S5PV210启动烧写过程信息
发布者:备战最新更新时间:2016-06-12 来源: eefocus关键字:S5PV210  启动  烧写过程 手机看文章 扫描二维码
随时随地手机看文章
记录下S5PV210启动烧写过程信息,对分析系统启动及烧写流程大有帮助:
通过串口烧的信息:
>OEMInitLIb is Success
+++InitializeInterrupt()
---InitializeInterrupt()
+++OTGDEV_InitOtg
OTGDEV_SetSoftDisconnect
---OTGDEV_InitOtg
TSR START ADDRESS : 0x47700000
TSR IMAGE SIZE : 0x00080000
DOWNLOADING IS COMPLETED
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Apr  6 2011 18:41:59
+OEMPlatformInit.
Microsoft Windows CE Bootloader for the Samsung SMDKV210 Version 2.5 Built Apr  6 2011
ARGS: Initializing BSP_ARGS back to initial state.
Initialize IRQ Vector Tables
EOTG: USB DeInit 0xE59FF3D8
TOC_Read: 5
 [SUN] g_ImageType: 0x8
TOC {
dwSignature: 0x434F544E
BootCfg
  ConfigFlags: 0x2020
  dwBootDelay: 0x5
  IP: 0.0.0.0
  MAC Address: 00:00:00:00:00:00
  Port: 0.0.0.0
  SubnetMask: 255.255.255.0
ID[0]
  dwVersion: 0x20005
  dwSignature: 0x544F4245
  String: eboot.bin
  dwImageType: 0x1
  dwTtlSectors: 0x100
  dwLoadAddress: 0x87700000
  dwJumpAddress: 0x87700000
  dwStoreOffset: 0x1
ID[1]
  dwVersion: 0x0
  dwSignature: 0x0
  String:
  dwImageType: 0x0
  dwTtlSectors: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
ID[2]
  dwVersion: 0x0
  dwSignature: 0x0
  String:
  dwImageType: 0x0
  dwTtlSectors: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
ID[3]
  dwVersion: 0x1
  dwSignature: 0x48534643
  String: NK
  dwImageType: 0x8
  dwTtlSectors: 0x40B2
  dwLoadAddress: 0x80020000
  dwJumpAddress: 0x80027E94
  dwStoreOffset: 0x0
ID[4]
  dwVersion: 0x0
  dwSignature: 0x0
  String:
  dwImageType: 0x0
  dwTtlSectors: 0x877499A4
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
[Eboot] g_pBSPArgs->bDVFSDisable: 0
[EBOOT] ++OEMPMICInit
[EBOOT] this is test text
[I2CEMUL] VERSION INFO : 31
 PMIC8937_SLAVE_ADDR : 91 . [EBOOT] SET OEMPMICInit------DVS_1_300
[EBOOT] --OEMPMICInit
[Eboot] ++InitializeDisplay()
[LDI]++LDI_initialize_register_address(0xb1300000, 0xb7100000, 0xb0200000)
[LDI:INF] g_pSPIReg = 0xb1300000
[LDI:INF] g_pDispConReg = 0xb7100000
[LDI:INF] g_pGPIOReg    = 0xb0200000
[LDI]--LDI_initialize_register_address() : 0
[DISP]++Disp_initialize_register_address(0xb7100000, 0xb0200000, 0xb0100000, 0xa0000800, 0xb0107000)
[DISP:INF] g_pDispConReg = 0xb7100000
[DISP:INF] g_pGPIOReg    = 0xb0200000
[DISP:INF] g_pCMUCLKReg  = 0xb0100000
[DISP:INF] g_pBSPArg     = 0xa0000800
[DISP:INF] g_pCMUMISCReg     = 0xb0107000
[DISP]--Disp_initialize_register_address() : 0
[LDI]++LDI_set_LCD_module_type(7)
[LDI]--LDI_set_LCD_module_type() : 0
[LDI]++LDI_fill_output_device_information()
[LDI:INF] Output Device Type [7] = LDI_AT043TN24_RGB
[LDI]--LDI_fill_output_device_information()
[DISP]++Disp_set_output_device_information(80017b2408x)
[DISP]--Disp_set_output_device_information()
[DISP]++Disp_initialize_output_interface(0)
[DISP]++Disp_initialize_port_RGBIF(0)
[DISP]--Disp_initialize_port_RGBIF() : 0
