** File: IIC.c | IIC Communication |
** Version: 1.0
** Description : 430 WRITE AND READ 24C02 VIA IIC BUS
** Author: LightWu
** Date: 2013-4-11
#include
//注意:两次发送间隔必须要有延时,否则不能再次发送,串口发送格式:
unsigned char PTxData[250]; // Pointer to TX data
unsigned char pHead;
unsigned char pTail;
unsigned char pHeadR;
unsigned char pTailR;
unsigned char TXByteCtr;
const unsigned char TxData[] = // Table of data to transmit
0x01,
0x02,
0x03,
0x04,
0x05
unsigned char RxData[] ;
void UartInit(void)
if (CALBC1_1MHZ==0xFF) // If calibration constant erased
while(1); // do not load, trap CPU!!
DCOCTL = 0; // Select lowest DCOx and MODx settings
BCSCTL1 = CALBC1_1MHZ; // Set DCO
DCOCTL = CALDCO_1MHZ;
P3SEL |= 0x30; // P3.4,5 = USCI_A0 TXD/RXD
UCA0CTL1 |= UCSSEL_2; // SMCLK
UCA0BR0 = 104; // 1MHz 9600; (104)decimal = 0x068h
UCA0BR1 = 0; // 1MHz 9600
UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
void UartSend( unsigned char Data )
UCA0TXBUF = Data; // TX -> RXed character
while (!(IFG2&UCA0TXIFG)); // USCI_A0 TX buffer ready?,发送缓冲区空
void IICInit(void)
UCB0CTL1 |= UCSWRST; // Enable SW reset
UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz
UCB0BR1 = 0;
UCB0I2CSA = 0xA0>>1; // Slave Address is ,注意地址需要右移一位,24C02地址为0XA0,故要写入0X50
// 7位地址模式,器件会发送一位读写位,正好8位。
UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
IE2 |= UCB0TXIE; // Enable TX interrupt
IE2 |= UCB0RXIE;
void IICSend( void )
int i;
for(i=3000;i>0;i--); //两次发送间隔必须要有延时,否则不能再次发送
while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition
__bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts
void IICRecv( void )
int i;
UCB0CTL1 &= ~UCTR;
UCB0CTL1 |= UCTXSTT;
int main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P3SEL |= 0x06; // Assign I2C pins to USCI_B0
IICInit();
UartInit();
while (1)
UartSend('A');
PTxData[0] = 1;
PTxData[1] = 'M';
PTxData[2] = 3;
PTxData[3] = 4;
PTxData[4] = 5;
pTail = 2;
IICSend();
UartSend('B');
pHeadR = 0;
pTailR = 3;
IICRecv();
UartSend(RxData[0]);
UartSend(RxData[1]);
UartSend(RxData[2]);
while(1);
// The USCIAB0TX_ISR is structured such that it can be used to transmit any
// number of bytes by pre-loading TXByteCtr with the byte count. Also, TXData
// points to the next byte to transmit.
#pragma vector = USCIAB0TX_VECTOR
__interrupt void USCIAB0TX_ISR(void)
if ( pHead < pTail ) // Check TX byte counter
UCB0TXBUF = PTxData [pHead++ ]; // Load TX buffer
else
pHead = 0;
// UCB0CTL1 |= UCTXSTP; // I2C stop condition,if write finish
IFG2 &= ~UCB0TXIFG; // Clear USCI_B0 TX int flag
__bic_SR_register_on_exit(CPUOFF); // Exit LPM0
#pragma vector = USCIAB0RX_VECTOR
__interrupt void USCIAB0RX_ISR(void)
if ( pHeadR < pTailR ) // Check TX byte counter
RxData[ pHeadR++ ] = UCB0RXBUF; // Move RX data to address PRxData
else
pHeadR = 0;
IFG2 &= ~UCB0RXIFG; // Clear USCI_B0 RX int flag
上一篇:MSP430F249 IIC write and Uart send
下一篇:MSP430F249UART
推荐阅读最新更新时间:2024-03-16 15:46
