SupertexHV9861A21W通用AC输入高亮LED驱动方案
最新更新时间:2013-01-22来源: 电子技术应用关键字:SupertexHV9861A21W  LED  驱动方案 手机看文章 扫描二维码
随时随地手机看文章
LED驱动器,从而大大地改善了LED电流的精度,线路和负载调整精度而不需要回路补偿或高边电流检测,LED输出电流精度±3%.主要用在DC/DC或AC/DC LED驱动器,LCD屏的LED背光驱动,通用恒流源,LED显示屏,建筑和装饰照明以及LED街道照明.本文介绍了HV9861A主要特性,方框图,典型应用电路以及21W通用AC输入电压LED驱动器演示板主要指标,电路图,材料清单和PCB布局图.
The HV9861A is a patented, average-mode, constant current control LED driver IC operating in a constant off-time mode. Unlike the HV9910B, this control IC does not produce a peak-to-average error, and therefore greatly improves the accuracy, line and load regulation of the LED current without any need for loop compensation or highside current sensing. The output LED current accuracy is ±3%.
The IC is equipped with a current limit comparator for hiccup-mode output short circuit protection. Internal over-temperature protection is provided. The internally regulated voltage (VDD) for the HV9861A is 7.5V.
The IC can be powered from a 12 - 450V supply. A PWM dimming input is provided that accepts an external control TTL-compatible signal. The output current can be programmed by an internal 270mV reference, or controlled externally through a 0 - 1.5V dimming input.
The IC is pin-to-pin compatible with the Supertex HV9910B and HV9961, and can be used as a drop-in replacement for many applications to improve the LED current accuracy and regulation.
HV9861A主要特性:
►► Fast average current control
►► Programmable constant off-time switching
►► PWM / linear dimming input
►► Output short circuit protection with skip mode
►► Ambient operating temperature -40OC to +125OC
►► Pin-compatible with the HV9910B and HV9961
HV9861A应用:
►► DC/DC or AC/DC LED driver applications
►► LED backlight driver for LCD displays
►► General purpose constant current source
►► LED signage and displays
►► Architectural and decorative LED lighting
►► LED street lighting
图1.HV9861A方框图
图2.HV9861A应用电路图
21W通用AC输入电压LED驱动器
21-Watt, Universal, AC LED Driver Demoboard with Accurate Average-Mode, Constant Current Control
The HV9861ADB1 demoboard is a high-brightness LED driver employing the patented average-mode, constant current control scheme by Supertex Inc. The power conversion stage of the HV9861ADB1 consists of a diode bridge rectifier followed by a buck converter operating with fixed off-time of 20μs.
The HV9861ADB1 LED driver features tight regulation of the LED current within a few milliamps over the entire range of the input AC line and the output LED string voltage. The LED current accuracy is almost insensitive to the passive component tolerances, such as the output filter inductance or the timing resistor. The accuracy of the LED current is mainly determined by the internal 270mV ± 3% reference voltage of the HV9861A control IC and by the external current sense resistor tolerance.
(Note, that the linear dimming input of the HV9861A disables switching, when its voltage falls below a 200mV threshold. Expect the LED driver to shut off when the LED current falls below 50 ~ 55mA.)
PWM dimming can be achieved by applying a pulse-widthmodulated square wave signal between the PWMD and GND pins.
The HV9861ADB1 features protection from an output short circuit condition. Open LED protection is inherent, since the output filter capacitor can accept the full rated rectified AC line voltage.
Please, note that the demoboard is not CISPR15 compliant.An additional input EMI filter circuit is required to make the board meet conducted electro-magnetic emission limits.