[DISP]++Disp_initialize_RGBIF()
[DISP]++Disp_get_vclk_direction_divider(4)
[DISP:INF] MPLL_USE IS TRUE
[DISP:INF] CLK_SRC_MASK0 = 0xffffffff
[DISP:INF] CLK_SRC1    = 0x00600000
[DISP:INF] CLK_DIV1  = 0x00200400
[DISP:INF] MPLLout = (667000000 Hz)
[DISP:INF] VCLK Source = LCDCLK (222333333 Hz)
[DISP:INF] VCLKSrc = 222333333, VCLK = 0, Div = 17
[DISP:INF] VCLK Direction = Divided, Divider = 14, VCLK = 15880952 Hz
[DISP] --Disp_get_vclk_direction_divider()
[DISP]--Disp_initialize_RGBIF() : 0
[DISP]--Disp_initialize_output_interface() : 0
[DISP]++Disp_set_window_mode(3)
[DISP]++Disp_window1_initialize(3, 5, 480, 272, 0, 0)
[DISP]--Disp_window1_initialize() : 0
[DISP]--Disp_set_window_mode() : 0
[Eboot:LCD_Bpp = 16]
[DISP]++Disp_set_framebuffer(1, 0x47e00000)
[DISP]++Disp_window_registers_lock(1)
[DISP]--Disp_window_registers_lock() : 0
[DISP]++Disp_window_registers_unlock(1)
[DISP]--Disp_window_registers_unlock() : 0
[DISP]++Disp_window_onfoff(1, 1)
[DISP]--Disp_window_onfoff() : 0
[LDI]++LDI_initialize_LCD_module()
[LDI:INF] LDI_initialize_LCD_module() : Type [7] LDI_AT043TN24_RGB
[LDI]++LDI_AT043TN24_RGB_power_on()
[LDI]--LDI_AT043TN24_RGB_power_on() : 0
[LDI]++LDI_AT043TN24_RGB_initialize()
[LDI]--LDI_AT043TN24_RGB_initialize() : 0
[LDI]--LDI_initialize_LCD_module() : 0
[DISP]++Disp_envid_onoff(1)
[DISP:INF] DUALCON = 0x00000000
[DISP:INF] VIDCON2    = 0x00000000
[DISP:INF] DISPLAY_CONTROL  = 0x00000002
[DISP:INF] GPOUTCON0    = 0x00000000
[DISP:INF] VIDCON0 = 0x00000357
[mDNIe:INF] CLK_SRC_MASK1 = 0xffffffff
[mDNIe:INF] CLK_SRC3    = 0x00000000
[mDNIe:INF] CLK_DIV3  = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDCON0 = 0x00000357
[DISP:INF]Disp_envid_onoff() : VIDCON1 = 0x0000e660
[DISP:INF]Disp_envid_onoff() : VIDCON2 = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDCON3 = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDTCON0 = 0x00062902
[DISP:INF]Disp_envid_onoff() : VIDTCON1 = 0x002f0f7f
[DISP:INF]Disp_envid_onoff() : VIDTCON2 = 0x000879df
[DISP:INF]Disp_envid_onoff() : VIDOSD2A = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDOSD2B = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDOSD2C = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDW02ADD0B0 = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDW02ADD1B0 = 0x00000000
[DISP:INF]Disp_envid_onoff() : VIDW02ADD2 = 0x00000000
[DISP:INF]Disp_envid_onoff() : WINCON2 = 0x00000000
[DISP:INF] CLK_GATE_IP0 = 0xffffffff
[DISP:INF] CLK_GATE_IP1 = 0xffffffff
[DISP:INF] CLK_GATE_IP2 = 0xffffffff
[DISP:INF] CLK_GATE_IP3 = 0xffffffff
[DISP:INF] CLK_GATE_IP4 = 0xffffffff
[DISP:INF] CLK_GATE_BLOCK = 0xffffffff
[DISP]--Disp_envid_onoff() : 0
[Eboot] --InitializeDisplay()
Press [ENTER] to download now or [SPACE] to cancel.
Initiating image download in 0 seconds. EOTG: USB Init
EOTG: Receive ATUD 2
EDNL: [13]Eboot version=
EDNL: boot Downloading...
