unsigned char position1=1;//position一共有3种状态,0代表最边上,1代表初始位置,2代表最前的位置 unsigned char position2=1;//position一共有3种状态,0代表最边上,1代表初始位置,2代表最前的位置 unsigned char fist1=0;//1没有出拳 unsigned char fist2=0;//2没有出拳 unsigned char leg1=0;//1没有出脚 unsigned char leg2=0;//2没有出脚 unsigned char count_back1=0; unsigned char count_back2=0; unsigned char count_forth1=0; unsigned char count_forth2=0; unsigned char time0_count=0; unsigned char time1_count=0; unsigned char blood1=7; unsigned char blood2=7; unsigned char buff1[16]={0x00,0x18,0x24,0x24,0x18,0x18,0x7E,0x66,//右边小人的初始形态 0x66,0x24,0x3C,0x24,0x24,0x24,0x24,0x00}; unsigned char buff2[16]={0x00,0x18,0x24,0x24,0x18,0x18,0x7E,0x66,//右边小人的初始形态 0x66,0x24,0x3C,0x24,0x24,0x24,0x24,0x00}; //定义两名选手的操作键 //选手1 #define S11 P1_0//向前 #define S12 P1_1//后退 #define S13 P1_2//出拳 #define S14 P1_3//出腿 //选手2 #define S21 P1_4//向前 #define S22 P1_5//向后 #define S23 P1_6//出出 #define S24 P1_7//腿拳 //两个选手的led点阵行扫描使能端 #define A_1 P0_0 #define B_1 P0_1 #define C_1 P0_2 #define D_1 P0_3 //两个选手的2个595使能端 #define SCLK P2_0 #define SI P2_1 #define RCLK P2_2 //当按下S1时 开始游戏,游戏结束时显示哪方获胜,然后按下S2键后重新开始新一轮游戏 #define S1 P2_6 #define S2 P2_7 //第一个人的74HC154区域行选 #define NUMLED1OPEN(); {D_1=0;C_1=0;B_1=0;A_1=0;}; #define NUMLED2OPEN(); {D_1=0;C_1=0;B_1=0;A_1=1;}; #define NUMLED3OPEN(); {D_1=0;C_1=0;B_1=1;A_1=0;}; #define NUMLED4OPEN(); {D_1=0;C_1=0;B_1=1;A_1=1;}; #define NUMLED5OPEN(); {D_1=0;C_1=1;B_1=0;A_1=0;}; #define NUMLED6OPEN(); {D_1=0;C_1=1;B_1=0;A_1=1;}; #define NUMLED7OPEN(); {D_1=0;C_1=1;B_1=1;A_1=0;}; #define NUMLED8OPEN(); {D_1=0;C_1=1;B_1=1;A_1=1;}; #define NUMLED9OPEN(); {D_1=1;C_1=0;B_1=0;A_1=0;}; #define NUMLED10OPEN(); {D_1=1;C_1=0;B_1=0;A_1=1;}; #define NUMLED11OPEN(); {D_1=1;C_1=0;B_1=1;A_1=0;}; #define NUMLED12OPEN(); {D_1=1;C_1=0;B_1=1;A_1=1;}; #define NUMLED13OPEN(); {D_1=1;C_1=1;B_1=0;A_1=0;}; #define NUMLED14OPEN(); {D_1=1;C_1=1;B_1=0;A_1=1;}; #define NUMLED15OPEN(); {D_1=1;C_1=1;B_1=1;A_1=0;}; #define NUMLED16OPEN(); {D_1=1;C_1=1;B_1=1;A_1=1;}; //0是第一个选手的索引表的开始 80是第二个选手开始在表中的位置 #define START1 0 #define START2 80 #define INIT 16//第一个选手从的初始状态在中间 为16 #define JUMP_UP_AND_BACK1 48//向后跳起的缓冲动作的位置 #define JUMP_UP_AND_BACK2 64//向后跳起的缓冲动作的位置 #define BACK 0//在最边后面的状态的位置 #define FORTH 32//在最前面的状态的位置 #define GO 0//游戏的开始画面 然后按S1开始游戏 //#define KO 32 #define P1_WIN 64//显示P1胜利在索引表中的位置 #define P2_WIN 96//显示P2胜利在索引表中的位置 //图像表 //人物的各种形态和位置 unsigned char code role_action[]= { 0x00,0x0C,0x12,0x12,0x0C,0x0C,0x3F,0x33,//左边小人后退一步的状态0 0x33,0x12,0x1E,0x12,0x12,0x12,0x12,0x00, 0x00,0x18,0x24,0x24,0x18,0x18,0x7E,0x66,//左边小人的初始形态16 0x66,0x24,0x3C,0x24,0x24,0x24,0x24,0x00, 0x00,0x30,0x48,0x48,0x30,0x30,0xFC,0xCC,//左边小人前进一步的状态32 0xCC,0x48,0x78,0x48,0x48,0x48,0x48,0x00, 