The ADM1275 is a hot-swap controller that allows a circuit board to be removed from or inserted into a live backplane. It also features current and voltage readback via an integrated 12-bit analog-to-digital converter (ADC), accessed using a PMBus™ interface.
The load current is measured using an internal current sense amplifier that measures the voltage across a sense resistor in the power path via the SENSE+ and SENSE− pins. A default limit of 20 mV is set, but this limit can be adjusted, if required, using a resistor divider network from the internal reference voltage to the ISET pin.
The ADM1275 limits the current through the sense resistor by controlling the gate voltage of an external N-channel FET in the power path, via the GATE pin. The sense voltage—and, therefore, the load current—is maintained below the preset maximum. The ADM1275 protects the external FET by limiting the time that the FET remains on while the current is at its maximum value. This current limit time is set by the choice of capacitor connected to the TIMER pin. In addition, a foldback resistor network can be used to actively lower the current limit as the voltage across the FET is increased. This helps to maintain constant power in the FET and allows the safe operating area (SOA) to be adhered to in an effective manner.
In case of a short-circuit event, a fast internal overcurrent detec-tor responds within 370 ns and signals the gate to shut down. A 1500 mA pull-down device ensures a fast FET response. The ADM1275 features overvoltage and undervoltage protection, programmed using external resistor dividers on the UV and OV pins. A PWRGD signal can be used to detect when the output supply is valid, using the FLB pin to monitor the output. GPO pins can be configured as various output signals that can be asserted when a programmed current or voltage level is reached.
The 12-bit ADC can measure the current in the sense resistor, as well as the supply voltage on the SENSE+ pin or the output voltage. A PMBus interface allows a controller to read current and voltage data from the ADC. Measurements can be initiated by a PMBus command. Alternatively, the ADC can run continu-ously, and the user can read the latest conversion data whenever required. Up to four unique PMBus addresses can be selected, depending on the way that the ADR pin is connected.
The ADM1275-1 and ADM1275-3 are available in a 20-lead QSOP and 20-lead LFCSP and have a LATCH pin that can be configured for automatic retry or latch-off when an overcurrent fault occurs. The ADM1275-2 is available in a 16-lead QSOP with latch-off mode only.
ADM1275主要特性:
Controls supply voltages from 2 V to 20 V
370 ns response time to short circuit
Resistor-programmable 5 mV to 25 mV current limit
±1% accurate, 12-bit ADC for current, VIN/VOUT readback
Charge-pumped gate drive for multiple external N-channel FETs
High gate drive voltage to ensure lowest RDSON
Foldback for tighter FET SOA protection
Automatic retry or latch-off on current fault
Programmable current limit timer for SOA
Programmable, multifunction GPOs
Power-good status output
Analog UV and OV protection
ENABLE pin (ADM1275-3 only)
Peak detect registers for current and voltage
PMBus fast mode compliant interface
16-lead QSOP and 20-lead QSOP and LFCSP
ADM1275应用:
Power monitoring and control/power budgeting
Central office equipment
Telecommunication and data communication equipment
PCs/servers
图1.ADM1275-1功能方框图
图2.ADM1275-2功能方框图
图3.ADM1275-3功能方框图
评估板EVAL-ADM127xEBZ
The EVAL-ADM127xEBZ is a compact full feature evaluation board for the ADM1275-1ACPZ, ADM1275-3ACPZ, and ADM1276-3ACPZ devices. The elaborated layout gives users a clear visual of all the peripheral components and the hot-swap power path. The layout also maximizes the board’s ability to dissipate heat for some of the key components on the power path, allowing the evaluation of very high current hot-swap setups.
Three sense-resistor slots and six multipackage FET slots give users great flexibility and allow them to simulate a wide range of application setups.
Multiple test points allow easy access to all critical points/pins. Six LEDs give users direct visual indication on variations in the board status, such as supply input, output, IC power good output, latch output, and GPO outputs. Six ADT75 digital temperature sensors on the back of the board allow users to obtain the board’s thermal data through an I2C bus in real time.
The kit supports I2C communication, allowing users to communicate with the ADM1275/ADM1276 and the ADT75. The evaluation kit also supports cascade setup so multiple evaluation boards can be connected together and share the same I2C bus.
The boards are fully compatible with the ADM1275/ADM1276 evaluation software tool, which can be downloaded at: www.analog.com/hotswap_powermonitor.
