ADIADP5034微电源管理(PMU)解决方案
最新更新时间:2011-12-24来源: chinaaet关键字:电源管理  DC/DC转换器  PWM 手机看文章 扫描二维码
随时随地手机看文章
电源管理单元(PMU)评估板主要特性,电路图,材料清单和元器件布局图.
The ADP5034 combines two high performance buck regulators and two low dropout (LDO) regulators in a small, 24-lead 4 mm × 4 mm LFCSP to meet demanding performance and board space requirements.
The high switching frequency of the buck regulators enables tiny multilayer external components and minimizes the board space. When the MODE pin is set to high, the buck regulators operate in forced PWM mode. When the MODE pin is set to low, the buck regulators operate in PWM mode when the load is above a pre-defined threshold. When the load current falls below a predefined threshold, the regulator operates in power save mode (PSM), improving the light load efficiency.
The two bucks operate out of phase to reduce the input capacitor requirement. The low quiescent current, low dropout voltage, and wide input voltage range of the ADP5034 LDOs extend the battery life of portable devices. The ADP5034 LDOs maintain power supply rejection greater than 60 dB for frequencies as high as 10 kHz while operating with a low headroom voltage.
Regulators in the ADP5034 are activated through dedicated enable pins. The default output voltages can be externally set in the adjustable version, or factory programmable to a wide range of preset values in the fixed voltage version.
ADP5034主要特性:
Main input voltage range: 2.3 V to 5.5 V
Two 1200 mA buck regulators and two 300 mA LDOs
24-lead, 4 mm × 4 mm LFCSP package
Regulator accuracy: ±3%
Factory programmable or external adjustable VOUTx
3 MHz buck operation with forced PWM and auto PWM/PSM modes
BUCK1/BUCK2: output voltage range from 0.8 V to 3.8 V
LDO1/LDO2: output voltage range from 0.8 V to 5.2 V
LDO1/LDO2: low input supply voltage from 1.7 V to 5.5 V
LDO1/LDO2: high PSRR and low output noise
ADP5034应用:
Power for processors, ASICS, FPGAs, and RF chipsets
Portable instrumentation and medical devices
Space constrained devices
图1. ADP5034方框图
图2. ADP5034典型应用电路图
图3. ADP503采用PSM/PWM控制的处理器系统电源管理图
图4. ADP5034带使能引脚的固定输出电压电路图
图5. ADP5034带使能引脚的可调输出电压电路图
材料清单:
ADP5034微电源管理单元(PMU)评估板
The ADP5034 evaluation board has two step-down regulators with two LDOs that enable evaluation of the ADP5034. The evaluation board is available in standard voltage options.
The ADP5034 uses a proprietary high speed, current mode, constant frequency, pulse-width modulation (PWM) control scheme for excellent stability and transient response. To ensure the longest battery life in portable applications, the ADP5034 features a power save mode (PSM) that reduces the switching frequency under light load conditions, as well as the option to change the mode to fixed PWM operation. The 3 MHz switching frequency minimizes the size of the external components.
The low quiescent current, low dropout voltage, and wide input voltage range of the ADP5034 LDO regulators extend the battery life of portable devices.
图6.ADP5034微电源管理单元(PMU)评估板外形图
ADP5034微电源管理单元(PMU)评估板主要特性:
Full-featured evaluation board for the ADP5034 Standalone capability Simple device measurements, including line and load regulation, demonstrable with A single voltage supply A voltmeter A current meter Load resistors Easy access to external components Cascading options to supply the low dropout (LDO) from either buck Dedicated enable option for each channel Mode option to change bucks from PFM to PWM operation