EDNL: [4]Flash write RAMAddr=80200000, Length=00000003, ROMAddr=80200000
g_ImageType = IMAGE_TYPE_BOOTIMAGE
dwImageLength = 0x84000
dwNumBlocks = 0x5
++ WriteBlock  0
Checksum = bd8fb,  header = 4000 0 bd8fb 0
++ FMD_WriteSector_Stepldr : 0xa0020000
-- FMD_WriteSector_Stepldr
++ FMD_WriteSector_Stepldr : 0xa0020800
++ FMD_WriteSector_Stepldr : 0xa0021000
++ FMD_WriteSector_Stepldr : 0xa0021800
++ FMD_WriteSector_Stepldr : 0xa0022000
++ FMD_WriteSector_Stepldr : 0xa0022800
++ FMD_WriteSector_Stepldr : 0xa0023000
++ FMD_WriteSector_Stepldr : 0xa0023800
 End of writing Stepldr : BREAK!
-- WriteBlock
dwBytesPerBlock : 131072
++ WriteBlock  1
 ++ FMD_WriteSector: 1 block, 0 sector,
 -- FMD_WriteSector
 ++ FMD_WriteSector: 1 block, 1 sector,
 -- FMD_WriteSector
 ++ FMD_WriteSector: 1 block, 2 sector,
 -- FMD_WriteSector
 ++ FMD_WriteSector: 1 block, 3 sector,
 -- FMD_WriteSector
 -- FMD_WriteSector
 ++ FMD_WriteSector: 1 block, 60 sector,
 -- FMD_WriteSector
 ++ FMD_WriteSector: 1 block, 61 sector,
 -- FMD_WriteSector
 ++ FMD_WriteSector: 1 block, 62 sector,
 -- FMD_WriteSector
 ++ FMD_WriteSector: 1 block, 63 sector,
 -- FMD_WriteSector
-- WriteBlock
++ WriteBlock  2
++ WriteBlock  4
 ++ FMD_WriteSector: 4 block, 0 sector,
 -- FMD_WriteSector
 ++ FMD_WriteSector: 4 block, 1 sector,
 -- FMD_WriteSector
 -- FMD_WriteSector
-- WriteBlock
EDNL: Store Start address 80200000 & Length 00000003 to flash.
EDNL: ### Clear password ###
EDNL: [1000] OPENSTL cmd
EDNL: PDA Downloading...
EDNL: [4]Flash write RAMAddr=80200000, Length=000000D4, ROMAddr=80200000
EDNL: Store Start address 80200000 & Length 000000D4 to flash.
EDNL: End of command loop...
System ready!
Preparing for download...
Please send the Image through USB.
BL_IMAGE_TYPE_BIN
Download BIN file information:
[0]: Base Address=0x80020000  Length=0x358c6d0
dwStartAddr = 0x80020000
dwLength = 0x358c6d0
NK image
rom_offset=0x0.
ImageStart = 0x80020000, ImageLength = 0x358C6D0, LaunchAddr = 0x80027F34
Completed file(s):
[0]: Address=0x80020000  Length=0x358C6D0  Name="" Target=FLASH
OEMWriteFlash 0x80020000 0x358C6D0
OEMWriteFlash 0x8
Enter LowLevelFormat [0x0, 0x7ff].
Erasing flash block(s) [0x0, 0x7ff] (please wait): EraseBlocks: preserving reserved block (0x0)
EraseBlocks: preserving reserved block (0x1)
EraseBlocks: preserving reserved block (0x2)
EraseBlocks: preserving reserved block (0x3)
EraseBlocks: preserving reserved block (0x4)
EraseBlocks: preserving reserved block (0x5)
EraseBlocks: found a bad block (0x61) - skipping...
EraseBlocks: found a bad block (0x1a6) - skipping...
EraseBlocks: found a bad block (0x48c) - skipping...
EraseBlocks: found a bad block (0x54d) - skipping...
EraseBlocks: found a bad block (0x644) - skipping...
Done.
WriteMBR: MBR block = 0x6.
Done.
IsValidMBR: MBR sector = 0x180 (valid MBR)
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0x1fd3f.
CreatePartition: Start = 0x1, Num = 0x6b40.
Log2Phys: Logical 0x1 -> Physical 0x181
OpenPartition: Partition Exists=0x0 for part 0xb.
CreatePartition: Enter CreatePartition for 0xb.
FindFreeSector: FreeSector is: 0x6b41 after processing part 0x21.
CreatePartition: Num sectors set to 0x19080 to allow for compaction blocks.
CreatePartition: Start = 0x6b80, Num = 0x19080.
