在STM32的固件库中定义了三个结构体与这三个寄存器组相对应,这三个结构体与ARM手册中寄存器的对应关系如下:
一、NVIC寄存器组
STM32的固件库中有如下定义:
typedef struct
vu32 ISER[2];
u32 RESERVED0[30];
vu32 ICER[2];
u32 RSERVED1[30];
vu32 ISPR[2];
u32 RESERVED2[30];
vu32 ICPR[2];
u32 RESERVED3[30];
vu32 IABR[2];
u32 RESERVED4[62];
vu32 IPR[11];
} NVIC_TypeDef;
它们对应ARM手册中的名称为
ISER = Interrupt Set-Enable Registers
ICER = Interrupt Clear-Enable Registers
ISPR = Interrupt Set-Pending Register
ICPR = Interrupt Clear-Pending Register
IABR = Active Bit Register
IPR = Interrupt Priority Registers
每个寄存器有240位,以Interrupt Set-Enable Registers说明,ISER[0]对应中断源0~31,ISER[1]对应中断源32~63,STM32只有60个中断源,所以没有ISER[2:7]。
参考STM32技术参考手册中的中断向量表,中断源的位置为:
位置0 - WWDG = Window Watchdog interrupt
位置1 - PVD = PVD through EXTI Line detection interrupt
位置2 - TAMPER = Tamper interrupt
位置58 - DMA2_Channel3 = DMA2 Channel3 global interrupt
位置59 - DMA2_Channel4_5 = DMA2 Channel4 and DMA2 Channel5 global interrupts
二、系统控制寄存器组
STM32的固件库中有如下定义:
typedef struct
vuc32 CPUID;
vu32 ICSR;
vu32 VTOR;
vu32 AIRCR;
vu32 SCR;
vu32 CCR;
vu32 SHPR[3];
vu32 SHCSR;
vu32 CFSR;
vu32 HFSR;
vu32 DFSR;
vu32 MMFAR;
vu32 BFAR;
vu32 AFSR;
} SCB_TypeDef; /* System Control Block Structure */
它们对应ARM手册中的名称为
CPUID = CPUID Base Register
ICSR = Interrupt Control State Register
VTOR = Vector Table Offset Register
AIRCR = Application Interrupt/Reset Control Register
SCR = System Control Register
CCR = Configuration Control Register
SHPR = System Handlers Priority Register
SHCSR = System Handler Control and State Register
CFSR = Configurable Fault Status Registers
HFSR = Hard Fault Status Register
DFSR = Debug Fault Status Register
MMFAR = Mem Manage Address Register
BFAR = Bus Fault Address Register
AFSR = Auxiliary Fault Status Register
三、系统时钟寄存器组
STM32的固件库中有如下定义:
typedef struct
vu32 CTRL;
vu32 LOAD;
vu32 VAL;
vuc32 CALIB;
} SysTick_TypeDef;
它们对应ARM手册中的名称为
CTRL = SysTick Control and Status Register
LOAD = SysTick Reload Value Register
VAL = SysTick Current Value Register
CALIB = SysTick Calibration Value Register
关键字:STM32 NVIC 寄存器组
引用地址:
【STM32】NVIC寄存器组
推荐阅读最新更新时间:2024-03-16 15:14
意法半导体:低功耗策略的延伸
“现在低功耗看起来是个非常热门的词,但实际上我们04年左右就已经制定这个策略了。”意法半导体大中国区微控制器市场经理James表示。伴随着云计算概念的普及,智能家居再一次被人们所关注,而意法半导体显然不愿意错过终端处理器市场。 STM32L低功耗处理器发布 STM32L处理器是意法半导体最新发布的一款基于Cortex-M3 32位内核的低功耗处理器,与之前的STM32其他系列产品相比,最大的特点是采用了EnergyLite超低功耗平台。 究竟何为EnergyLite呢?意法半导体单片机部市场经理张军辉解释道,“EnergyLite包含两部分,一个是意法半导体独创的130nm技术的抄底漏电流工艺,另外则是与S
