关于ARM2440中断源个数的一点想法
发布者:beta12最新更新时间:2016-08-04 来源: eefocus关键字:ARM2440  中断源 手机看文章 扫描二维码
随时随地手机看文章
S3c2440支持多达36个内部中断源和24个外部中断源,分别使用内部终端屏蔽寄存器INTMSK和外部中断寄存器MSK进行屏蔽控制。其中,外部中断源通过GPIO以复用的方式成为内部中断源的一部分。
但是我们清楚,INTMSK是一个32位的寄存器,最多只能支持32中断,它是如何对应这么多中断的呢?
首先我们先看INTMSK对应的位。
INTERRUPT MASK (INTMSK) REGISTER (Continued)
INT_ADC [31] 0 = Service available, 1 = Masked 1
INT_RTC [30] 0 = Service available, 1 = Masked 1
INT_SPI1 [29] 0 = Service available, 1 = Masked 1
INT_UART0 [28] 0 = Service available, 1 = Masked 1
INT_IIC [27] 0 = Service available, 1 = Masked 1
INT_USBH [26] 0 = Service available, 1 = Masked 1
INT_USBD [25] 0 = Service available, 1 = Masked 1
INT_NFCON [24] 0 = Service available, 1 = Masked 1
INT_UART1 [23] 0 = Service available, 1 = Masked 1
INT_SPI0 [22] 0 = Service available, 1 = Masked 1
INT_SDI [21] 0 = Service available, 1 = Masked 1
INT_DMA3 [20] 0 = Service available, 1 = Masked 1
INT_DMA2 [19] 0 = Service available, 1 = Masked 1
INT_DMA1 [18] 0 = Service available, 1 = Masked 1
INT_DMA0 [17] 0 = Service available, 1 = Masked 1
INT_LCD [16] 0 = Service available, 1 = Masked 1
INT_UART2 [15] 0 = Service available, 1 = Masked 1
INT_TIMER4 [14] 0 = Service available, 1 = Masked 1
INT_TIMER3 [13] 0 = Service available, 1 = Masked 1
INT_TIMER2 [12] 0 = Service available, 1 = Masked 1
INT_TIMER1 [11] 0 = Service available, 1 = Masked 1
INT_TIMER0 [10] 0 = Service available, 1 = Masked 1
INT_WDT_AC97 [9] 0 = Service available, 1 = Masked 1
INT_TICK [8] 0 = Service available, 1 = Masked 1
nBATT_FLT [7] 0 = Service available, 1 = Masked 1
INT_CAM [6] 0 = Service available, 1 = Masked 1
EINT8_23 [5] 0 = Service available, 1 = Masked 1
EINT4_7 [4] 0 = Service available, 1 = Masked 1
EINT3 [3] 0 = Service available, 1 = Masked 1
EINT2 [2] 0 = Service available, 1 = Masked 1
EINT1 [1] 0 = Service available, 1 = Masked 1
EINT0 [0] 0 = Service available, 1 = Masked 1
我们发现INTMSK的第5,6位对应了EINT4_7, EINT8_23,20个外部中断,也就是所,这20个GPIO引脚只能触发这两个中断。
但是当中断到来时,我们如果判断是由哪一个GPIO引脚触发的呢?这个时候我们可以通过查询EINTMASK来判断中断源。
EINTMASK Bit Description
EINT23 [23] 0 = enable interrupt 1= masked
EINT22 [22] 0 = enable interrupt 1= masked
EINT21 [21] 0 = enable interrupt 1= masked
EINT20 [20] 0 = enable interrupt 1= masked
EINT19 [19] 0 = enable interrupt 1= masked
EINT18 [18] 0 = enable interrupt 1= masked
EINT17 [17] 0 = enable interrupt 1= masked
EINT16 [16] 0 = enable interrupt 1= masked
EINT15 [15] 0 = enable interrupt 1= masked
EINT14 [14] 0 = enable interrupt 1= masked
EINT13 [13] 0 = enable interrupt 1= masked
EINT12 [12] 0 = enable interrupt 1= masked
EINT11 [11] 0 = enable interrupt 1= masked
EINT10 [10] 0 = enable interrupt 1= masked
EINT9 [9] 0 = enable interrupt 1= masked
EINT8 [8] 0 = enable interrupt 1= masked
EINT7 [7] 0 = enable interrupt 1= masked
EINT6 [6] 0 = enable interrupt 1= masked
EINT5 [5] 0 = enable interrupt 1= masked
EINT4 [4] 0 = enable interrupt 1= masked
Reserved [3:0] Reserved
但是还有一个疑问,不是说60个中断源吗?除去24个外部中断源应该还有60-24 -(32-6)=10个内部中断源啊。他们在哪呢?
