驱动-按键-中断模式
eint_drv.c
/*******驱动代码************/
#include #include #include #include #include #include #include #include #include #include #include static struct class *eintdrv_class; static struct class_device *eintdrv_class_dev; volatile unsigned long *gpfcon; volatile unsigned long *gpfdat; volatile unsigned long *gpgcon; volatile unsigned long *gpgdat; /*声明等待队列头,名字为button_waitq*/ static DECLARE_WAIT_QUEUE_HEAD(button_waitq); /* 中断事件标志, 中断服务程序将它置1,eint_drv_read将它清0 */ static volatile int ev_press = 0; struct pin_desc{ unsigned int pin; unsigned int key_val; }; /* 键值: 按下时, 0x01, 0x02, 0x03, 0x04 */ /* 键值: 松开时, 0x81, 0x82, 0x83, 0x84 */ static unsigned char key_val; struct pin_desc pins_desc[4] = { {S3C2410_GPF0, 0x01}, {S3C2410_GPF2, 0x02}, {S3C2410_GPG3, 0x03}, {S3C2410_GPG11, 0x04}, }; /* * 确定按键值 */ static irqreturn_t buttons_irq(int irq, void *dev_id) { struct pin_desc * pindesc = (struct pin_desc *)dev_id; unsigned int pinval; pinval = s3c2410_gpio_getpin(pindesc->pin); if (pinval) { /* 松开 */ key_val = 0x80 | pindesc->key_val; printk("pinval1=%dn", pinval); } else { /* 按下 */ key_val = pindesc->key_val; printk("pinval2=%dn", pinval); } /* 表示中断发生了 */ ev_press=1; /* 唤醒休眠的进程 */ wake_up_interruptible(&button_waitq); return IRQ_RETVAL(IRQ_HANDLED); } static int eint_drv_open(struct inode *inode, struct file *file) { /* 配置GPF0,2为输入引脚 */ //*gpfcon &= ~((3<<4)|(3<<0)); *gpfcon &=~((1<<0)|(1<<2)); /* 配置GPG3,11为输入引脚 */ //*gpgcon &= ~((3<<6)|(3<<22)); *gpgcon &= ~((1<<3)|(1<<11)); /*request_irq(中断类型,响应函数,触发方式,名称,数据)*/ request_irq(IRQ_EINT0, buttons_irq, IRQT_BOTHEDGE, "S2", &pins_desc[0]); request_irq(IRQ_EINT2, buttons_irq, IRQT_BOTHEDGE, "S3", &pins_desc[1]); request_irq(IRQ_EINT11, buttons_irq, IRQT_BOTHEDGE, "S4", &pins_desc[2]); request_irq(IRQ_EINT19, buttons_irq, IRQT_BOTHEDGE, "S5", &pins_desc[3]); return 0; } ssize_t eint_drv_read(struct file *file, char __user *buf, size_t size, loff_t *ppos) { if (size != 1) return -EINVAL; /* 如果没有按键动作, 休眠 */ wait_event_interruptible(button_waitq,ev_press); /* 如果有按键动作, 返回键值 */ copy_to_user(buf, &key_val, 1); ev_press = 0; return 1; } int eint_drv_close(struct inode *inode, struct file *file) { /*free_irq*/ free_irq(IRQ_EINT0,&pins_desc[0]); free_irq(IRQ_EINT2,&pins_desc[1]); free_irq(IRQ_EINT11,&pins_desc[2]); free_irq(IRQ_EINT19,&pins_desc[3]); return 0; } static struct file_operations sencod_drv_fops = { .owner = THIS_MODULE, /* 这是一个宏,推向编译模块时自动创建的__this_module变量 */ .open = eint_drv_open, .read = eint_drv_read, .release = eint_drv_close, }; int major; static int eint_drv_init(void) { major = register_chrdev(0, "eint_drv", &sencod_drv_fops); eintdrv_class = class_create(THIS_MODULE, "eint_drv"); eintdrv_class_dev = class_device_create(eintdrv_class, NULL, MKDEV(major, 0), NULL, "buttons"); /* /dev/buttons */ gpfcon = (volatile unsigned long *)ioremap(0x56000050, 16); gpfdat = gpfcon + 1; gpgcon = (volatile unsigned long *)ioremap(0x56000060, 16); gpgdat = gpgcon + 1; return 0; } static void eint_drv_exit(void) { unregister_chrdev(major, "eint_drv"); class_device_unregister(eintdrv_class_dev); class_destroy(eintdrv_class); iounmap(gpfcon); iounmap(gpgcon); return 0; } module_init(eint_drv_init); module_exit(eint_drv_exit); MODULE_LICENSE("GPL"); eintTest.c #include #include #include #include #include /* thirddrvtest */ int main(int argc, char **argv) { int fd; unsigned char key_val; fd = open("/dev/eintTest", O_RDWR);//O_RDWR 读、写打开。 if (fd < 0) { printf("can't open!n"); } while (1) { read(fd, &key_val, 1); printf("key_val = 0x%xn", key_val); sleep(5); } return 0; } makefile KERN_DIR = /work/system/linux-2.6.22.6 all: make -C $(KERN_DIR) M=`pwd` modules clean: make -C $(KERN_DIR) M=`pwd` modules clean rm -rf modules.order obj-m += eint_drv.o
上一篇:按键-LED
下一篇:中断-按键控制LED灯
