基于LM032L液晶的电子时钟显示程序
发布者:WhisperingSoul最新更新时间:2012-10-17 来源: 21ic 关键字:LM032  L液晶  电子时钟  显示程序 手机看文章 扫描二维码
随时随地手机看文章
元器件:
Atmel89c51
LM032L液晶屏
Button
仿真已经测试通过,大家使用只需要自己修改液晶的端口即可.
点击浏览下一页
C程序代码:
/*电子时钟 1062液晶显示
#include
#define uchar unsigned char
#define uint unsigned int
sbit LCD_EN=P3^4;
sbit LCD_RS=P3^5;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit rd=P3^7;
uchar count,s1num;
char miao,shi,fen;
uchar code table[]=" 2010-06-25 FIR";
uchar code table1[]="    20:25:00";
void delay(uint z)
 uint x,y;
 for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void write_com(uchar com)
 LCD_RS=0;
 P1=com;
 delay(5);
 LCD_EN=1;
 delay(5);
 LCD_EN=0;
void write_data(uchar date)
 LCD_RS=1;
 P1=date;
 delay(5);
 LCD_EN=1;
 delay(5);
 LCD_EN=0;
void init()
 uchar num;
 LCD_EN=0;
 write_com(0x38);
 write_com(0x0f);
 write_com(0x06);
 write_com(0x01);
 write_com(0x80);
 for(num=0;num<15;num++)
   write_data(table[num]);
   delay(5);
 write_com(0x80+0x40);
 for(num=0;num<12;num++)
   write_data(table1[num]);
   delay(5);
 TMOD=0x01;
 TH0=(65536-50000)/256;
 TL0=(65536-50000)%256;
 EA=1;
 ET0=1;
 TR0=1;
void write_sfm(uchar add,uchar date)
 uchar shi,ge;
 shi=date/10;
 ge=date%10;
 write_com(0x80+0x40+add);
 write_data(0x30+shi);
 write_data(0x30+ge);
void keyscan()
 rd=0;
 if(s1==0)
  delay(5);
  if(s1==0)
  { s1num++;
   while(!s1);
   if(s1num==1)
    TR0=0;
    write_com(0x80+0x40+10);
    write_com(0x0f);
   if(s1num==2)
    write_com(0x80+0x40+7);
   if(s1num==3)
    write_com(0x80+0x40+4);
   if(s1num==4)
    s1num=0;
    write_com(0x0c);
    TR0=1;
  if(s1num!=0)
   if(s2==0)
    delay(5);
    if(s2==0)
     while(!s2);
     if(s1num==1)
      miao++;
      if(miao==60)
       miao=0;
      write_sfm(10,miao);
     if(s1num==2)
      fen++;
      if(fen==60)
       fen=0;
      write_sfm(7,fen);
     if(s1num==3)
      shi++;
      if(shi==24)
       shi=0;
      write_sfm(4,shi);
   if(s3==0)
    delay(5);
    if(s3==0)
     while(!s3);
     if(s1num==1)
      miao--;
      if(miao==-1)
       miao=59;
      write_sfm(10,miao);
     if(s1num==2)
      fen--;
      if(fen==-1)
       fen=59;
      write_sfm(7,fen);
     if(s1num==3)
      shi--;
      if(shi==-1)
       shi=23;
      write_sfm(4,shi);
void main()
 init();
 while(1)
  keyscan();
void timer0() interrupt 1
 count++;
if(count==18)
   count=0;
   miao++;
   if(miao==60)
    miao=0;
    fen++;
    if(fen==60)
     fen=0;
     shi++;
     if(shi==24)
      shi=0;
     write_sfm(4,shi);
    write_sfm(7,fen);
   write_sfm(10,miao);
关键字:LM032  L液晶  电子时钟  显示程序 引用地址:基于LM032L液晶的电子时钟显示程序
上一篇:单片机最小系统的制作电路图
下一篇:浅析基于DS18B20与AT89C2051的温度测量器设计方案
推荐阅读最新更新时间:2024-03-16 13:10
单片机按键扫描程序显示程序及延时程序解析
//程序中没有做按键去抖,也没有考虑多个键同时按下的情况。 //最低两位数码管显示相应的按键(如按下S10,在显示10;按下S25,则显示25) //无按键按下的时候显示FF //按键跟按键的扫描结果满足如下关系: //按键扫描结果(result)按键扫描结果 //K100XE7K180XB7 //K110XEBK190XBB //K120XEDK200XBD //K130XEEK210XBE //K140XD7K220X77 //K150XDBK230X7B //K160XDDK240X7D //K170XDEK250X7E #include//包含 单片机 内部资源预定义 __CONFIG(0x1832); //芯片配