其实这里涉及到了子中断源的概念。
Sub Sources Descriptions Source
INT_AC97 AC97 interrupt             INT_WDT_AC97
INT_WDT Watchdoc interrupt       INT_WDT_AC97
INT_CAM_P P-port capture interrupt in camera interface        INT_CAM
INT_CAM_C C-port capture interrupt in camera interface       INT_CAM
INT_ADC_S ADC interrupt                                                      INT_ADC
INT_TC Touch screen interrupt (pen up/down)                    INT_ADC
INT_ERR2 UART2 error interrupt                                        INT_UART2
INT_TXD2 UART2 transmit interrupt                        INT_UART2
INT_RXD2 UART2 receive interrupt                          INT_UART2
INT_ERR1 UART1 error interrupt                              INT_UART1
INT_TXD1 UART1 transmit interrupt I                        NT_UART1
INT_RXD1 UART1 receive interrupt                           INT_UART1
INT_ERR0 UART0 error interrupt                              INT_UART0
INT_TXD0 UART0 transmit interrupt                         INT_UART0
INT_RXD0 UART0 receive interrupt                          NT_UART0
关键字:ARM2440  中断源 引用地址:关于ARM2440中断源个数的一点想法
上一篇:ARM NAND FLASH读写错误解决办法
下一篇:s3c2440定时器简介
推荐阅读最新更新时间:2024-03-16 15:03
ARM中断之定时器中断
实时时钟请求中断。在控制中遇到定时检测和控制,为此常采用一个外部时钟电路(可编程)控制其时间间隔。需要定时时,CPU发出命令使时钟电路开始工作,一旦到达规定时间,时钟电路发出中断请求,由CPU转去完成检测和控制工作。 走到这里,大家肯定对Linux的中断处理有概念了,下面我们通过一个具体的实例,来了解Linux内核处理中断的全过程,那就是定时器中断。在详细分析这个过程之前,我们把Linux时间管理的概念先缕一缕。 在当前的80x86体系结构上,内核显式地与几种时钟和定时器电路打交道,其主要分为了时钟和定时器两大类: - 时钟电路同时用于跟踪当前时间和产生精确的时间度量。 - 定时器电路由内核编程,所以它们以固定的、
[单片机]
arm2440的nandflash相关函数
K9F2G08U0A nand flash 的容量为256M byte,其内部有2048块,每块有64页,每页有2K+64字节,其中每页会分为main区(主域)和spare区(备用域),main区一般用来存入主要数据,spare一般用来存放ECC校验码。 下面几点是编程时需要注意的: 1.NAND FLASH芯片手册里说的column是指页内地址,row是指页地址,page也是指页; 2.删除时是以块为单位的,但是删除块时写的是row地址,自动会删除row所在的块; 3.读写方式有页读写,或随机读写,所谓的随机读写就是可以在页内的任一地方读写一个字节; 4.ECC校验码分为main区的ECC和spare区的ECC,它们一
[单片机]
STM32中断位置
在...CMSISDeviceSTSTM32F10x中的stm32f10x.h, 然后在结构体IRQn_Type找到对应单片机型号的代码片段。 比如STM32F103C8T6属于STM32F10X_MD, 那对应的中断源为: 再比如STM32F103ZET6对应的是STM32F10X_HD
[单片机]
STM32<font color='red'>中断</font><font color='red'>源</font>位置
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
更多精选电路图
换一换 更多 相关热搜器件
随便看看