BP_SetDataPointer at 0x0
WriteFlashNK : dwStoreOffset = 0x0
WriteData: Start = 0x0, Length = 0x358c6d0.
WriteFlashNK : Kernel 0x0  0x358C6D0  0x80020000
ROMHDR at Address 80020044h
TOC {
BootCfg
  ConfigFlags: 0x2020
  dwBootDelay: 0x5
  IP: 0.0.0.0
  Port: 0.0.0.0
ID[0]
  dwVersion: 0x20005
  String: eboot.bin
  dwImageType: 0x1
  dwTtlSectors: 0x100
  dwStoreOffset: 0x1
ID[1]
  dwVersion: 0x0
  dwSignature: 0x0
  String:
  dwImageType: 0x0
  dwTtlSectors: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
ID[2]
  dwVersion: 0x0
  dwSignature: 0x0
  String:
  dwImageType: 0x0
  dwTtlSectors: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
ID[3]
  dwVersion: 0x1
  String: NK
  dwImageType: 0x8
  dwTtlSectors: 0x6B19
  dwJumpAddress: 0x80027F34
  dwStoreOffset: 0x0
ID[4]
  dwVersion: 0x0
  dwSignature: 0x0
  String:
  dwImageType: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x87762790
A XIP region was written to the flash memory successfully.
INFO: OEMLaunch: Jumping to Physical Address 0x40027F34h (Virtual Address 0x80027F34h)...
Windows CE Kernel for ARM (Thumb Enabled) Built on Nov  3 2010 at 07:30:04
OAL Log enable : 0
OAL Log mask : 103
System Clock Info
[OAL] APLL_CLK    :  800000000 Hz
[OAL] MPLL_CLK    :  667000000 Hz
[OAL] EPLL_CLK    :   96000000 Hz
[OAL] VPLL_CLK    :   54000000 Hz
[OAL] ARM_CLK     :  800000000 Hz
[OAL] HCLK_MSYS   :  200000000 Hz
[OAL] PCLK_MSYS   :  100000000 Hz
[OAL] HCLK_DSYS   :  166750000 Hz
[OAL] PCLK_DSYS   :   83375000 Hz
[OAL] HCLK_PSYS   :  133400000 Hz
[OAL] PCLK_PSYS   :   66700000 Hz
System Clock Info
OEM:-------------------------------------------
OEM: Normal Boot!!
DCache: 128 sets, 4 ways, 64 line size, 32768 size
ICache: 128 sets, 4 ways, 64 line size, 32768 size
+OALInterruptInit
-OALInterruptInit(rc = 1)
DMSG: DrvWAITInitialize
-OALIoCtlHalGetHWEntropy(rc = 0)
[I2C:I] I2C Channel 0 is open
[I2C:I] I2C Channel 1 is open
[I2C:I] I2C Channel 2 is open
[I2C:I] I2C Channel 3 is open
[CMM_Init] VirAddrDram_0 : 0xad480000 VirAddrDram_1 : 0xa5f00000
############################### EHCI INIT ########################
[EHCI] InitailizeEHCI
[EHCI:INF] ++InitializeEHCI(): IRQ 144 sysintr 22 for EHCI interrupt.
############################### --EHCI INIT ########################
############################### OHCI INIT ########################
[XEINT4] Set xeint4 Low.
[XEINT4] Set xeint4 High.
############################### --OHCI INIT ########################
[WAV] I2C OPEN : I2C0: SUCCESS
[WAV] ACTUAL I2C CLCOK SPEAD : 64 Khz
[CEC] DllEntry() : Process Attach
[CEC] CEC_Init()
::AttachDevice SUCCESS_HS:2000
[dm9]:[CUSTOM_BOARD_STR]
[dm9] NewOBJ-2009
[dm9] NewOBJ-2009 V2.08
[dm9] NewOBJ-2009 CUSTOM_SMDKV210
[dm9] .Send connection!
