#define uchar unsigned char #define uint unsigned int uchar index; uchar a,b,c; //定义三个变量、。 uchar m; // uint teempr; // uint z,i; //*********************************************★下面是PWM调制的数组★******************************************************** //220- zhan0.02 214--0.04 209-0.07 203-0.11 195- 0.15 185-0.25 173-0.31 160-0.38 145-0.45 129-0.48 111-0.48 42OFF //0.74 .81 .91 1.03 1.22 1.45 1.69 2.28 2.62 0.74 0.81 0.90 1.03 右大 // 热敏电阻受热以后阻值变小。受凉以后阻值变大。 uchar code pwm[]={1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38, 39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79, 80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,112,113,114,115, 116,117,118,119,120,121,122,123,124,125,126,127,128,129,130,131,132,133,134,135,136,137,138,139,140,141,142,143,144,145,146, 147,148,149,150,151,152,153,154,155,156,157,158,159,160,161,162,163,164,165,166,167,168,169,170,171,172,173,174,175,176,177, 178,179,180,181,182,183,184,185,186,187,188,189,190,191,192,193,194,195,196,197,198,199,200,201,202,203,204,205,206,207,208, 209,210,211,212,213,214,215,216,217,218,219,220,221,222,223,224,225,226,227,228,229,230,231,232,233,234,235,236,237,238,239, 240,241,242,243,244,245,246,247,248,249,250,251,252,253,254}; //3525 2脚电压高输出占空比也大,2脚电压越低那么占空比也就越小。 6脚电压拉低的话频率就升高,6脚电压高频率就降低。 //************************************************************************************************************************ //************************************************************************************************************************ //************************************************ 下面的是DISP显示数组*************************************************** uchar code table100[]={"※※※※※※※※"}; uchar code table101[]={" www.51hei.com "}; uchar code table1[]={"★当前档位一★"}; uchar code table2[]={"★当前档位二★"}; uchar code table3[]={"★当前档位03★"}; uchar code table4[]={"★当前档位四★"}; uchar code table5[]={"★当前档位五★"}; uchar code table6[]={"★当前档位六★"}; uchar code table7[]={"★当前档位七★"}; uchar code table8[]={"★当前档位八★"}; uchar code table9[]={"★当前档位九★"}; uchar code table10[]={"★当前档位十★"}; uchar code table11[]={"测试版本:V1.1"}; uchar code table12[]={"zhinengjiqi.com"}; uchar code table13[]={"欢迎使用智能机器"}; uchar code table14[]={"GSM:18663523202"}; uchar code table15[]={"警告电压过高保护"}; uchar code table16[]={"警告检测短路故障"}; uchar code table17[]={"警告长时间没放锅"}; uchar code table18[]={"警告线盘温度过高"}; uchar code table19[]={"警告散热器温度高"}; uchar code table20[]={"警告风扇发生故障"}; uchar code table21[]={"警告环境湿度过高"}; uchar code table22[]={"机器锁定咨询客服"}; uchar code table23[]={"警告电源线未接好"}; uchar code table24[]={"Θ开机软启动中Θ"}; uchar code table25[]={"请稍候¨¨"}; //****************************************************************************************************************** //*************************************************按键定义*********************************************************** sbit pd = P0^4 ; //占空比升高 sbit px = P0^5 ; //占空比降低 sbit zd = P0^6 ; //频率增加 sbit zx = P0^7 ; // 频率减小 //**************************************************按键定义到此结束。****************************************************** sbit rs=P0^0; //数据,命令选择端 sbit rw=P0^1; //读写选择 sbit beiguang=P0^3;//LED背光 sbit e=P0^2; //使能端 sbit baohu=P5^3; //PWM保护关闭。 //*************************************************** 液晶pin定义结束。*************************************************** sbit DQ=P3^4; //温度探头数据口。 sbit yurest=P4^4; //语音复位 sbit yushuju=P4^1; //语音数据 sbit yuzhuangtai=P4^5; //语音状态 //***************************************************语音pin定义到此结束***************************************************** //********************************************************************************************************* //**************************************************** 各种延时子函数******************************************************* void yanshi(uint xms)//延时多久需要计算。 { uint x ,y; for(x=xms;x>0;x--) for(y=110;y>0;y--); } //****************************************************************************************************************** void delay_1ms(uint z) //延时一毫秒的指令。核对过时间很准确 { uint x,y; for(x=z;x>0;x--) for(y=1800;y>0;y--); } //************************************************************** void delay_50us(uint t) //延时50微秒的指令。核对过时间很准确 { uint j; for(;t>0;t--) for(j=91;j>0;j--); } //************************************************************************************************************************ //@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ //************************************************************************************************************************ //************************************************以下是12864显示的子函数***************** ****************************** //****************************************************************************************************************** void write_12864_com(uchar com) //写命令子函数 { rs=0; //数据命令选择端口。=1写数据,=0写命令 。 P2=com;//把数据送到P2口传递给液晶。 e=1;//使能端高电平。 delay_50us(10); //延时一小会保证使能的高电平宽度达到要求、 e=0;//完成使能信号的脉冲要求给置零。 delay_50us(2); } //******************************************************* void write_12864_dat(uchar dat) //写数据子函数 { rs=1; //数据命令选择端口。=1写数据,=0写命令 。 rw=0; //读写 delay_50us(1); P2=dat;//把数据送到P2口传递给液晶。 e=1;//使能端高电平。 delay_50us(10); //延时一小会保证使能的高电平宽度达到要求、 e=0;//完成使能信号的脉冲要求给置零。 delay_50us(2); } //******************************************************************************************************** void init_12864() //液晶初始化子函数。 { delay_1ms(100); write_12864_com(0x30); //基本指令操作); // delay_50us(4); write_12864_com(0x0c); write_12864_com(0x06); delay_50us(10); } //***************************************************以下是各个档位的画面*********************************************** void dispdangwei(uint f) //*****************************f是多少就是几档画面************************************************* { init_12864();//初始化液晶。 write_12864_com(0x80);//设定显示位置是第一行。 for(i=0;i<16;i++) //第一行有多少字,汉字占两个位置。标点符号一个。 { write_12864_dat(table101[i]); //开始挨个把表中的字一位一位的通过12864的数据发送子程序发送出去。 delay_50us(1); //延时一会保证数据有发送完毕。 } write_12864_com(0x90); //设定第二行。 for(i=0;i<16;i++) {dat(table100[i]);; } write_12864_com(0x88); //设定第三行 for(i=0;i<14;i++) { switch(f) { case 1: write_12864_dat(table1[i]); break; case 2: write_12864_dat(table2[i]); break; case 3: write_12864_dat(table3[i]); break; case 4: write_12864_dat(table4[i]); break; case 5: write_12864_dat(table5[i]); break; break; case 7: write_12864_dat(table7[i]); break; case 8: write_12864_dat(table8[i]); break; case 9: write_12864_dat(table9[i]); break; case 10: write_12864_dat(table10[i]); break; } delay_50us(1);行显示位置。 for(i=0;i<16;i++) { write_12864_dat(table100[i]); delay_50us(1); } } //************************************************************************************************************************* //*********************************************************************************************************************** //******************************************************************************************************************* //*********************************************************************************************************************** //***********************************************下面是语音参数设定****************************************************** //*********************************************************************************************************************** void yufuwei() //语音复位子程序。 { yurest=0;//这句是防止REST不是低电平。保险起见给他拉低。 yurest=0; //到这里语音就复位结束。 } //********************************************************************************************************************** void yuyin(z) //语音的播放程序。