PIC16F877A串口发送字符串问题
发布者:数字思维最新更新时间:2020-02-10 来源: eefocus关键字:PIC16F877A  串口发送  字符串 手机看文章 扫描二维码
随时随地手机看文章
PIC16F877A串口发送,查询方式,就为了调出这个费了我一天时间,原来是串口芯片电压问题,现总结如下:
1、注意232串口芯片供电电压,有5V和3.3V的
2、注意TXD、RXD接线,单片机的TXD接232芯片的R2OUT,单片机的RXD接232芯片的T2IN
3、注意ESP8266的UTXD接MCU的RX,URXD接MCU的TX
4、注意ESP8266的UTXD接232的T2IN,URXD接232的R2OUT
5、串口波特率设置成9600
6、注意连接线的可靠性,如果用线连的话一定要检查线和插座是否稳定连接
PIC16F877A串口发送
//以下是串口发送程序
#include
#define ucharunsigned char
#define uint unsigned int
__CONFIG(0x3B32);
void delay2ms(uint x)
uint a,b;
for(a=x; a>0; a--)
for(b=152; b>0; b--);
void UART_SendByte(unsigned char dat)
TXREG=dat;
while(TRMT==0);
void serial_init()
TRISC=0xbf;//设置RX为输入,TX为输出
TXSTA=0x24;
RCSTA=0x80;
SPBRG=0x33;//本人使用的是8MHz晶振,9600=8000000/(16*(X+1))->X=51->X=0x33
GIE=1;
PEIE=1;
RCIE=1;
void main()
serial_init();
while(1)
UART_SendByte(0x31);
UART_SendByte(0x32);
UART_SendByte(0x33);
delay2ms(500);
//以下是MCU发送AT命名给ESP8266的程序
#include
#define uchar unsigned char
#defineLEDRD1
__CONFIG(0x3B32);
#define LED_OPEN() (LED=1)
#define LED_CLOSE() (LED=0)
#defineCPU_FOSC8000000
#defineBAUD9600
unsigned char* LYMS="AT+CWMODE=3r";
unsigned char* SZLY="AT+CWSAP="ESP8277_CYT","1234567890",11,3r";
unsigned char* RST="AT+RSTr";
unsigned char* LCAP="AT+CWLAPr";
unsigned char* SZDLJ="AT+CIPMUX=1r";
unsigned char* KQFU="AT+CIPSERVER=1,5000r";
unsigned char* FSSJ="AT+CIFSRr";
uint a,b;
for(a=x; a>0; a--)
void sys_init()
TRISD=0x00;//设置PORTD口为输出
void usart_init()
TXSTA=0x24;
RCSTA=0x80;
GIE=1;
PEIE=1;
RCIE=1;
void usart0_putchar(unsigned char data)
while (!TRMT);
TXREG = data;
void print(unsigned char* p_string)
while (*p_string)
if (*p_string != 'r')
usart0_putchar(*p_string);
else
usart0_putchar('r');
usart0_putchar('n');
p_string++;
void send_command()
print(LYMS);delay2ms(500);delay2ms(500);
print(SZLY);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);
print(RST);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);
print(LCAP);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);
print(SZDLJ);delay2ms(500);delay2ms(500);
print(KQFU);delay2ms(500);delay2ms(500);
print(FSSJ);delay2ms(500);delay2ms(500);
void main()
sys_init();
usart_init();
send_command();
while(1)
PORTD = 0xff;
delay2ms(500);
PORTD = 0x00;
delay2ms(500);
//以下是MCU发送AT命名给ESP8266的程序,并接收命令、解析并作出反应
#include
unsigned char RX_Buffer[32];
unsigned char RX_CNT=0;
#define LED1RD1
#define LED2RD2
#define LED3RD3
__CONFIG(0x3B32);
#define LED1_OPEN() (LED1=1)
#define LED1_CLOSE() (LED1=0)
#define LED2_OPEN() (LED2=1)
#define LED2_CLOSE() (LED2=0)
#define LED3_OPEN() (LED3=1)
#define LED3_CLOSE() (LED3=0)
#defineBAUD9600
unsigned char* SZLY="AT+CWSAP="ESP8277_TYC","1234567890",11,3r";
uint a,b;
for(a=x; a>0; a--)
void sys_init()
void usart_init()
TRISC=0x80;//设置RX为输入,TX为输出
TXSTA=0x24;
RCSTA=0x90;
RCIE=0x01;
TXEN=0x01;
TXIE=0x01;
PEIE=0x01; //外部中断使能
GIE=1;//总中断使能
while (!TRMT);
TXREG = data;
while (*p_string)
else
p_string++;
void send_command()
print(LYMS);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);
print(SZDLJ);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);
print(KQFU);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);
print(FSSJ);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);delay2ms(500);
void interrupt usart(void)
if(RCIE&&RCIF)
//TXREG = RCREG;
