DRAM: 64 MB
Flash: 2 MB
NAND: 256 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x240000, size 0x200000
2097152 bytes read: OK
## Booting from zImage at 30008000 ---by ce123
Starting kernel ...
Uncompressing Linux...................................................................................... done, booting the kernel.
Linux version 2.6.14 (root@czu) (gcc version 3.4.1) #2 Wed Dec 19 22:34:57 CST 2012
CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T)
Machine: SMDK2440
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C2440: core 405.600 MHz, memory 101.400 MHz, peripheral 50.700 MHz
S3C2410 Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists
Kernel command line: noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0
irq: clearing pending ext status 00000200
irq: clearing subpending status 00000002
PID hash table entries: 512 (order: 9, 8192 bytes)
timer tcon=00500000, tcnt a509, tcfg 00000200,00000000, usec 00001e4c
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 64MB = 64MB total
Memory: 62080KB available (2210K code, 453K data, 104K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
softlockup thread 0 started up.
NET: Registered protocol family 16
S3C2410 Power Management, (c) 2004 Simtec Electronics
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, UPLL 48.000 MHz, DVS off
S3C2410 DMA Driver, (c) 2003-2004 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS version 1.0, (C) 1999, 2000 Axis Communications AB
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
yaffs Dec 19 2012 20:52:49 Installing.
lp: driver loaded but no devices found
S3C2410 RTC, (c) 2004 Simtec Electronics
ppdev: user-space parallel port driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
Serial: 8250/16550 driver $Revision: 1.90 $ 8 ports, IRQ sharing enabled
s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: loaded (max 8 devices)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
BAST NOR-Flash Driver, (c) 2004 Simtec Electronics
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2410-nand: mapped registers at c4a00000
s3c2410-nand: timing: Tacls 20ns, Twrph0 60ns, Twrph1 20ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 1945 at 0x0f320000
Creating 3 MTD partitions on "NAND 256MiB 3,3V 8-bit":
0x00000000-0x00080000 : "Board_uboot"
0x00240000-0x00440000 : "Board_kernel"
0x00440000-0x0ff80000 : "Board_yaffs2"
mice: PS/2 mouse device common for all mice
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 99 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
TCP bic registered
NET: Registered protocol family 1(停在这有3-5分钟,之后才输出后面的信息)
VFS: Mounted root (jffs filesystem).
Freeing init memory: 104K
Warning: unable to open an initial console.
Failed to execute /linuxrc. Attempting defaults...
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
上一篇:linux-2.6.14挂载NFS文件系统
下一篇:linux内核编译错误
推荐阅读最新更新时间:2024-03-16 14:46