[单片机]
怎么使用ST的库开发STM32
我使用的芯片是 STM32F103VET 和编译器是 IAR ARM V5.5,调试器用 JLINK V8 1,下载ST的库,现在的版本是 STM32F10x_StdPeriph_Lib_V3.3.0,解压缩,然后将 Libraries整个拷贝到你的工作目录,Project 目录是很多演示代码,可以参考怎么怎么编程,很容易的,readme里面都有说明。 2,建立一个 IAR 的project 选择 C 的空项目,为了方便管理我分了多个文件夹,分别是 建立一个 CMSIS目录 放内核启动代码添加两个系统启动文件,分别是在 STM32F10x_StdPeriph_Lib_V3.3.0\Libraries\CMSIS\CM3\Devi
[单片机]
STM32如何从串口接收数据,取出数据中的密码段再保存到flash中
STM32如何从串口接收数据,取出数据中的密码段再保存到flash中 u8 Usart2_buf ; unsigned int usart2_lent; void main(void) { char buf_password = 000000 ;//6位密码 memset((char *) &buf_password, 0, sizeof(buf_password)); strncpy(buf_password, Usart2_buf + 9, 6);//从外键获取的信息保存到Usart2_buf中,其中从第10-15位保存的是密码 if(save_password()==1) { soundBe
[单片机]
STM32之通用定时器计数器模式
#include stm32f10x.h /* RCC时钟配置 */ void RCC_config() { ErrorStatus HSEStartUpStatus; /* RCC寄存器设置为默认配置 */ RCC_DeInit(); /* 打开外部高速时钟 */ RCC_HSEConfig(RCC_HSE_ON); /* 等待外部高速时钟稳定 */ HSEStartUpStatus = RCC_WaitForHSEStartUp(); if(HSEStartUpStatus == SUCCESS) { /* 设置HCLK = SYSCLK */ RCC_HCLKConfig(RCC_SYSCLK_Div1); /
[单片机]
STM32 KEIL里的MAP文件分析
一、文件分析流程 1、第一部分:Section Cross References 主要是各个源文件生成的模块之间相互引用的关系。 stm32f10x.o(STACK) refers (Special) to stkheap2.o(.text) for __use_two_region_memory 比如上面这句话,stm32f10x.o是stm32f10x.s生成的目标文件模块,(STACK)是文件内定义的一个段,链接器把它视为一个Section,输入节。它引用了模块stkheap2.o输入节(.text)里面的一个全局符号__use_two_region_memory(可能是一个函数或变量)。这个(Special)不知道是什
[单片机]
STM32之 UART4 和UART5所遇到的问题
最近在写一个人机界面,由于硬件同事布板的问题,必须要用到串口4,先开始我还觉得没什么,就是把USART1改成4以及改下开启时钟和配置引脚。 但是事实证明我的想法是多么愚蠢,调了整整2天,UART4发送很好,但是就是在接收时死活的卡在中断之前,就会进入HardFaultException B HardFaultException。真是百思不得其解,我就一步步调试跟踪,也没有发现任何问题,UART4的配置都是正确的,引脚也都没问题。这两天真是调试的快崩溃了。在网上查询该问题,大家也都没有答案,有些人甚至直接说UART4不能用,说心里话我不相信,别个STM那么大的公司,会推出不能用的功能? 在我最无助的时候
[单片机]
STM32——库函数开发小结
基本上所有外设都有以下几类寄存器:【CR/DR/SR】 (1)控制寄存器 xxx_CR(Control/Configuration Register):这类寄存器是用来配置、控制 相应 外 设 的 工 作 方 式 的 。 如 GPIOx_CRL、GPIOx_CRH, AFIO_EXTICR1~AFIO_EXTICR4,串口的 USART_CR1~USART_CR3等。 (2)数据寄存器 xxx_DR(Data Register):这类寄存器主要是存储了外设进行输出输入的数据。如 GPIOx_IDR、GPIOx_ODR、USART_DR 等。 (3)状态寄存器 xxx_SR(Status Register):这类寄存器主
[单片机]
stm32---DAC
DAC即数字模拟转换器,它可以将数字信 号转换为模拟信号。 它的功能与 ADC 相反。在常见的数字信号系统中,大部分传 感器信号被转化成电压信号,而 ADC 把电压模拟信号转换成易于计算机存储、 处理的数字编码,由计算机处理完成后,再由 DAC 输出电压模拟信号,该电压 模拟信号常常用来驱动某些执行器件,使人类易于感知。如音频信号的采集及还 原就是这样一个过程。 触发方式 前面是定时器TIM,中间是外部中断9,后面是软件触发 dac.c #include dac.h void DAC1_Init() { GPIO_InitTypeDef GPIO_InitStructure; DAC_InitTyp
[单片机]
