简介:用TMR0实现定时查询。任何带中断的PIC上都可以实现。可用此法扩展多个串口。
;| Implement duplex USART base on normal I/O pin |
;| Using TIMER0 interrupt for bit timing |
;| Tested on PIC16F83 running at 4MHz |
;| Written by Paul Zhang, Microchip Tech Inc |
;| 6 Aug, 2000 |
;| All rights reserved |
errorlevel -302 ;no bank warning
errorlevel -301 ;no default file warning
list p=16F83 ;define processor
#include __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC ;code protect = OFF ;watchdog = OFF ;power-up delay timer = ON ;oscillator mode = XT ;=============================== ;define RAM variables cblock 0x0c ;GPR start from 0x0c w_temp ;W context saving during interrupt status_temp ;STATUS context saving during interrupt pclath_temp ;PCLATH context saving during interrupt USART_F ;containing flags for USART RX_BUFF ;USART received data buffer TX_BUFF ;USART transmitting data buffer RX_SLICE ;RX bit-timing control TX_SLICE ;TX bit-timing control RX_bcnt ;RX received bit counting TX_bcnt ;TX transmitting bit counting RX_STA ;RX STATE-MACHINE controller TX_STA ;TX STATE-MACHINE controller endc ;=============================== ;pre-definition for readability #define RX_PIN PORTA,2 ;assign RX pin #define TX_PIN PORTA,3 ;assign TX pin #define TXEN USART_F,0 ;USART transmit enable #define TXBUSY USART_F,1 ;USRAT transmit is in progress #define RXBF USART_F,2 ;USART receive buff full #define RXBUSY USART_F,3 ;USART receive is in progress #define RX_ERR USART_F,4 ;USART receive error #define TX_ERR USART_F,5 ;USART transmit error ;=============================== ;define constant #define OSC_FREQ .4000 ;oscillator frequency in KHz #define BAUDRATE .2400 #define TMR0CONST .118 ;256-OSC_FREQ*1000/4/(BAUDRATE*3) + 2 ;=============================== ;for my personal style #define skp0 btfsc #define skp1 btfss ;********************************************************************** ORG 0x000 clrwdt goto MAIN ; go to beginning of program ;======================================= ;Interrupt service routine ORG 0x004 ; interrupt vector location movwf w_temp ; save off current W register contents movf STATUS,w ; move status register into W register banksel status_temp movwf status_temp ; save off contents of STATUS register movf PCLATH,w movwf pclath_temp ; save off contents of PCLATH banksel INTCON ;select bank skp0 INTCON,T0IF ;test for TMR0 interrupt goto tmr0IntStart ;do TMR0 ISR ;here test for any other interrupt source goto int_end tmr0IntStart ;TIMER0 interrupt service bcf INTCON,T0IF ;clear T0IF ;====== start of RX ======= movlw high($) movwf PCLATH ;set PCLATH before PCL change movf RX_STA,w ;get the state value for RX andlw 0x03 ;for safeguard purpose addwf PCL,f ;switch to STATE goto rxStartChk ;check for START bit goto rxReceiveBit ;receive DATA bit goto rxIdle ;wait for idle goto rxEnd ;do nothing rxStartChk ;check for START bit skp0 RX_PIN ;test RX pin for START bit goto rxEnd ;not found ;start bit found. do following movlw .8 movwf RX_bcnt ;count for 8 bits incoming data movlw .4 movwf RX_SLICE ;wait 4 time-slice for 1st data bit movlw .1 movwf RX_STA ;switch to STATE 1 for 1st data bit sampling goto rxEnd rxReceiveBit ;receive DATA bit decfsz RX_SLICE,f ;wait of bit timing goto rxEnd ;time to sample incoming data bit rrf RX_BUFF,f ;right shift for new bit space bcf RX_BUFF,7 ;pre-set to 0 skp0 RX_PIN ;incoming data bit test bsf RX_BUFF,7 ;set if data bit = 1 movlw .3 ;3 slice for data bit timing movwf RX_SLICE ;bit timing for next data bit decfsz RX_bcnt,f ;see if 8-bit completed goto rxEnd ;bit receive completed, do follwoing movlw .2 movwf RX_STA ;set to STATE 2 for idle waiting bsf RXBF ;set receive buffer full movf RX_BUFF,w ;display data on PORTB movwf PORTB goto rxEnd rxIdle ;wait for idle skp0 RX_PIN ;try to find STOP bit clrf RX_STA ;back to STATE 0 for next byte goto rxEnd ;====== End of RX ========= rxEnd ;====== start of TX ======= ;do TX, if transmit is engaged skp1 TXEN ;skip if TXEN set, do TX goto tmr0IntEnd ;not in transmit mode movf TX_SLICE,f ;see if in bit-timing delay skpnz ; goto txDo ;bit-timing completed decfsz TX_SLICE,f ;keep bit-timing delay goto txEnd txDo ;Transmit STATE-MACHINE control movlw high($)
上一篇:PIC16F877A串口发送字符串问题
下一篇:PIC16f877A AD转换LED显示8位值
推荐阅读最新更新时间:2024-11-09 01:25
设计资源 培训 开发板 精华推荐
- DC2364A,用于具有集成终端的 LTC2873 单总线 RS232/RS485 多协议收发器的演示板
- 用于工业控制的 16 位 DAC
- Openpilot:一个Github上星标49.2k、开源的高级驾驶员辅助系统
- Mini TPS62130
- OP113ESZ-REEL 超低噪声、单电源仪表放大器的典型应用
- STR-NCV8163-NCP163-EVK:Strata Enabled NCV8163/NCP163 - 250mA LDO,具有 1.2V 至 5.3V 的固定输出电压
- LT3755EUD-2 降压模式 1.4A LED 驱动器的典型应用电路
- LTC2862ACS8-1 PROFIBUS 兼容线路接口的典型应用
- LTC3624IMSE-2 可调输出电压、2A 同步降压稳压器、同步至 500kHz、强制连续模式的典型应用
- OP213ESZ-REEL7 假接地发生器的典型应用