[单片机]
单片机按键扫描<font color='red'>程序</font>和<font color='red'>显示</font><font color='red'>程序</font>及延时<font color='red'>程序</font>解析
基于单片机、DS1302、DS1602的电子时钟
这是DS1602+DS1302完整程序,其中P1口接独立键盘。 DS1602部分: # include "SYSTEM.H" //#ifndef __LCD1602_8_H__ //#define __LCD1602_8_H__ //LCD接口定义 sfr io = 0x80; //P0-0x80,P1-0x90,P2-0xA0,P3-0xB0; sbit rs = P2^6; //LCD数据/命令选择端(H/L) sbit rw = P2^5; //LCD读/写选择端(H/L) sbit ep = P2^7; //LCD使能控制 sbit bz = io^7;
[单片机]
LCD1602屏幕显示邮箱手机号(滚动和闪烁显示程序Proteus仿真)
学习了LCD用来显示两行邮箱和手机号 三种显示方式: 直接显示 滚动显示 闪烁显示 仿真原理图如下 单片机源程序如下: #include reg51.h sbit rs=P2^0; sbit rw=P2^1; sbit en=P2^2; #define uint unsigned int #define uchar unsigned char uchar code tab1 ={ 123456@163.com }; uchar code tab2 ={ tel:1234567891 }; void delay(unsigned int xms); void write_com(uchar com) { rw=0; r
[单片机]
LCD1602屏幕<font color='red'>显示</font>邮箱手机号(滚动和闪烁<font color='red'>显示</font><font color='red'>程序</font>Proteus仿真)
51单片机定时中断实现显示程序
第一位始终显示0,第二位显示在0-9之间循环 ;************************************************** Counter EQU 59H ;计数器,显示程序通过它得知现正显示哪个 数码管 FIRST EQU P2.7 ;第一位数码管的位控制 SECOND EQU P2.6 ;第二位数码管的位控制 DISPBUF EQU 5AH ;显示缓冲区为5AH和5BH ORG 0000H AJMP START ORG 000BH ;定时器T0的入口 AJMP DISP ;显示程序 ORG 30H START: MOV SP,#5FH ;设置堆栈 MOV P1,#0FFH MOV P0,#0FFH
[单片机]
T2做串口数码管显示C51程序+电路图
原理图: 电路图 程序: #include reg52.h #define UCHAR unsigned char #define UINT unsigned int UCHAR table = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; UCHAR timer; UCHAR conter; void initserial(void) { timer='0'; conter=0; SCON=0X50; RCLK=1; TCLK=1; RCAP2L=
[单片机]
T2做串口数码管<font color='red'>显示</font>C51<font color='red'>程序</font>+电路图
单片机动态数码管显示hello汇编程序
51单片机动态数码显示技术 电路是P0口接数码管的字型码笔段,P2口接数码管的数位选择端,P1。7接一个开关,当开关接高电平时,显示 12345 字样;当开关接低电平时,显示 hello 字样。 汇编语言源程序: ORG 00H START: JB P1.7,DIR1 MOV DPTR ,#TABLE1 SJMP DIR DIR1: MOV DPTR ,#TABLE2 DIR: MOV R0,#00H MOV R1,#01H NEXT: MOV A,R0 MOVC A,@A+DPTR MOV P0,A
[单片机]
代码显示谷歌Fuchsia运行Android应用程序
集微网消息,谷歌研发Fuchsia操作系统已经有一段时间了,除了前阵子华为工程师在谷歌开源社区提交了基于荣耀Play的Fuchsia测试代码,并添加了对麒麟970平台的支持外就没有更多的消息了。 最近在Android的Gerrit源代码管理页面上发现了一个新的代码,确认了Fuchsia操作系统将能够运行Android应用程序。在新版本的README文件中显示,借助于新版本ART运行机制,Fuchsia将可以运行针对Android操作系统开发的应用程序。 Fuchsia的ART运行机制不同于现有的ART,它是专门针对Fuchsia这款操作系统研发的,至于它的相关原理,目前尚不清楚。 有报道称,谷歌可能最终会用Fuchsia取
[手机便携]
代码<font color='red'>显示</font>谷歌Fuchsia运行Android应用<font color='red'>程序</font>
MSP430程序库<九>数码管显示
数码管也是单片机系统最常用的输出设备之一(还有液晶、发光二极管等)。七段(这里用的是8段,有小数点)数码管可以完成显示0-9数字和一部分的英文字符如:A、b。本文实现的程序完成显示数字和可显示的英文字符;同时完成数码管显示的printf函数的移植,以支持printf的格式化字符等好用的特点(我用的数码管8个排为一排,方便数字等的显示)。 硬件介绍: 这里所用到的硬件资源包括8个数码管、和msp430单片机的两个8位IO口(这里用的是P3和P5口,如有改变,可以通过宏定义更改)。 数码管是8个共阴的数码管,a-h 8段通过一个200Ω的电阻接到430单片机的P5口。共阴端是由单片机的P3口控制,单片机的一位IO通过一个三极管
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
