word文档链接:http://download.csdn.net/detail/mjlsuccess/6031351,免费的
工程连接:http://download.csdn.net/detail/mjlsuccess/6202155
/** @date 2013/8/28
@author Mei Jilin
@brief ADC1的配置完成3通道的数据采集
@attention
1 ----------- adc_config(); //配置adc
2 ----------- adc_start(); //启动adc,开始转换
3 ----------- get_ChannelValue(ADC_Channel_x); //读取相应通道的adc值
#include "stm32f10x.h"
#include "adc.h"
#define CH_NUM 3 //要使用的ADC通道数
static uint16_t ad_value[CH_NUM]={0};
/** @para none
* @ret none
* @brief adc对应的gpio初始化
void adc_gpio_init(void)
GPIO_InitTypeDef gpio;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
gpio.GPIO_Mode = GPIO_Mode_AIN; //配置为模拟输入
gpio.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2; //ADC1 --channel0,1,2
gpio.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&gpio);
/** @para none
* @ret none
* @brief adc配置
void adc_init(void)
ADC_InitTypeDef adc;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
RCC_ADCCLKConfig(RCC_PCLK2_Div6); //设置ad时钟为72/6=12M,ad最大时钟频率为14M
ADC_DeInit(ADC1);
adc.ADC_Mode = ADC_Mode_Independent; //工作在独立模式
adc.ADC_ContinuousConvMode = ENABLE; //连续转换模式
adc.ADC_DataAlign = ADC_DataAlign_Right; //数据右对齐
adc.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//不使用外部触发
adc.ADC_NbrOfChannel = CH_NUM ; //转换3个通道
adc.ADC_ScanConvMode = ENABLE; //连续转换模式
ADC_Init(ADC1,&adc);
//设定指定的ADC通道组,设置转化顺序和采样时间
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_55Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_55Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_55Cycles5);
//开启adc的DMA
ADC_DMACmd(ADC1,ENABLE);
//使能ADC1
ADC_Cmd(ADC1, ENABLE);
/* Enable ADC1 reset calibaration register */
ADC_ResetCalibration(ADC1); //重新校准
/* Check the end of ADC1 reset calibration register */
while(ADC_GetResetCalibrationStatus(ADC1)); //等待重新校准完成
/* Start ADC1 calibaration */
ADC_StartCalibration(ADC1); //开始校准
/* Check the end of ADC1 calibration */
while(ADC_GetCalibrationStatus(ADC1)); //等待校准完成
/** @para none
* @ret none
* @brief 配置dma
void adc_dma_init()
DMA_InitTypeDef dma;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
DMA_DeInit(DMA1_Channel1);
dma.DMA_PeripheralBaseAddr = (u32)&(ADC1->DR); //DMA对应的外设基地址
dma.DMA_MemoryBaseAddr = (u32)&ad_value; //内存存储基地址
dma.DMA_DIR = DMA_DIR_PeripheralSRC;//DMA的转换模式为SRC模式,由外设搬移到内存
dma.DMA_M2M = DMA_M2M_Disable; //M2M模式禁用
dma.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//定义外设数据宽度为16位
dma.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //DMA搬移数据尺寸,HalfWord就是为16位
dma.DMA_BufferSize = CH_NUM; //DMA缓存大小CH_NUM个
dma.DMA_MemoryInc = DMA_MemoryInc_Enable; //接收一次数据后,目标内存地址后移
dma.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //接收一次数据后,设备地址禁止后移
dma.DMA_Mode = DMA_Mode_Circular; //转换模式,循环缓存模式。
dma.DMA_Priority = DMA_Priority_High; //DMA优先级高
DMA_Init(DMA1_Channel1,&dma);
/** @para none
* @ret none
* @brief 完成adc配置
void adc_config(void)
adc_gpio_init();
adc_dma_init();
adc_init();
/** @para none
* @ret none
* @brief 启动adc,开始转换
void adc_start(void)
/* Start ADC1 Software Conversion */
ADC_SoftwareStartConvCmd(ADC1, ENABLE); //连续转换开始,ADC通过DMA方式不断的更新RAM区。
DMA_Cmd(DMA1_Channel1,ENABLE);
/** @para ADC_Channel --- (ADC_Channel0 ~ ADC_Channel17)
* @ret ADC_Channel_x 的ADC值
uint16_t get_ChannelVale(uint8_t ADC_Channel)
uint16_t ret = 0;
switch(ADC_Channel)
case ADC_Channel_0:
ret = ad_value[0];
break;
case ADC_Channel_1:
ret = ad_value[1];
break;
case ADC_Channel_2:
ret = ad_value[2];
break;
return ret;
上一篇:STM32+ULN2003驱动步进电机
下一篇:STM32之外部中断 EXTI
推荐阅读最新更新时间:2024-11-11 18:31
设计资源 培训 开发板 精华推荐
- AD8657ARMZ-RL同相运算放大器配置的典型应用电路
- USB-SDP-CABLEZ,串行接口板提供 USB 连接,USB 2.0 高速连接到计算机
- NCV47411PAAJGEVB,双通道可调低压差稳压器
- LT3663EMS8E、1.2V 降压转换器的典型应用
- ADR365A 5 Vout 低功耗、低噪声电压基准的典型应用,具有灌电流/拉电流能力
- EPT1020xS,QorIQ PowerPC 板,紧凑、经济高效且功能强大的平台,用于开发高性能网络控制设备
- CGD15SG00D2,第 3 代 (C3M) SiC MOSFET 的栅极驱动器参考设计
- LM317、5V电子关断稳压器的典型应用
- LTC6262IDC SAR ADC 驱动器、运算放大器的典型应用
- LT6657BHMS8-2.5 1.5V 最小电源电压的典型应用电路