0x18,0x24,0x24,0x18,0x18,0x66,0x66,0x65,//左边小人向右后方向跳起的动作1 48 0x24,0x3C,0x24,0x12,0x12,0x12,0x00,0x00, 0x0C,0x12,0x12,0x0C,0x0C,0x33,0x33,0x53,//左边小人向右后方向跳起的动作2 64 0x12,0x1E,0x12,0x24,0x24,0x24,0x00,0x00, 0x00,0x30,0x48,0x48,0x30,0x30,0xCC,0xCC,//右边小人后退一步的动作80 0xCC,0x48,0x78,0x48,0x48,0x48,0x48,0x00, 0x00,0x18,0x24,0x24,0x18,0x18,0x7E,0x66,//左边小人的初始形态96 0x66,0x24,0x3C,0x24,0x24,0x24,0x24,0x00, 0x00,0x0C,0x12,0x12,0x0C,0x0C,0x33,0x33,//右边小人前进一步的状态112 0x33,0x12,0x1E,0x12,0x12,0x12,0x12,0x00, 0x18,0x24,0x24,0x18,0x18,0x66,0x66,0xA6,//右边小人向左后方向跳起的动作1 128 0x24,0x3C,0x24,0x48,0x48,0x48,0x00,0x00, 0x30,0x48,0x48,0x30,0x30,0xCC,0xCC,0xCA,//右边小人向左后方向跳起的动作2 144 0x48,0x78,0x48,0x24,0x24,0x24,0x00,0x00 }; //开机画面和结束时显示哪方胜利的索引表 unsigned char code welecome_and_end[]= { 0x00,0x00,0x00,0x04,0xF9,0xF4,0xF9,0xF4,0x00,0x04,0xF9,0xF4,0xF9,0xF4,0x00,0x00, 0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//GO!!! 0 0x00,0x00,0x22,0x38,0x24,0x44,0x28,0x44,0x30,0x44,0x28,0x44,0x24,0x44,0x22,0x44, 0x22,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x92,0x49,0x45,0x14,0x28,0xA2,0x92,0x49,//KO 32 0x00,0x00,0x00,0x00,0x00,0x00,0x25,0x12,0x51,0x13,0x55,0x12,0x55,0x52,0x54,0xA7, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//P1 WIN 64 0x00,0x00,0x00,0x00,0x00,0x00,0x4A,0x24,0xA2,0x2A,0xAA,0x24,0xAA,0xA2,0xA9,0x4E, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00//P2 WIN 96 }; void delayu(unsigned int time);//延时函数 延时0.1ms void delay(unsigned int time);//延时函数 延时1ms void NUMLEDOPEN(int i);//74HC154进行行选择,第i行 void dat_in(unsigned char dat);//将8为数据从597传送过去 void display_one_page();//先加载各方“血”的状态,并显示一张图片,显示人的状态和血的状态 void display_scene(int scene);//显示开机画面和胜负画面的函数 void change_buffer_to1(int position);//修改1的图像状态缓冲 从人物索引表的第position个8位数个开始显示 void change_buffer_to2(int position);//修改2的图像状态缓冲 从人物索引表的第position个8位数个开始显示 void action_back1();//第1个人向后一步 并将position减1 直到它不能后退 void action_back2();//第2个人向后一步 并将position减1 直到它不能后退 void action_forth1();//第1个人向前一步 并将position加1 直到它不能后退 void action_forth2();//第2个人向前一步 并将position加1 直到它不能后退 void fist_change_buff1();//由于1出拳对画面的改动 要调用change_buff1_to_bit(int pos)和change_buff1_to_bit_low(int pos)函数 void leg_change_buff1();//由于1出腿对画面的改动 要调用change_buff1_to_bit(int pos)和change_buff1_to_bit_low(int pos)函数 void fist_change_buff2();//由于2出拳对画面的改动 要调用change_buff1_to_bit(int pos)和change_buff1_to_bit_low(int pos)函数 void leg_change_buff2();//由于2出腿对画面的改动 要调用change_buff1_to_bit(int pos)和change_buff1_to_bit_low(int pos)函数 void change_buff1_to_bit(int pos); //将特定某一位置一 void change_buff2_to_bit(int pos);//将特定某一位置一 void change_buff1_to_bit_low(int pos);//将特定某一位置0 void change_buff2_to_bit_low(int pos);//将特定某一位置0 void action_fist1();//第1个人出拳 并处理减血情况 void action_fist2();//第2个人出拳 并处理减血情况 void