ICL8001G是Infineon公司的准谐振模式LED驱动器,精密的PWM可用于相位调光,功率因素大于98%,效率高达90%,工作电压高达26V。本文介绍了ICL8001G主要特性和亮点,方框图以及初级控制应用电路图和EVAL-LED-ICL8001G-Bulb02演示板主要特性,电路图,材料清单和变压电路图。
ICL8001G 产品亮点:
• Quasi-Resonant Control For Highly Efficient LED Driving Solutions
• Primary Side Flyback Control With Integrated PFC And Phase-Cut Dimming
• Integrated HV Startup Cell For Short Time To Light
• Best In Class System BOM For Dimmable LED Bulb
ICL8001G主要特性:
• High, stable efficiency over wide operating range
• Optimized for trailing- and leading-edge dimmer
• Precise PWM for primary PFC and dimming control
• Power cell for Vcc pre-charging with constant current
• Built-in digital soft-start
• Foldback correction and cycle-by-cycle peak current limitation
• VCC over/ under-voltage lockout
• Auto restart mode for short circuit protection
• Adjustable latch-off mode for output overvoltage protection
图1。ICL8001G方框图
图2。ICL8001G初级控制应用电路图
EVAL-LED-ICL8001G-Bulb02 Quasi-Resonant Flyback Converter for Phase Cut Dimming with High Power Factor
The EVAL-LED-ICL8001G-Bulb02 demonstrates the single-stage flyback and PFC controller ICL8001G in an LED Bulb application. Its quasiresonant operation mode, primary side control, integrated PFC and phase-cut dimming control makes it the best in class system solution for dimmable LED bulbs.
EVAL-LED-ICL8001G-Bulb02演示板主要特性:
•High, stable efficiency over wide operating range through quasiresonant operation mode
•Primary side side flyback control with integrated PFC and phase-cut dimming
•Energy efficient phase cut dimming
•Power cell for VCC pre-charging with constant current
•Built-in digital soft-start
•Foldback correction and cycle-by-cycle peak current limitation
•VCC over- and under-voltage lockout
•Auto restart mode for short circuit protection
•Adjustable latch-off mode for output overvoltage protection
•Best in class system BOM for dimmable bulbs
图3。EVAL-LED-ICL8001G-Bulb02演示板外形图
图4。EVAL-LED-ICL8001G-Bulb02演示板电路
EVAL-LED-ICL8001G-Bulb02演示板材料清单(BOM):
图5。EVAL-LED-ICL8001G-Bulb02演示板变压器电路图
关键字:ICL8001G 准谐振 LED
编辑:神话 引用地址:基于ICL8001G设计的准谐振模式LED驱动技术
ICL8001G 产品亮点:
ICL8001G主要特性:
图1。ICL8001G方框图
上一篇:基于LT3748设计的绝缘反激拓扑开关电源控制技术
下一篇:我国LED产业的发展困境
推荐阅读最新更新时间:2023-10-13 10:55
如何采用电源方式及4层底板使小型LED灯泡接连亮
如何采用电源方式及4层底板使小型LED灯泡接连亮相
使用夏普基于各资料而推测的数据。由于小数点第2位进行了四舍五入,合计后数值并非100%.
夏普投入AQUOS电视的电源开发团队
“先设计再开发”(夏普 健康及环保系统业务本部 LED照明业务推进中心 副所长兼商品企划部长桃井恒浩)。夏普采用了无限接近E17型灯泡外形尺寸的设计。 为了实现电源电路的小型化,该公司投入了液晶电视“AQUOS”的电源开发团队。在采用原来的E26型LED灯泡使用的电源电路时,变压器及电解电容器过大,无法收藏于E17型灯泡内。因此,AQUOS的电源开发团队大幅改进了电源电路,并将此前的降压斩波方式改成了回扫方式。这
