The LT®3799 is an isolated flyback controller with power factor correction specifically designed for driving LEDs. The controller operates using critical conduction mode allowing the use of a small transformer. Using a novel current sensing scheme, the controller is able to deliver a well regulated current to the secondary side without using an opto-coupler. A strong gate driver is included to drive an external high voltage MOSFET. Utilizing an onboard multiplier, the LT3799 typically achieves power factors of 0.97. The FAULT pin provides notification of open and short LED conditions.
The LT3799 uses a micropower hysteretic start-up to efficiently operate at offline input voltages, with a third winding to provide power to the part. An internal LDO provides a well regulated supply for the part’s internal circuitry and gate driver.
LT3799主要特性:
Isolated PFC LED Driver with Minimum Number of External Components
TRIAC Dimmable
VIN and VOUT Limited Only by External Components
Active Power Factor Correction (Typical PFC > 0.97)
Low Harmonic Content
No Opto-Coupler Required
Accurate Regulated LED Current (±5% Typical)
Open LED and Shorted LED Protection
Thermally Enhanced 16-lead MSOP Package
LT3799应用:
Offline 4W to 100W+ LED Applications
High DC VIN LED Applications
图1。LT3799方框图
图2。LT3799 90-150VAC输入TRIAC调光20W LED驱动器
图3。LT3799通用TRIAC调光20W LED驱动器
不同输入电压的元件值:
图4。LT3799通用TRIAC调光4W LED驱动器
上一篇:LED点阵屏显示单元的设计与驱动控制
下一篇:数字电源技术推动LED照明的解决方案
推荐阅读最新更新时间:2023-10-18 15:21
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
