//代码仅仅是配置使能串口和相应的中断处理函数,具体功能需要自己定义
//IAR 7.1
#include "stm32_uart.h"
uint8_t card_ture=0;
uint16_t add_count=0;
uint8_t Key_Data[1]={0};
uint8_t Media_Flag=0;
uint8_t card_code[4]; //[5:1]save the card SN, [0]valid or invalid
uint8_t Temp_Card_Num[4];
uint8_t cardcode_rx_complete = 0;
uint32_t uart_config_record_map[4] = {
0,
UART_CONFIG_UART_MEMORY_ADDR,
FIRMWARE_VERSION_MEMORY_ADDR,
SCHEME_SPECIFIC_MEMORY_ADDR
UartConfig_TypeDef the_uart_config;
void stm32_uart_init(uint8_t uart_port, uint32_t BaudRate)
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
/*Fill the structure of uart init*/
if(uart_port == UART2)
USART_InitStructure.USART_BaudRate = BaudRate;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
/*Enable priph clock*/
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
/*Config gpio as uart pin */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
/*Init uart*/
USART_Init(USART2, &USART_InitStructure);
/*Enable uart*/
/*Clear flags*/
USART_ClearFlag(USART2, USART_FLAG_TC);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
USART_Cmd(USART2, ENABLE);
else if(uart_port == UART1)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
if(the_uart_config.checksum==Parity_No)
USART_InitStructure.USART_WordLength = USART_WordLength_8b; //USART_WordLength_8b
USART_InitStructure.USART_Parity = USART_Parity_No; //USART_Parity_No
else if(the_uart_config.checksum==Parity_Odd)
USART_InitStructure.USART_WordLength = USART_WordLength_9b; //USART_WordLength_9b
USART_InitStructure.USART_Parity = USART_Parity_Odd; //USART_Parity_Odd
else if(the_uart_config.checksum==Parity_Even)
USART_InitStructure.USART_Parity = USART_Parity_Even; //USART_Parity_Even
else
GPIO_InitStructure.GPIO_Pin = UART1_TX;
/*Init uart*/
USART_Init(USART1, &USART_InitStructure);
/*Enable uart*/
//USART_Cmd(USART1, ENABLE);
/*Clear flags*/
USART_ClearFlag(USART1, USART_FLAG_TC);
#if 0
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
//USART_ITConfig(USART1, USART_IT_RXNE | USART_IT_TXE, ENABLE);
#endif
static void stm32_uart_senddatas(uint8_t uart_port, const uint8_t* data, uint16_t len)
uint16_t count;
for(count = 0; count < len; count++)
USART_SendData(USART1, data[count]);
while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
else if(uart_port == UART2)
USART_SendData(USART2, data[count]);
while(USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET);
static uint8_t* uart1_tx_buffer;
static uint8_t uart1_tx_buffer_len;
static uint8_t uart1_tx_buffer_index = 0;
void stm32_uart_pro_poweron(ProComm_TypeDef comm)
USART_ClearFlag(USART1,USART_FLAG_TC); //清除标志位 否则第一位数据丢失
switch(comm)
//USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
void stm32_uart2_senddata(uint8_t uart_port, const uint8_t* data, uint16_t len)
USART_ClearFlag(USART2,USART_FLAG_TC); //清除标志位 否则第一位数据丢失
stm32_uart_senddatas(uart_port, data,len);
void USART1_IRQHandler(void)
if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
USART_ClearITPendingBit(USART1, USART_IT_TXE);
/* Write one byte to the transmit data register */
USART_SendData(USART1, uart1_tx_buffer[uart1_tx_buffer_index++]);
if(uart1_tx_buffer_index == uart1_tx_buffer_len)
/* Disable the USARTz Transmit interrupt */
USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
void USART2_IRQHandler(void)
static uint8_t index = 1;
static uint8_t checksum = 0;
if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)
USART_ClearITPendingBit(USART2, USART_IT_RXNE);
card_code[index] = USART_ReceiveData(USART2);
if(index < 5)
checksum ^= card_code[index++];
else
if(checksum == card_code[5])
else
cardcode_rx_complete = 1;
checksum = 0;
uint8_t index=0;
Key_Data[index] = USART_ReceiveData(USART2);
switch(Key_Data[0])
//if(USART_GetITStatus(USART2, USART_IT_TXE) != RESET)
// USART_ClearITPendingBit(USART2, USART_IT_TXE);
上一篇:STM32f103 看门狗使用
下一篇:STM32f103 定时器配置和中断处理函数
推荐阅读最新更新时间:2024-03-16 15:39
