流水灯跑起来了,是不是有点小兴奋,一鼓作气再来玩玩其他的,用PC机写程序,出了问题可以用perror等打印出信息,给调试带来了很大方便,可是板子上没有显示屏,没法打印怎么办?这次就写一个通过串口向PC机串口调试终端打印信息的小程序,方便以后的调试。串口通信的基本知识就不说了哈,网上很多的,直接上代码:
uart.c
1 #include "s3c2410.h"
3 void uart_sendchar(char a)
4 {
5 if(a == 'n'){
6 while( !(UTRSTAT0 & (0x1<<2)) );
7 UTXH0 = 'r';
8 }
9 while( !(UTRSTAT0 & (0x1<<2)) );
10 UTXH0 = a;
11 }
13 void sendstring(const char *str)
14 {
15 while(*str){
16 uart_sendchar(*str);
17 str++;
18 }
19 }
21 void uart_init()
22 {
23 GPHCON = (GPHCON & ~(0xf<<4)) | (0xa<<4);
24
25 ULCON0 = 0x3;
26 UCON0 = 0x5;
27
28 UBRDIV0 = (int)(PCLK/(115200*16)) - 1;
29
30 }
GPHCON配置使用串口0, ULCON0 = 0X3配置串口使用8位数据位,一位停止位,无校验,UCON0 = 0X5设置传输模式,默认时钟使用PCLK。UTXH0为发送buffer, 往其中写数据后发送,UTRSTAT0检测数据线上有无数据,从而控制在一个字符发送完成后再发下一个。
还有注意n的处理,因为windows的回车是rn,所以有单独的判断。
哦,你可能会问这个s3c2410.h在哪里,哦,这个其实是板子带的,就是定义了一堆寄存器地址,完全也可以自己定义。向这种格式:
s3c2410.h
1 /* WOTCH DOG register */
2 #define WTCON (*(volatile unsigned long *)0x53000000)
3 #define WTDAT (*(volatile unsigned long *)0x53000004)
4 #define WTCNT (*(volatile unsigned long *)0x53000008)
39 /*UART registers*/
40 #define ULCON0 (*(volatile unsigned long *)0x50000000)
41 #define UCON0 (*(volatile unsigned long *)0x50000004)
42 #define UFCON0 (*(volatile unsigned long *)0x50000008)
43 #define UMCON0 (*(volatile unsigned long *)0x5000000c)
44 #define UTRSTAT0 (*(volatile unsigned long *)0x50000010)
45 #define UTXH0 (*(volatile unsigned char *)0x50000020)
46 #define URXH0 (*(volatile unsigned char *)0x50000024)
47 #define UBRDIV0 (*(volatile unsigned long *)0x50000028)
48
49
50 /*interrupt registes*/
51 #define SRCPND (*(volatile unsigned long *)0x4A000000)
52 #define INTMOD (*(volatile unsigned long *)0x4A000004)
53 #define INTMSK (*(volatile unsigned long *)0x4A000008)
54 #define PRIORITY (*(volatile unsigned long *)0x4A00000c)
55 #define INTPND (*(volatile unsigned long *)0x4A000010)
56 #define INTOFFSET (*(volatile unsigned long *)0x4A000014)
57 #define SUBSRCPND (*(volatile unsigned long *)0x4A000018)
58 #define INTSUBMSK (*(volatile unsigned long *)0x4A00001c)
59
60 /*external interrupt registers*/
61 #define EINTMASK (*(volatile unsigned long *)0x560000a4)
62 #define EINTPEND (*(volatile unsigned long *)0x560000a8)
63
64 #define EXTINT2 (*(volatile unsigned long *)0x56000090)
65
66 /*clock registers*/
67 #define LOCKTIME (*(volatile unsigned long *)0x4c000000)
68 #define MPLLCON (*(volatile unsigned long *)0x4c000004)
69 #define UPLLCON (*(volatile unsigned long *)0x4c000008)
70 #define CLKCON (*(volatile unsigned long *)0x4c00000c)
71 #define CLKSLOW (*(volatile unsigned long *)0x4c000010)
72 #define CLKDIVN (*(volatile unsigned long *)0x4c000014)
73
74
75 /*PWM & Timer registers*/
76 #define TCFG0 (*(volatile unsigned long *)0x51000000)
77 #define TCFG1 (*(volatile unsigned long *)0x51000004)
78 #define TCON (*(volatile unsigned long *)0x51000008)
79 #define TCNTB0 (*(volatile unsigned long *)0x5100000c)
80 #define TCMPB0 (*(volatile unsigned long *)0x51000010)
81 #define TCNTO0 (*(volatile unsigned long *)0x51000014)
82 /* frequecy */
^M
83 #define FCLK (202800000)
84 #define HCLK (FCLK/2)
85 #define PCLK (FCLK/4)
注意要用volatile 和 unsigned 来保证优化和移位不会处差错。
上一篇:s3c2410--watchdog
下一篇:S3c2410裸板程序入门---单按键(一)
推荐阅读最新更新时间:2024-11-19 15:48
设计资源 培训 开发板 精华推荐
- LT1187 的典型应用 - 低功率视频差动放大器
- AD8367-EVAL,用于 AD8367 500 MHz、带 AGC 检测器的线性 dB VGA 评估板
- 使用 Analog Devices 的 LT1587CM-3.45 的参考设计
- Digispark,最小系统采用Tiny85 MCU
- AD8039ART-EBZ,适用于双通道、高速运算放大器的通用评估板,采用 8 引脚 SOT-23 封装
- 使用外部基准电流的 LT3088EM 线性稳压器的典型应用
- 【电子竞赛】21年电赛F题-智能送药小车
- AD9289-65EB,用于 AD9289 四通道、8 位、65 MSPS、串行 LVDS ADC 转换器的评估板
- LT8631IFE 5V、低纹波 1A 降压转换器的典型应用电路
- Si4739-EVB,Si4739 高性能、76 至 108 MHz 数字无线电调谐器评估板
- 希润医疗孟铭强:手功能软体机器人,让脑卒中患者重获新生
- 柔灵科技陈涵:将小型、柔性的脑机接口睡眠设备,做到千家万户
- 微灵医疗李骁健:脑机接口技术正在开启意识与AI融合的新纪元
- USB Type-C® 和 USB Power Delivery:专为扩展功率范围和电池供电型系统而设计
- 景昱医疗耿东:脑机接口DBS治疗技术已实现国产替代
- 首都医科大学王长明:针对癫痫的数字疗法已进入使用阶段
- 非常见问题解答第223期:如何在没有软启动方程的情况下测量和确定软启动时序?
- 兆易创新GD25/55全系列车规级SPI NOR Flash荣获ISO 26262 ASIL D功能安全认证证书
- 新型IsoVu™ 隔离电流探头:为电流测量带来全新维度
- 英飞凌推出简化电机控制开发的ModusToolbox™电机套件