图7.ADP5034微电源管理单元(PMU)评估板电路图
图8.ADP5034微电源管理单元(PMU)评估板元件布局图(顶层)
图9.ADP5034微电源管理单元(PMU)评估板元件布局图(底层)
ADP5034评估板材料清单:
详情请见:
http://www.analog.com/static/imported-files/data_sheets/ADP5034.pdf
http://www.analog.com/static/imported-files/user_guides/UG-271.pdf
关键字:电源管理  DC/DC转换器  PWM 编辑:探路者 引用地址:ADIADP5034微电源管理(PMU)解决方案
上一篇:实现功率因数校正的电源和适配器方案
下一篇:单相逆变电源设计
推荐阅读最新更新时间:2023-10-18 16:16
Dialog推出新型计算平台电源管理解决方案
20A 的DA9312电源管理集成电路(PMIC)达到空前的98%的效率,帮助笔记本电脑的电源设计尺寸缩小一半 高度集成电源管理、AC/DC电源转换、固态照明(SSL)和Bluetooth Smart(智能蓝牙)无线技术供应商Dialog 半导体公司(法兰克福证券交易所交易代码:DLG)日前宣布,推出一款新型的电源管理IC---DA9312,支持由双芯(2S)锂离子或锂聚合物电池供电的更小更轻薄的笔记本电脑和平板电脑的电源设计。笔记本电脑电池的发展趋势是从三芯转到二芯,平板电脑则从单芯转到二芯。Dialog的DA9312以目前集成度最高的电源管理解决方案支持这个潮流。 DA9312仅需要很少的
[电源管理]
Buck-Boost PWM DC/DC转换器的级联
  利用三种最基本的PWM转换器,除了可以利用演化的方式派生出新的转换器之外,利用级联方式也可以派生出新的转换器。   将两个Buck-Boost电路组合后,可以得到单开关Buck-Boost级联,其演化过程如图所示。   其中,演化过程需要注意的是,第二级在如图(b)中的极性反转,以对应前级输出极性:在如图(c)中,第二级回路中加人一个二极管砀,以阻止与第一级连接后,在开关管V关断期间第一级电流窜人第二级。将如图(e)第一级与第二级中的开关管V,电容C重合,得到如图(d)所示的电路,其输出黼入关系为如图 Buck-Boost与Buck级联的演化过程。   如图 Buck-Boost与Buc
[电源管理]
Buck-Boost <font color='red'>PWM</font> <font color='red'>DC</font>/<font color='red'>DC转换器</font>的级联
6MHz升降压DCDC转换器芯片【富士通半导体】
    上海,2011年2月24日- 富士通半导体(上海)有限公司今日宣布推出6MHz升降压DCDC转换器芯片-MB39C326。该芯片适用于移动电话、智能手机、电子阅读器和其它手持移动设备的射频功率放大器。富士通将于2011年6月起提供该新产品的样片。     升降压DCDC转换器芯片-MB39C326主要应用于射频功率放大器,工作频率为6MHz,可谓行业领先。该芯片以6MHz的较高频率工作时,可以大幅减少电源部分的贴装面积(仅为现存产品的一半。)     升降压操作可使锂离子电池在更宽的电池电压范围下工作。当锂离子电池电压下降时,MB39C326可为设备提供稳定的电压,并延长锂离子电池的寿命。     移动电话、智
[电源管理]
6MHz升降压<font color='red'>DC</font><font color='red'>DC转换器</font>芯片【富士通半导体】
51单片机学习笔记:定时器产生PWM可调方波,控制led灯亮度
使用定时器T0产生PWM方波, 用按键调整占空比,20级可调 控制led灯的亮度等级. C代码 #include my51.h #include timer0.h #define grading 20 //亮度20级变化 sbit keyS3=P3^5; //按键调整占空比,PWM_keyChange++ sbit keyS4=P3^6; // PWM_keyChange-- u8 PWM_keyChange=10; //初值,按键调整在1~20之间变化 //占空比 PWM_key
[单片机]
51单片机学习笔记:定时器产生<font color='red'>PWM</font>可调方波,控制led灯亮度
单片机控制的步进电机PWM控制程序
8051单片机控制步进电机的C51语言编写的PWM控制程序 #include intrins.h #include stdio.h #include math.h #include UPSD3200.H #include upsd_pwm.h #define uint unsigned int #define uchar unsigned char PSD_REGS PSD8xx_reg _at_ csiop; #define KEYIO (~(PSD8xx_reg.DATAIN_A)) & 0x07 sbit CP=P4^7; sbit U_D=P1^1; void ini
[单片机]
e络盟开售Nordic Semiconductor最新款电源管理IC
e络盟开售Nordic Semiconductor最新款电源管理IC Nordic Semiconductor nPM1100 PMIC非常适合高级可穿戴无线设备,其“效率-尺寸比”超过所有其他PMIC解决方案 中国上海,2022年10月27日 – 安富利旗下全球电子元器件产品与解决方案分销商e络盟开售Nordic Semiconductor最新款电源管理IC(PMIC)nPM1100。与业界其他PMIC解决方案相比,nPM1100具备更高的效率-尺寸比,PCB占位面积低至23mm²。 这款超小型PMIC产品非常适合各种空间受限应用,包括手持式设备、便携式产品、高级可穿戴无线设备及联网医疗设备中的电池充电和供电。
[电源管理]
e络盟开售Nordic Semiconductor最新款<font color='red'>电源管理</font>IC
香港理工大学开发PWM技术 改善LED系统效率
得益于香港理工大学电子与资讯工程系研究人员最近所开发的高性能 LED驱动 器, LED 灯可以比以往更亮更节能。   这一获奖的高效率技术可应用于许多领域,比如LED广告牌,并可再节能15%   这种新驱动器采用创新的多级PWM技术为LED灯供电,与当下LED产品采用的PWM和线性驱动器相比,这种技术显著改善了光质量和能效。这种方式不局限于LED驱动器,并可提供比PWM或恒流模式多更多的好处和选择。   采用传统的PWM方式,LED接受的电流是脉冲式的,而不是直流。这种驱动电流以人眼所无法察觉的速度快速开关。以脉冲电流为LED供电使得光输出更容易控制。   由Lai Yuk Ming博士、Loo Ka Hong博士以及Michae
[电源管理]
IM2605 TYPEC拓展坞电源管理芯片
IM2605集成了一个同步4开关Buck-Boost变换器,在输入电压小于或大于输出电压时保持输出电压调节。当输入电压足够大于输出电压时,它作为Buck变换器工作,并随着输入电压接近输出逐渐过渡到Buck-Boost模式。它还具有内部固定软启动功能,并提供保护功能包括输入UVLO、OCP、过载保护(OLP)、OVP和热关机。此外,它还具有可选择的FCCM或DCM操作,用于轻负载。IM2605还控制两个低N-MOSFET作为负载开关,有助于降低BOM成本。采用微处理器,可实现电源交换时的输入体电容放电。 IM2605特征 ⚫集成4开关,实现高效同步 Buck-Boost变换器 ⚫输入电压工作范围从4V到23V ⚫开关频率可调:3
[嵌入式]
IM2605 TYPEC拓展坞<font color='red'>电源管理</font>芯片
小广播
最新电源管理文章
换一换 更多 相关热搜器件
