什么是fsk调制 fsk调制是什么意思
最新更新时间:2011-09-13来源: 互联网关键字:fsk  调制 手机看文章 扫描二维码
随时随地手机看文章
什么是fsk调制?  fsk调制是什么意思?
数字调频又称移频键控,简记为FSK,它是载波频率随数字信号而变化的一种调制方式。利用基带数字信号离散取值特点去键控载波频率以传递信息的一种数字调制技术。除具有两个符号的二进制频移键控之外,尚有代表多个符号的多进制频移键控,简称多频调制。一种用多个载波频率承载数字信息的调制类型。最常见的是用两个频率承载二进制1和0的双频FSK系统。
FSK (频移键控) ,也称为移频调制和移频信号。 Frequency Shift Keying is a data signal converted into a specific frequency or tone in order to transmit it over wire, cable, optical fiber or wireless media to a destination point.频移键控是一个数据信号转换成特定频率或音调,以便将其转交超过电线,电缆,光纤或无线媒介,以一个目的地一点。 The history of FSK dates back to the early 1900s, when this technique was discovered and then used to work alongside teleprinters to transmit messages by radio (RTTY).历史上的FSK可以追溯到20世纪初叶,当这一技术被发现,然后用并肩工作, teleprinters传递信息,由电台( rtty ) 。 But FSK, with some modifications, is still effective in many instances including the digital world where it is commonly used in conjunction with computers and low speed modems.但在FSK ,作出一些修改,但仍然有效,在许多事例中,包括数位世界中,这是常用的结合电脑和低速调制解调器。 In fact, the contributions of FSK are much more far reaching.事实上,在捐款的FSK更为深远。 For example, the principle of FSK has laid the path to the development of other similar techniques such as the Audio Frequency Shift Keying (AFSK) and Multiple Frequency Shift Keying (MFSK) just to name a few.举例来说,原则上的FSK奠定了发展的路径其他类似技术,如声频移键控( afsk )及多频移键控(多进制频移键控)刚刚仅举几例。
In Frequency Shift Keying, the modulating signals shift the output frequency between predetermined levels.在频移键控,调制信号转移输出频率之间预定的水平。 Technically FSK has two classifications, the non-coherent and coherent FSK.技术上的FSK有两个分类,非相干和相干的FSK 。 In non-coherent FSK, the instantaneous frequency is shifted between two discrete values named mark and space frequency, respectively.在非相干的FSK ,瞬时频率是转移双方离散值命名为马克和空间频率,分别为。 On the other hand, in coherent Frequency Shift Keying or binary FSK, there is no phase discontinuity in the output signal.在另一方面,在相干频移键控或二进制的FSK ,是没有间断期在输出信号。
In this digital era, the modulation of signals are carried out by a computer, which converts the binary data to FSK signals for transmission, and in turn receives the incoming FSK signals and converts it to corresponding digital low and high, the language the computer understands best.在这数字化时代,调制的信号是由一台电脑,而转换为二进制数据的FSK信号的传输,从而获得来袭的FSK信号转换为相应的数字低及高,语言的计算机理解最好的。
There are Frequency Shift Keying standards, used in various countries across the globe.有频移键控标准,可应用在许多国家,在全球各地。 They are the ETSI FSK, Bellcore FSK, BT (British Telecom) FSK and CCA (Cable Communication Association) FSK.他们是欧洲电信标准协会的FSK ,贝尔的FSK ,英国电信(英国电信)的FSK及文建会(电缆通信协会)的FSK 。 The Bellcore standard is used in United States, Australia, China, Hong Kong and Singapore.在贝尔标准是用来在美国,澳大利亚,中国,香港和新加坡。 It uses the 1200 baud Bell 202 tone modulation and the first bit of data is transferred after receiving the first ring tone.它使用1200波特率贝尔202音频调制和第一位元的资料传送接收后首铃声。