action_leg1();//第1个人出腿 并处理减血情况 void action_leg2();//第2个人出腿 并处理减血情况 void scan_key(); //这个是函数的主体部分 分别扫描并处理向后退 向前走 出拳 出腿的动作 当出拳和出腿的时候 开启定时器 //这300ms内记录是否有对方出拳出腿的动作 并按照先扫描向后退 后扫描向前进的顺序 扫描一遍 并处理 如果没有这两个动作 直接返回调用出拳 //否则处理后再出拳 出脚的道理一致 void init_interrupt();//中断位的设置 //开启定两个时器中断 16位模式 void shed_blood1(); //记录流血的数字 void shed_blood2(); void main() { int i; while(1) { if(S1==0) { delay(1); if(S1==0) { for(i=0;i0) { if(position1==2) { i=15; change_buffer_to1(START1+JUMP_UP_AND_BACK2); while(i--) display_one_page(); i=5; change_buffer_to1(START1+INIT); while(i--) display_one_page(); } else if(position1==1) { i=15; change_buffer_to1(START1+JUMP_UP_AND_BACK2); while(i--) display_one_page(); i=5; change_buffer_to1(START1+BACK); while(i--) display_one_page(); } position1--; } } void action_back2()//第2个人向后一步 { //先显示向后跳起的动作 再显示后退的状态 int i; if(position2>0) { if(position2==2) { i=15; change_buffer_to2(START1+JUMP_UP_AND_BACK1); while(i--) display_one_page(); i=5; change_buffer_to2(START2+INIT); while(i--) display_one_page(); } else if(position2==1) { i=15; change_buffer_to2(START2+JUMP_UP_AND_BACK2); while(i--) display_one_page(); i=5; change_buffer_to2(START2+BACK); while(i--) display_one_page(); } position2--; } } void action_forth1()//第1个人向前一步 { int i; if(position1<2) { if(position1==1) { i=10; change_buffer_to1(START1+FORTH); while(i--) display_one_page(); } else if(position1==0) { i=10; change_buffer_to1(START1+INIT); while(i--) display_one_page(); } position1++; } } void action_forth2()//第2个人向前一步 { //直接显示向前一步的状态 int i; if(position2<2) { if(position2==1) { i=10; change_buffer_to2(START2+FORTH); while(i--) display_one_page(); } else if(position2==0) { i=10; change_buffer_to2(START1+INIT); while(i--) display_one_page(); } position2++; } } void change_buff1_to_bit(int pos) { int p1=pos/8; int p2=pos%8; unsigned char flag=0x01; flag=flag< 0) blood1--; } } else if(position2==2) { if(position1>0) { if(blood1>0) blood1--; } } } void shed_blood2() { if(position1==1) { if(position2==2) { if(blood2>0) blood2--; } } else if(position1==2) { if(position2>0) { if(blood2>0) blood2--; } } } void handle1() interrupt 1 { EA=0; TH0=63536/256;//2ms一次定时器中断 TL0=63536%256; time0_count++; if(time0_count==200) { time0_count=0; TR0=0; if(count_back2==1) { count_back2=0; action_back2(); } else if(count_forth2==1) { count_forth2=0; action_forth2(); } } EA=1; } void handle2() interrupt 3 { EA=0; TH1=63536/256;//2ms一次定时器中断 TL1=63536%256; time1_count++; if(time1_count==200) { time1_count=0; TR1=0; if(count_back1==1) { count_back1=0; action_back1(); } else if(count_forth1==1) { count_forth1=0; action_forth1(); } } EA=1; }
上一篇:51单片机学习之1-锁存器驱动led灯
下一篇:基于51单片机驱动LCD1602液晶显示thb6064ah细分64
推荐阅读最新更新时间:2024-03-16 14:04
