通过几天的工作点阵屏终于完工,不过因为缺少元件只能算完成了一半。。。。。。
不想多说直接上C51程序代码
//行扫1#74hc154芯片对应数据输入口:P0^0->P0^3数据输入控制口:P0^4低电平有效;行扫输出为互斥低电平输出;
//列扫1#74hc595芯片对应数据输入口:P0^5移位寄存器时钟信号;P0^6存储寄存器数据更新时钟;P0^7数据输出使能,低电平时输出有效;[page]
//P2^0串行数据输入
#include
#include
#define uchar unsigned char//宏定义
#define uint unsigned int//宏定义
uchar code ZM000[]=
//源文件 / 文字: 祝
0x00,0x00,0x20,0x00,0x11,0xF8,0x01,0x08,
0x79,0x08,0x09,0x08,0x11,0x08,0x11,0xF8,
0x38,0x90,0x54,0x90,0x10,0x90,0x10,0x90,
0x11,0x14,0x11,0x14,0x12,0x0C,0x00,0x00,
uchar code ZM001[]=
//源文件 / 文字: 荣
0x00,0x00,0x08,0x20,0x7F,0xFC,0x08,0x20,
0x00,0x00,0x7F,0xFC,0x40,0x04,0x01,0x00,
0x01,0x00,0x7F,0xFC,0x03,0x80,0x05,0x40,
0x19,0x30,0x61,0x0C,0x01,0x00,0x00,0x00,
sbit HC154_A=P0^0;//HC154数据输入口
sbit HC154_B=P0^1;//HC154数据输入口
sbit HC154_C=P0^2;//HC154数据输入口
sbit HC154_D=P0^3;//HC154数据输入口
sbit G1=P0^4;//HC154使能端控制
sbit SH=P0^5;//HC595移位控制
sbit ST=P0^6;//HC595锁存更新显示
sbit OE=P0^7;//HC595使能端控制
sbit DS=P2^0;//HC595串行数据输入
void chushihua() //硬件初始化
OE=1; //关闭HC595输出
G1=1; //关闭HC154输出
void delay(uint ms)//延时子程序
uint x,y;
for(x=ms;x>0;x--)
for(y=0;y<240;y++);
//低位先入
void sendbyte(uchar Rdate)//HC595串口输入一个字节
uchar a;
uchar date=Rdate;
for(a=0;a<8;a++)
SH=0;
if(date&0x01)//先将最低位移入
DS=1;
SH=1;
else
DS=0;
SH=1;
date=date>>1;//输入的字节位右移
void HC595_GX() //HC595锁存数据更新并输出
ST=0;
_nop_();
_nop_();
ST=1; //HC595锁存数据更新
_nop_();
_nop_();
OE=0; //HC595输出
void HC154_HS(uint x)//X行低电平输出
G1=0;
switch(x)
case 1:
HC154_A=0;
HC154_B=0;
HC154_C=0;
HC154_D=0;
break;
case 2:
HC154_A=1;
HC154_B=0;
HC154_C=0;
HC154_D=0;
break;
case 3:
HC154_A=0;
HC154_B=1;
HC154_C=0;
HC154_D=0;
break;
case 4:
HC154_A=1;
HC154_B=1;
HC154_C=0;
HC154_D=0;
break;
case 5:
HC154_A=0;
HC154_B=0;
HC154_C=1;
HC154_D=0;
break;
case 6:
HC154_A=1;
HC154_B=0;
HC154_C=1;
HC154_D=0;
break;
case 7:
HC154_A=0;
HC154_B=1;
HC154_C=1;
HC154_D=0;
break;
case 8:
HC154_A=1;
HC154_B=1;
HC154_C=1;
HC154_D=0;
break;
case 9:
HC154_A=0;
HC154_B=0;
HC154_C=0;
HC154_D=1;
break;
case 10:
HC154_A=1;
HC154_B=0;
HC154_C=0;
HC154_D=1;
break;
case 11:
HC154_A=0;
HC154_B=1;
HC154_C=0;
HC154_D=1;
break;
case 12:
HC154_A=1;
HC154_B=1;
HC154_C=0;
HC154_D=1;
break;
case 13:
HC154_A=0;
HC154_B=0;
HC154_C=1;
HC154_D=1;
break;
case 14:
HC154_A=1;
HC154_B=0;
HC154_C=1;
HC154_D=1;
break;
case 15:
HC154_A=0;
HC154_B=1;
HC154_C=1;
HC154_D=1;
break;
case 16:
HC154_A=1;
HC154_B=1;
HC154_C=1;
HC154_D=1;
break;
default:
break;
void OUT16x16(uchar code ZM[31])//输出一个16x16点阵字模子程序
uint y;//行扫数据控制
uint x_H;//列高位数据控制
uint x_L;//列低位数据控制
for(y=1,x_H=0,x_L=1;y<=16;y++)
sendbyte(ZM[x_L]);
sendbyte(ZM[x_H]);
HC595_GX();
HC154_HS(y);
x_H+=2;
x_L+=2;
delay(1);
void main() //主函数
uint x;
while(1)
//输出祝字
for(x=0;x<5000;x++)
OUT16x16(ZM000);
//输出荣字
for(x=0;x<5000;x++)
OUT16x16(ZM001);
上一篇:浅谈用单片机模拟PLC(山寨三菱系列)
下一篇:I2C总线协议(AT24c02)程序
推荐阅读最新更新时间:2024-03-16 14:02
