STARTUP.A51文件分析
发布者:BlissfulMoments最新更新时间:2015-09-28 来源: eefocus关键字:STARTUP  A51  文件分析 手机看文章 扫描二维码
随时随地手机看文章
$NOMOD51  Ax51宏汇编器控制命令,禁止预定义的8051。使编译器不使能预定义的;8051符号,避免产生重复定义的错误。
 This file is part of the C51 Compiler package
 Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
 STARTUP.A51:  This code is executed after processor reset.
 To translate this file use A51 with the following invocation:
    A51 STARTUP.A51
 To link the modified STARTUP.OBJ file to your application use the following
 BL51 invocation:
    BL51 , STARTUP.OBJ
    BL51是Keil使用的链接器(Linker),这是命令行的使用格式,一般不用,使用IDE环境,
;用project管理,有相应的按钮可以实现该功能.
 User-defined Power-On Initialization of Memory ---  初始化RAM单元
;  With the following EQU statements the initialization of memory---用下面的EQU声明初
;始化ram单元
 at processor reset can be defined:
              ; the absolute start-address of IDATA memory is always 0
IDATALEN  EQU  80H ; the length of IDATA memory in bytes.--根据你选用的芯片可以适
;当 的修改这些值 。IDATALEN  只是一个标号,EQU只是做宏一样的替换,类似于C语;言中的#define uint (unsigned int),以上的代码使得程序以后在碰到IDATALEN时替换;成80H
XDATASTART      EQU     0H      ; the absolute start-address of XDATA memory--以下
;两项根据目标系统的外设配置和连接自己修改
XDATALEN        EQU     0H      ; the length of XDATA memory in bytes.
PDATASTART      EQU     0H      ; the absolute start-address of PDATA memory
PDATALEN        EQU     0H      ; the length of PDATA memory in bytes.
 Notes:  The IDATA space overlaps physically the DATA and BIT areas of the
         8051 CPU. At minimum the memory space occupied from the C51
         run-time routines must be set to zero.
 Reentrant Stack Initilization   --注意:再入堆栈的方向区别于芯片自带的堆栈的生长方
;式,自顶向下生长的!而SP是是自底向上的!
  --且再入堆栈是由编译器自己管理的,一般不必去关心,只是在有再入函数的时候,根据
;函数的存储器模式使用相应的RAM空间做为再入堆栈。
 The following EQU statements define the stack pointer for reentrant
 functions and initialized it:
;Keil C默认情况不是用堆栈来传递参数的,所以造成函数不可重入,Keil要求用户显示声
;明函数是否具有可重入属性,以便为C函数调用初始化栈。
 Stack Space for reentrant functions in the SMALL model.
IBPSTACK        EQU     0       ; set to 1 if small reentrant is used.
IBPSTACKTOP     EQU     0FFH+1  ; set top of stack to highest location+1.
 Stack Space for reentrant functions in the LARGE model.
XBPSTACK        EQU     0       ; set to 1 if large reentrant is used.
XBPSTACKTOP     EQU     0FFFFH+1; set top of stack to highest location+1.
 Stack Space for reentrant functions in the COMPACT model.
PBPSTACK        EQU     0       ; set to 1 if compact reentrant is used.
PBPSTACKTOP     EQU     0FFFFH+1; set top of stack to highest location+1.
;不同内存模式下的堆栈。Keil 编译器中有三种模式设置:
;Small:所有的变量都放在内部RAM区
;Compact:所有变量在默认情况下都会放在外部RAM的低256字节中(可由R0寻址)
;Large:所有变量都放在外部RAM中(DPTR寻址)
;这是由51处理器繁多的寻址模式导致的,不同的寻址模式有不同的效率
 Page Definition for Using the Compact Model with 64 KByte xdata RAM
 The following EQU statements define the xdata page used for pdata
 variables. The EQU PPAGE must conform with the PPAGE control used
 in the linker invocation.
PPAGEENABLE     EQU     0       ; set to 1 if pdata object are used.
PPAGE           EQU     0       ; define PPAGE number.