Note that users may need the USB-to-I2C dongle, USB-SMBUS-CABLEZ, to use the evaluation software tools.
The standard evaluation kit is prepopulated and tested with a 12 V, 60 A hot-swap design capable of working with a 4.7 mF output capacitor.
Complete specifications for the ADM1275 and the ADM1276 are available in the ADM1275 and the ADM1276 data sheets available from Analog Devices and should be consulted in conjunction with this user guide when using the evaluation boards.
评估板EVAL-ADM127xEBZ主要特性:
Full functions support evaluation kit for the ADM1275 and the ADM1276
Supports LFCSP device package
Populated and tested with 12 V, 60 A, 4.7 mF design
Capable of evaluating high current designs for over 100 A
Special NMOSFET footprint suits different packages
Supports up to 3 sense resistors in parallel
Supports up to 6 FETs in parallel
LED indicated status outputs
Wild input voltage range of up to 20 V
Allows separate VCC and VIN for low voltage sensing
6 on-board ADT75 accurate temperature sensors
Supports cascade setup for multiple boards
Toggle and push-button switch for easy input control
PMBus communication support
图4.评估板EVAL-ADM127xEBZ外形图
图5.评估板EVAL-ADM127xEBZ电路图(1)
图6.评估板EVAL-ADM127xEBZ电路图(2)
图7.评估板EVAL-ADM127xEBZ PCB布局图
评估板EVAL-ADM127xEBZ材料清单(BOM):
详情请见:
http://www.analog.com/static/imported-files/data_sheets/ADM1275.pdf
和
http://www.analog.com/static/imported-files/user_guides/UG-263.pdf
上一篇:ZNR系列智能高压变频器在循环水泵节能改造中的应用
下一篇:台达变频器干扰案例问题分析及其处理
推荐阅读最新更新时间:2023-10-18 16:30
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- Vishay推出适用于恶劣环境的紧凑型密封式SMD微调电阻器
- MathWorks 和 NXP 合作推出用于电池管理系统的 Model-Based Design Toolbox
- 意法半导体先进的电隔离栅极驱动器 STGAP3S为 IGBT 和 SiC MOSFET 提供灵活的保护功能
- 全新无隔膜固态锂电池技术问世:正负极距离小于0.000001米
- 东芝推出具有低导通电阻和高可靠性的适用于车载牵引逆变器的最新款1200 V SiC MOSFET
- 【“源”察秋毫系列】 下一代半导体氧化镓器件光电探测器应用与测试
- 采用自主设计封装,绝缘电阻显著提高!ROHM开发出更高电压xEV系统的SiC肖特基势垒二极管
- 艾迈斯欧司朗发布OSCONIQ® C 3030 LED:打造未来户外及体育场照明新标杆
- 氮化镓取代碳化硅?PI颠覆式1700V InnoMux2先来打个样
- Allegro MicroSystems 在 2024 年德国慕尼黑电子展上推出先进的磁性和电感式位置感测解决方案
- 左手车钥匙,右手活体检测雷达,UWB上车势在必行!
- 狂飙十年,国产CIS挤上牌桌
- 神盾短刀电池+雷神EM-i超级电混,吉利新能源甩出了两张“王炸”
- 浅谈功能安全之故障(fault),错误(error),失效(failure)
- 智能汽车2.0周期,这几大核心产业链迎来重大机会!
- 美日研发新型电池,宁德时代面临挑战?中国新能源电池产业如何应对?
- Rambus推出业界首款HBM 4控制器IP:背后有哪些技术细节?
- 村田推出高精度汽车用6轴惯性传感器
- 福特获得预充电报警专利 有助于节约成本和应对紧急情况
- 或彻底摆脱电池厂商?整车企业自建电池厂成趋势
- 用于车载(符合 AEC-Q100)18V 操作驱动器 Tr 同步整流降压 DC/DC 的转换器
- Vishay推出新型汽车级接近传感器,压力感测分辨率高达20 µm
- Elektrobit 支持 BlackBerry QNX OS 构建基于 HPC 的车辆架构
- ACES 竞赛:半导体将指引汽车制造商到达终点线
- PlayStation 5今天上市发售:次世代已来
- iPad mini 6配置消息曝光:8.5英寸屏幕的方正设计平板
- 疑vivo X60真机图片曝光:搭载Exynos 1080芯片
- 苹果更新 TestFlight 3.0 版本:能自动更新内测应用
- TCL华星推全球首款34英寸R1000 165Hz超宽电竞屏
