#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
//设置gpio的工作模式,是输入,输出还是其他的
//s3c2410_gpio_cfgpin(S3C2410_GPB(5),S3C2410_GPIO_INPUT),就是设置GPB5为输入模式
void s3c2410_gpio_cfgpin(unsigned int pin, unsigned int function)
void __iomem *base = S3C24XX_GPIO_BASE(pin);
unsigned long mask;
unsigned long con;
unsigned long flags;
if (pin < S3C2410_GPIO_BANKB) {
mask = 1 << S3C2410_GPIO_OFFSET(pin);
} else {
mask = 3 << S3C2410_GPIO_OFFSET(pin)*2;
switch (function) {
case S3C2410_GPIO_LEAVE:
mask = 0;
function = 0;
break;
case S3C2410_GPIO_INPUT:
case S3C2410_GPIO_OUTPUT:
case S3C2410_GPIO_SFN2:
case S3C2410_GPIO_SFN3:
function -= 1;
function &= 1;
function <<= S3C2410_GPIO_OFFSET(pin);
} else {
function &= 3;
function <<= S3C2410_GPIO_OFFSET(pin)*2;
/* modify the specified register wwith IRQs off */
local_irq_save(flags);
con = __raw_readl(base + 0x00);
con &= ~mask;
con |= function;
__raw_writel(con, base + 0x00);
local_irq_restore(flags);
EXPORT_SYMBOL(s3c2410_gpio_cfgpin);
//作用:返回对应的GPIO的配置情况,例如pin=s3c2410_GPB5,则
unsigned int s3c2410_gpio_getcfg(unsigned int pin)
unsigned long val = __raw_readl(base);
val >>= S3C2410_GPIO_OFFSET(pin);
val &= 1;
val += 1;
} else {
val >>= S3C2410_GPIO_OFFSET(pin)*2;
val &= 3;
return val | S3C2410_GPIO_INPUT;
EXPORT_SYMBOL(s3c2410_gpio_getcfg);
//设置相应的GPIO的上拉电阻,当to为1时候,相应的pin引脚设置为1,表示该GPIO要上拉电阻,to为0时候,相应的pin引脚配置为0,表示不要上拉电阻
void s3c2410_gpio_pullup(unsigned int pin, unsigned int to)
unsigned long offs = S3C2410_GPIO_OFFSET(pin);
unsigned long up;
return;
up = __raw_readl(base + 0x08);
up &= ~(1L << offs);
up |= to << offs;
__raw_writel(up, base + 0x08);
EXPORT_SYMBOL(s3c2410_gpio_pullup);
int s3c2410_gpio_getpull(unsigned int pin)
return -EINVAL;
return (__raw_readl(base + 0x08) & (1L << offs)) ? 1 : 0;
EXPORT_SYMBOL(s3c2410_gpio_getpull);
//当GPIO的工作为输入时候,设置某个GPIO的值
//s3c2410_gpio_setpin(S3C2410_GPB(5),0),设置GPB5的输入值是0,就是低电平,to为1,表示该pin输出为1
void s3c2410_gpio_setpin(unsigned int pin, unsigned int to)
unsigned long dat;
dat = __raw_readl(base + 0x04);
dat &= ~(1 << offs);
dat |= to << offs;
__raw_writel(dat, base + 0x04);
EXPORT_SYMBOL(s3c2410_gpio_setpin);
//当GPIO为输出模式时候,获取GPIO的输出数值
//s3c2410_gpio_getpin(S3C2410_GPB(5)),获取GPB5的输出值
unsigned int s3c2410_gpio_getpin(unsigned int pin)
return __raw_readl(base + 0x04) & (1<< offs);
EXPORT_SYMBOL(s3c2410_gpio_getpin);
unsigned int s3c2410_modify_misccr(unsigned int clear, unsigned int change)
unsigned long misccr;
misccr = __raw_readl(S3C24XX_MISCCR);
misccr &= ~clear;
misccr ^= change;
__raw_writel(misccr, S3C24XX_MISCCR);
return misccr;
EXPORT_SYMBOL(s3c2410_modify_misccr);
int s3c2410_gpio_getirq(unsigned int pin)
if (pin < S3C2410_GPF(0) || pin > S3C2410_GPG(15))
return -EINVAL; /* not valid interrupts */
if (pin < S3C2410_GPG(0) && pin > S3C2410_GPF(7))
return -EINVAL; /* not valid pin */
if (pin < S3C2410_GPF(4))
return (pin - S3C2410_GPF(0)) + IRQ_EINT0;
if (pin < S3C2410_GPG(0))
return (pin - S3C2410_GPF(4)) + IRQ_EINT4;
return (pin - S3C2410_GPG(0)) + IRQ_EINT8;
EXPORT_SYMBOL(s3c2410_gpio_getirq);
上一篇:S3C2440 摄像接口CamInit()函数初始化之分析
下一篇:有关STM32固件库的一些想法
推荐阅读最新更新时间:2024-03-16 15:15