[电源管理]
一种连接传感器的智能LED方案
智能照明的概念崛起,让LED照明灯更受宠。智能照明系统的基本原理是用户对终端模块(包括移动终端)下指令,通过电子感应将信号传递给控制中心软件,借助控制器调节电路的电压和电流幅度,从而对光源强度、色彩等进行调控。整个系统可分为智能照明控制系统、数字可寻址LED驱动、灯具和光源几项产品。 一个典型的智能照明系统是完成从数据指令从输入端到输出端的传递。用户可以通过多种输入方式(控制软件、传感器、智能插座等)将数据传输到主控制器(网关),之后由主控制器通过ZigBee等网络协议实现对输出端(LED筒灯、LED面板灯)的控制。 LED照明灯具与传统的照明灯具最大的区别,LED照明灯具是一个完全的电子产品,而传统的照明灯具仅是一个
[电源管理]
LED柔性霓虹灯的特点与发展
1、背景
由于霓虹灯具有光线均匀连续的特点,在装饰照明市场中,得到广泛的应用已有很多年。在商业领域的门面、招牌、字幕广告、酒店酒吧、建筑物轮廓等装饰照明场所都有霓虹灯闪烁的身影。但是,传统霓虹灯采用的是玻璃灯管,存在包装运输时易破碎及不易制作、安装等缺陷。
很久以前,人们就期望能把小灯泡安装在电线里用于装饰和照明。如今,这种灯已遍布欧、美、亚各国,走进了大街小巷,走进了人们的生活中。我们把这种柔软、似管状的长条形灯具统称为“软管灯”。
2、软管灯技术的发展
软管灯在照明装饰市场上又被称为“塑料霓虹灯”或“柔性霓虹灯”。软管灯具有以下特性:生产时 自动化 机器挤出成型、制作成本低,
[电源管理]
基于LYTSwitch-4的大功率LED电源解决方案
1 概述 PowerInt公司的LYTSwitch-4系列产品LYT4211-4218/4311-4318把控制器和高压大功率FET组合在同一封装中,控制器提供高功率因素和恒流输出,具有优于±5%的恒流性能,TRIAC调光,全亮度的起动时间小于250ms,功率因素大于0.9,高达92%的效率,开关频率132kHz可使用较小的磁性材料。主要用在大功率LED驱动。 LYTSwitch-4系列产品具有卓越的导通特性,可用于前沿和后沿可控硅调光。这使其具有广泛的调光范围,并可快速启动驱动器(即使从一个低导通角启动)。采用LYTSwitch-4系列的LED驱动器不使用初级侧的,大体积铝电解电容器。这意味着大大延长了驱动器的使用
[电源管理]
LED道路照明与传统道路照明的比较
如某城市城区道路需建设2km 的道路照明,路灯高度为10m,路灯间隔为40m,两侧对称布置、所需102 盏路灯。有两种方案可供选择,方案一是采用高压钠灯作为光源,方案二是采用LED 路灯作为光源。以250W 钠灯为标准,比较其成本。
5.1 方案1 成本分析
传统路灯灯具(含光源电器)单价为1,000 元,合价为102,000 元;电缆规格16mm2 单价为70 元/m, 合价为280,000 元;路灯灯杆单价为2,000 元,合价为204,000 元。
年使用电费每千瓦1.2 元,每天使用10 小时计算,365×10×1.2×102×0.25=111,690 元。
5.2 方案2
[电源管理]
简析LED照明在实际应用中的热特性
引言
每个设计师只有清楚地了解LED内部从PN结到环境的热特性,才能确保得到一个安全,可靠的设计和令人满意的性能。
在热流路径中可能有裸芯片或胶层等多个导热界面,并且它们的厚度和热阻很难在生产过程中进行控制。此外,在LED封装和作为散热器的照明设备外壳之间的导热界面进一步增加了设计的挑战性。必须在样机阶段尽可能早地了解LED的热阻值。
1 电流、颜色和效能
LED的光输出特性主要取决于其工作条件。前向电流增加会使LED产生更多的光。但当前向电流保持不变,光输出会随着LED的温度升高而下降。图1描述了温度,电流和光输出的关系。并且描述了一个LED相关的颜色光谱在峰值波长处的偏移。用于普通照
[电源管理]
LED驱动电源与去驱动将会有一个持久战!
今年三四月份热闹非凡,除了大大小小的经销商大会、项目和新品发布会外,一股 驱动电源 领域的小浪潮正在兴起。3月底4月初,聚科照明、长运通、新力光源等3家 LED 企业先后举办发布会,大力宣扬去电源化驱动产品和技术,或者与下游企业强强联合,全力推动去电源化驱动发展。为什么短期内会出现多家业内知名LED企业争先发布去电源化驱动产品或合作项目呢?去电源化驱动是否将掀起一场驱动革命的浪潮呢? 新一轮驱动技术革命启动 去电源化驱动是个什么东西,很多业内人士都弄不清楚,事实上,不管是去电源化驱动技术还是业内称呼的“去电源化”技术,这些说法都不够准确,不是没有驱动,而是通过电路设计及微电子工艺,将驱动电路做小,并与LED实现高度集成。 去电
[电源管理]
51单片机用PWM控制LED渐亮与渐灭
设计思路:用定时器中断产生最小时间单位T0,每m个T0组成一个子周期T10,其中前n个T0为LED导通时间,即Ton=n*T0,则Toff=(m-n)*T0
;每X个T10组成一个母周期T20,其中前y个T10为有效控制时间,后续的(x-y)个T10令LED熄灭或者子周期占空比调至最小。
;适当调节n/m和x/y的比例使显示效果达到最佳。
;以下是刚刚调试通过的小段程序,显示效果良好。
;子周期的最小占空比的宽度应大于LED的点亮时间,即点亮LED的时间宽度n/m*T0应足够产生余辉。类似于动态数码管对点亮时间的要求。
;母周期的宽度应小于1/50s,提高刷新频率以令肉眼察觉不出闪烁。
;芯
[单片机]