[dm9]:[DM9000_CAST_IO_ADDRESS]
[dm9]:[DM9000_CAST_DATA_OFFSET]
[dm9]:[DM9000_CAST_IRQ_NUMBER]
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_IO_BASE_ADDRESS]=0xa0000000
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_DATA_OFFSET]=0x4
[dm9] Device::AttachDevice SUCCESS_HS:2000
RetriveConfigurations:m_szConfigures[CID_IRQ_NUMBER]=0xa
[dm9] --
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_BUS_DRIVE]=0x61
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_INT]=0x1
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_TXBUFFER_NUMBER]=32
[dm9] DeviceRetriveConfigurations:m_szConfigures[CID_RXBUFFER_NUMBER]=32
[dm9] -
[dm9] m_szConfigures[CID_IRQ_LEVEL]=15
[dm9] m_szConfigures[CID_IRQ_SHARED]=1
[dm9] m_szConfigures[CID_CHECK_FOR_HANG_PERIOD]=3
[dm9] Init.TQu m_szConfigures[CID_TXBUFFER_NUMBER]=32*2
[dm9]:[ID_Custom_Init()]
[dm9]:[ID_Custom_IO_Timing()]
[CPU TO DM9000: IO Timing 0 4 d  4 0]
[CPU TO DM9000: IO Timing -Tcah PMC -0 0]
[DM9] Chip signature rate 60000/60000]
[DM9] Chip signature  is  0A469000]
[DM9] -- Chip revision  -- REVISION : 18 --
[dm9]:[ID_CUSTOM_READ_MAC()]
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[0]=0x20
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[1]=0x4
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[2]=0x9
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[3]=0x18
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[4]=0x0
[dm9] Device.cpp EDeviceLoadEeprom m_szEeprom[5]=0x7
[dm9] -- ----------------- REG38.b[6:5] : CURR= 00 (2mA) --
[dm9] -- ----------------- REG38.b[6:5] : CURR= 11 (8mA) --
[DM9]:-- -- CURR REG38 --- 0x0 -- CURR= 00
[DM9]:-- --- INT REG39 --- 0x0
[DM9]:-- * INT REG39 * INT Active high
[dm9]:[ID_CUSTOM_INT_EN]
[DM9]:DeviceEnableInterrupt
+OALIntrEnableIrqs(10,)
[dm9] DeviceStart:[dm9] --
[UART] DMA init CH:0
[SDMMCCh0] SDHCControllerIst - Card is Removed!
[SDMMCCh2] SDHCControllerIst - Card is Removed!
[SDMMCCh3] SDHCControllerIst - Card is Removed!
++PHY_SetPowerDown
0x01
0x05 0x00 0xd8 0x10 0x1c 0x30 0x40 0x6b
0x10 0x02 0x52 0x1f 0x23 0x5b 0x7e 0x84
0x00 0x10 0x38 0x00 0x08 0x10 0xe0 0x22
0x40 0xf3 0x26 0x00 0x00 0x00 0x80
--PHY_SetPowerDown
[CMM] v_addr : 0xad480000 p_addr : 0x25480000 size : 0x004e0000 loc : 0
[IOCTL_CODEC_MEM_ALLOC] u_addr:0xd33c0000  CallerProcessID : 0x400002
[MFC_DRV: WARNING] MfcFWBufMemMapping: virFWBuf : d33c0000
[MFC_DRV: WARNING] MfcFWBufMemMapping: phyFWAddr : 25480000
[MFC_DRV: WARNING] MFC_Open: It is called by Power Manager
[MFC_DRV: WARNING] MFC_IOControl: POWER_CAPABILITIES : 0x11
MFC power on
[MFC_DRV: WARNING] MFCOpen++:
[UFNPDD] USB_POWER : D[MFC_DRV: WARNING] MFCOpen: FirmwareVersion : 00100407
[MFC_DRV: WARNING] MFC_Open(): Instance Number : 1
[MFC_DRV: WARNING] MFC_Open(): CLK_CNTL is enabled
[MFC_DRV: WARNING] MFC_Close(): MfcCtx->InstNo : 1
[MFC_DRV: WARNING] MFCClose:
0 IN
[UFN[MFC_DRV: ERROR] WaitForDone: Interrupt :: MFC_R2H_CMD_ERR_RET(0x4)
[MFC_DRV: ERROR] MFCClose: closing is failed
MFC power off
PDD] USB_POWER : D0 OUT
[UFNPDD] USB Serial Function Class Enabled
LayMgr.cpp: Layout Manager successfully initialized to  1
Maximum Allowed Error 7:
Backlight driver: GetSystemPowerStstusEx2 failed with error 0x1f.
MSIM: IM_ReadRegistry read KB 5
[BootCompleteApp] Boot Complete Event Occured
[UFNPDD] USB_POWER : D0 IN
[UFNPDD] USB_POWER : D0 OUT
UsbFnMdd!UfnMdd_Notify: Ignoring notification 0x00000001 - 0x00000003 from PDD
[dm9] .NSR.PHYoff c / BMSR 7849
[dm9] .Send disconnection!
