内核版本:Linux Kernel 2.6.39
硬件平台:FL2440
开发板系统:Linux Kernel 2.6.28
下面是用CPU轮寻的方式来判断AD转换完成的
- #include
- #include
- #include
- #include
/*创建设备节点*/ - #include
- #include
/*延时函数*/ - #include
- #include
- #include
- #include
- #define ADC_MAJOR 102
- #define ADC_NAME "my_adc"
- #define SUCCESS 0
- static int adc_open(struct inode *,struct file *);
- static int adc_release(struct inode *,struct file *);
- static int __init adc_init(void);
- static int __exit adc_exit(void);
- static ssize_t adc_read(struct file *,char *,size_t,loff_t *);
- volatile unsigned long adc_con;
- unsigned long adc_dat0;
- //#define adc_con (unsigned long)ioremap(0x58000000,4)
- //#define adc_dat0 (volatile unsigned long)ioremap(0x5800000c,4)
- struct clk *adc_clk;
- struct file_operations adc_ops =
- .owner = THIS_MODULE,
- .read = adc_read,
- .open = adc_open,
- .release = adc_release,
- int ret;
- adc_clk = clk_get(NULL,"adc");//获取时钟
- clk_enable(adc_clk);//使能时钟
- ret=register_chrdev(ADC_MAJOR,ADC_NAME,&adc_ops); //注册设备
- if(ret<0)
- printk("register device fail/n");
- return ret;
- adc_con=(unsigned long)ioremap(0x58000000,4);
- adc_dat0=(volatile unsigned long)ioremap(0x58000000+S3C2410_ADCDAT0,4);
- if(adc_con&adc_dat0==0)
- printk("Failed to ioremap/n");
- goto handle;
- printk("Initialized.../n");
- return SUCCESS;
- handle:
- unregister_chrdev(ADC_MAJOR,ADC_NAME);
- return -1;
- static int adc_open(struct inode * inode,struct file * file) //打开设备函数
- return SUCCESS;
- static int adc_release(struct inode * inode,struct file * file) //关闭设备函数
- return SUCCESS;
- static ssize_t adc_read(struct file *file,
- char * buffer,
- size_t length,
- loff_t * offset)//设备读取函数
- unsigned int buf;
- int tmp;
- int i;
- writew((1<<14)|(0x31<<6),adc_con); //设置ADCCON
- writew((readw(adc_con) | 0x1),adc_con); //启动AD转换
- while(readw(adc_con) & 0x1) ; //启动转换后,等待启动位清零
- while(!(readw(adc_con) & 0x8000)) ; //等待转换是否完毕
- //for(i=0;i<200000;i++) ;
- mdelay(100);
- buf=(readw(adc_dat0) & 0x3ff ); //取出转换后得到的有效数据
- copy_to_user(buffer, (char *)&buf, sizeof(buf));
- //printk("The value is %x/n",buf);
- return 2;
- static int __exit adc_exit(void) //驱动卸载函数
- iounmap(adc_con);
- iounmap(adc_dat0);
- clk_disable(adc_clk);
- clk_put(adc_clk);
- printk("The adc is unintialized/n");
- return SUCCESS;
- module_init(adc_init);
- module_exit(adc_exit);
- MODULE_LICENSE("GPL");
其中控制寄存器的第15未标明AD转换是否完成,当AD完成转换时,控制寄存器自动置一,但是由于数据存在延迟,当第15位置一的时候读出的数据并不稳定,需要在其后加个延迟的函数,在内核态使用的延迟函数包含头文件./linux/delay.h
mdelay(int x);延时x毫秒
udelay(int x);延时x微秒
ndelay(int x);延时x纳秒
测试函数如下:
- #include
- #include
- #include
- #define ADC_DEVICE "/dev/my_adc"
- int main()
- int ret;
- unsigned int data;
- ret=open(ADC_DEVICE,0);
- if(ret<0)
- printf("Open adc fail/n");
- return ret;
- for(;;)
- //printf("cnt=%d/n",cnt);
- read(ret,&data,sizeof(data));
- printf("The value is 0x%x/n",data);
- close(ret);
- return 0;
测试结果
上一篇:linux-2.6.35.3内核移植(s3c2440)
下一篇:ARM Cortex-M3 学习笔记(4-2)
推荐阅读最新更新时间:2024-03-16 14:52