The BT FSK or British Telecom Frequency Shift Keying is an original standard that was developed by the British Telecom.英国电讯的FSK或英国电信的频移键控,是原来的标准,这是由英国电信公司。 This standard wakes up the display with a line reversal and transmits the data as CITT V23 modem tones, a format similar to MDMF.这个标准醒来,展示同一条线扭转和传递数据,作为citt v23调制解调器铃声,格式相似mdmf 。 British Telecom itself uses this standard as well as some wireless networks such as the late Lonica and some cable companies as well.英国电信本身使用这个标准,以及部分无线网络,如已故lonica及一些有线电视公司以及。 More details about the British Telecom Frequency Shift Keying standards can be obtained from the document Designing Caller Identification Delivery Using XR-2211 for B.T.更详细了解英国电信频移键控标准,可以直接从该文件中的设计来电识别交付使用XR型- 2211为英国电信 or the Supplier Information Notes (SINs) 227 and 242.或供应商的资料,笔记(罪过) 227和242 。
In Cable Communication Association standard, data is sent after a short first ring, either as Bell 202 or V23 tones.在有线通信协会标准,使数据发送经过短暂的第一环,无论是贝尔202或v23铃声。 Here the transport layer is more like Bellcore even though the data format looks much like British Telecom's, because of this, European or North American kits are more likely to detect it.这里交通层更象是贝尔即使数据格式看起来很像英国电讯公司的,正因为如此,欧洲或北美袋较容易探测出来。
The basic principle of Frequency Shift Keying is at least a century old.基本原则的频移键控是至少一个世纪老人。 Despite its age, FSK has successfully maintained its use during more modern times and has adapted well to the digital domain, and continues to serve those that need to transfer data via computer, cable, or wire.尽管其年龄, FSK信号已成功地保持了其使用过程中更现代的时代,并已适应良好,数位领域,并继续服务于那些需要传输的数据通过计算机,电缆,电线。 There is no doubt that FSK will be around as long as there is a need to transmit information in a highly effective and affordable manner.这是毫无疑问的FSK会期约,只要有需要,以传递信息,在一个高效和负担得起的方式。 FSK就是这个意思。
关键字:fsk  调制 编辑:神话 引用地址:什么是fsk调制 fsk调制是什么意思
上一篇:FSK解调电路图
下一篇:pll环路滤波器是什么意思
推荐阅读最新更新时间:2023-10-12 20:29
如何为智能电表选择适合的PLC调制解调器方案
  近年来,以智能电表为核心的智能电网成为欧美日中等诸多国家竞相发展的一个热点领域。欧盟委员强制要求2022年前所有欧盟成员国的电表都替换为智能仪表。美国也计划在每个家庭都安装智能仪表。中国在2009年5月开始提出构建坚强智能电网的构想,准备投资高达4万亿元,计划到2020年基本实现构想。在此推动下,电网技术面临着一场重要的革命,而不只是简单的技术演进。 表1:传统电网与新的智能电网之间的简单对比   在智能电网中,智能电表发挥关键的作用,可以使用户与电力系统之间实现互动。如一方面帮助电力机构精确了解用户的用电规律,为高峰用电或低谷用电设定差异化的电价;另一方面,用户也可以合理调整自己的用电计划,从而优化电费支出。从功能
[嵌入式]
MAX2452 工作2.7V_5mA电流的SSB调制
调制器是邻频调制器的简称,也常被称作射频调制器或电视调制器,是前端电视机房的主要设备之一.