PPAGE_SFR       DATA    0A0H    ; SFR that supplies uppermost address byte
    (most 8051 variants use P2 as uppermost address byte) 很多的外部页面寻址以P2
;口为高位地址的数值,有使用外部页面RAM的情况
    对PPAGEENABLE 设置为1 ,根据硬件连接修改PPAGE的值。
; Standard SFR Symbols ---标准的SFR符号
ACC   DATA   0E0H;关键字DATA A51伪指令定义单片机内部数据存储器字节地址的符号
      DATA    0F0H
SP      DATA    81H
DPL     DATA    82H
DPH     DATA    83H
                                  NAME          ?C_STARTUP   ;定义当前程序模块的目标模块名
?C_C51STARTUP     SEGMENT   CODE       ;定义一个可再定位的段符号名和段所在的
;存储空间,汇编器产生的这个段符号名在BL51/L51连接定位时用
?STACK                     SEGMENT   IDATA      ;定义一个IDATA段,段名?STACK ,符合
;C51编译器的命名规则   (SEGMENT   用于定义一个段)
                                  RSEG           ?STACK    ;声明当前段是IDATA段,段中保留空间
;RSEG伪指令用于选择一个事先用SEGMENT伪指令声明的普通段
                                  DS                 DS是预留空间定义指令
                                  EXTRN  CODE (?C_START ;声明本模块引用的外部全局符号,
;用于和C相连接在.src文件中可以看到这个符号
                                  PUBLIC        ?C_STARTUP     ;声明可被其他模块使用的全局符
;号,由.src文件中可以看出这个符号的作用。
                                  CSEG           AT              ;结束当前的IDATA段,产生一个位于
;CODE中新段,起始地址是0000H。代码段的起始点
?C_STARTUP:           LJMP           STARTUP1       ;C编译器编译源程序后,芯片复位之
;后的复位代码第一个就是执行这条语句。
                                  RSEG           ?C_C51STARTUP  ;选择段名为?C_C51STARTUP
;的CODE段为当前段,存储程序代码。
STARTUP1:
IF IDATALEN <> 0                      ;条件汇编指令,有IDATA区的话,清IDATA区。
                                  MOV                   R0,#IDATALEN – 1  ;区域为0——IDATALEN-1
                                  CLR             A
IDATALOOP:      MOV                   @R0,A
                                  DJNZ                  R0,IDATALOOP
ENDIF   ;(一)如果上;面idatalen=80H,那么是对0~7FH清零;如果你的程序是改写成:
;IDATALEN    EQU    0100H    ;
;就是对0~FFH清零。
;             (二)二、如何按你意愿加载这段程序
;一般考虑到这个往往是你的设计中要区分上电复位和程序复位。有时候当程序复位时
;你不希望一些内存单元被清零了,那么你不对startup.a51作点修改,就不行了。
;默认是自动加载这段startup.a51的。
;所以你要这样做:
;把lib目录下的原始startup.a51文件拷到你的项目所在目录下,再把你项目目录下的
;这个startup.a51加入到你的项目中
;比如改成:
;IDATALEN    EQU    00H    the length of IDATA memory in bytes.
;然后编译链接。这样你的程序中就不会包含对idata清零的内码了。
;为什么?上面提到的IF语句的作用呀!当定义IDATALEN=0时,清零代码被跳过!
