代码如下:
/*************定义地址指针,指向基址***********/
unsigned char xdata *SJA_base_Adr = SJA_BaseAdr;
/*************定义SJA1000读写缓冲区的数据结构***********/
struct BASICCAN_BUFStruct{
unsigned char IDH8;
unsigned char IDL_R_DLC;
unsigned char Frame_Data[2];
}receive_BUF,send_BUF;
*函数功能:写SJA1000的寄存器
*入口参数:地址 SJAREG_ADR,数据 setting
*出口参数:无
void Write_SJA1000(unsigned char SJAREG_ADR, unsigned char setting)
*(SJA_base_Adr+SJAREG_ADR)=setting;
*函数功能:读SJA1000的寄存器
*出口参数:无
unsigned char Read_SJA1000(unsigned char SJAREG_ADR)
unsigned char SJAREG_data;
SJAREG_data=*(SJA_base_Adr+SJAREG_ADR);
return(SJAREG_data);
*函数功能:测试SJA1000是否正常连接
*入口参数:无
*出口参数:connect_OK
bit Judge_SJA1000_connect(void)
bit connect_OK=0;
Write_SJA1000(REG_TEST,0xAA); //写AA到测试寄存器(地址09)
if(Read_SJA1000(0x09)==0xAA)
connect_OK=1; //连接正常
else
connect_OK=0; //连接故障
return(connect_OK);
*函数功能:设置SJA1000为工作模式
*入口参数:无
*出口参数:SJA_mode
bit Setting_SJA1000_workingmode(void)
bit SJA_mode;
unsigned char CONTROL_REGdata;
CONTROL_REGdata=Read_SJA1000(REG_CONTROL);
CONTROL_REGdata&=0xFE;
Write_SJA1000(REG_CONTROL,CONTROL_REGdata);
if((Read_SJA1000(REG_CONTROL)&0x01)!=0x01)
SJA_mode=1; //置工作模式成功
else
SJA_mode=0; //置工作模式失败
return(SJA_mode);
*函数功能:设置SJA1000为复位模式
*入口参数:无
*出口参数:SJA_mode
bit Setting_SJA1000_resetmode(void)
bit SJA_mode;
CONTROL_REGdata|=0x01;
if((Read_SJA1000(REG_CONTROL)&0x01)==0x01)
SJA_mode=1; //置复位模式成功
else
SJA_mode=0; //置复位模式失败
return(SJA_mode);
*函数功能:设置SJA1000波特率
*入口参数:无
*出口参数:setting_success
bit Setting_SJA1000_rate(void)
bit setting_success;
while(Setting_SJA1000_resetmode()==0)
Setting_SJA1000_resetmode(); //设置SJA工作在复位模式
Write_SJA1000(REG_BTR0,SJA_BTR0);
Write_SJA1000(REG_BTR1,SJA_BTR1);
if((Read_SJA1000(REG_BTR0)==SJA_BTR0)&(Read_SJA1000(REG_BTR1)==SJA_BTR1))
setting_success=1; //波特率设置成功
else
setting_success=0; //波特率设置失败
return(setting_success);
*函数功能:设置SJA1000的滤波寄存器和屏蔽寄存器
*入口参数:无
bit Setting_SJA1000_dataselect(void)
Write_SJA1000(REG_ACR,SJA_ACR);
Write_SJA1000(REG_AMR,SJA_AMR);
if((Read_SJA1000(REG_ACR)==SJA_ACR)&(Read_SJA1000(REG_AMR)==SJA_AMR))
setting_success=1; //滤波器设置成功
else
setting_success=0; //滤波器设置失败
*函数功能:设置SJA1000的时钟分频器
*入口参数:无
bit Setting_SJA1000_CDR(void)
Write_SJA1000(REG_CDR,SJA_CDR);
if(Read_SJA1000(REG_CDR)==SJA_CDR)
else
*函数功能:设置SJA1000的输出控制寄存器
*入口参数:无
bit Setting_SJA1000_OCR(void)
Write_SJA1000(REG_OCR,SJA_OCR);
if(Read_SJA1000(REG_OCR)==SJA_OCR)
else
*函数功能:初始化SJA1000
*入口参数:无
void Initial_SJA1000(void)
while(Judge_SJA1000_connect==0);
do
while(Setting_SJA1000_resetmode()==0);
while(Setting_SJA1000_CDR()==0);
while(Setting_SJA1000_rate()==0);
while(Setting_SJA1000_OCR()==0);
while(Setting_SJA1000_dataselect()==0)
do
Setting_SJA1000_workingmode();
while(Setting_SJA1000_workingmode()==0);
*函数功能:初始化发送数据
*入口参数:无
*出口参数:setting_success,指示初始化是否成功
bit Initial_transmitter_BUF(void)
bit setting_success=0;
send_BUF.IDH8 = 0x30;
send_BUF.IDL_R_DLC = 0x22; //IDL_R_DLC。4即为RTR位,数据=0,远程=1;
send_BUF.Frame_Data[0] = 0x10;
send_BUF.Frame_Data[1] = 0x00;
setting_success = 1;
*函数功能:对SJA1000发送数据
*入口参数:无
*出口参数:无
void Transmitter_SJA1000(void)
unsigned char state;
unsigned char i;
do
while(Initial_transmitter_BUF()==0); //初始化发送数据
do
state = Read_SJA1000(REG_STATUS); //REG_STATUS为SJA1000的状态寄存器
//查询SJA1000是否处于接收状态,发送完毕状态,或者发送缓存器被锁;
while( ((state&0x10)==0x10) & ((state&0x08)!=0x08) & ((state&0x04)!=0x04) );
Write_SJA1000(REG_TxBuffer1,send_BUF.IDH8);
Write_SJA1000(REG_TxBuffer2,send_BUF.IDL_R_DLC);
for(i=0;i<2;i++)
Write_SJA1000(REG_TxBuffer3+i,send_BUF.Frame_Data[i]);
Write_SJA1000(REG_COMMAND,TR_CMD);
do
while( (state&0x08)!=0x08); //查询SJA1000是否发送完毕状态
void main(void)
unsigned char i;
Initial_SJA1000();
delay1ms(1);
while(1)
if((P1_0==0)|(P1_1==0)|(P1_2==0))
delay1ms(5);
while((P1_0==0)|(P1_1==0)|(P1_2==0));
for(i=0;i<100;i++)
Transmitter_SJA1000();
上一篇:51单片机 同时扩展ROM,RAM的具体实现及kiel的具体设置
下一篇:[C51代码]4*4键盘扫描
推荐阅读最新更新时间:2024-03-16 15:02
- 热门资源推荐
- 热门放大器推荐
设计资源 培训 开发板 精华推荐
- MPS探索营 “正经玩技术”!创意征集 | 解锁锂电池充电的无限玩法!
- 有奖直播:TI 超低功耗 MCU 在触摸及智能化工业网关中的应用
- 直播已结束|贝能国际新型玻璃破碎检测方案
- 快来访问泰克高速串行通信专题 配置您的专属解决方案 赢好礼!
- 直播已结束【借助 TI DLP 技术,开始您的下一代4K显示应用设计】
- 非凡富士通FRAM,仅需微小电源即可高速写入数据!看视频答题有礼!
- 雅特力AT32WB415系列蓝牙BLE 5.0 MCU,免费抢鲜体验!
- 有奖活动|逛安富利人工智能云会展,解锁AI资料,赢好礼!
- 【EEWORLD大学堂】玩转LaunchPad及TI MSP430G2XX系列超值单片机!!!
- 有奖直播【Keysight World Tech Day 2023分论坛——汽车自动驾驶与新能源】
