用stm32的高级定时器TIM1和TIM8产生PWM,需要注意:
1.都有TIM1,但只有flash容量大于256K的大容量单片机才有TIM8
2.高级定时器相对于通用定时器,多了TIM_CtrlPWMOutputs(TIM8, ENABLE);
TIM1产生四路PWM程序:
static void TIM1_GPIO_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9| GPIO_Pin_10 | GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 复用推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
static void TIM1_Mode_Config(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
u16 CCR1_Val = 500;
u16 CCR2_Val = 500;
u16 CCR3_Val = 500;
u16 CCR4_Val = 500;
TIM_TimeBaseStructure.TIM_Period = 999; //当定时器从0计数到999,即为1000次,为一个定时周期
TIM_TimeBaseStructure.TIM_Prescaler = 71;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ; //设置时钟分频系数:不分频
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数模式
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //配置为PWM模式1
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
// TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse = CCR1_Val; //设置跳变值,当计数器计数到这个值时,电平发生跳变
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //当定时器计数值小于CCR1_Val时为高电平
TIM_OC1Init(TIM1, &TIM_OCInitStructure); //使能通道1
TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
TIM_OCInitStructure.TIM_Pulse = CCR2_Val; //设置通道2的电平跳变值,输出另外一个占空比的PWM
TIM_OC2Init(TIM1, &TIM_OCInitStructure); //使能通道2
TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
TIM_OCInitStructure.TIM_Pulse = CCR3_Val; //设置通道3的电平跳变值,输出另外一个占空比的PWM
TIM_OC3Init(TIM1, &TIM_OCInitStructure); //使能通道3
TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
TIM_OCInitStructure.TIM_Pulse = CCR4_Val; //设置通道4的电平跳变值,输出另外一个占空比的PWM
TIM_OC4Init(TIM1, &TIM_OCInitStructure); //使能通道4
TIM_OC4PreloadConfig(TIM1, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM1, ENABLE); // 使能TIM1重载寄存器ARR
TIM_CtrlPWMOutputs(TIM1, ENABLE);
TIM_Cmd(TIM1, ENABLE);
void TIM1_PWM_Init(void)
TIM1_GPIO_Config();
TIM1_Mode_Config();
TIM8产生2路PWM程序:
static void TIM8_GPIO_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_9;
GPIO_Init(GPIOC, &GPIO_InitStructure);
static void TIM8_Mode_Config(void)
u16 CCR1_Val = 500;
u16 CCR2_Val = 500;
u16 CCR3_Val = 500;
u16 CCR4_Val = 500;
TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure);
TIM_OC1Init(TIM8, &TIM_OCInitStructure); //使能通道1
TIM_OC1PreloadConfig(TIM8, TIM_OCPreload_Enable);
TIM_OC2Init(TIM8, &TIM_OCInitStructure); //使能通道2
TIM_OC2PreloadConfig(TIM8, TIM_OCPreload_Enable);
TIM_OC3Init(TIM8, &TIM_OCInitStructure); //使能通道3
TIM_OC3PreloadConfig(TIM8, TIM_OCPreload_Enable);
TIM_OC4Init(TIM8, &TIM_OCInitStructure); //使能通道4
TIM_OC4PreloadConfig(TIM8, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM8, ENABLE); // 使能TIM8重载寄存器ARR
TIM_Cmd(TIM8, ENABLE);
void TIM8_PWM_Init(void)
TIM8_GPIO_Config();
TIM8_Mode_Config();
上一篇:stm32 TIM2 重映射
下一篇:STM32 TIM2通道重映射 PWM 无输出波形
推荐阅读最新更新时间:2024-03-16 15:41
