最新的MSP430普通IO模拟IIC程序!
发布者:熙风细雨最新更新时间:2015-07-09 来源: 51hei关键字:MSP430  普通IO  模拟IIC 手机看文章 扫描二维码
随时随地手机看文章
#include
#include
#include
#include
#define IicWpDirOut           P6DIR |=  BIT5
#define IicWpLow              P6OUT &=~ BIT5
#define IicWpHig              P6OUT |=  BIT5
#define IicSclDirOut          P6DIR |=  BIT6
#define IicSclLow             P6OUT &=~ BIT6
#define IicSclHig             P6OUT |=  BIT6
#define IicSdaDirOut          P6OUT &= ~BIT7
#define IicSdaLow             P6DIR |=  BIT7
#define IicSdaHig             P6DIR &=~ BIT7
#define IicSdaInSt            P6IN  &   BIT7
bool AckErr;
//------------------------------ *** - 时间延时 - *** ------------------------------//
void Delay(unsigned int count)
   unsigned int i;
   _NOP();
   _NOP();
   for(i=count; i>0; i--);
void IIcDelay(void)
   _NOP();
//-----***-IIC初始化-***-----//
void IicInit(void)
IicWpDirOut;
IicSdaDirOut;
IicSclDirOut;
IicWpHig;
IicSdaHig;
IicSclHig;
//-----***-IIC启示-***-----//
void IicStart(void)
      IicSdaHig;//IicSda=1;
      IIcDelay();
      IicSclHig;//IicScl=1;
      IIcDelay();
      IicSdaLow;//IicSda=0;
      IIcDelay();
      IicSclLow;//IicScl=0;
      IIcDelay();
//-----***-IIC停止-***-----//
void IicStop(void)
      IIcDelay();
      IIcDelay();
      IIcDelay();
//-----***-IIC应答-***-----//
void SendAcknowledge(bool ack)
      IicSdaDirOut;
      if(ack)//IicSda=ack;
              IicSdaHig;
      else
              IicSdaLow;
      IIcDelay();
      IIcDelay();
      IIcDelay();
//-----***-从slave端读取一个数据-***-----//
unsigned char IicReceiveByte(void)
      unsigned char i;
      unsigned char bytedata=0;
      IicSdaDirOut;
      for(i=0;i<8;i++)
          IIcDelay();
          bytedata<<=1;
          if(IicSdaInSt)
                  bytedata |=0x01;
          else
                  bytedata &=0xfe;
          IIcDelay();
      IicSdaDirOut;
      return bytedata;
//-----***-传送一个 Byte 数据到 slave-***-----//
void IicSentByte(unsigned char DataByte)
    unsigned char i;
    for(i=0;i<8;i++)
        if(DataByte & 0x80)
     else
     DataByte <<=1;
     IIcDelay();
     IIcDelay();
     IIcDelay();
    IicSdaHig;//IicSda=1;-----Y------D---IicSdaDirIn
    IIcDelay();
    IIcDelay();
    IIcDelay();
//-----***-无扇区读---多字节-***-----//
//读取指定器件无扇区指定地址多字节数据到指定地址
//Device=器件地址---单字节
//DataAdd=字节地址---单字节
void IicMuchByteRead(unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
    unsigned char i;
    _DINT();
    WDT();
    IicInit();
    IicStart();
    IicSentByte(0xa0);
    IicSentByte(DataAdd);
    IicStart();
    IicSentByte(0xa1);
    for(i=DataLend-1;i>0;i--)
          *DataDptr=IicReceiveByte();
          DataDptr++;
       SendAcknowledge(0);
    SendAcknowledge(1);
    IicStop();
    WDT();
    Delay(500);
    _EINT();
//-----***-无扇区写---多字节-***-----//
//写入指定器件无扇区指定地址中的多字节数据
//Device=器件地址---单字节
//DataAdd=字节地址---双字节
//DataByte=被存放数据的地址
//DataLend=被存放数据的长度
void IicMuchByteWrite(unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
    unsigned char i;
    _DINT();
    WDT();
    IicInit();
    IicWpLow;
    IicStart();
    IicSentByte(0xa0);
    for(i=DataLend;i>0;i--)
        IicSentByte(*DataDptr);
        DataDptr++;
    IicStop();
    WDT();
    Delay(3500);
    IicWpHig;
    _EINT();
//---特别说明
//---利用430芯片来模拟IIC,是不能够把SDA设置为输出模式而是
//---设置为输入,然后利用方向控制器来输出高或者低
//---如下:
关键字:MSP430  普通IO  模拟IIC 引用地址:最新的MSP430普通IO模拟IIC程序!
