>收集<font color='red'>电池</font><font color='red'>增压</font>转换器设计方案
小广播
最新电源管理文章
换一换 更多 相关热搜器件
