TI 公司的TPA2028D1是单声道 3W 无滤波器D类音频功率放大器,集成了音量控制,动态范围压缩(DRC)和自动增益控制(AGC).DRV/AGC功能可通过数字I2C接口进行编程.5V电源时能向4欧姆负载提供3W功率(THD+N为10%),工作电压从2.5 V 到5.5 V,工作电流1.8mA,关断电流0.2uA,主要用在无线或蜂窝手机与PDA,PND,DVD播放器,笔记本电脑,手提无线电和游戏机以及教育类玩具.本文介绍TPA2028D1主要特性,功能方框图, 指标测试方框图,以及TPA2028D1YZFEVM评估板性能,电路图和材料清单(BOM).
The TPA2028D1 is a mono, filter-free Class-D audio power amplifier with volume control, dynamic range compression (DRC) and automatic gain control (AGC). It is available in a 1,63 mm x 1,63 mm wafer chip-scale package (WCSP).
The DRC/AGC function in the TPA2028D1 is programmable via a digital I2C interface. The DRC/AGC function can be configured to automatically prevent distortion of the audio signal and enhance quiet passages that are normally not heard. The DRC/AGC can also be configured to protect the speaker from damage at high power levels and compress the dynamic range of music to fit within the dynamic range of the speaker. The gain can be selected from –28 dB to +30 dB in 1-dB steps.
TPA2028D1主要特性:
Fast AGC Start-up Time: 5 ms
Pin-out Compatible with TPA2018D1
Filter-Free Class-D Architecture
3 W Into 4 at 5 V (10% THD+N)
880 mW Into 8 at 3.6 V (10% THD+N)
Power Supply Range: 2.5 V to 5.5 V
Flexible Operation With/Without I2C
Programmable DRC/AGC Parameters
Digital I2C Volume Control
Selectable Gain from –28 dB to 30 dB in 1-dB Steps (when compression is used)
Selectable Attack, Release and Hold Times
4 Selectable Compression Ratios
Low Supply Current: 1.8 mA
Low Shutdown Current: 0.2 µA
High PSRR: 80 dB
AGC Enable/Disable Function
Limiter Enable/Disable Function
Short-Circuit and Thermal Protection
Space-Saving Package
1,63 mm × 1,63 mm Nano-Free WCSP (YZF)
TPA2028D1应用:
• Wireless or Cellular Handsets and PDAs
• Portable Navigation Devices
• Portable DVD Player
• Notebook PCs
• Portable Radio
• Portable Games
• Educational Toys
• USB Speakers
图1.TPA2028D1功能方框图
图2.TPA2028D1指标测试方框图
图3.TPA2028D1简化应用方框图
TPA2028D1YZFEVM评估板
The TPA2028D1 evaluation module (EVM) is a complete, stand-alone audio board. It contains the TPA2028D1 WCSP (YZF) Class-D audio power amplifier.
TPA2028D1YZFEVM评估板指标:
图4.TPA2028D1YZFEVM评估板外形图
图5.TPA2028D1YZFEVM评估板电路图(1)
图6.TPA2028D1YZFEVM评估板电路图(2)
TPA2028D1YZFEVM评估板材料清单(BOM):
关键字:基于TPA2028D1 滤波器 D类音频 放大
编辑:神话 引用地址:基于TPA2028D1设计的3W无滤波器D类音频放大技术
推荐阅读最新更新时间:2023-10-12 20:30
基于AVR的数字滤波器滤除工频干扰的快速算法实现
工频干扰广泛存在各种工业现场中,其产生的途径主要包括输电馈线、照明设备、发动机以及各种电子仪器设备等。一般可以通过滤波电路消除工频干扰,但这必将增加硬件结构的复杂程度。实际上,还可以采用数字信号处理的相关算法,通过软件滤波器滤除工频干扰。软件滤波算法的采用,无疑会在简化电路结构的同时,使系统的硬件资源得到更加充分的利用,并达到降低产品成本的要求。