Explorer(V2.0) taskbar thread started.
NDISPWR:: Found adapter [DM9000]
NDISPWR:: Found adapter [WWAN1]
[UFNPDD] OTG Cable Attached
[UFNPDD] RESET Again
!USBD: Could not load driver for attached device
BLUETOOTH GATEWAY:: Failed to enable device btline1. Error code 717
BLUETOOTH GATEWAY:: Failed to enable device btline0. Error code 717
kernel IOCTL_POWER_SET setting state 1
kernel IOCTL_POWER_SET setting state 0
[PWC_PM:INFO] Check LP Mode 4, 1, 0, 2, 0, 0, 0
[PWC_PM:INFO] Check LP Mode 4, 0, 0, 3, 0, 0, 0
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
Entering LP_NORMAL
Entering LP_READY
[UFNPDD] OTG Cable Detached
UsbFnMdd!UfnMdd_Notify: Ignoring notification 0x00000001 - 0x00000000 from PDD
[UFNPDD] Reset Exception
UsbFnMdd!UfnMdd_Notify: Ignoring notification 0x00000001 - 0x00000002 from PDD
关键字:S5PV210  启动  烧写过程 引用地址:S5PV210启动烧写过程信息
上一篇:MSP430看门狗定时器
下一篇:瑞萨单片机在交流电机的设计
推荐阅读最新更新时间:2024-03-16 14:56
Intel成都工厂二期启动生产工艺过渡到65纳米
“65纳米已经开始在中国大批量的开始封装,英特尔对AMD的优势又将拉大了。”在英特尔成都芯片封装测试项目二期工程的竣工仪式,一位产业人士感叹到。 今天(2006年10月25日)上午,英特尔成都芯片封装测试项目二期工程的正式竣工。一年前建成投产的一期芯片组工厂在这一天也还迎来了第1880万颗芯片组产品下线。而与之相对的,AMD对其苏州工厂的封装和测试设备的增置工作,计划完成的时间还停留在2008年。 英特尔公司总裁兼首席执行官保罗·欧德宁,也专程抵达成都,参加竣工典礼,而他在中国的停留时间还不到三天。欧德宁近竣工仪式上表示:“英特尔的生产设施和规模化的生产能力,是确保公司成功的关键因素。成都这座先进的封装测试新工厂将生产英特尔公司
[焦点新闻]
手把手之STM32启动代码
对于熟悉电脑的伙伴们来说,BIOS(那个蓝色的界面)可能不会太陌生吧,这货就是电脑的启动代码。没有BIOS的电脑,那注定是一块板砖!BIOS主要是做一些开机前的准备工作,例如系统时间设定、启动顺序。。。扯远了 其实电脑本身就是从单片机而来,那么单片机也是有启动代码的,只是我们绝大部分情况 不去关心它。 启动代码究竟都干了些什么工作,为何需要它?想想你在c语言中用到了什么东西,而这些东西却是拿来就可以用的?堆、栈!没错,就是他们。我们知道堆和栈是内存中划分出的一块区域,那为什么我们没有亲自划分呢,因为启动代码帮了你的忙!!!再想想单片机工作的时候,有哪些配置被我们忽略了,而它却可以用?时钟,就是这货,我们可以不配置时钟,而你
[单片机]
手把手之STM32<font color='red'>启动</font>代码
汽车之家赴港二次上市,启动新“增”程
近两年,阿里巴巴、网易、京东等中概股先后赴港二次上市,掀起中概股回归潮。2021年年初,汽车之家、B站、百度、携程、唯品会、腾讯音乐娱乐集团等多家中概股被曝出正寻求在香港进行二次上市,中概股回港上市迎来爆发期。 3月12日,汽车之家发布公告称:“公司发行约3029.12万股,每股定价176.3港元,每手100股,预期3月15日上市。”值得注意的是,汽车之家折价率高于此前热门二次上市的中概股阿里、网易与京东集团,投资者热情高涨。3月15日9点30分,汽车之家正式在港交所挂牌上市,开盘价181.3港元,较发行价上涨2.67%。 这些年,从内容型垂直媒体服务商升级为数据与技术驱动的汽车平台,汽车之家跟随汽车行业的快速发展,实