[模拟电子]
调制电路与解调电路详解(一)
一、调幅电路 调幅电路是把调制信号和载波信号同时加在一个非线性元件上(例如晶体二极管或三极管)经非线性变换成新的频率分量,再利用谐振回路选出所需的频率成分。 调幅电路分为二极管调幅电路和晶体管基极调幅、发射极调幅及集电极调幅电路等。 通常,多采用三极管调幅电路,被调放大器如果使用小功率小信号调谐放大器,称为低电平调幅;反之,如果使用大功率大信号调谐放大器,称为高电平调幅。 在实际中,多采用高电平调幅,对它的要求是:(1)要求调制特性(调制电压与输出幅度的关系特性)的线性良好;(2)集电极效率高;(3)要求低放级电路简单。 1、基极调幅电路 图1是晶体管基极调幅电路,载波信号经过高频变压器T1加到BG的基极上,低频调制信号通过一个电
[模拟电子]
<font color='red'>调制</font>电路与解调电路详解(一)
基于IGBT的固态脉冲调制器设计
   在雷达发射机脉冲调制器中,广泛采用的是电真空管作为开关管。这种结构的脉冲调制器具有配套技术复杂、造价高、使用寿命短等缺点,尤其是其不适用于大功率、高重复频率等工作场合的缺陷,使其已经远远不能满足现代雷达的复杂信号处理的需求。     随着电力电子技术的快速发展,新型功率开关器件IGBT(绝缘栅双极晶体管)迅速占领了市场,满足了人们把大功率、超高频率开关元件实现固态化的期望,有着完全取代电真空管的趋势。这也为在雷达发射机脉冲调制器中采用IGBT作为开关管以替代电真空管奠定了理论和实践基础。 1 脉冲调制器的结构     根据脉冲调制器的任务,它基本由下列3部分组成:电源部分、能量储存部分、脉冲形成部分。其结构如图1所示。
[电源管理]
基于IGBT的固态脉冲<font color='red'>调制</font>器设计
智能楼宇不再难:意法半导体电力线调制解调器嵌入IPv6协议
摘要 当你驾车回家时,车库门自动开启,无需按任何按钮;当你穿过一条小路时,路灯自动提高亮度,如果后面没有其他人,路灯还会自动降低亮度;当你打开房门时,喇叭自动播放你最喜欢的音乐,LED照明灯点亮你的房间,光线颜色和亮度都是你最喜欢的类型。洗衣机、洗碗机等所有家电全都由智能电表管理,按照你的用电曲线为你节能电能。 不论是繁华的都市,还是偏僻的乡村,随着楼宇智能化程度不断提高,我们看到,全球新建筑正在发生巨变,而且变化速度非常快。楼宇智能化概念将有助于未来建筑业取得巨大成功。 为实现上述设想的应用场景,意法半导体开发出了各种半导体产品,例如,为高效电源管理设计的电源芯片,基于ARM CORTEX
[物联网]
智能楼宇不再难:意法半导体电力线<font color='red'>调制</font>解调器嵌入IPv6协议
继承脉宽调制器TL494及电路图
另一种开关稳压电源控制用的脉宽调制器是TL494,其内部组成如图2-20所示。
[电源管理]
继承脉宽<font color='red'>调制</font>器TL494及电路图
一种扩频通信调制器的FPGA设计与仿真
近年来,随着经济的高速增长,无线通信得到了飞速地发展。由于扩展频谱信号具有抗干扰、保密、抗侦破和抗衰落等特点,扩频通信在军事无线通信领域(如测控通信)中被广泛应用;随着技术的成熟及成本的降低,其在民用通信市场上具有更广大的发展前景。 本文首先介绍了FPGA的设计思想及流程,然后以一种扩频通信调制器为例,描述了如何实现自顶向下的设计:包括调制器的顶层设计、划分的下一层基本单元的设计等,并重点分析了基本单元之一的PN码产生器的设计实现及仿真验证过程。 FPGA设计方法简介 FPGA技术的飞速发展,对国内的电子设计工程师提出了严峻的挑战,以往传统的设计方法,如单纯的原理图输入方法,已很难满足目前
[安防电子]
一种扩频通信<font color='red'>调制</font>器的FPGA设计与仿真
小广播
最新模拟电子文章
换一换 更多 相关热搜器件