IF XDATALEN <> 0          ;如果有外部数据区,则把外部数据区中从XDATASTART到
;XDATASTART+ XDATALEN的区域清零
                                  MOV                   DPTR,#XDATASTART
                                  MOV                   R7,#LOW (XDATALEN)
    IF (LOW (XDATALEN)) <> 0
                                  MOV                   R6,#(HIGH (XDATALEN)) +1 ;如果低地址是零,一个
;高地址就代表256字节
ELSE
                           MOV           R6,#HIGH (XDATALEN)
ENDIF
                           CLR             A
XDATALOOP:            MOVX          @DPTR,A
                           INC              DPTR
                           DJNZ                  R7,XDATALOOP
                           DJNZ                  R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0                   ;清外部页RAM区域
                                  MOV                   PPAGE_SFR,#PPAGE ;给P2口赋相应的值,根据用
;户自己的目标系统。
ENDIF
IF PDATALEN <> 0                     ;清外部页RAM区域
                                  MOV                   R0,#LOW (PDATASTART)
                                  MOV                   R7,#LOW (PDATALEN)
                                  CLR             A
PDATALOOP:            MOVX          @R0,A
                                  INC              R0
                                  DJNZ                  R7,PDATALOOP
ENDIF
IF IBPSTACK <> 0        ;使用再入堆栈的情况,用户自己在程序中定义函数的存储模式。
 ; C51定义了三个全局变量,?C_IBP,?C_XBP,?C_PBP来存储再入堆栈的栈顶地址
EXTRN DATA (?C_IBP)     声明本模块使用的外部全局符号,符号的段类型限制了符号
;的使用范围,而符号本身则代表的是一个RAM单元的地址址
                                  MOV                   ?C_IBP,#LOW IBPSTACKTOP
ENDIF
IF XBPSTACK <> 0                      ;函数是Large存储模式的时候,存储再入堆栈的区域。
EXTRN DATA (?C_XBP)                   ;
                                  MOV                   ?C_XBP,#HIGH XBPSTACKTOP
                                  MOV                   ?C_XBP+1,#LOW XBPSTACKTOP
ENDIF
IF PBPSTACK <> 0       ;函数是Compact模式的时候,存储再入堆栈栈顶地址的存储单元
;和栈的利用空间
EXTRN DATA (?C_PBP)
                                  MOV                   ?C_PBP,#LOW PBPSTACKTOP
ENDIF
                                  MOV                   SP,#?STACK-1  ;定义的硬件栈的常数。区别再入堆
;栈和硬件栈。定义的段符号代表该段的首地址
; This code is required if you use L51_BANK.A51 with Banking Mode 4
#if  0
EXTRN CODE (?B_SWITCH0)
                                  CALL    ?B_SWITCH0  ; init bank mechanism to code bank 0
#endif
                                  LJMP           ?C_START       ;把执行的权力交给C主函数。也就是;说指定函数的入口点。改句话结束以后将跳入C的main函数开始执行。
                                  END
关键字:STARTUP  A51  文件分析 引用地址:STARTUP.A51文件分析
上一篇:如何区分51单片机中的单周期和双周期指令
下一篇:51单片机中常见问题的解决方法
推荐阅读最新更新时间:2024-03-16 14:33
Xilinx FPGA的Fast Startup
 在众多当代应用中,嵌入式系统必须满足极其苛刻的时序要求。其中之一就是启动时间——即上电后电子系统进入可操作状态所需要的时间。PCI Express®产品或汽车应用中基于CAN的电子控制单元(ECU)就是具有严格时序要求的电子系统的应用实例。     标准PCI Express®(PCIe)系统上电后仅100毫秒,系统的根组件就开始扫描总线以便弄清拓扑结构,并在这一过程中进行初始化配置。 如果PCIe设备没有准备好响应配置请求,根组件就找不到此PCIe设备,并认为它不存在。该设备将无法加入PCIe总线系统。     汽车应用中的情形与此大体相仿。在基于CAN的网络中,ECU进入睡眠模式,这时它们将停止运行并切断电源连接。只有很少部分
