FairchildFAN302HL5W手机充电器解决方案
最新更新时间:2012-03-11来源: 中电网关键字:电源管理  DC/DC转换器  手机充电器 手机看文章 扫描二维码
随时随地手机看文章
    Fairchild公司的FAN302HL是高度集成的PWM控制器,采用mWSaver™技术,提供业界最好的待机功耗,低于10mW,远低于能源之星的30mW要求.固定的PWM频率85kHz和跳频技术解决了EMI问题.主要用在手机,无绳电话,PDA和数码相机以及电动工具等的电池充电器.本文介绍了FAN302HL主要特性,方框图, 反激转换器电路图, 典型应用电路图以及采用FAN302HL的5V / 1A PSR手机电池充电器主要指标,电路图,材料清单和PCB布局图.
    FAN302HL: mWSaver™ PWM Controller for Low Standby Power Battery-Charger Applications
    This highly integrated PWM controller, FAN302HL, provides several features to enhance the performance of general flyback converters. The constant-current control, proprietary topology enables simplified circuit designs without secondary feedback circuitry for batterycharger applications. A proprietary Burst-Mode function with low operation current minimizes standby power consumption.
    The FAN302HL controller also provides several protections. Cycle-by-cycle current limiting ensures the fixed peak current limit level, even if a short circuit occurs. The gate output is clamped at 15V to protect the power MOS from high gate-source voltage conditions. If either VS OVP or internal OTP is triggered, the circuit enters Latch Mode until AC power is removed.
    Using FAN302HL, a charger can be implemented with few external components and minimized cost, compared to a conventional design or a linear transformer.
    FAN302HL主要特性:
 mWSaver™ Technology Provides Industry’s Bestin-Class Standby Power
- Achieve Under 10mW; Far Below Energy Star’s 5-Star Level (<30mW)
- Proprietary 500V High-Voltage JFET Startup Reduces Startup Resistor Loss
- Low Operation Current in Burst Mode: Maximum 350μA
 Constant-Current (CC) Control without Secondary-Feedback Circuitry
 Fixed PWM Frequency at 85kHz with Frequency Hopping to Solve EMI Problem
 Low Operating Current: 3.5mA
 Peak-Current-Mode Control in CV Regulation
 Cycle-by-Cycle Current Limiting
 VDD Over-Voltage Protection (Auto-Restart)
 VS Over-Voltage Protection (Latch Mode)
 VDD Under-Voltage Lockout (UVLO)
 Gate Output Maximum Voltage Clamped at 15V
 Fixed Over-Temperature Protection (Latch Mode)
 Available in an 8-Lead SOIC Package
    FAN302HL应用:
    Battery chargers for cellular phones, cordless phones, PDA, digital cameras, and power tools. Replaces linear transformers and RCC SMPS.
图1. FAN302HL方框图
图2. 简化的反激转换器电路图
图3. FAN302HL HV起动电路图
图4. FAN302HL典型应用电路图
    FAN302HL 5V / 1A PSR手机电池充电器
    FAN302HL 5V / 1A PSR Mobile Phone Battery Charger
    This document describes a 5W power supply using a FAN302HL device. This power supply is targeted for mobile phone battery chargers with a 10mW solution and requiring high efficiency.
    To get the standby power consumption lower than 10mW at 230VAC, the FAN302HL has functions to enhance the standby power consumption, including proprietary Burst Mode with lower operation current under light-load conditions and built-in HV startup circuitry in the IC side to reduce startup resistor power loss.
    Using FAN302HL, a charger can be implemented with the few external components and minimized cost.