RX_Buffer[RX_CNT] = RCREG;
if(RX_Buffer[0]==0x45)
RX_CNT++;
else
RX_CNT=0;
if(RX_CNT>=10)
if(RX_Buffer[0]==0x45&&RX_Buffer[1]==0x53&&RX_Buffer[2]==0x50)
if(RX_Buffer[4]==0x4C&&RX_Buffer[5]==0x45&&RX_Buffer[6]==0x44)
if(RX_Buffer[7]==0x31)
if(RX_Buffer[3]==0x4B)
LED1_OPEN();
if(RX_Buffer[3]==0x47)
LED1_CLOSE();
RX_CNT=0;
void main()
sys_init();
usart_init();
send_command();
LED1_OPEN();
LED2_OPEN();
LED3_OPEN();
while(1);
关键字:PIC16F877A  串口发送  字符串 引用地址:PIC16F877A串口发送字符串问题
上一篇:怎样解决pic单片机读修改写问题
下一篇:PIC单片机模拟异步串行通讯UART源程序
推荐阅读最新更新时间:2024-11-20 10:54
PIC16F877A和AVR的单片机的PWM输出程序
//在PICC编译器主,调试通过,PIC16F877A的PWM信号输出 #include pic.h #define uchar unsigned char #define uint unsigned int __CONFIG(0x1832); void delay() { uint k; for(k=0;k 5000;k++); } void main() { uchar k; T2CON=0X04; //开定时器2 CCPR1L=0X0F; //PWM匹配初值 CCP1CON=0X3C; //设置CCP1 模块为PWM 工作方式,且其工作循环 PR2=0XFF; //设置PWM 的工作周期 TRI
[单片机]
飞思卡尔MC9S12G64串口发送接收驱动
因为之前刚入职,对串口调试不了解,下面整理一下书上的串口程序。 移植性还比较强 使用说明:MC9S12系列的串口有两种查询方式 1》使用中断方式查询 2》在主函数中使用轮询的方式的方法进行查询 这两种方法在下面函数中都有体现,需要在用的时候注意分别提取 主要是初始化的SCI1CR2的寄存器配置和调用中断的时候,注意串口1的中断号是VectorNumber_Vsci1 21 注意串口0的中断号是VectorNumber_Vsci0 20
[单片机]
PIC16F877A单片机(如何写 配置字)
1 MPLAB X V5.0,编译器为XC8(V2.0) 单击production—set Configuration Bit----点击 generate source code to output ----复制生成内容到main函数 // PIC16F877A Configuration Bit Settings // 'C' source line config statements // CONFIG #pragma config FOSC = EXTRC // Oscillator Selection bits (RC oscillator) #pragma config WDTE = O
[单片机]
<font color='red'>PIC16F877A</font>单片机(如何写 配置字)
51单片机实现通过串口用delay延时方式发送一串数据
一、使用proteus绘制简单的电路图,用于后续仿真 二、编写程序 /******************************************************************************************************************** ---- @Project: USART ---- @File: main.c ---- @Edit: ZHQ ---- @Version: V1.0 ---- @CreationTime: 20200713 ---- @ModifiedTime: 20200713 ----
[单片机]
51单片机实现通过<font color='red'>串口</font>用delay延时方式<font color='red'>发送</font>一串数据
基于PIC16F877A单片机的一种车载红外夜视仪设计
0 引言 随着汽车市场的快速发展和安防意识的日益强化,人们对汽车安全保障技术的要求越来越高,而现有汽车照明系统在雪夜、雪天或大雾等能见度较低情况下视距不远、效果不佳的弊病成为汽车行驶的安全隐患之一。更严重的是在夜晚行车时,驾驶员通常会被对方车辆的灯光干扰出现盲区,容易发生车祸。夜视系统却可以在黑暗中帮助驾驶员导航,使驾驶员在有灯光和黑暗两种情况下都能看清驾驶环境。因此开发一种结构简单、性能稳定、可靠性好、适用性强的汽车红外夜视系统,具有重要的市场应用前景。 1 系统总体设计 1)系统原理 根据工作原理的不同,红外夜视系统分为被动红外夜视系统和主动红外夜视系统。主动红外夜视系统利用其所携带的红外光源主动照射目标,由光学系
[单片机]
基于<font color='red'>PIC16F877A</font>单片机的一种车载红外夜视仪设计
51单片机中用中断方式实现串口数据发送与接收
/* Description:用中断方式实现串口数据发送 Author:Jcy Date:2012-5-2 */ #include reg52.h #define uint unsigned int #define uchar unsigned char uchar receive_ser; //串口接收到的数据 uchar flag=0; uchar receivebuf = Jcy ; uchar i=0; uchar j; void init_ser() { TMOD=0X20;//定时器1工作在方式2 TH1=0XFD; TL1=0XFD; //波特率9600,51单片机大多用这个 TR
[单片机]
空数组和空字符串的判定
空数组是不含任何元素的数组,他的基本特征是数组长度是否为0,为0则为空,非0则非空。8.0以前就是这样判定的。以下是两种方法的比较。 1. 空字符串是不含任何字符的字符串,相当C语言中 新增的空字符串VI是个多态VI,共可以检测5种数据类型。 String,path,variant,picture 和DSC TAG
[测试测量]
空数组和空<font color='red'>字符串</font>的判定
Labview串口程序中字符串与其它类型数据的转换问题
Labview的串口只能传送字符串类型的数据,所以要把数值型数据进行收发要进行数据类型转换 数值型数据 字符串数据 ------ 数据发送--------- 接收到的字符串 数值型数据 原理看似很简单,但是在实际的执行过程中却碰到了很多问题 现象1: 用单片机向Labview串口发送数据,在Lv中经过字符串至字节数组转换,再索引数组即可得到发送的数值,跟程序中的大小相符,没有出现ASCII码格式过来捣乱的情况 但是如果由Lv向单片机发送数据,按照逆向思维,先将数据转换至字符串,然后再写入缓冲区,单片机接收到的却是ASCII码,而且是0~9的ASCII码,不知道哪个地方出了问题
[测试测量]
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
