stm32l476 FLASH特征
• Up to 1 Mbyte of Flash memory with dual bank architecture supporting read-while-write
capability (RWW).
• Memory organization: 2 banks (Bank 1 and Bank 2)
– main memory: 512 Kbyte per bank
– information block: 32 Kbyte per bank
• 72-bit wide data read (64 bits plus 8 ECC bits)
• 72-bit wide data write (64 bits plus 8 ECC bits)
• Page erase (2 Kbyte), bank erase and mass erase (both banks)
摘自 STM32 RM0351 Reference manual 文档
stm32l476 dual bank 地址表
写入操作流程
FLASH解锁
HAL_FLASH_Unlock();擦除FLASH
HAL_StatusTypeDef HAL_FLASHEx_Erase(FLASH_EraseInitTypeDef *pEraseInit, uint32_t *PageError);写入FLASH
HAL_FLASH_Program(uint32_t TypeProgram, uint32_t Address, uint64_t Data);锁定FLASH
HAL_FLASH_Lock();
读取操作
直接从目标地址读取, uint8_t* 按照1个字节读取,如果是uint32_t* 按照一个字读取
buff[i] = *(__IO uint8_t*)(dest_addr + i);
//直接从目标地址读取, uint8_t* 按照1个字节读取,如果是uint32_t* 按照一个字读取
具体实现
* @brief Initializes Memory.
* @param None
* @retval 0 if operation is successeful, MAL_FAIL else.
flash_status_t Flash_If_Init(void)
/* Unlock the internal flash */
HAL_FLASH_Unlock();
return FLASH_OK;
* @brief De-Initializes Memory.
* @param None
flash_status_t Flash_If_DeInit(void)
/* Lock the internal flash */
HAL_FLASH_Lock();
return FLASH_OK;
* @brief Erases sector.
* @param Add: Address of sector to be erased.
flash_status_t Flash_If_Erase(uint32_t Add)
uint32_t PageError = 0;
/* Variable contains Flash operation status */
HAL_StatusTypeDef status;
FLASH_EraseInitTypeDef eraseinitstruct;
/* Clear OPTVERR bit set on virgin samples */
__HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_OPTVERR);
/* Get the number of sector to erase from 1st sector*/
eraseinitstruct.Banks = GetBank(Add);
eraseinitstruct.TypeErase = FLASH_TYPEERASE_PAGES;
eraseinitstruct.Page = GetPage(Add);
eraseinitstruct.NbPages = 1;
status = HAL_FLASHEx_Erase(&eraseinitstruct, &PageError);
if (status != HAL_OK)
return FLASH_ERR;
return FLASH_OK;
* @brief Writes Data into Memory.
* @param src: Pointer to the source buffer. Address to be written to.
* @param dest: Pointer to the destination buffer.
* @param Len: Number of data to be written (in bytes).
flash_status_t Flash_If_Write(uint8_t *src, uint32_t dest_addr, uint32_t Len)
uint32_t i = 0;
for(i = 0; i < Len; i += 8)
/* Device voltage range supposed to be [2.7V to 3.6V], the operation will
be done by byte */
if(HAL_FLASH_Program(FLASH_TYPEPROGRAM_DOUBLEWORD, (uint32_t)(dest_addr+i), *(uint64_t*)(src+i)) == HAL_OK)
/* Check the written value */
if(*(uint64_t *)(src + i) != *(uint64_t*)(dest_addr+i))
/* Flash content doesn't match SRAM content */
return FLASH_CHECK_ERR;
else
/* Error occurred while writing data in Flash memory */
return FLASH_ERR;
return FLASH_OK;
* @brief Reads Data into Memory.
* @param Len: Number of data to be read (in bytes).
* @retval return FLASH_OK.
flash_status_t Flash_If_Read(uint8_t* buff, uint32_t dest_addr, uint32_t Len)
uint32_t i;
for(i = 0; i < Len; i++){
/* Return a valid address to avoid HardFault */
return FLASH_OK;
* @brief Gets the page of a given address
* @param Addr: Address of the FLASH Memory
* @retval The page of a given address
static uint32_t GetPage(uint32_t Addr)
uint32_t page = 0;
if (Addr < (FLASH_BASE + FLASH_BANK_SIZE))
/* Bank 1 */
page = (Addr - FLASH_BASE) / FLASH_PAGE_SIZE;
else
/* Bank 2 */
page = (Addr - (FLASH_BASE + FLASH_BANK_SIZE)) / FLASH_PAGE_SIZE;
return page;
* @brief Gets the bank of a given address
* @retval The bank of a given address
static uint32_t GetBank(uint32_t Addr)
uint32_t bank = 0;
if (READ_BIT(SYSCFG->MEMRMP, SYSCFG_MEMRMP_FB_MODE) == 0)
/* No Bank swap */
bank = FLASH_BANK_1;
else
bank = FLASH_BANK_2;
else
/* Bank swap */
else
return bank;
上一篇:STOP状态下通过串口唤醒MCU
下一篇:stm32时钟分割
推荐阅读最新更新时间:2024-03-16 16:11