AVR单片机是Atmel公司生产的8位精简指令集(RISC)单片机。与同类单片机相比,在运算速度、外设资源、灵活性等方面性能均衡,性价比较高。AVR单片机适合C语言开发,Mega系列AVR单片机还有一个内部硬件乘法器单元。这些特点都为软件滤波器的实现提供了极大的便利。
1 滤
[单片机]
消除共模电压的放大器
有史以来(或至少是有精密电子以来),模拟设计者最头痛的问题之一就是 CMV(共模电压)带来的误差,或称之为可怕的地回路。尽管恐惧冲击着工程师们的心灵,但 CMV 并没有什么特别神秘之处。CMV 误差的产生原因很简单:不同位置上电路的公共电压基准(即:地),如一个机箱的传感器和另一个机箱的 ADC,两个基准电位是不同的。因此,当你在相距遥远的电路之间传送信号时,CMV 的差异会表现为附加的噪声和偏移,损害了所需信号。
消除 CMV 误差有很多方法。包括一种在接地互连处使用大量铜箔的强力方案,用全差分仪表放大器信号调整器,以及使用电流隔离器。根据不同因素在CMV问题中所占比重,以及需要CMV矫正的信号通道数量,每种方法都能
[模拟电子]
基于FPGA的超声诊断仪动态滤波器的设计
引言 超声成像是当今医学影像诊断的主要成像方法之一,它以超声波与生物之间的相互作用作为成像基础,具有对人体无伤害、无电离辐射、使用方便、适用范围广、设备价格低等优点。为了让超声图像能够更加清晰,现代超声诊断仪对超声信号进行动态滤波。动态滤波包含模拟动态滤波和数字动态滤波。模拟动态滤波器要改变器件的参数,从而达到改变通频带中心频率的效果,方法简易,效果很好。同时,控制信号是来自FPGA输送出的数字信号,经D/A转换所得,采用FPGA实现控制信号,实现了很高的精度,达到了预想的效果。 选用cycloneⅢ EP3C16Q240C8在FPGA内实现数字电路,工作频率高,同时各个模块并行工作,能够很好的解决系统时序上的问题。
[模拟电子]
磁放大器在DC-DC变换器中的应用
目前,对于多输出的推挽和正激变换器,主输出(一般是最大电流输出或5v电压输出)一般是采用电压负反馈的方式来进行稳压。而辅输出工作在开环状态,其导通时间受主输出反馈环控制。当线电压变化时,主输出和辅输出都能自动调整,但辅输出对主输出负载变化或辅输出本身负载变化都不能很好地调整。当主输出负载的变化引起辅输出电压改变的现象称为交叉影响。当输出电压变化最大时,辅输出电压变化可能高达80%【1】。这种电源只适用对辅输出电压精度要求不高的情况。当需要精确稳定的辅输出时,一般采用一级稳压电路方法对辅输出再次稳压,而一种更好的解决方案是磁放大器后级调节技术。本文研究了磁放大器在多输出变换器中的应用。 1,磁放大器的基本原理 磁放大器是利用
[电源管理]
新型绿色能效D类音频放大器设计应用
引 言
多媒体时代,传统A类、B类、AB类线性模拟音频放大器因效率低,能耗大,已不能满足电子视听类LCD/PDP/OLED/LCOS/PDA等绿色节能、高效、体积小等新发展趋势,而非线性音频放大器件Class-D类功放因具备节能、高效率、高输出功率、低温升效应、占用空间小等优点,将被纳入越来越多新产品设计中。D类放大器架构上分半桥非对称型和全桥对称型,而全桥类相对半桥型具有高达4倍的输出功率,更为高效;从信号适应上分模拟型和I2S全数字型,因全数字型尚处发展阶段,成本高,而模拟型因成本优势将在未来几年处于应用主流。本文重点剖析了全桥模拟型D类功放设计要素,实现了一种基于NXP公司新型绿色能效模拟D类功放TFA9810T
[嵌入式]
AR微波功率放大器在无线通信测试中的应用
1 QFN 封装特点
AR 射频/ 微波仪表部门, 可设计制造频率覆盖DC~45GHz,功率覆盖1~16000W 的功率放大器。应用范围包 含了电磁兼容测试(EMC),射频元器件测试、物理学(等离子体生长)和化学(质谱)应用,军工(干扰器、雷达),材料试验(超声波),医疗诊断测试(核磁共振,MRI)和一般实验室使用。本文将主要讨论AR "S" 系列微波功率放大器在无线通信测试中的应用。
在过去二十多年中,无线通信应用呈现爆炸式增长。从AT&T 在1983 年研制开发Advanced Mobile Phone Service(AMPS) 开始,个人通讯服务(PCS)迅速开始盛行。在此期间,通讯测试系统对高线性功率放大器的
[测试测量]
BA系列常用音频放大电路
BA328 立体声前置放大电路 BA328具有双路前置放大电路,它具有外接元件少,安装方便等特点,单8脚直插封装。电路特点如下:工作电压范围宽,噪声小,开环增益高,左右声道平衡性好。常用于磁带录放音机,汽车立体声收音机及家用音响设备。 BA328极限参数如下:最高电源电压18V,最大功耗:540mW,工作温度:-25-70℃。
BA532 音频功率放大电路 BA532与用于OTL电路的低频功率放大电路,输出功率高达5.8W,内设负载短路、过电压和过热保护电路,单列10 脚封装,电路特点有: 在电源电压为13.8V时,8Ω负载阻抗,THD=10%
[模拟电子]
Doherty功率放大器理论研究与电路设计
射频功率放大器被广泛应用于各种无线通信发射设备中。线性功放在基站中的成本比例约占1/3,如何有效、低成本地解决功放的线性化问题显得非常重要。高效率高线性度的功放研究是一个热门课题,特别是近几年针对WCDMA功率放大器。目前国内能生产10 W以上的WCDMA功率放大器厂家只有少数几家公司,因为WCD-MA功率放大器对线性度的要求更高。而用普通的回退法生产的WCDMA功率放大器符合指标的只能做到几瓦,这个功率用在基站上是远远不够的,只能用在一般的小型直放站上。
功率放大器的线性度和效率是设计功率放大器的重点。在线性度方面,前馈结构是目前比较成熟的结构,广泛运用于现代通信系统中,数字预失真在业界则被认为是功率放大器线性化的
[模拟电子]