图3. 21W通用AC输入电压LED驱动器外形图
图4. 21W通用AC输入电压LED驱动器电路图
21W通用AC输入电压LED驱动器主要指标:
21W通用AC输入电压LED驱动器材料清单(BOM):
图5.21W通用AC输入电压LED驱动器PCB布局图
详情请见:
http://www.supertex.com/pdf/datasheets/HV9861A.pdf
http://www.supertex.com/pdf/misc/HV9861ADB1.pdf
关键字:SupertexHV9861A21W  LED  驱动方案 编辑:探路者 引用地址:SupertexHV9861A21W通用AC输入高亮LED驱动方案
上一篇:14W高效率LED驱动器电源设计
下一篇:建筑LED与室内LED的驱动电路
推荐阅读最新更新时间:2023-10-17 15:13
适合LED街灯的高能效28 V、3.3 A LED驱动器设计
随着LED在性能及成本几乎各个方面的持续改进,LED照明正在用于越来越宽的应用领域,其中LED街灯就是业界关注的一个焦点。安森美半导体身为应用于高能效电子产品的首要高性能硅方案供应商,针对各类LED照明应用提供丰富的驱动器、稳压器、稳流器,及通信、光传感器、MOSFET、整流器、保护、滤波器及热管理产品等完整方案。本文将介绍一款用于LED街灯等应用的28 V、3.3 A的离线高功率因数LED驱动器设计。这设计基于安森美半导体的NCL30001 LED驱动器及NCS1002恒压恒流控制器,采用90至265 V交流电压供电,提供最大90 W的输出功率,具有高功率因数,同时符合相关谐波含量标准,并能够配合脉宽调制(PWM)调光。
[电源管理]
适合<font color='red'>LED</font>街灯的高能效28 V、3.3 A <font color='red'>LED</font>驱动器设计
一种三基色LED驱动原理及应用IC线路设计方案
三基色组成方式 在 三基色 设计应用中通常是,通过调节设定 LED 电流来达到白平衡和最大的期望亮度值。 我们一般将最简单、最优化的配色方式作为,设计全彩显示技术的颜色再现方法。白平衡是检验颜色组成的重要标志之一。三基色白光一般是红绿蓝三基色按亮度比例混合而成,当光线中绿色的亮度为69%,红色的亮度为21%,蓝色的亮度为10%时,混色后人眼感觉到的是纯白色。早前的CRT电视机到现在的LCD 液晶显示都是这样组成的,LED当然将成熟的技术照搬。 LED 红、绿、蓝三色的色品坐标因工艺过程等原因无法达到全色谱的效果,而控制原色包括有偏差的原色的亮度得到白色光,称为配色。当为全彩色LED 显示屏进行配色前,为了达到最佳亮度和最低的成本
[电源管理]
一种三基色<font color='red'>LED</font>驱动原理及应用IC线路设计方案
LED市场:背光需求旺盛,上游芯片持续缺货
  根据产业研究机构LEDinside分析统计,2010年5月台湾上市上柜LED厂商营收总额共96.5亿元,相较2010年4月份营收90.33亿元上升6.8%(YoY+85.5%)。其中LED芯片厂5月营收总额为42.73亿元,较4月份增加6%﹔LED封装厂商5月份营收53.79亿,较4月增加7.5%。   而由LEDinside所编制的LED产业指数(LEDX),透过LED产业市值的表现来观察产业。目前LED磊晶指数 (Chip LEDX)的指数已经回落到3949点,而LED封装指数 (Package LEDX)也来到了5050点。尽管台湾LED厂商的产值持续写下历史新高,但是LED产业指数相较今年初高点跌幅将近20%,与
[电源管理]
台<font color='red'>LED</font>市场:背光需求旺盛,上游芯片持续缺货
2019年H1中国照明出口情况分析