Z等于几就播放第几段。(语音参数内部调用,主程序不用。) { yufuwei(); //清除以前的播放数据进行复位。防止和前次的播放数据相加播放错误、 while(z>0) { yushuju=0; } //********************************************************************************************** void dangweitouyin() // 语音:档位。 用来给档位语音添加头音。 { yufuwei(); //语音复位子函数。目的是在播放这段之前停止正在播放的。、一小会。 yuyin(11); //指定播放语音IC中的第11段语音。 } //******************************************************************************************************** void jinggao() //报警用的音乐文件。 用来给各种告警添加头音。只是警告语音的前头那段音乐。位子函数。目的是在播放这段之前停止正在播放的。、 机速度太快了延一小会。 yuyin(23); //指定播放语音IC中的第11段语音。 } //*********************************************************************************************** void baojing(uint o) // 各种报警的子函数里面的O等于几就是对应的报警。 { jinggao(); //这里是警告的头音音乐文件。 delay_1ms(2000);//延时2秒想起来警告头音。 yuyin(o); //警告的内容。 } //***************************************************************************************** void jinggaoduanlu() //短路保护警告音。 { baojing(18);//播放第18条报警语音。内容是:短路保护. } //***************************************************************************************** void jinggaofengshanguzhang() { baojing(19);//播放第19条报警语音。内容是:警告风扇故障。 } //***************************************************************************************** void jinggaoguoyabaohu() { baojing(21);//播放第12条报警语音。内容是:电源线未接好,请检查。 } //***************************************************************************************** void jinggaoguowenbaohu() { baojing(20);//播放第20条报警语音。内容是:警告过压保护。 } //***************************************************************************************** void dianyuanxianweijiehao() { baojing(12);//播放第12条报警语音。内容是:电源线未接好,请检查。 } //***************************************************************************************** void jinggaomima() { baojing(22);//播放第22条报警语音。内容是:请咨询客服输入密码。 } //***************************************************************************************** void jinggao1() //报警用的音乐文件。 用来给各种告警添加头音。只是警告语音的前头那段音乐。 { yufuwei(); //语音复位子函数。目的是在播放这段之前停止正在播放的。、 delay_50us(1);//单片机速度太快了延一小会。 yuyin(26); //指定播放语音IC中的第11段语音。 } //******************************************************************************************************************** void music(uint j) //带参数的子函数,里面的J等于几就是播放 第几段语音。 { dangweitouyin();//档位头音。 if(yuzhuangtai==0) //检测是不是语音头文件在播放。如果播放就让程序进入里面等一会让头文件播放结束。 { while(!yzhuangtai);//如果检测到语音状态发生了改变那么就跳出来这个死循环。否则就在这原地打转等待。 } if(yuzhuagtai==1) //检测是不是语音头文件播放结束了。如果结束了那么开始播放本段语音。 { if(j==10) //因为语音的十不是在语音的第十段,那就利用这么两个if语句进行判断是不是档位数据送来10. { yuyin(28); //如果来的数据是10,那么就进入把语音的子函数参数修改成 28执行档位十的语音。 } if(j!=10) //又为了避免在档位十的时候送完28的语音参数再过来送10的错误数据,所以在送来不是10的时候才执行1-9数据 { yuyin(j); //播放语音的第K段。~~~~~~~~~~~~~~~内容是:j ~~~~~~~~~~~~~~~~~ } } }[page] //********************************************************************************************************************* //********************************************************************************************************************* //********************************************************************************************************************* //********************************************************************************************************************* //********************************************************************************************************************* //***********************************下面是1-10档位的子函数调用了显示画面和语音***************************************** //********************************************************************************************************************** void dangwei(uint k) // 档位1-10的子函数。 { switch(k) { case 1: //档位1. a=25;//火力的占空比是25. break; case 2: //档位2. a=50;//火力的占空比是50. break; case 3: //档位3 a=75;//火力的占空比是75. break; case 4: //档位4 a=100;//火力的占空比是25. break; case 5: //档位5 a=125;//火力的占空比是25. break; case 6: //档位6 a=25;//火力的占空比是25. break; case 7: //档位7 a=25;//火力的占空比是25. break; case 8: //档位8 a=25;//火力的占空比是25. break; case 9: a=25;//火力的占空比是25. break; case 10: a=25;//火力的占空比是25. break; } dispdangwei(k);//档位K的画面 music(k);//档位K的语音。 } //********************************************************************************************************************** //************************************************************************************************************************* //******************************************到这里档位定义信息完毕!!***************************************************** //********************************************************************************************************************** //****************************************************下面是PCA计数器初始化************************************************ void init_pca(void)//pca计数器初始化函数 { CMOD=0x00; CCON=0x00; CCAP0=0X2; //8位PWM输出,无中断。PWM0 CCAP1=0x2;//8位PWM输出,无中断 。PWM1 CL=0x00;//清零pca计数器 CH=0x00; CCA1L=pm[0]; //初始化PWM1输出的占空比 CCA1H=pw[0]; CCA0L=pm[0]; //初始化PWM0输出的占空比 CCA0H=pm[0]; CR=1;//运行pca计数器 } //************************************************************************************************************************* //***************************************************************************************************************** //*********************************************************************************************************************** void huanying() { yuyin(30);//语音的欢迎语。 init_12864();//初始化液晶。 write_12864_com(0x80);//设定显示位置是第一行。 for(i=0;i<16;i++) //第一行有多少字,汉字占两个位置。标点符号一个。 { write_12864_at(table100[i]); //开始挨个把表中的字一位一位的通过12864的数据发送子程序发送出去。 delay_50us(1); //延时一会保证数据有发送完毕。 } write_12864_com(0x90); //设定第二行。 for(i=0;i<16;i++) { write_1284_dat(table24[i]); delay_50us(1; } write_12864_com(0x88); //设定第三行 for(i=0;i<10i++) { write_12864_dat(table25[i]); delay_50us(1); } write_12864_com(0x98);//设定第四行显示位置。 for(i=0;i<16;i++) { write_12864dat(table100[i]); delay_50us(1); } //##################################第二幅画面。 delay_1s(2000);//延时保持2秒钟的第一幅画面。 init_12864();//初始化液晶。 write_12864_com(0x80);//设定显示位置是第一行。 for(i=0;i<14;i++) //第一行有多少字,汉字占两个位置。标点符号一个。 { write_12864_dat(table11[i]); //开始挨个把表中的字一位一位的通过12864的数据发送子程序发送出去。 delay_50us(1); //延时一会保证数据有发送完毕。 } write_12864_com(0x90); //设定第二行。 for(i=0;i<16;i++) { write_12864_dat(table13[i]); delay_50us(1); write12864_com(0x88); //设定第三行 for(i=0;i<16;i++) { write_12864_dat(table12[i]); delay_50us(1); } write_12864_com(0x98);//设定第四行显示位置。 for(i=0;i<16;i++) { write_12864_dat(table14[i]); delay_50us(1); } } //*********************************************************************************************************************** //********************************************************************************************************************* void main() { P4SW=0x7F; //设置P4为双向IO口。 c=0;//写入未执行过按键操作的标志位 baohu=1;//先强制打开保护功能,促使PWN彻底关闭,防止上机的那种不可控的频率。让PWM有规律可循。 beiguang=1;//打开背光 yanshi(30);//延时一小会保证已经彻底关闭。 init_pa();//初始化PWM控制器。 m=0; temp=0; init_1864();//初始化液晶。 huanying();//开机欢迎语和欢迎画面。 while(1) { if(pd==0) //档位加 { yanshi(50); if(pd==0) { m++ //检测火力+按键按了几次。是几次就是几档位、 if(m==11) //当档位增加到11次以后,就给复位到档位1.防止出现错误。 { m=1; } dangwei(m); //档位的各种信息。 while(!pd); } } if(px==0) //档位减 { yanshi(50); if(px==0) { if(m==0) { m=2; } m--; //检测火力-按键按了几次。是几次就是几档位、 if(m<=0)//当档位增加到0次以后,就关闭所有档位的输出。 { m=1; } dangwei(m); //档位的各种信息。 while(!p); } } if(zd==0) { yanshi(10); if(zd==0) { b--; if(b<=0) { b=56; }; c=1; while(!zd); } } if(zx==0) { yanshi(10); if(zx==0) { b++; if(b>=56) { b=0; }; while(!zx); } } CCAP1L=pwm[a]; //初始化PWM1输出的占空比 CCAP1H=pwm[a]; CCAP0L=pw[b]; //初始化PWM0输出的占空比 CCAP0H=pm[b]; if(c>=1)//检测是不是已经稳定好了PWM。 { baohu=0;//开启PWM输出。 } } }
上一篇:HMC5883 IIC测试程序
下一篇:keilc51中如何看堆栈的分配情况
推荐阅读最新更新时间:2024-03-16 14:25