[嵌入式]
汽车之家赴港二次上市,<font color='red'>启动</font>新“增”程
苹果新的iPhone供应链启动供货
苹果今年新款iPhone 12虽延迟发布,但市场普遍预料第4季初就会亮相,近期供应链传出消息,苹果已开始要求零组件厂开始备货,包括大立光、稳懋、鸿准、可成等苹果供应链厂商,近期都会开始出货给下游代工厂。 iPhone 12将搭载A14 Bionic处理器,由台积电5nm制程制造,性能及处理速度较前一代处理器A13 Bionic更好;其中游戏性能可提高五成以上。 此外,苹果为迎接5G时代来临,今年也在新机的前后镜头导入ToF传感器或LiDAR扫描仪,借此为用户实现更佳的AR/VR体验,此一零组件目前由稳懋负责供应。 此前据路透社报道,苹果供应商博通Broadcom周四公布第三季度收入增长5.6%,至58.2亿美元,高于57.6亿美元
[手机便携]
阿里云盘正式启动公测;90后将游戏账号虚拟财产列成遗产
集微网3月22日消息,据报道,3月22日起,阿里云盘正式启动公测。各大应用商店用户评论显示,5G网络下用户下载速度50~100MB/秒,可使用最高2TB免费存储空间。对此,阿里云盘还表示:“无论免费收费,未来都不限速”。网盘这类的工具,受市场、政策、公司战略之类的影响太大,所以对于阿里云盘的登场,不必抱太大的期望。 90后、00后订立遗嘱受到社会广泛关注,不仅因年龄问题,还因为他们的遗嘱丰富多样。“90后”遗嘱中,“虚拟财产”的纳入和安排成为其一个突出的特征:支付app、社交软件、游戏账号等虚拟财产是“90后”遗嘱中常见的财产类型。虚拟财产被列入遗嘱是一个好现象,即使百年之后那些东西一文不值,但让人活着的时候有成就感,平生足矣
[手机便携]
阿里云盘正式<font color='red'>启动</font>公测;90后将游戏账号虚拟财产列成遗产
STM32F103启动文件注释
1、启动文件作用: (1) 初始化堆栈指针 (2)初始化PC指针指向复位程序 (3)初始化中断向量表 (4)配置系统时钟(3.0版本之前,进入main函数后,首先配置系统时钟,但是3.5.0版本固件库配置了时钟,所以就不用配置 了,因此在用固件库的时候,看一下注释,如果已经配置,就不用自己配置了。) (5)调用C库函数_main,进入C语言的世界。 ;******************** (C) COPYRIGHT 2011 STMicroelectronics ******************** ;* File Name : startup_stm32f10x_hd.s
[单片机]
S5PV210(TQ210)学习笔记——输入子系统驱动
前面的文章简单的讲述了字符设备驱动程序的编写,用字符设备驱动的方式实现了按键驱动,但是,出了我们的自己编写的针对我们的这个驱动程序的应用程序之外,其他应用程序都无法接收我们这个驱动的键值输入,为了让所有应用程序都可以接收我们的按键驱动解析的键值,Linux内核定义了 输入子系统 的概念,也就是说,只要我们按照这个模型进行驱动开发,并为其提供必须的接口函数,那么,Linux内核就可以正常来获取我们的键盘值了。 输入子系统的原理分析强烈推荐观看韦东山老师的视频讲座,讲的非常清楚,我这里是按照输入子系统的方式实现的按键驱动,下面是源码,放在这里做个备份: #include linux/types.h #include linux
[单片机]
一种新的模糊PID控制在电机软启动中的仿真
摘要:由于异步电机软启动过程中非线性时变的特点,采用传统的PID控制方法难以达到理想的控制效果。为了大大减小交流电机启动过程中的电流,在此结合智能控制理论,设计出一种新型的模糊PID软启动控制器。通过对电流大小进行控制,优化了系统的控制效果,实现了交流电机恒流软启动控制。最后通过Matlab仿真,证实了该系统具有良好的动静态性能,达到了平稳启动的目的,具有有效性和广泛应用性。 关键词:软启动;模糊控制;异步电动机;Matlab 0 引言 异步电机以其优良的性能及无需维护的特点,在工农业中得到广泛应用。三相异步电机的启动方法很多,比如直接启动、自耦降压启动、延边三角形启动等等。对于风机泵类等恒功率负载,如果在额定电压下直接启动三
[工业控制]
一种新的模糊PID控制在电机软<font color='red'>启动</font>中的仿真
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