PSR手机电池充电器主要指标:
图5.PSR 5V/1A手机电池充电器
图6.PSR 5V/1A手机电池充电器电路图
PSR 5V/1A手机电池充电器材料清单:
图7.PSR 5V/1A手机电池充电器PCB布局图:上:顶层,下:底层
详情请见:
http://www.fairchildsemi.com/ds/FA/FAN302HL.pdf
http://www.fairchildsemi.com/products/evaluationboards/FEBFAN302HL_CH442v1.pdf?user-guide=%3CIMG+alt%3D%22%22+src%3D%22pdf_icon.gif%22+align%3DabsMiddle+border%3D0%3E+User+Guide
关键字:电源管理  DC/DC转换器  手机充电器 编辑:探路者 引用地址:FairchildFAN302HL5W手机充电器解决方案
上一篇:UC3842笔记本电脑电源适配器的故障检修
下一篇:满足30mW待机功耗要求的手机充电器解决方案
推荐阅读最新更新时间:2023-10-18 16:29
ARM切入电源管理市场
德国的Dialog半导体公司宣布,它已授权将ARM公司的Cortex-M0微处理器应用于下一代的混合信号电源管理电路产品中,以使芯片可以应用到四核甚至更先进的手机产品中。Dialog公司表示,这也是首次将标准的32位处理器内核集成到混合信号的电源管理IC上。 ARM的Cortex-M0处理器是最小的也是功耗最低的,被认为最适合于超低功耗MCU和混合信号应用。 ARM的总裁Tudor Brown在一次Dialog公司发表的声明中强调:“通过与Dialog公司的合作,我们也为ARM处理器在智能手机与平板设计领域开辟了一个全新的应用市场。Dialog走在高度集成电源管理系统技术的前沿,我相信使用了基于ARM处理系统的电源管理
[电源管理]
如何为笔记本电脑选择合适的电源管理IC
  在笔记本电脑中,高效率的电源管理电路能够提供较长的电池寿命,而且只占用较小的电路板尺寸,同时还可以提供低噪声、低成本、极短的设计周期等优势。先进的模拟IC公司针对各种便携产品推出了众多电源管理IC,对于笔记本电脑设计者来说,首先需要考虑的是根据特定设计目标选择合适的产品。   如果把CPU看作笔记本电脑的大脑,遍布整个主板的电源则被视为心脏和血管 — 将能量输送到大脑及系统的其它部分。不同负载需要不同类型的电源,但共用同一输入电源,输入电压范围从7V直至20V。产生5V以及3.3V总线电源的电池充电器、主调节器,以及为图形芯片组、DDR内存、I/O控制器和CPU核供电的调节器都是典型的降压型开关调整器,如同步整流变换器。唯一具
[电源管理]
如何为笔记本电脑选择合适的<font color='red'>电源管理</font>IC
负载开关技术的发展在电源管理中的作用
电源是推动我们现代世界技术的命脉,我们越来越依赖高科技产品在忙碌的工作中和工作外的生活中帮助我们。管理和控制电源是高科技、低功耗应用的一个重要主题。无论是为更大的设备开发复杂的多轨电源系统,还是利用电池供电设备的最后一小部分电量,电源管理都是设计人员的首要优先项目。 在大大小小的系统中,负载开关在电源管理和负载保护中发挥重要作用。在为特定应用选择负载开关时有一些因素要考虑,此外,现在还可以使用一些性能和功能得以改进的新器件。 任何负载开关的主要功能是连接/断开电源和负载。可采用仅使用一个简单的通路MOSFET的分立方案来实现这个功能;但全集成的负载开关器件通常比分立方案小,减少了器件的数量,并且提供更强大的功能,包括对过温
[电源管理]
负载开关技术的发展在<font color='red'>电源管理</font>中的作用
探讨太阳能手机锂离子电池充电器
