内核移植(3)修改MTD分区
发布者:梦想启航最新更新时间:2023-08-28 来源: elecfans关键字:内核移植 手机看文章 扫描二维码
随时随地手机看文章
修改MTD分区,在arch/arm/plat-s3c24xx/common-smdk.c修改:
static struct mtd_partition smdk_default_nand_part[] = {
        [0] = {
                .name   = "Boot Agent",
                .size   = SZ_16K,
                .offset = 0,
        [1] = {
                .name   = "S3C2410 flash partition 1",
                .offset = 0,
                .size   = SZ_2M,
        [2] = {
                .name   = "S3C2410 flash partition 2",
                .offset = SZ_4M,
                .size   = SZ_4M,
        [3] = {
                .name   = "S3C2410 flash partition 3",
                .offset = SZ_8M,
                .size   = SZ_2M,
       [4] = {
                .name   = "S3C2410 flash partition 4",
                .offset = SZ_1M * 10,
                .size   = SZ_4M,
        [5] = {
                .name   = "S3C2410 flash partition 5",
                .offset = SZ_1M * 14,
                .size   = SZ_1M * 10,
        [6] = {
                .name   = "S3C2410 flash partition 6",
                .offset = SZ_1M * 24,
                .size   = SZ_1M * 24,
        [7] = {
                .name   = "S3C2410 flash partition 7",
                .offset = SZ_1M * 48,
                .size   = SZ_16M,
修改为:
        [0] = {
               .name   = "kernel",//kernel
               .size   = SZ_2M,
               .offset = 0,
        [1] = {
               .name   = "jffs2",
               .offset = MTDPART_OFS_APPEND,
               .size   = SZ_8M,
        [2] = {
                .name   = "yaffs",
                .size   = MTDPART_SIZ_FULL,
/*      [0] = {
                .size   = SZ_16K,
                .offset = 0,
       [1] = {
                .offset = 0,
                .size   = SZ_2M,
        [2] = {
                .offset = SZ_4M,
                .size   = SZ_4M,
        [3] = {
                .offset = SZ_8M,
                .size   = SZ_2M,
        [4] = {
                .size   = SZ_4M,
        [5] = {
                .size   = SZ_1M * 10,
        [6] = {
                .size   = SZ_1M * 24,
        [7] = {
                .size   = SZ_16M,
U-Boot控制界面,看到内核的启动信息如下:
loop: module loaded
dm9000 Ethernet Driver
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
BAST NOR-Flash Driver, (c) 2004 Simtec Electronics
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2410-nand s3c2410-nand: Tacls=3, 30ns Twrph0=7 70ns, Twrph1=3 30ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 3 MTD partitions on "NAND 64MiB 3,3V 8-bit":
[1] [2]
关键字:内核移植 引用地址:内核移植(3)修改MTD分区
上一篇:内核移植(4)移植yaffs文件系统
下一篇:内核移植(1)首次生成uImage映象文件
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