[嵌入式]
Xilinx FPGA的Fast <font color='red'>Startup</font>
STM32 USB工程的文件分析
先介绍下我参考其他工程而建立的STM32 USB工程: 简单介绍下:Startup当然放置STM32的启动文件,CMSIS放置着STM32内核ARMCortex的内核文件,StdPeripheral_Driver目录里放置着STM32外设的库函数,这几个都是STM32工程必须的,这里不仔细讲诉,User Source里放着自己的应用代码,如main.c,stm32f10x_it.c等文件都放这里。USB-FS-Driver_Driver下放着USB的库,这里暂时不讲述,我重点想分析的文件在USB-User里,这个目录主要放着一些与USB库和用户相关的文件,起着USB库与用户之间的桥梁作用,文件如下图所示,该目录包含
[单片机]
STM32 USB工程的<font color='red'>文件</font><font color='red'>分析</font>
意法半导体成为Startup Autobahn主要合作伙伴
意法半导体成为Startup Autobahn主要合作伙伴助力未来的汽车创新企业 Startup Autobahn计划是连接初创公司与主要汽车品牌的投资开发平台 意法半导体是第一家半导体厂商身份的主要合作伙伴 中国,2021年8月5日–服务多重电子应用领域的全球半导体领导者意法半导体(STMicroelectronics,简称ST;纽约证券交易所代码:STM)加入Startup Autobahn计划,成为其主要合作伙伴。Startup Autobahn由Plug-and-Play公司创办和管理,旨在于推进汽车产业技术创新,为老牌的科技公司引荐优选的有活力的新企业。Plug-and-Play是硅谷的科技企业加速器和投
[汽车电子]
单片机中工程的文件结构分析
一直以来都是在原有的工程上直接新建自己的模块文件,现在一到自己新建工程的时候就出现了各种的链接错误(当然我这里说的是多文件的工程,单文件工程不会出现链接错误的),平常接触的51,32,飞思卡尔K66等芯片都的工程都有自己的工程结构。简单的51来说一般都是单文件的工程,毕竟本身的资源不多,引脚定义也少。如果你的工程在各模块编译没有错的情况下,link时出现错误或警告,一定是文件结构有问题。通俗来讲就是乱定义。 这里以51为例提供一种常用的工程结构定义,绝对不会出错。 /*新建工程后,建立一个总的.h文件可以,暂且命名为include.h。include.h下包含工程下所有的.h文件(包括所需的C库.h和各模块的.h)关于寄存
[单片机]
STM32启动过程解析-2.02固件库启动文件分析
启动过程也许平时开发的时候不用太多关注,但是了解一下有助于我们加深对芯片工作过程的理解。 相对于ARM上一代的主流ARM7/ARM9内核架构,新一代Cortex内核架构的启动方式有了比较大的变化。ARM7/ARM9内核的控制器在复位后,CPU会从存储空间的绝对地址0x000000取出第一条指令执行复位中断服务程序的方式启动,即固定了复位后的起始地址为0x000000(PC = 0x000000)同时中断向量表的位置并不是固定的。而Cortex-M3内核则正好相反,有3种情况: 1、 通过boot引脚设置可以将中断向量表定位于SRAM区,即起始地址为0x2000000,同时复位后PC指针位于0x2000000处; 2、 通过boo
[单片机]
keil MDK启动文件分析---基于LPC2100系列
转用MDK有一段时间了,越来越觉得MDK的强大,因为我之前都是用ADS1.2开发产品,所以更能体会到MDK的强大与易用性。MDK编译出来的代码与ADS1.2相比,代码量减少了很多,我的一个工程用ADS1.2编译为25.4KB(都是bin格式),但用MDK编译出来仅有19.5KB(采用默认优化级别,即L2优化级别)。根据我个人的经验,使用一个新的编译器,难点往往有三个,一个是建立一个新的工程,以及工程项目的配置;二是启动代码的编写;三是如何下载和单步调试。今天重点写一下MDK的启动代码。使用MDK版本为V4.01。 MDK编译器所追求的是要让arm 处理器像单片机那样简单使用,所以每个厂家的各种ARM,MDK都会有一个自带的启动
[单片机]
keil MDK启动<font color='red'>文件</font><font color='red'>分析</font>---基于LPC2100系列
51单片机keil提供的启动代码解析(STARTUP.A51)
1.由Keil C生成的启动代码 程序清单1.1 AT89C51启动代码 $NOMOD51 //不使用51默认的特殊功能寄存器 ;------------------------------------------------------------------------------ ; This file is part of the C51 Compiler package ; Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc. ;------------------------------------------------------
[单片机]
STM32固件库文件分析
1-汇编编写的启动文件 startup_stm32f10x_hd.s:设置堆栈指针、设置PC指针、初始化中断向量表、配置系统时钟、对用C库函数_main最终去到C的世界 2-时钟配置文件 system_stm32f10x.c:把外部时钟HSE=8M,经过PLL倍频为72M。 3-外设相关的 stm32f10x.h:实现了内核之外的外设的寄存器映射 xxx:GPIO、USRAT、I2C、SPI、FSMC stm32f10x_xx.c:外设的驱动函数库文件 stm32f10x_xx.h:存放外设的初始化结构体,外设初始化结构体成员的参数列表,外设固件库函数的声明 4-内核相关的 CMSIS - Cortex 微控制器软件接
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
