The LinkSwitch-PL family enables a very small and low cost single-stage power factor corrected constant current driver for solid state lighting. Optimized for direct LED current sensing, the LinkSwitch-PL operates over a wide input voltage range delivering an output power of up to 16 W. The LinkSwitch-PL control algorithm provides flicker-free TRIAC dimming with minimal external components.
Each device incorporates a 725 V rated power MOSFET, a novel discontinuous mode variable frequency variable on-time controller, frequency jitter, cycle by cycle current limit and hysteretic thermal shutdown in a monolithic 4-pin IC, available in SO-8C, eSOP-12, and eDIP-12 packages.
LinkSwitch-PL系列产品亮点:
Dramatically Simplifies Off-line LED Drivers
• Flicker-free phase-controlled TRIAC dimming
• Single stage power factor correction and accurate constant current (CC) output
• Very low component count with small non-electrolytic bulk capacitor for compact replacement lamp designs
• Compact SO8, eSOP, and eDIP packages
• Completely eliminates control loop compensation
Advanced Performance Features
• Optimized for non-isolated flyback designs
• Frequency jitter greatly reduces EMI filter size and costs
• Low dissipation direct sensing of LED current
Advanced Protection and Safety Features
• Cycle skipping regulation for abnormally low output power to clamp peak output current delivered
• 725 V integrated power MOSFET allows small bulk capacitance and maximizes power capability
• Short-circuit, overload, open feedback and output overvoltage protection
• Hysteretic thermal shutdown
• Meets high-voltage creepage between DRAIN and all other pins both on PCB and at package
EcoSmart™ - Energy Efficient
• High power factor optimizes system lumen per input VA
• Control algorithm balances switching and conduction losses over line and load to maintain optimum efficiency
图1。LinkSwitch-PL系列功能方框图
图2。LinkSwitch-PL系列典型应用电路图
图3。采用LinkSwitch-PL系列的替代A19白炽灯的5W 15V LED驱动器电路图
DER322参考设计
High Efficiency (>93%), High Power Factor(>0.9), 18 W Output Non-Isolated Buck LED Driver Using LinkSwitchTM-PL LNK460VG
The document describes a non-isolated, high efficiency, high power factor (PF) LED driver designed to drive a nominal LED string voltage of 78 V at 230 mA from an input voltage range of 195 VAC to 265 VAC (47 Hz – 63 Hz). The LED driver utilizes the LNK460VG from the LinkSwitch-PL family of ICs.
The topology used is a single-stage non-isolated buck that meets the stringent space and efficiency requirements for this design. LinkSwitch-PL based designs provide high power factor (>0.9) meeting international requirements.
This document contains the LED driver specification, schematic, PCB details, bill of materials, transformer documentation and typical performance characteristics.
DER322参考设计主要特性:
Single-stage power factor correction combined with constant current (CC) output
Low cost, low component count, small size and single-sided PCB
Highly energy efficient, >93% at 230 VAC input for 78 V LED Load
Integrated protection and reliability features
Single shot no-load protection / output short-circuit protected with auto-recovery
Auto-recovering thermal shutdown with large hysteresis protects both components and PCB
No damage during brown-out conditions
PF >0.9 at 230 VAC
% ATHD <20% at 230 VAC; 78 V LED
Meets IEC ring wave, differential line surge and EN55015 conducted EMI
图4。DER322参考设计外形图:上:顶视图,下:底视图
DER322参考设计电源指标:
图5。DER322参考设计电路图
DER322参考设计材料清单(BOM):
图6。DER322参考设计PCB布局图(53.5 mm x 19.6 mm):上:顶层;下:底层
详情请见:
http://www.powerint.com/sites/default/files/product-docs/linkswitch-pl_family_datasheet.pdf
和
http://www.powerint.com/sites/default/files/PDFFiles/der322.pdf
上一篇:高亮度LED太阳能路灯照明系统设计方案
下一篇:LED的伏安特性及多路输出LED的恒流技术介绍
推荐阅读最新更新时间:2023-10-18 16:35
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- Bourns 推出两款厚膜电阻系列,具备高功率耗散能力, 采用紧凑型 TO-220 和 DPAK 封装设计
- Bourns 全新高脉冲制动电阻系列问世,展现卓越能量消散能力
- Nexperia推出新款120 V/4 A半桥栅极驱动器,进一步提高工业和汽车应用的鲁棒性和效率
- 英飞凌推出高效率、高功率密度的新一代氮化镓功率分立器件
- Vishay 新款150 V MOSFET具备业界领先的功率损耗性能
- 强茂SGT MOSFET第一代系列:创新槽沟技术 车规级60 V N通道 突破车用电子的高效表现
- 面向车载应用的 DC/DC 电源
- Vishay推出适用于恶劣环境的紧凑型密封式SMD微调电阻器
- MathWorks 和 NXP 合作推出用于电池管理系统的 Model-Based Design Toolbox
- 大联大品佳集团推出以复旦微和ams OSRAM产品为主的汽车氛围灯方案
- 为啥车载操作系统(Vehicle OS)越来越重要了呢?
- 车载传感器 — 一文详解激光雷达
- 汽车(超声波、毫米波、激光)雷达之间的简单区别
- 汽车电路相关知识大全
- SABIC进一步深化与博鳌亚洲论坛的战略合作伙伴关系
- 使用 3.3V CAN 收发器在工业系统中实现可靠的数据传输
- 凌华智能推出AmITX Mini-ITX 主板,助力边缘人工智能和物联网创新
- 英飞凌携手马瑞利采用AURIX™ TC4x MCU系列推动区域控制单元创新