上一篇:矩阵键盘扫描
下一篇:at45db161驱动
推荐阅读最新更新时间:2024-03-16 14:24
MSP430常见问题之看门狗及定时器类
Q1. 定时器两个中断TAIE 和CCIE,有什么区别?两个中断的中断向量一样吗? A1:TAIE 和CCIE指的是不同事件。TAIE指TAR 计数器溢出,从65535 到0 的变化,由TAIFG 引起的。CCIE指捕获到相应信号(捕获模式下);定时时间到(比较模式下)。由CCIFG引起的。两个中断的中断向量不一样,TAIFG 一般进TIMERA1_VECTOR;CCIFG 的话要看用的是哪个定时器如果是CCR0 的话就进TIMERA0_VECTOR,如果是CCR1,CCR2……则进TIMERA1_VECTOR。(中断向量的写法因器件不同而有所不同) Q2 用F149 的定时器B 的捕捉功能, 遇到问题,在等待捕捉时,读取TB
[单片机]
基于MSP430的零序直流小电流接地选线装置设计
  1 引言   小电流接地系统(NUGS)广泛应用于国内的供用电系统,66kV, 35kV,6kV, 3kV和部分380V系统均为NUGS,接地方式多为不接地系统(NUS)或消弧线圈接地系统(NES),近年也出现了电阻接地方式(NRS)。因NUGS中单相接地电流很小,但是,长时间的接地运行,极易形成两相接地短路,弧光接地还会引起全系统过电压,保护或选线难度很大。为此,生产实践中希望尽快准确地选出故障线路并及时将之切除。国内自1958年以来从第一台小电流接地故障选线装置研制成功到现在,电网单相接地故障选线问题的研究已经走过了几十年的历程,但现场运行的结果表明 ,装置的选线效果并不理想,平均80%的选线装置因为选线效果不佳退出了运
[单片机]
基于<font color='red'>MSP430</font>的零序直流小电流接地选线装置设计
MSP430f5529之PWM控制舵机程序
#include msp430.h //函数库 int sum=0; //全局变量 int main(void) { volatile unsigned int i; //局部变量 //设置timerA相关参数 WDTCTL = WDTPW+WDTHOLD; // 关闭看门狗 P1DIR |= BIT2; // 将P1.2设置为输出端口,验证状态 P2DIR |= BIT0; //P2.0输出PWM波 TA0CCTL1 = OUTMOD_7;
[单片机]
基于VxWorks的油井数据采集远程终端的设计
   0 引 言   目前,采油厂多以抽油机采油生产为主要任务,抽油机的分布点多面广,工作在条件恶劣的环境中,容易损坏和遭外力破坏,需要经常巡测,人员工作强度大。目前油井工作状态参数监控由于缺乏远程手段,对油井的生产状况均处于事后处理状态,油井出现异常或被盗破坏时不能及时处理,造成大量不明损失。基于CD-MA通迅信道的远程终端(Remote Terminal Unit,RTU)充分利用现有的计算机网络,通过对现场的监测和数据采集、传输,可以满足油井远程监控的需求。该远程终端可以对油井运行时的负荷、位移、油管回压、温度、冲次、工作电流、电压等参数进行实时全自动在线抄收;当现场有异常情况发生时,监控中心能自动发出相关报警信息,调度
[嵌入式]
MSP430初学:MSP430单片机C语言基础(二)
1.进制转换 作为一名”勤快“少年,我自然是: 2.数值数据的表示 1.储存单位 计算机的数据是以二进制形式存在的,所以它的储存单位也与二进制有关 储存单位:位bit,b,是数据储存的最小单位,表示一位二进制信息 字节Byte,B,是信息储存的基本单位,1B由8位二进制数字组成,1B=8b 2.有符号的二进制数 计算机中,无符号位和有符号位的取值范围区别_HD243608836的博客-CSDN博客_符号位 char 8bit 1Byte 2^8=256 C语言各数据类型大小和取值范围_画船听雨眠-CSDN博客_c语言数据类型范围 十进制数有正数和负数之分,二进制数也有
[单片机]
<font color='red'>MSP430</font>初学:<font color='red'>MSP430</font>单片机C语言基础(二)
MSP430x14x之BCS ---基本时钟系统
MSP430F169的时钟源有三: 高速晶体振荡器XT2、低速晶体振荡器XT1、数字控制振荡器DCO。各振荡器产生的时钟信号可由软件分配到ACLK,MCLK,SMCLK三路重要的时钟信号通道。 单片机的频率:高频率,低频率,稳定频率。 ACLK的时钟只能来自XT1 MCLK的时钟能来自XT1,XT2,DCO SMCLK的时钟能来自XT2,DCO XT1和DCO振荡器上电即启动,XT2振荡器需要操作XT2OFF方能启动。上电复位后默认XT2关,ACLK来自XT1,MCLK和SMCLK都来自DCO。 当振荡器失效后,我们要检查失效标志,注意要延迟一段时间,再检查失效标志,因为振荡器起振需要一段毫秒级的时间。
[单片机]
MSP430G2553做DS18B20温度控制器
//P2.5 继电器输出 #include msp430g2553.h #include LCD1602_4bit.h #include DS18B20.H unsigned char temp_L,temp_H,temp_s,temp_s_flag,temp_s_H,temp_s_M,temp_s_L,temp; unsigned char time_num; unsigned char i1; unsigned char table_1 = Real: ; unsigned char table_2 = set: ; unsigned char table_3 = setting: ; unsigned cha
[单片机]
MSP430省电方式的两种唤醒方法
1MSP430省电方式简介 MSP430以其低功耗著称于世,它可以外接2个时钟源——XIN、XT2IN,内部还有1个DC0振荡器,可以产生高达8 MHz的内部时钟。一般XT2IN的频率为高频,按实际应用时的要求来选用;XIN为低频,可以是32 768Hz。XIN的用途主要是在低功耗时使系统保持“活着”。MSP430共有5种省电方式,即LPM0~4。其中, LPM0:CPU、MCLK关闭,SMCLK、ACLK打开,功耗79uA; LPM1:CPU、MCLK、DCO关闭,SMCLK、ACLK打开,功耗4luA; LPM2:CPU、MCLK、SMCLK、DC0关闭,DC产生器、ACLK打开,功耗17uA; LPM3:CPU、MC
[单片机]
<font color='red'>MSP430</font>省电方式的两种唤醒方法
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