 0 引言 能源危机的出现和环境污染的日益恶化,使太阳能作为清洁干净的可再生能源得到世界各国的高度重视。随着太阳能技术的发展,近年来超薄、超轻的光伏电池在便携式电子设备中的应用也得到了很大发展。太阳能手机锂电池充电器摆脱了传统充电电源的束缚,节能与环保,具有良好的发展前景。 由于光伏电池的输出功率受光照、温度等环境因素的影响,太阳能充电器既要与使用交流市电的充电器一样对锂离子电池进行安全快速充电,又要解决以下问题 :①如何将环境温度、光照强度以及其他外界条件的变化融入充电控制方法;②充电控制器的最佳拓扑结构是什么;③如何实现光伏电池输出功率的最大化。针对上述问题,本文对现在常用的三种手机锂电池充电器拓扑与控制方法进行了分析,指出
[嵌入式]
QNX 发布智能家用能源管理系统的参考设计
2010 年 3 月 2 日讯——哈曼国际集团(NYSE:HAR)旗下的 QNX 软件系统公司今日发布了最新的智能能源参考,即一种便于设计、部署和扩展智能家用能源管理系统的预集成软件栈。 这种能源参考可立即支持 Zigbee 传感器、Insteon 家用局域网 (HAN)、流式 IP 视频摄像头(安全监控用)、用于计算能耗成本的应用程序,以及获取气象信息并执行远程控制和故障诊断的因特网连接。其他功能还包括区域温度控制、独立照明和区域照明控制以及家电监测和控制。 智能能源参考是基于 QNX® Aviage® 人机界面套件的系统,它提供的框架允许开发人员通过 Adobe Flash 创建引人入胜的家用能源
[嵌入式]
英飞凌:新兴应用将为电源管理市场提供增长动力
英飞凌 科技执行董事、中国区 电源管理 及多元化市场事业部总监梁锦文 2014年5月,谷歌、IEEE以及美国国家可再生能源实验室在全球范围内发起了一个旨在推动高功率密度逆变器设计的“Little Box”的挑战赛。英飞凌作为官方指定的主要高性能半导体提供商之一, 为大赛提供高性能的MCU, 高低压MOSFET, IGBT, 硅以及碳化硅二极管产品。大赛要求逆变器的最小功率密度不能低于50W每立方英尺,由此可见,高效率和高功率密度依然是电源产品的发展方向。那么对于电源管理半导体,就会要求器件损耗越来越低,封装越来越小,集成功能越来越多。市场方面,在当前的移动互联时代,消费类电子以及数据处理领域对于电源管理的需求依然强劲。此外,
[嵌入式]
数字电源管理优点分析
新一代lC需要更低电源电压。单个器件往往用多个电压。而这些电压必须以正确的时序加到器件上。到lC的这些非常低的电压必须板上产生、必须使压降最小和保持稳压。大多数板上电源系统用模块 DC-DC 转换器 做为构建单元。高性能的 DC-DC 转换器 模块适用于宽范围电源 即可做为隔离砖式 转换器 。也可做为非隔离负载点(POL)转换器。 在这些环境下 需要电源管理功能与构建单元结合在一起。 并构成一个完整工作、健全的电源系统。电源管理包括:电源系统监控。定序和跟踪 监视和失效保护 事实上 每个功能都与 DC-DC 转换的大电流电路隔断。 在一个采用中间总线(旧)和电源管理的典型48V电源系统中 一个单砖式转换器产生中间
[电源管理]
数字<font color='red'>电源管理</font>优点分析
IR推出新型330W隔离式DC-DC转换器参考设计,工作效率提升至97%
国际整流器公司(International Rectifier,IR)近日推出针对IR2086S DC总线转换器控制IC及DirectFET功率MOSFET芯片组的参考设计IRDC2086-330W。 该款参考设计简化了用于网络、通信和高端服务器应用的48V输入砖和嵌入式电源的开发。IRDC2086-330W是一款工作效率高达97%的48V至9.6V(35A)非稳压DC总线转换器,体积比业界标准的四分之一砖稳压器缩小30%。此外,IRDC2086-330W将功率转换元件的数目从3颗IC及14颗场效应管减少到一颗IC和8颗场效应管。 新款参考设计的芯片组包括IR2086S初级全桥控制IC和8颗功率转换M
[新品]
小广播
最新电源管理文章