01、概况:整体出口增长乏力,替换市场已近高峰 2019年上半年,中国照明全行业出口额约为210.86亿美元,整体同比略有增长达4.08%。 2019年上半年,中国共出口光源产品约45.88亿只,同比减少6.90%;其中白炽灯9.22亿只,卤钨灯2.10亿只;紧凑型荧光灯4.58亿只,直管/环形荧光灯1.49亿只;HID灯共0.28亿只; LED 光源28.20亿只,占比达到61.5%,比重同比有所提升(去年同期为58%);同时传统光源仍占38.5%,替换市场依旧具备一定潜力。 ❶ 传统光源:卤钨产品断崖下滑 随着相关LED照明产品的替代和全球对高耗能产品的淘汰,传统照明产品中包括热辐射光源类的白炽灯和卤钨灯
[嵌入式]
2019年H1中国照明出口情况分析
浅析LED常规性老化方式
  led常规性老化试验对比   一般来说,尤其是大功率LED在初始点亮阶段光度都会有一定的衰减,LED封装厂为了提供给应用端厂商发光稳定的产品,或者是应用端厂商家为了获得稳定的led材料,通常都会做一些老化试验。当然LED老化试验有多种方式,如常规性老化、过电流冲击破坏性试验等等。   LED厂商通常会用以下几种方式进行常规性老化:   1、多颗管串联老化:恒压老化电路和恒流老化电路   2、多颗管并联老化   3、多颗管串并联老化:串并恒压老化和串并恒流老化   4、单管恒流老化   比较以上4种老化方式, 1、3种方式中只要有一颗LED出现品质故障,比如LED短路或者断路都会影
[电源管理]
世界首创可成形LED背光源提供柔性设计
   Lumex宣佈业界首创的QuantumBrite可成形LED背光源。採用该新型可成形LED 背光源,可以将孔切割成几乎任何形状 (例如,以为电路板上的开关或其他元件留出空间) 的背光源。这种可成形柔性 LED 背光源技术组合在业内独一无二。并为各种新型 LED 背光源应用开启了机会之门,这些应用可完全自订,能在平面及曲面上呈现为任何形状、尺寸或颜色。这项新型背光源技术可提供的亮度高达20cd/m2,这令其成为需要不刺眼、自然的柔和光照应用的理想选择。   超薄的QuantumBrite LED 背光源视区外形高度仅 0.125mm,较传统 LED 背光源技术薄 97%,而较其他柔性 LED 背光源技术薄79%。外形高度仅
[电源管理]
大功率LED路灯散热
往往有很多人把主要的目光都放在了led的流明数上,而对LED灯具的散热则的关注较少。实际上,LED的流明数正在迅速的增加。2006年量产LED的单瓦流明数已经达到50流明,而且这一数值还在快速地增长。与之对应的传热学理论体系已经成熟,我们可以使用的传热手段也基本明确:传导、对流、辐射和相变传热(例如热管)。因此,在传热或者说散热问题上,我们可以采取的措施是可见的、有限的。 根据光通量(流明)与辐射通量(瓦)以下的当量关系:其中,Km = 683 lm/w, 是光通量的比例尺, 是辐通量的比例尺。也就是说1W的辐通量在最理想的情况下(黑体辐射)可能产生683lm光通量。所以,即使LED的光效达到200lm/w
[电源管理]
浅谈新式LED散热技术IVC一举突破传统LED散热技术限制
LED 产业随着厂商能力的不同,而有分成主打高技术水准、高毛利,以及一般技术水准、低毛利,还有两种方式兼顾等模式。而争议很大的 LED散热 技术,尽管很多做中低阶LED产品的厂商不在意,但相关技术的发展倒是日新月异,毫不停歇,以求打造出高毛利、高附加价值的应用来,但相关开发成本与难度,也是不少厂商为之却步,选择其它产品来做的原因之一。 而我们这次要介绍的是新式的LED散热技术IVC,也就是真空均温板架构。它的原理很简单,就是透过抽取空气的方式,建立一个内部中空的金属物,接着利用特殊介质和同质材料的饱和蒸气物质,填满金属物的中空部分。 这样的架构很类似水冷、液体冷却的循环管线系统,只要高 功率 LED发光时,发光二极管产生的热量,将
[电源管理]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
